Modbus reading CVM-C10
[{"id":"ec4ecc87b7fdcd02","type":"inject","z":"558b5a2b977363b8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"4","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":60,"wires":[["d7f1fcf8548b2f72"]]},{"id":"d7f1fcf8548b2f72","type":"function","z":"558b5a2b977363b8","name":"fc3-id6","func":"msg.payload = {\n    //value: msg.payload,\n    'fc': 3, \n    'unitid': 6,\n    'address': 0x0,\n    'quantity': 0x46 \n    } \n\nreturn msg\n","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":130,"y":100,"wires":[["c5e72a295fdd745b"]]},{"id":"c5e72a295fdd745b","type":"modbus-flex-getter","z":"558b5a2b977363b8","name":"","showStatusActivities":true,"showErrors":true,"showWarnings":true,"logIOActivities":false,"server":"29e54e5ad8dcbd66","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":true,"keepMsgProperties":true,"delayOnStart":false,"startDelayTime":"","x":170,"y":140,"wires":[["a00ad9ad32d87d6c","ebb72df448f19fa4","98d880e63d594a0b","c921bed51ff991df","e4b71f42fcd48dc6","bb4c630ae0dd6975","bf8345cbe03a0f15"],[]]},{"id":"ebb72df448f19fa4","type":"function","z":"558b5a2b977363b8","name":"unit","func":"var regi = [\n [\"V \"] ,\n [\"V \"] ,\n [\"V \"] ,\n\n [\"A \"] ,\n [\"A \"] ,\n [\"A \"] ,\n\n [\"W \"],\n [\"W \"] ,\n [\"W \"] ,\n \n [\"varL \"] ,\n [\"varL \"] ,\n [\"varL \"] ,\n\n [\"varC \"] ,\n [\"varC \"] ,\n [\"varC \"] ,\n\n [\"VA \"] ,\n [\"VA \"] ,\n [\"VA \"] ,\n\n [\"- \"] ,\n [\"- \"] ,\n [\"- \"] ,\n\n [\"-\"] ,\n [\"-\"] ,\n [\"-\"] ,\n\n [\"W \"] ,\n [\"varL \"] ,\n [\"varC \"] ,\n [\"VA \"] ,\n [\"-\"] ,\n [\"-\"] ,\n\n [\"Hz\"] ,\n\n [\"V\"] ,\n [\"V\"] ,\n [\"V\"] ,\n \n [\"A\"]];\nmsg.payload = regi;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":180,"wires":[["b5bb50e6f4dc2a2d"]]},{"id":"b5bb50e6f4dc2a2d","type":"ui_template","z":"558b5a2b977363b8","group":"2702adcb99ee2f30","name":"units","order":4,"width":2,"height":19,"format":"<table id=\"table\" border=\".1\">\n <tr>\n <th>Unit</th>\n </tr>\n <tbody>\n <tr ng-repeat=\"row in msg.payload\">\n <td ng-repeat=\"item in row\" >{{item}}</td>\n </tr>\n </tbody>\n</table>\n\n","storeOutMessages":false,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","className":"","x":770,"y":180,"wires":[[]]},{"id":"a00ad9ad32d87d6c","type":"function","z":"558b5a2b977363b8","name":"items","func":"var regi = [\n    [\"V1      \"],\n    [\"V2      \"],\n    [\"V3      \"],\n\n    [\"A1      \"],\n    [\"A2      \"],\n    [\"A3      \"],\n\n    [\"kW1     \"],\n    [\"kW2     \"],\n    [\"kW3     \"],\n\n    [\"kvarL1  \"],\n    [\"kvarL2  \"],\n    [\"kvarL3  \"],\n    \n    [\"kvarC1  \"],\n    [\"kvarC2  \"],\n    [\"kvarC3  \"],\n\n    [\"kVA1    \"],\n    [\"kVA2    \"],\n    [\"kVA3    \"],\n\n    [\"PF1     \"],\n    [\"PF2     \"],\n    [\"PF3     \"],\n\n    [\"CosPhi1 \"],\n    [\"CosPhi2 \"],\n    [\"CosPhi3 \"],\n\n    [\"kWIII   \"],\n    [\"kvarLIII\"],\n    [\"kvarCIII\"],\n    [\"kVAIII  \"],\n    [\"PFIII   \"],\n    [\"CosPhiII\"],\n\n    [\"Hz      \"],\n\n    [\"V12     \"],\n    [\"V23     \"],\n    [\"V31     \"],\n    \n    [\"AN      \"]];\nmsg.payload = regi;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":100,"wires":[["1e01f0c03ffb60cc"]]},{"id":"1e01f0c03ffb60cc","type":"ui_template","z":"558b5a2b977363b8","group":"2702adcb99ee2f30","name":"Variable","order":2,"width":2,"height":19,"format":"<table id=\"table\" border=\".1\">\n <tr>\n <th>item</th>\n </tr>\n <tbody>\n <tr ng-repeat=\"row in msg.payload\">\n <td ng-repeat=\"item in row\" >{{item}}</td>\n </tr>\n </tbody>\n</table>\n\n","storeOutMessages":false,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","className":"","x":760,"y":100,"wires":[[]]},{"id":"9b65c102250fdc0e","type":"csv","z":"558b5a2b977363b8","name":"","sep":";","hdrin":true,"hdrout":"once","multi":"mult","ret":"\\r\\n","temp":"\"timestamp\",\"V1\",\"V2\",\"V3\",\"A1\",\"A2\",\"A3\",\"kW1\",\"kW2\",\"kW3\",\"kvarL1\",\"kvarL2\",\"kvarL3\",\"kvarC1\",\"kvarC2\",\"kvarC3\",\"kVA1\",\"kVA2\",\"kVA3\",\"PF1\",\"PF2\",\"PF3\",\"CosPhi1\",\"CosPhi2\",\"CosPhi3\",\"kWIII\",\"kvarLIII\",\"kvarCIII\",\"kVAIII\",\"PFIII\",\"CosPhiII\",\"Hz\",\"V12\",\"V23\",\"V31\",\"AN\"","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":770,"y":220,"wires":[["a883e507b2f622e8"]]},{"id":"9e5844d55e9e991d","type":"file","z":"558b5a2b977363b8","name":"file","filename":"filename","filenameType":"msg","appendNewline":false,"createDir":true,"overwriteFile":"false","encoding":"none","x":770,"y":300,"wires":[[]]},{"id":"a883e507b2f622e8","type":"function","z":"558b5a2b977363b8","name":"","func":"var now = new Date();\n// Create formatted time\nvar yyyy = now.getFullYear();\nvar mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\nvar dd = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\nvar hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\nvar mmm = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\nvar ss = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\n\nvar path = \"/home/pi/logs/\"; // This is the path    Month+mm+\"/\"\nvar filename = yyyy + \"-\" + mm + \"-\" + dd + \"\\xa0\"+\"CVM6.csv\"; // file name  \"_\"+hh+mmm+ss+\"   \"_\"+mmm+\nmsg.filename = path + filename;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":260,"wires":[["9e5844d55e9e991d"]],"outputLabels":["msg.filename"]},{"id":"c921bed51ff991df","type":"function","z":"558b5a2b977363b8","name":"function 2","func":"var fecha = Date.now();\nvar regi = [\n    [fecha/86400000+25569,msg.payload[0]*0x1000+msg.payload[1]/10,msg.payload[16]*0x1000+msg.payload[17]/10,msg.payload[32]*0x1000+msg.payload[33]/10,msg.payload[2]*0x1000+msg.payload[3]/1000,msg.payload[18]*0x1000+msg.payload[19]/10,msg.payload[34]*0x1000+msg.payload[35]/10,msg.payload[4]*0x1000+msg.payload[5]/1,msg.payload[20]*0x1000+msg.payload[21]/10,msg.payload[36]*0x1000+msg.payload[37]/10,msg.payload[6]*0x1000+msg.payload[7]/10,msg.payload[22]*0x1000+msg.payload[23]/10,msg.payload[38]*0x1000+msg.payload[39]/10,msg.payload[8]*0x1000+msg.payload[9]/10,msg.payload[24]*0x1000+msg.payload[25]/10,msg.payload[40]*0x1000+msg.payload[41]/10,msg.payload[10]*0x1000+msg.payload[11]/10,msg.payload[26]*0x1000+msg.payload[27]/10,msg.payload[42]*0x1000+msg.payload[43]/10,msg.payload[12]*0x1000+msg.payload[13]/10,msg.payload[28]*0x1000+msg.payload[29]/10,msg.payload[44]*0x1000+msg.payload[45]/10,msg.payload[14]*0x1000+msg.payload[15]/10,msg.payload[30]*0x1000+msg.payload[31]/10,msg.payload[46]*0x1000+msg.payload[47]/10,msg.payload[48]*0x1000+msg.payload[49]/10,msg.payload[50]*0x1000+msg.payload[51]/10,msg.payload[52]*0x1000+msg.payload[53]/10,msg.payload[54]*0x1000+msg.payload[55]/10,msg.payload[56]*0x1000+msg.payload[57]/10,msg.payload[58]*0x1000+msg.payload[59]/10,msg.payload[60]*0x1000+msg.payload[61]/100,msg.payload[62]*0x1000+msg.payload[63]/10,msg.payload[64]*0x1000+msg.payload[65]/10,msg.payload[66]*0x1000+msg.payload[67]/10,msg.payload[68]*0x1000+msg.payload[69]/10]];\nmsg.payload = regi;\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":420,"y":220,"wires":[["9b65c102250fdc0e"]]},{"id":"43b4e2a6f0c9d239","type":"inject","z":"558b5a2b977363b8","name":"Clear","props":[{"p":"payload"},{"p":"topic","v":"","vt":"date"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"[\"timestamp\",\"V1\",\"V2\",\"V3\",\"A1\",\"A2\",\"A3\",\"kW1\",\"kW2\",\"kW3\",\"kvarL1\",\"kvarL2\",\"kvarL3\",\"kvarC1\",\"kvarC2\",\"kvarC3\",\"kVA1\",\"kVA2\",\"kVA3\",\"PF1\",\"PF2\",\"PF3\",\"CosPhi1\",\"CosPhi2\",\"CosPhi3\",\"kWIII\",\"kvarLIII\",\"kvarCIII\",\"kVAIII\",\"PFIII\",\"CosPhiII\",\"Hz\",\"V12\",\"V23\",\"V31\",\"AN\"]","payloadType":"json","x":430,"y":260,"wires":[["a34f6e8f281d9505","9b65c102250fdc0e"]]},{"id":"579bee6e9890aec3","type":"file","z":"558b5a2b977363b8","name":"file","filename":"filename","filenameType":"msg","appendNewline":true,"createDir":true,"overwriteFile":"delete","encoding":"none","x":770,"y":340,"wires":[[]]},{"id":"a34f6e8f281d9505","type":"function","z":"558b5a2b977363b8","name":"","func":"var now = new Date();\n// Create formatted time\nvar yyyy = now.getFullYear();\nvar mm = now.getMonth() < 9 ? \"0\" + (now.getMonth() + 1) : (now.getMonth() + 1); // getMonth() is zero-based\nvar dd = now.getDate() < 10 ? \"0\" + now.getDate() : now.getDate();\nvar hh = now.getHours() < 10 ? \"0\" + now.getHours() : now.getHours();\nvar mmm = now.getMinutes() < 10 ? \"0\" + now.getMinutes() : now.getMinutes();\nvar ss = now.getSeconds() < 10 ? \"0\" + now.getSeconds() : now.getSeconds();\n\nvar path = \"/home/pi/logs/\"; // This is the path    Month+mm+\"/\"\nvar filename = yyyy + \"-\" + mm + \"-\" + dd + \"\\xa0\"+\"Log.csv\"; // file name  \"_\"+hh+mmm+ss+\"   \"_\"+mmm+\nmsg.filename = path + filename;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":340,"wires":[["579bee6e9890aec3"]],"outputLabels":["msg.filename"]},{"id":"98d880e63d594a0b","type":"function","z":"558b5a2b977363b8","name":"build array CVM1","func":"var regi1 = [\n    //V x 10\n    [msg.payload[0] * 0x1000 + msg.payload[1]   / 10],\n    [msg.payload[16] * 0x1000 + msg.payload[17] / 10],\n    [msg.payload[32] * 0x1000 + msg.payload[33] / 10],\n\n    //Currents x 1000\n    [msg.payload[2] * 0x1000 + msg.payload[3]   / 1000],\n    [msg.payload[18] * 0x1000 + msg.payload[19] / 1000],\n    [msg.payload[34] * 0x1000 + msg.payload[35] / 1000],\n\n    //kWs\n    [msg.payload[4] * 0x1000 + msg.payload[5]   / 1],\n    [msg.payload[20] * 0x1000 + msg.payload[21] / 1],\n    [msg.payload[36] * 0x1000 + msg.payload[37] / 1],\n\n    //kVArL\n    [msg.payload[6] * 0x1000 + msg.payload[7]   / 1],\n    [msg.payload[22] * 0x1000 + msg.payload[23] / 1],\n    [msg.payload[38] * 0x1000 + msg.payload[39] / 1],\n\n    //kVArC\n    [msg.payload[8] * 0x1000 + msg.payload[9]   / 1],\n    [msg.payload[24] * 0x1000 + msg.payload[25] / 1],\n    [msg.payload[40] * 0x1000 + msg.payload[41] / 1],\n\n    //kVA\n    [msg.payload[10] * 0x1000 + msg.payload[11] / 1],\n    [msg.payload[26] * 0x1000 + msg.payload[27] / 1],\n    [msg.payload[42] * 0x1000 + msg.payload[43] / 1],\n\n    //PF x100\n    [msg.payload[12] * 0x1000 + msg.payload[13] / 1],\n    [msg.payload[28] * 0x1000 + msg.payload[29] / 1],\n    [msg.payload[44] * 0x1000 + msg.payload[45] / 1],\n\n    //CosPhi x 100\n    [msg.payload[14] * 0x1000 + msg.payload[15] / 1],\n    [msg.payload[30] * 0x1000 + msg.payload[31] / 1],\n    [msg.payload[46] * 0x1000 + msg.payload[47] / 1],\n    \n    //kWIII, kvarLIII, kvarCIII, kVAIII\n    [msg.payload[48] * 0x1000 + msg.payload[49] / 1],\n    [msg.payload[50] * 0x1000 + msg.payload[51] / 1],\n    [msg.payload[52] * 0x1000 + msg.payload[53] / 1],\n    [msg.payload[54] * 0x1000 + msg.payload[55] / 1],\n    \n    // PFIII, CosPhiII\n    [msg.payload[56] * 0x1000 + msg.payload[57] / 100],\n    [msg.payload[58] * 0x1000 + msg.payload[59] / 100],\n\n    //Hz\n    [msg.payload[60] * 0x1000 + msg.payload[61] / 100],\n\n    //U\n    [msg.payload[62] * 0x1000 + msg.payload[63] / 10],\n    [msg.payload[64] * 0x1000 + msg.payload[65] / 10],\n    [msg.payload[66] * 0x1000 + msg.payload[67] / 10],\n\n    //AN\n    [msg.payload[68] * 0x1000 + msg.payload[69] / 1000]];\nmsg.payload = regi1;\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":450,"y":140,"wires":[["b428ee785b40538a"]]},{"id":"b428ee785b40538a","type":"ui_template","z":"558b5a2b977363b8","group":"2702adcb99ee2f30","name":"CVM1","order":3,"width":2,"height":19,"format":"<table id=\"table\" border=\".1\" class=\"sortable\">\n <tr>\n <th>CVM1</th>\n </tr>\n <tbody>\n <tr ng-repeat=\"row in msg.payload\">\n <td ng-repeat=\"item in row\" >{{item}}</td>\n </tr>\n </tbody>\n</table>\n\n","storeOutMessages":false,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","className":"","x":770,"y":140,"wires":[[]]},{"id":"aa899fd136b70388","type":"ui_template","z":"558b5a2b977363b8","group":"2702adcb99ee2f30","name":"Tables Styles","order":42,"width":6,"height":1,"format":"<style>\n    #table {\n    //    font-family: Arial, Helvetica, sans-serif;\n        border-collapse: collapse;\n        width: 90%;\n    }\n\n    #table td,\n    #table th {\n        border: 1px solid #ddd;\n        padding: 0px;\n   }\n\n    #table tr:nth-child(even) {\n        background-color:#f2f2f2 ; //green\n    }\n\n    #table tr:hover {\n        background-color: #ddd;\n    }\n\n    #table th {\n        padding-top: 5px;\n        padding-bottom: 2px;\n        text-align: center;\n        background-color: yellow ;#04AA6D\n        color: white;\n    }\n</style>","storeOutMessages":false,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"global","className":"","x":770,"y":400,"wires":[[]]},{"id":"e4b71f42fcd48dc6","type":"link out","z":"558b5a2b977363b8","name":"link out 1","mode":"link","links":["b151beaf15cf59c5"],"x":375,"y":300,"wires":[]},{"id":"bb4c630ae0dd6975","type":"function","z":"558b5a2b977363b8","name":"function 19","func":"msg.payload = msg.payload[15]\n//<< 16) >> 16\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":480,"wires":[["d0b7ab622b8f7159"]]},{"id":"d0b7ab622b8f7159","type":"debug","z":"558b5a2b977363b8","name":"debug 211","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":710,"y":500,"wires":[]},{"id":"bf8345cbe03a0f15","type":"function","z":"558b5a2b977363b8","name":"function 20","func":"msg.payload = msg.payload[14]\n//<< 16) >> 16\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":520,"wires":[["d0b7ab622b8f7159"]]},{"id":"29e54e5ad8dcbd66","type":"modbus-client","name":"","clienttype":"serial","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"127.0.0.1","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB0","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true},{"id":"2702adcb99ee2f30","type":"ui_group","name":"Measurements","tab":"9fa73108ebd10193","order":2,"disp":true,"width":"18","collapse":true,"className":""},{"id":"9fa73108ebd10193","type":"ui_tab","name":"CVM","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Created 2 years, 11 months ago
  • csv (x1)
  • file (x2)
  • function (x9)
  • inject (x2)
  • link out (x1)
  • modbus-client (x1)
  • modbus-flex-getter (x1)
  • ui_group (x1)
  • ui_template (x4)
  • CVM-C10
  • Modbus
  • Write
  • File
