ESP32 flow
Web Flow For ESP32 to on/off builtin led
[{"id":"b906b448.4e3898","type":"tab","label":"Web-client Flow","disabled":false,"info":""},{"id":"b74149e9.760b78","type":"mqtt out","z":"b906b448.4e3898","name":"","topic":"$aws/things/{thingname}/shadow/update","qos":"0","retain":"","broker":"ab556423.32db78","x":860,"y":160,"wires":[]},{"id":"bf1d674c.a2b408","type":"http in","z":"b906b448.4e3898","name":"","url":"/ON","method":"get","upload":false,"swaggerDoc":"","x":220,"y":80,"wires":[["7c2a605c.c71a1","b832311f.b95dd","9c1b1511.db8e28"]],"info":"<html>\r\n    <head></head>\r\n    <body>\r\n        <h1>Hello World!</h1>\r\n    </body>\r\n</html>"},{"id":"b475b454.5b0308","type":"mqtt out","z":"b906b448.4e3898","name":"","topic":"$aws/things/{thingname}/shadow/get","qos":"","retain":"","broker":"ab556423.32db78","x":850,"y":40,"wires":[]},{"id":"7c2a605c.c71a1","type":"function","z":"b906b448.4e3898","name":"payload","func":"msg.payload = {\"state\": {\"desired\": {\"power\": \"1\"}}}\nreturn msg;","outputs":1,"noerr":0,"x":500,"y":160,"wires":[["b74149e9.760b78"]]},{"id":"46c5736c.85a90c","type":"http in","z":"b906b448.4e3898","name":"","url":"/OFF","method":"get","upload":false,"swaggerDoc":"","x":220,"y":380,"wires":[["ea9a1fab.59f27","1e2599f1.98e4f6","10f44e87.4e3ae1"]]},{"id":"33a832be.a343ce","type":"mqtt out","z":"b906b448.4e3898","name":"","topic":"$aws/things/{thingname}/shadow/get","qos":"","retain":"","broker":"ab556423.32db78","x":850,"y":380,"wires":[]},{"id":"70023a73.90c904","type":"mqtt out","z":"b906b448.4e3898","name":"","topic":"$aws/things/{thingname}/shadow/update","qos":"0","retain":"","broker":"ab556423.32db78","x":860,"y":480,"wires":[]},{"id":"ea9a1fab.59f27","type":"function","z":"b906b448.4e3898","name":"payload","func":"msg.payload = {\"state\": {\"desired\": {\"power\": \"0\"}}}\nreturn msg;","outputs":1,"noerr":0,"x":500,"y":480,"wires":[["70023a73.90c904"]]},{"id":"b832311f.b95dd","type":"template","z":"b906b448.4e3898","name":"","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"<!DOCTYPE html><html>\n<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n<link rel=\"icon\" href=\"data:,\">\n<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}\n</style></head>\n<body><h1>Cloud Home Automation Series</h1>\n<p>Bulb - is - ON , Click to Turn it OFF</p>\n<p><a href=\"/OFF\"><button style=\"background-color:transparent; border-color:transparent;\"><img src=\"https://automationking.s3.jp-tok.cloud-object-storage.appdomain.cloud/ON.jpg\" height=\"400\"/></button></a></p>\n</body></html>","output":"str","x":500,"y":260,"wires":[["d931c2b5.a5299"]]},{"id":"d931c2b5.a5299","type":"http response","z":"b906b448.4e3898","name":"","statusCode":"200","headers":{},"x":740,"y":260,"wires":[]},{"id":"1e2599f1.98e4f6","type":"template","z":"b906b448.4e3898","name":"","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"<!DOCTYPE html><html>\n<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\n<link rel=\"icon\" href=\"data:,\">\n<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}\n</style></head>\n<body><h1>Cloud Home Automation Series</h1>\n<p>Bulb - is - OFF , Click to Turn it ON</p>\n<p><a href=\"/ON\"><button style=\"background-color:transparent; border-color:transparent;\"> \n  <img src=\"https://automationking.s3.jp-tok.cloud-object-storage.appdomain.cloud/OFF.jpg\" height=\"400\"/></button></a></p>\n</body></html>\n</body></html>","output":"str","x":500,"y":580,"wires":[["8f1e8ebc.3c8d9"]]},{"id":"8f1e8ebc.3c8d9","type":"http response","z":"b906b448.4e3898","name":"","statusCode":"200","headers":{},"x":760,"y":580,"wires":[]},{"id":"9c1b1511.db8e28","type":"delay","z":"b906b448.4e3898","name":"","pauseType":"delay","timeout":"30","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":510,"y":40,"wires":[["b475b454.5b0308"]]},{"id":"10f44e87.4e3ae1","type":"delay","z":"b906b448.4e3898","name":"","pauseType":"delay","timeout":"30","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":510,"y":380,"wires":[["33a832be.a343ce"]]},{"id":"ab556423.32db78","type":"mqtt-broker","z":"","name":"AWS_Broker","broker":"endpoint.iot.us-east-1.amazonaws.com","port":"8883","tls":"6dae71c2.4c17b","clientid":"","usetls":true,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"6dae71c2.4c17b","type":"tls-config","z":"","name":"","cert":"","key":"","ca":"","certname":"","keyname":"","caname":"","servername":"","verifyservercert":true}]
Created 3 years, 9 months ago
Rating: 4 1
  • delay (x2)
  • function (x2)
  • http in (x2)
  • http response (x2)
  • mqtt out (x4)
  • mqtt-broker (x1)
  • template (x2)
  • tls-config (x1)
