Cycle actions (subflow)
This simple subflow can be used to cycle actions such as choosing a new scene or radio station for each new payload received. Suitable to be used in conjunction with a change node. Double click the subflow to set the numbr of scenes/actiona and set AutoReset to true if you want the counter to reset after 3 seconds (great if you want an easy way to default to your favourite scene).
Subflow
Example flow 1
Example flow 2
Copy the subflow below to your clipboard and then import into Node-RED using the Import From > Clipboard (Ctrl-I) menu option
[{"id":"99fb54ac.f882f8","type":"subflow","name":"Cycle actions","info":"","category":"","in":[{"x":60,"y":130,"wires":[{"id":"ae3e5b31.5a9118"},{"id":"48a3b254.5f1a9c"}]}],"out":[{"x":350,"y":150,"wires":[{"id":"ae3e5b31.5a9118","port":0}]}],"env":[{"name":"Actions","type":"num","value":"3","ui":{"type":"input","opts":{"types":["num"]}}},{"name":"AutoReset","type":"bool","value":"false"}],"color":"#DDAA99","outputLabels":["Action number"],"icon":"font-awesome/fa-refresh","status":{"x":350,"y":110,"wires":[{"id":"ae3e5b31.5a9118","port":0}]}},{"id":"ae3e5b31.5a9118","type":"function","z":"99fb54ac.f882f8","name":"Cycle actions","func":"var Actions = flow.get(\"toggleNext\") + 1||1;\n\nif (Actions >= env.get(\"Actions\")){\n    flow.set(\"toggleNext\",0);\n    msg.payload = env.get(\"Actions\");\n    }\nelse{\n    flow.set(\"toggleNext\", Actions);\n    msg.payload = Actions\n    }\nreturn msg;","outputs":1,"noerr":0,"x":200,"y":130,"wires":[[]]},{"id":"53bd1934.771a68","type":"trigger","z":"99fb54ac.f882f8","op1":"","op2":"true","op1type":"nul","op2type":"bool","duration":"3","extend":true,"units":"s","reset":"","bytopic":"all","name":"","x":260,"y":210,"wires":[["7b3ccef9.bbba9"]]},{"id":"7b3ccef9.bbba9","type":"change","z":"99fb54ac.f882f8","name":"reset counter","rules":[{"t":"set","p":"toggleNext","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":250,"wires":[[]]},{"id":"48a3b254.5f1a9c","type":"switch","z":"99fb54ac.f882f8","name":"AutoReset on/off","property":"AutoReset","propertyType":"env","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":210,"y":170,"wires":[["53bd1934.771a68"]]},{"id":"aa7fa079.8627","type":"comment","z":"99fb54ac.f882f8","name":"Latest version of this and other flows can be found at: https://flows.nodered.org/collection/YsSoz9IDM4Z_","info":"","x":400,"y":50,"wires":[]}]
Created 6 years ago
  • change (x1)
  • switch (x1)
  • trigger (x1)
  • subflow (x1)
  • Cycle
  • scenes
  • actions
  • Presets
