Comfort Zone calculated by Temperature, Humidity, Clothing and Environment
Description
This flow uses the measurements of a temperature and humidity sensor and calculates the standardised comfort zone in relation to clothing, room conditions, metabolic rate and air circulation. It is focused on the use case of living rooms.
You can use this flow as a template for your own environment conditions, use cases and sensor setup.
Dependencies
[{"id":"f8cc4e4.08abcb","type":"ui_gauge","z":"61aa57b3.d74588","name":"Show Temperature","group":"cdcc200.969bbe","order":0,"width":"6","height":"6","gtype":"gage","title":"Temperature","label":"°C","format":"{{value}}","min":"0","max":"50","colors":["#0092b5","#00b500","#ca3838"],"seg1":"10","seg2":"30","x":910,"y":180,"wires":[]},{"id":"c80ac488.b4b508","type":"comment","z":"61aa57b3.d74588","name":"Get Temperature & Humidity","info":"","x":140,"y":120,"wires":[]},{"id":"1584e29d.e65d1d","type":"rpi-dht22","z":"61aa57b3.d74588","name":"Temperature & Humidity Sensor","topic":"Temperature","dht":"11","pintype":"2","pin":"37","x":230,"y":180,"wires":[["40005bd6.c8eb94","4815289b.5b7d78"]]},{"id":"b9339bda.dde228","type":"ui_gauge","z":"61aa57b3.d74588","name":"Show Humidity","group":"cdcc200.969bbe","order":0,"width":"6","height":"6","gtype":"wave","title":"Humidity","label":"%RH","format":"{{value}}","min":"0","max":"100","colors":["#0092b5","#00b500","#ca3838"],"seg1":"10","seg2":"30","x":900,"y":240,"wires":[]},{"id":"40005bd6.c8eb94","type":"change","z":"61aa57b3.d74588","name":"Get Humidity","rules":[{"t":"set","p":"payload","pt":"msg","to":"humidity","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"Humidity","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":240,"wires":[["9953d62f.60f418"]]},{"id":"42f52f56.a5899","type":"inject","z":"61aa57b3.d74588","name":"Sensor pulse","topic":"","payload":"","payloadType":"date","repeat":"0.5","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":60,"wires":[["464a297.d5ae8d8"]]},{"id":"464a297.d5ae8d8","type":"link out","z":"61aa57b3.d74588","name":"","links":["2a686303.4a378c","d135ea4d.c340e8"],"x":235,"y":60,"wires":[]},{"id":"d135ea4d.c340e8","type":"link in","z":"61aa57b3.d74588","name":"Get Temperature & Humidity","links":["464a297.d5ae8d8"],"x":55,"y":180,"wires":[["1584e29d.e65d1d"]]},{"id":"4815289b.5b7d78","type":"change","z":"61aa57b3.d74588","name":"Save Temperature","rules":[{"t":"set","p":"state.temperature","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":180,"wires":[["f8cc4e4.08abcb"]]},{"id":"9953d62f.60f418","type":"change","z":"61aa57b3.d74588","name":"Save Humidity","rules":[{"t":"set","p":"state.humidity","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":240,"wires":[["b9339bda.dde228"]]},{"id":"a4f7980c.ef06a8","type":"comfort","z":"61aa57b3.d74588","name":"","tempField":"state.temperature","tempFieldType":"global","mrtField":"","mrtFieldType":"operative","humidityField":"state.humidity","humidityFieldType":"global","airspeedField":"0","airspeedFieldType":"num","metabolicRateField":"state.metabolic","metabolicRateFieldType":"global","clothingLevelField":"state.clothinglevel","clothingLevelFieldType":"global","comfortField":"state.comfort","comfortFieldType":"global","sensationField":"state.sensation","sensationFieldType":"global","x":160,"y":520,"wires":[["181c99a4.dd3f96","5028b222.b5098c"]]},{"id":"bc75eb2b.c7c838","type":"comment","z":"61aa57b3.d74588","name":"Get Comfort Level","info":"","x":110,"y":460,"wires":[]},{"id":"2a686303.4a378c","type":"link in","z":"61aa57b3.d74588","name":"Get Comfort Level","links":["464a297.d5ae8d8"],"x":55,"y":520,"wires":[["a4f7980c.ef06a8"]]},{"id":"56d94f9.8f6d9b","type":"ui_text","z":"61aa57b3.d74588","group":"5664af2f.e29e5","order":0,"width":"3","height":"1","name":"Display Comfort Level","label":"Comfort Level","format":"{{msg.payload | number:2}}","layout":"col-center","x":920,"y":500,"wires":[]},{"id":"181c99a4.dd3f96","type":"change","z":"61aa57b3.d74588","name":"Get Comfort Level","rules":[{"t":"set","p":"payload","pt":"msg","to":"state.comfort","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":500,"wires":[["56d94f9.8f6d9b"]]},{"id":"5028b222.b5098c","type":"change","z":"61aa57b3.d74588","name":"Get Comfort","rules":[{"t":"set","p":"payload","pt":"msg","to":"state.sensation","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":540,"wires":[["704677e1.e92088"]]},{"id":"704677e1.e92088","type":"ui_text","z":"61aa57b3.d74588","group":"5664af2f.e29e5","order":0,"width":"3","height":"1","name":"Display Comfort","label":"Sensation","format":"{{msg.payload}}","layout":"col-center","x":900,"y":540,"wires":[]},{"id":"17563110.150c9f","type":"ui_dropdown","z":"61aa57b3.d74588","name":"","label":"Metabolic Rate","place":"Select option","group":"5664af2f.e29e5","order":0,"width":0,"height":0,"passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":600,"y":660,"wires":[["68d0f433.2368ec"]]},{"id":"940e5519.01dcf8","type":"change","z":"61aa57b3.d74588","name":"Set Metabolic Dropdown","rules":[{"t":"set","p":"options","pt":"msg","to":"[{\"Sleeping\":0.7},{\"Reclining\":0.8},{\"Sitting\":1},{\"Typing\":1.1},{\"Standing\":1.2},{\"Cooking\":1.8},{\"Cleaning\":2.7},{\"Walking - casually\":1.7},{\"Walking - slow\":2},{\"Walking - medium\":2.6},{\"Walking - fast\":3.8},{\"Working - light\":2.2},{\"Working - medium\":2.7},{\"Working - heavy\":4},{\"Exercise - light\":3.4},{\"Exercise - moderate\":3.8},{\"Exercise - hard\":7}]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":660,"wires":[["17563110.150c9f"]]},{"id":"75bae571.98314c","type":"inject","z":"61aa57b3.d74588","name":"Initial Metabolic Rate","topic":"","payload":"1","payloadType":"num","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":160,"y":660,"wires":[["940e5519.01dcf8"]]},{"id":"b74243e3.b3a6f","type":"comment","z":"61aa57b3.d74588","name":"Configure Comfort Level","info":"","x":130,"y":600,"wires":[]},{"id":"68d0f433.2368ec","type":"change","z":"61aa57b3.d74588","name":"Set Metabolic Rate","rules":[{"t":"set","p":"state.metabolic","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":790,"y":660,"wires":[[]]},{"id":"b1dc2c71.98e6e","type":"change","z":"61aa57b3.d74588","name":"Set Clothing Dropdown","rules":[{"t":"set","p":"options","pt":"msg","to":"[{\"Naked\":0},{\"Summer indoor\":0.5},{\"Winter indoor\":1},{\"Sweat pants and sweatshirt\":0.74},{\"Sports wear\":0.36},{\"Business Suit - light\":0.79},{\"Business Suit - heavy\":1.02},{\"Coveralls\":0.72},{\"Hospital Gown\":0.31},{\"Pyjamas - short\":0.42},{\"Pyjamas - long\":0.57}]","tot":"json"},{"t":"set","p":"clothingAddOns","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":720,"wires":[["a7366ec9.de69b"]]},{"id":"e2344439.4737d8","type":"inject","z":"61aa57b3.d74588","name":"Initial Clothing","topic":"","payload":"0.57","payloadType":"num","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":140,"y":720,"wires":[["b1dc2c71.98e6e"]]},{"id":"a7366ec9.de69b","type":"ui_dropdown","z":"61aa57b3.d74588","name":"","label":"Clothing","place":"Select option","group":"5664af2f.e29e5","order":0,"width":0,"height":0,"passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":580,"y":720,"wires":[["65025c39.909584"]]},{"id":"65025c39.909584","type":"change","z":"61aa57b3.d74588","name":"Set Clothing","rules":[{"t":"set","p":"state.clothing","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":720,"wires":[["aaec160a.f86d68"]]},{"id":"f4099a08.72cc28","type":"ui_switch","z":"61aa57b3.d74588","name":"","label":"Blanket","group":"5664af2f.e29e5","order":0,"width":"3","height":"1","passthru":false,"decouple":"false","topic":"","style":"","onvalue":"0.2","onvalueType":"num","onicon":"","oncolor":"","offvalue":"-0.2","offvalueType":"num","officon":"","offcolor":"","x":580,"y":780,"wires":[["a1ec1e2e.0bfd1"]]},{"id":"aaec160a.f86d68","type":"change","z":"61aa57b3.d74588","name":"Set Clothing Level","rules":[{"t":"set","p":"state.clothinglevel","pt":"global","to":"$globalContext(\"state.clothing\") + $flowContext(\"clothingAddOns\")","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"state.clothinglevel","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":720,"wires":[[]]},{"id":"a1ec1e2e.0bfd1","type":"change","z":"61aa57b3.d74588","name":"Add On Clothing","rules":[{"t":"set","p":"clothingAddOns","pt":"flow","to":"$flowContext(\"clothingAddOns\") + msg.payload","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":790,"y":780,"wires":[["aaec160a.f86d68"]]},{"id":"4d779e8c.3dc6a","type":"ui_switch","z":"61aa57b3.d74588","name":"","label":"Sheet","group":"5664af2f.e29e5","order":0,"width":"3","height":"1","passthru":false,"decouple":"false","topic":"","style":"","onvalue":"0.1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"-0.1","offvalueType":"num","officon":"","offcolor":"","x":570,"y":840,"wires":[["a1ec1e2e.0bfd1"]]},{"id":"8537004e.511","type":"ui_switch","z":"61aa57b3.d74588","name":"","label":"Chair","group":"5664af2f.e29e5","order":0,"width":"3","height":"1","passthru":false,"decouple":"false","topic":"","style":"","onvalue":"0.01","onvalueType":"num","onicon":"","oncolor":"","offvalue":"-0.01","offvalueType":"num","officon":"","offcolor":"","x":570,"y":900,"wires":[["a1ec1e2e.0bfd1"]]},{"id":"f05cc684.097048","type":"ui_switch","z":"61aa57b3.d74588","name":"","label":"Armchair","group":"5664af2f.e29e5","order":0,"width":"3","height":"1","passthru":false,"decouple":"false","topic":"","style":"","onvalue":"0.25","onvalueType":"num","onicon":"","oncolor":"","offvalue":"-0.25","offvalueType":"num","officon":"","offcolor":"","x":580,"y":960,"wires":[["a1ec1e2e.0bfd1"]]},{"id":"d7560887.d5c378","type":"ui_switch","z":"61aa57b3.d74588","name":"","label":"Coat","group":"5664af2f.e29e5","order":0,"width":"3","height":"1","passthru":false,"decouple":"false","topic":"","style":"","onvalue":"0.6","onvalueType":"num","onicon":"","oncolor":"","offvalue":"-0.6","offvalueType":"num","officon":"","offcolor":"","x":570,"y":1020,"wires":[["a1ec1e2e.0bfd1"]]},{"id":"cdcc200.969bbe","type":"ui_group","z":"","name":"Conditions","tab":"9cb4eb1e.6f02b8","order":1,"disp":true,"width":"18","collapse":false},{"id":"5664af2f.e29e5","type":"ui_group","z":"","name":"Comfort","tab":"9cb4eb1e.6f02b8","disp":true,"width":"6","collapse":false},{"id":"9cb4eb1e.6f02b8","type":"ui_tab","z":"","name":"Sensors","icon":"dashboard","order":3}]
Created 7 years, 11 months ago
Updated 7 years, 4 months ago
  • change (x11)
  • comment (x3)
  • inject (x3)
  • link in (x2)
  • link out (x1)
  • comfort
  • comfortzone
  • sensors
  • temperature
  • humidity
  • raspberrypi
  • raspi
  • dashboard
  • dht11
  • dht22
