Forza Horizon 5 telemetry to InfluxDB
This node setups a UDP server that Forza Horizon 5 Telemetry can connect to. From what I understand the telemetry in Forza Horizon 5 could not connect to the same IP-address as the game is running on. So if that is true, you'll have to run Node-Red on a different PC/server/IP-address than the game runs on. According to what I could find this should work on Forza Horizon 4 aswell, but I cannot confirm since I don't have Forza Horizon 4.
The game sends 60 messages per second, which could be overwhelming, therefore use the throttle node to limit the number of messages. Grafana is struggling with anything less than 150-200ms refresh rate.
In the parser node you could change the element name, that is used as field in InfluxDB, and scale them to fit the preferable unit.
Only tested on InfluxDB 1.x.
This is what it could look like in Grafana: image
[{"id":"16679a3dcc0f0177","type":"tab","label":"Forza","disabled":false,"info":"","env":[]},{"id":"3489eba8b6ea3f72","type":"udp in","z":"16679a3dcc0f0177","name":"Forza","iface":"","port":"1050","ipv":"udp4","multicast":"false","group":"","datatype":"buffer","x":130,"y":100,"wires":[["efa1fb6baaa3c43b"]]},{"id":"efa1fb6baaa3c43b","type":"buffer-parser","z":"16679a3dcc0f0177","name":"Forza parser","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"uint32le","name":"IsRaceOn","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"EngineMaxRpm","offset":8,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"EngineIdleRpm","offset":12,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"CurrentEngineRpm","offset":16,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"AccelerationX","offset":20,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"AccelerationY","offset":24,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"AccelerationZ","offset":28,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"VelocityX","offset":32,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"VelocityY","offset":36,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"VelocityZ","offset":40,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"AngularVelocityX","offset":44,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"AngularVelocityY","offset":48,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"AngularVelocityZ","offset":52,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Yaw","offset":56,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Pitch","offset":60,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Roll","offset":64,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"NormalizedSuspensionTravelFrontLeft","offset":68,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"NormalizedSuspensionTravelFrontRight","offset":72,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"NormalizedSuspensionTravelRearLeft","offset":76,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"NormalizedSuspensionTravelRearRight","offset":80,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireSlipRatioFrontLeft","offset":84,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireSlipRatioFrontRight","offset":88,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireSlipRatioRearLeft","offset":92,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireSlipRatioRearRight","offset":96,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelRotationSpeedFrontLeft","offset":100,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelRotationSpeedFrontRight","offset":104,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelRotationSpeedRearLeft","offset":108,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelRotationSpeedRearRight","offset":112,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelOnRumbleStripFrontLeft","offset":116,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelOnRumbleStripFrontRight","offset":120,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelOnRumbleStripRearLeft","offset":124,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelOnRumbleStripRearRight","offset":128,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelInPuddleDepthFrontLeft","offset":132,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelInPuddleDepthFrontRight","offset":136,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelInPuddleDepthRearLeft","offset":140,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"WheelInPuddleDepthRearRight","offset":144,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"SurfaceRumbleFrontLeft","offset":148,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"SurfaceRumbleFrontRight","offset":152,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"SurfaceRumbleRearLeft","offset":156,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"SurfaceRumbleRearRight","offset":160,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireSlipAngleFrontLeft","offset":164,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireSlipAngleFrontRight","offset":168,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireSlipAngleRearLeft","offset":172,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireSlipAngleRearRight","offset":176,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireCombinedSlipFrontLeft","offset":180,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireCombinedSlipFrontRight","offset":184,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireCombinedSlipRearLeft","offset":188,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireCombinedSlipRearRight","offset":192,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"SuspensionTravelMetersFrontLeft","offset":196,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"SuspensionTravelMetersFrontRight","offset":200,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"SuspensionTravelMetersRearLeft","offset":204,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"SuspensionTravelMetersRearRight","offset":208,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"CarOrdinal","offset":212,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"CarClass","offset":216,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"CarPerformanceIndex","offset":220,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"DrivetrainType","offset":224,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"NumCylinders","offset":228,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"PositionX","offset":244,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"PositionY","offset":248,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"PositionZ","offset":252,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Speed","offset":256,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Speed km/t","offset":256,"length":1,"offsetbit":0,"scale":"3.6","mask":""},{"type":"floatle","name":"Power","offset":260,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Torque","offset":264,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireTempFrontLeft","offset":268,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireTempFrontRight","offset":272,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireTempRearLeft","offset":276,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"TireTempRearRight","offset":280,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Boost","offset":284,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"Fuel","offset":288,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"DistanceTraveled","offset":292,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"BestLap","offset":296,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"LastLap","offset":300,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"CurrentLap","offset":304,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"floatle","name":"CurrentRaceTime","offset":308,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"LapNumber","offset":312,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"RacePosition","offset":314,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"Accel","offset":315,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"Brake","offset":316,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"Clutch","offset":317,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"HandBrake","offset":318,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"Gear","offset":319,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int8","name":"Steer","offset":320,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int8","name":"NormalizedDrivingLine","offset":321,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int8","name":"NormalizedAIBrakeDifference","offset":322,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":330,"y":100,"wires":[["4fe8767cf540c1a4"]]},{"id":"f4cfb1e70481edd1","type":"influxdb out","z":"16679a3dcc0f0177","influxdb":"71105ad8b036bf76","name":"","measurement":"forza","precision":"","retentionPolicy":"","database":"database","precisionV18FluxV20":"ms","retentionPolicyV18Flux":"","org":"organisation","bucket":"bucket","x":740,"y":100,"wires":[]},{"id":"4fe8767cf540c1a4","type":"throttle","z":"16679a3dcc0f0177","name":"","throttleType":"time","timeLimit":"100","timeLimitType":"milliseconds","countLimit":0,"blockSize":0,"locked":false,"x":560,"y":100,"wires":[["f4cfb1e70481edd1"]]},{"id":"ca756d09424e693b","type":"comment","z":"16679a3dcc0f0177","name":"","info":"Forza sends 60 messages per second, so if you would like to have less messages use this node.\nGrafana have hard time with refresh rate quicker than 150-200ms, so messages with 16,67ms is perhaps not needed.","x":560,"y":60,"wires":[]},{"id":"71105ad8b036bf76","type":"influxdb","hostname":"127.0.0.1","port":"8086","protocol":"http","database":"forza","name":"forza","usetls":false,"tls":"","influxdbVersion":"1.x","url":"http://localhost:8086","rejectUnauthorized":true}]
Rating: 5 2
  • udp in (x1)
  • buffer-parser (x1)
  • influxdb (x1)
  • influxdb out (x1)
  • throttle (x1)
  • Forza Horizon 5
  • Forza
  • InfluxDB
