Node-Red Gotifier - Send Notifications Through Gotify
About
This flow creates a simple UI on the dashboard to send push notifications via Gotify. Simply set your Gotify server base URL and app token in the credentials node.
Image of Flow:
flow
Image of UI:
flow1
[{"id":"761e2d49685748c6","type":"tab","label":"Gotifier - Send Notifications","disabled":false,"info":"Send a custom push notification via Gotify."},{"id":"0a07eb38827d4d4d","type":"http request","z":"761e2d49685748c6","name":"Send Request","method":"POST","ret":"obj","paytoqs":"body","url":"{{{serverBaseURL}}}/message?token={{appToken}}","tls":"","persist":false,"proxy":"","authType":"","x":920,"y":260,"wires":[["1db22973dac45953","21c0c7a49cf8c834"]]},{"id":"df66206a0eaf57e3","type":"credentials","z":"761e2d49685748c6","name":"Data: Server URL & App Token","props":[{"value":"appToken","type":"msg"},{"value":"serverBaseURL","type":"msg"}],"x":710,"y":260,"wires":[["0a07eb38827d4d4d"]]},{"id":"cdf7a61aabd2f45b","type":"ui_form","z":"761e2d49685748c6","name":"Message Form","label":"","group":"ec74d5c2056e102f","order":5,"width":0,"height":0,"options":[{"label":"Title","value":"title","type":"text","required":true,"rows":null},{"label":"Message","value":"message","type":"text","required":true,"rows":null}],"formValue":{"title":"","message":""},"payload":"","submit":"submit","cancel":"cancel","topic":"topic","topicType":"msg","splitLayout":"","className":"","x":460,"y":220,"wires":[["b54a793a929d81c0"]]},{"id":"b083cb84ce95d52c","type":"ui_slider","z":"761e2d49685748c6","name":"priority","label":"Message Priority","tooltip":"","group":"ec74d5c2056e102f","order":4,"width":0,"height":0,"passthru":true,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":10,"step":1,"className":"","x":430,"y":160,"wires":[["9cd30fa332737e6a"]]},{"id":"9cd30fa332737e6a","type":"change","z":"761e2d49685748c6","name":"","rules":[{"t":"set","p":"priority","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":160,"wires":[[]]},{"id":"b54a793a929d81c0","type":"change","z":"761e2d49685748c6","name":"","rules":[{"t":"set","p":"payload.priority","pt":"msg","to":"priority","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":220,"wires":[["df66206a0eaf57e3"]]},{"id":"ad309df69537acf4","type":"template","z":"761e2d49685748c6","name":"Payload: Success","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Notification sent succesfully!","output":"str","x":1170,"y":200,"wires":[["0205db3a4af83546"]]},{"id":"0205db3a4af83546","type":"ui_toast","z":"761e2d49685748c6","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"className":"","topic":"","name":"","x":1160,"y":240,"wires":[]},{"id":"1db22973dac45953","type":"switch","z":"761e2d49685748c6","name":"Success?","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1140,"y":160,"wires":[["ad309df69537acf4"]]},{"id":"21c0c7a49cf8c834","type":"switch","z":"761e2d49685748c6","name":"Failure?","property":"statusCode","propertyType":"msg","rules":[{"t":"neq","v":"200","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":1140,"y":340,"wires":[["ba11ec746f458636"]]},{"id":"ba11ec746f458636","type":"template","z":"761e2d49685748c6","name":"Payload: Failure","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Notification Failed to send :[","output":"str","x":1160,"y":380,"wires":[["1fc522e03fc7c889"]]},{"id":"1fc522e03fc7c889","type":"ui_toast","z":"761e2d49685748c6","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"className":"","topic":"","name":"","x":1160,"y":420,"wires":[]},{"id":"ec74d5c2056e102f","type":"ui_group","name":"Send a Notification","tab":"951018d278c90a6e","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"951018d278c90a6e","type":"ui_tab","name":"Gotifier - Send Notifications","icon":"fa-comment","disabled":false,"hidden":false}]
Created 5 years ago
  • change (x2)
  • http request (x1)
  • switch (x2)
  • template (x2)
  • gotify
  • notification
  • push
  • http
