Creating Charts with uibuilder and ChartKick
The original for this is kept on the uibuilder WIKI, note that the WIKI version may get updated from time-to-time, please check there for the latest version.
Here is an example of how to use Chartkick with the default uibuilder v2 installation to add a multiple charts using both Chart.js and Google Charts.
ChartKick is a library that simplifies the creation of charts using one or more chart libraries: Chart.js, Google Charts, and Highcharts.
Add an instance of uibuilder to your flows and replace the index.html and index.js files with the code below.
I'm loading the chart libraries using a CDN here, the next step would be to install the two packages using uibuilder's npm interface.
The example flow sends an array of [timestamp,random-number] to the app every 10 seconds which is used to update the area chart with up to 1000 entries (after which the oldest entries are dropped off when a new msg arrives).
Note that the following flow also includes 2 comment nodes containing the html and javascript.
html
<!doctype html><html lang="en"><head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=yes">
    <title>Chartkick/VueJS Example - Node-RED UI Builder</title>
    <meta name="description" content="Node-RED UI Builder - Chartkick/VueJS Example">
    <link rel="icon" href="./images/node-blue.ico">
    <link type="text/css" rel="stylesheet" href="../uibuilder/vendor/bootstrap/dist/css/bootstrap.min.css" />
    <link type="text/css" rel="stylesheet" href="../uibuilder/vendor/bootstrap-vue/dist/bootstrap-vue.css" />
    <link rel="stylesheet" href="./index.css" media="all">
</head><body>
    <div id="app">
        <b-container id="app_container">
            <h1>
                Example of using <a href="https://chartkick.com/vue" target="_blank">Vue Chartkick</a>
                with uibuilder, VueJS and bootstrap-vue
            </h1>
            <b-row>
                <b-card cols="5" class="mr-1" header="Bar Chart" border-variant="primary" header-bg-variant="primary" header-text-variant="white" align="center">
                    <column-chart :data="[['Sun', 32], ['Mon', 46], ['Tue', 28]]"></column-chart>
                </b-card>
                <b-card  class="mr-1" header="Line Chart" border-variant="primary" header-bg-variant="primary" header-text-variant="white" align="center">
                    <line-chart :data="lineChartData"></line-chart>
                </b-card>
                <b-card  class="mr-1" header="Multi-Series Line Chart" border-variant="primary" header-bg-variant="primary" header-text-variant="white" align="center">
                    <line-chart :data="lineChartData2"></line-chart>
                </b-card>
                <b-card class="w-100 mt-3 mb-3" header="Area Chart" border-variant="primary" header-bg-variant="primary" header-text-variant="white" align="center">
                    <area-chart :data="areaChartData"></area-chart>
                </b-card>
                <b-card class="mr-1" header="Geo Chart (Google)" border-variant="primary" header-bg-variant="primary" header-text-variant="white" align="center">
                    <geo-chart width="800px" :data="[['United States', 44], ['Germany', 23], ['Brazil', 22]]"></geo-chart>
                </b-card>
                <b-card class="mr-1" header="Timeline (Google)" border-variant="primary" header-bg-variant="primary" header-text-variant="white" align="center">
                   <timeline width="800px" :data="[['Washington', '1789-04-29', '1797-03-03'], ['Adams', '1797-03-03', '1801-03-03']]"></timeline>
                </b-card>
            </b-row>
        </b-container>
    </div>
    <script src="../uibuilder/vendor/socket.io/socket.io.js"></script>
    <script src="../uibuilder/vendor/vue/dist/vue.min.js"></script>
    <script src="../uibuilder/vendor/bootstrap-vue/dist/bootstrap-vue.js"></script>
    <!-- Loading from CDN, use uibuilder to install packages and change to vendor links -->
    <script src="https://unpkg.com/[email protected]/dist/Chart.bundle.js"></script> <!-- Chart.js -->
    <script src="https://www.gstatic.com/charts/loader.js"></script> <!-- Google Charts -->
    <!-- <script src="https://code.highcharts.com/highcharts.js"></script>  HighCharts -->
    <script src="https://unpkg.com/[email protected]"></script>
    <script src="./uibuilderfe.min.js"></script> <!--    //prod version -->
    <script src="./index.js"></script>
</body></html>
javascript
/* jshint browser: true, esversion: 5 */
/* globals document,Vue,window,uibuilder */
// @ts-nocheck
  Copyright (c) 2019 Julian Knight (Totally Information)
  Licensed under the Apache License, Version 2.0 (the "License");
  you may not use this file except in compliance with the License.
  You may obtain a copy of the License at
  Unless required by applicable law or agreed to in writing, software
  distributed under the License is distributed on an "AS IS" BASIS,
  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  See the License for the specific language governing permissions and
  limitations under the License.
'use strict'
/** @see https://github.com/TotallyInformation/node-red-contrib-uibuilder/wiki/Front-End-Library---available-properties-and-methods */
// eslint-disable-next-line no-unused-vars
var app1 = new Vue({
    el: '#app',
    data: {
        // Single series line chart
        lineChartData: [
            ['Jan', 4], ['Feb', 2], ['Mar', 10], ['Apr', 5], ['May', 3],
        // Multi-series line chart
        lineChartData2: [
            {name: 'Workout', data: {'2017-01-01 00:00:00 -0800': 3, '2017-01-02 00:00:00 -0800': 4}},
            {name: 'Call parents', data: {'2017-01-01 00:00:00 -0800': 5, '2017-01-02 00:00:00 -0800': 3}},
        // Area chart
        areaChartData: [], //{
            //'2017-01-01 00:00:00 -0800': 2,
            //'2017-01-01 00:01:00 -0800': 5,
    }, // --- End of data --- //
    computed: {
    }, // --- End of computed --- //
    methods: {
    }, // --- End of methods --- //
    // Available hooks: init,mounted,updated,destroyed
    mounted: function(){
        /** **REQUIRED** Start uibuilder comms with Node-RED @since v2.0.0-dev3
         * Pass the namespace and ioPath variables if hosting page is not in the instance root folder
         * e.g. If you get continual `uibuilderfe:ioSetup: SOCKET CONNECT ERROR` error messages.
         * e.g. uibuilder.start('/nr/uib', '/nr/uibuilder/vendor/socket.io') // change to use your paths/names
        uibuilder.start()
        var vueApp = this
        // Process new messages from Node-RED
        uibuilder.onChange('msg', function (newVal) {
            // We are assuming that msg.payload is an array like [datenum, value]
            // Add new element
            vueApp.areaChartData.push( new Array( (new Date(newVal.payload[0])), newVal.payload[1] ) )
            // If data array > 1000 points, keep it at that length by losing the first point
            if ( vueApp.areaChartData.length > 1000 ) vueApp.areaChartData.shift()
            //console.log(vueApp.areaChartData)
    } // --- End of mounted hook --- //
}) // --- End of app1 --- //
// EOF
[{"id":"df81cc9e.a9171","type":"inject","z":"18cb249f.38bafb","name":"repeat every 10s","topic":"","payload":"","payloadType":"date","repeat":"10","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":80,"wires":[["6ca36476.d0597c"]]},{"id":"76678044.5aaeb","type":"debug","z":"18cb249f.38bafb","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":650,"y":60,"wires":[]},{"id":"bd9b5761.fb4918","type":"debug","z":"18cb249f.38bafb","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":630,"y":100,"wires":[]},{"id":"b18a50dd.f7e5c","type":"uibuilder","z":"18cb249f.38bafb","name":"","topic":"","url":"chart","fwdInMessages":false,"allowScripts":false,"allowStyles":false,"copyIndex":true,"showfolder":false,"x":490,"y":80,"wires":[["76678044.5aaeb"],["bd9b5761.fb4918"]]},{"id":"6ca36476.d0597c","type":"change","z":"18cb249f.38bafb","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[\t    payload, ($random()*10)\t]\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":80,"wires":[["b18a50dd.f7e5c"]]},{"id":"3ebfbce9.6ccd84","type":"comment","z":"18cb249f.38bafb","name":"html","info":"copy the following and paste into `index.html`\n\n```html\n<!doctype html><html lang=\"en\"><head>\n    <meta charset=\"utf-8\">\n    <meta http-equiv=\"X-UA-Compatible\" content=\"IE=edge\">\n    <meta name=\"viewport\" content=\"width=device-width, minimum-scale=1, initial-scale=1, user-scalable=yes\">\n\n    <title>Chartkick/VueJS Example - Node-RED UI Builder</title>\n    <meta name=\"description\" content=\"Node-RED UI Builder - Chartkick/VueJS Example\">\n\n    <link rel=\"icon\" href=\"./images/node-blue.ico\">\n\n    <link type=\"text/css\" rel=\"stylesheet\" href=\"../uibuilder/vendor/bootstrap/dist/css/bootstrap.min.css\" />\n    <link type=\"text/css\" rel=\"stylesheet\" href=\"../uibuilder/vendor/bootstrap-vue/dist/bootstrap-vue.css\" />\n\n    <link rel=\"stylesheet\" href=\"./index.css\" media=\"all\">\n</head><body>\n    <div id=\"app\">\n        <b-container id=\"app_container\">\n\n            <h1>\n                Example of using <a href=\"https://chartkick.com/vue\" target=\"_blank\">Vue Chartkick</a>\n                with uibuilder, VueJS and bootstrap-vue\n            </h1>\n\n            <b-row>\n                <b-card cols=\"5\" class=\"mr-1\" header=\"Bar Chart\" border-variant=\"primary\" header-bg-variant=\"primary\" header-text-variant=\"white\" align=\"center\">\n                    <column-chart :data=\"[['Sun', 32], ['Mon', 46], ['Tue', 28]]\"></column-chart>\n                </b-card>\n\n                <b-card  class=\"mr-1\" header=\"Line Chart\" border-variant=\"primary\" header-bg-variant=\"primary\" header-text-variant=\"white\" align=\"center\">\n                    <line-chart :data=\"lineChartData\"></line-chart>\n                </b-card>\n\n                <b-card  class=\"mr-1\" header=\"Multi-Series Line Chart\" border-variant=\"primary\" header-bg-variant=\"primary\" header-text-variant=\"white\" align=\"center\">\n                    <line-chart :data=\"lineChartData2\"></line-chart>\n                </b-card>\n\n                <b-card class=\"w-100 mt-3 mb-3\" header=\"Area Chart\" border-variant=\"primary\" header-bg-variant=\"primary\" header-text-variant=\"white\" align=\"center\">\n                    <area-chart :data=\"areaChartData\"></area-chart>\n                </b-card>\n\n                <b-card class=\"mr-1\" header=\"Geo Chart (Google)\" border-variant=\"primary\" header-bg-variant=\"primary\" header-text-variant=\"white\" align=\"center\">\n                    <geo-chart width=\"800px\" :data=\"[['United States', 44], ['Germany', 23], ['Brazil', 22]]\"></geo-chart>\n                </b-card>\n\n                <b-card class=\"mr-1\" header=\"Timeline (Google)\" border-variant=\"primary\" header-bg-variant=\"primary\" header-text-variant=\"white\" align=\"center\">\n                   <timeline width=\"800px\" :data=\"[['Washington', '1789-04-29', '1797-03-03'], ['Adams', '1797-03-03', '1801-03-03']]\"></timeline>\n                </b-card>\n\n            </b-row>\n\n        </b-container>\n    </div>\n\n    <script src=\"../uibuilder/vendor/socket.io/socket.io.js\"></script>\n    <script src=\"../uibuilder/vendor/vue/dist/vue.min.js\"></script>\n    <script src=\"../uibuilder/vendor/bootstrap-vue/dist/bootstrap-vue.js\"></script>\n\n    <!-- Loading from CDN, use uibuilder to install packages and change to vendor links -->\n    <script src=\"https://unpkg.com/[email protected]/dist/Chart.bundle.js\"></script> <!-- Chart.js -->\n    <script src=\"https://www.gstatic.com/charts/loader.js\"></script> <!-- Google Charts -->\n    <!-- <script src=\"https://code.highcharts.com/highcharts.js\"></script>  HighCharts -->\n    <script src=\"https://unpkg.com/[email protected]\"></script>\n\n    <script src=\"./uibuilderfe.min.js\"></script> <!--    //prod version -->\n    <script src=\"./index.js\"></script>\n\n</body></html>\n```","x":370,"y":40,"wires":[]},{"id":"7254bbb9.903ce4","type":"comment","z":"18cb249f.38bafb","name":"JavaScript","info":"Copy the following and paste into `index.js`\n\n```javascript\n/* jshint browser: true, esversion: 5 */\n/* globals document,Vue,window,uibuilder */\n// @ts-nocheck\n/*\n  Copyright (c) 2019 Julian Knight (Totally Information)\n\n  Licensed under the Apache License, Version 2.0 (the \"License\");\n  you may not use this file except in compliance with the License.\n  You may obtain a copy of the License at\n\n  http://www.apache.org/licenses/LICENSE-2.0\n\n  Unless required by applicable law or agreed to in writing, software\n  distributed under the License is distributed on an \"AS IS\" BASIS,\n  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.\n  See the License for the specific language governing permissions and\n  limitations under the License.\n*/\n'use strict'\n\n/** @see https://github.com/TotallyInformation/node-red-contrib-uibuilder/wiki/Front-End-Library---available-properties-and-methods */\n\n// eslint-disable-next-line no-unused-vars\nvar app1 = new Vue({\n    el: '#app',\n    data: {\n        // Single series line chart\n        lineChartData: [\n            ['Jan', 4], ['Feb', 2], ['Mar', 10], ['Apr', 5], ['May', 3],\n        ],\n        // Multi-series line chart\n        lineChartData2: [\n            {name: 'Workout', data: {'2017-01-01 00:00:00 -0800': 3, '2017-01-02 00:00:00 -0800': 4}},\n            {name: 'Call parents', data: {'2017-01-01 00:00:00 -0800': 5, '2017-01-02 00:00:00 -0800': 3}},\n        ],\n\n        // Area chart\n        areaChartData: [], //{\n            //'2017-01-01 00:00:00 -0800': 2,\n            //'2017-01-01 00:01:00 -0800': 5,\n        //},\n\n    }, // --- End of data --- //\n    computed: {\n    }, // --- End of computed --- //\n    methods: {\n    }, // --- End of methods --- //\n\n    // Available hooks: init,mounted,updated,destroyed\n    mounted: function(){\n        /** **REQUIRED** Start uibuilder comms with Node-RED @since v2.0.0-dev3\n         * Pass the namespace and ioPath variables if hosting page is not in the instance root folder\n         * e.g. If you get continual `uibuilderfe:ioSetup: SOCKET CONNECT ERROR` error messages.\n         * e.g. uibuilder.start('/nr/uib', '/nr/uibuilder/vendor/socket.io') // change to use your paths/names\n         */\n        uibuilder.start()\n\n        var vueApp = this\n\n        // Process new messages from Node-RED\n        uibuilder.onChange('msg', function (newVal) {\n            // We are assuming that msg.payload is an array like [datenum, value]\n\n            // Add new element\n            vueApp.areaChartData.push( new Array( (new Date(newVal.payload[0])), newVal.payload[1] ) )\n\n            // If data array > 1000 points, keep it at that length by losing the first point\n            if ( vueApp.areaChartData.length > 1000 ) vueApp.areaChartData.shift()\n\n            //console.log(vueApp.areaChartData)\n        })\n\n    } // --- End of mounted hook --- //\n\n}) // --- End of app1 --- //\n\n// EOF\n```\n","x":480,"y":40,"wires":[]}]
Created 7 years, 5 months ago
  • change (x1)
  • comment (x2)
  • debug (x2)
  • uibuilder (x1)
  • uibuilder
  • charting
  • VueJS
  • Vue
  • ChartKick
  • ChartJS
  • Google-Charts
  • Highcharts
