JSON Table view in Dashboard
This uses the node-red-dashboard template node to render JSON payload as a table. Inspired by https://jsongrid.com/json-grid.
[{"id":"e2bc8730ca71a33d","type":"ui_template","z":"7ea6fdd8cb895021","group":"f8acfcf9bb97cb20","name":"","order":0,"width":"18","height":"15","format":"<style>\n    div.tableContainer {\n        display: flex;\n        flex-direction: column;\n        word-wrap: break-word;\n        background-color: #303030;\n        border: 1px solid rgba(0,0,0,0.125);\n        border-radius: 0.25rem;\n        color: white;\n        font-size: 0.75rem;\n    }\n    \n    .table-collapse {\n        border-collapse: collapse;\n        border-spacing: 0;\n        display: flex;\n        height:100%;\n        flex: 0 0 auto;\n        transition: all 0.5s ease-in-out;\n    }\n    \n    .tableContainer table tbody {\n        border-collapse: collapse !important;\n        border: solid #B5B5B5 1px;\n        border-radius: 3px;\n        display: table-row-group;\n        vertical-align: middle;\n        border-color: inherit;\n    }\n    \n    .tableContainer table tr {\n        font-weight: bold;\n        border: none;\n    }\n    \n    .tableContainer table td {\n        vertical-align: top;\n        border: 1px solid #636363;\n        padding: 3px 10px 3px 10px;\n        white-space: nowrap;\n    }\n    \n    .endValue {\n        font-weight: initial;\n    }\n    \n    .expandButton {\n        font-size: 1.5rem;\n        cursor: pointer;\n    }\n    \n    .hidden {\n        height: 0;\n        max-height: 0;\n        opacity: 0;\n        overflow: hidden;\n    }\n    \n    .string {\n        color: rgb(155 185 91);\n    }\n    \n    .notString {\n        color: rgb(101 142 177);\n    }\n</style>\n<script>\nwindow.addEventListener('click', (e) => {\n    if (e.target.classList.contains('expandButton')) {\n        if (e.target.classList.contains('expanded')) {\n            e.target.innerHTML = '+';\n            e.target.classList.toggle(\"expanded\", false);\n            e.target.nextElementSibling.classList.toggle(\"hidden\", true);\n        } else {\n            e.target.innerHTML = '-';\n            e.target.classList.toggle(\"expanded\", true);\n            e.target.nextElementSibling.classList.toggle(\"hidden\", false);\n        }\n    }\n});\n</script>\n\n<div ng-bind-html=\"msg.payload\"></div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":660,"y":1180,"wires":[[]]},{"id":"dfa6f8ae37760595","type":"function","z":"7ea6fdd8cb895021","name":"CreateHTMLTableFromJSON","func":"const checkIfObjectOrArray = (value) =>  (\n    Object.prototype.toString.call(value) === '[object Array]'\n    || Object.prototype.toString.call(value) === '[object Object]'\n);\n\nconst isString = (value) => (typeof value === 'string' || value instanceof String);\n\nconst createTable = (json) => {\n    \n    const tableData = Object.keys(json).map((key) => {\n        \n        const createNewTableIfObjectOrArray = (value) => {\n\n            if(checkIfObjectOrArray(value)) {\n                return `\n                    <tr>\n                        <td>${key}</td>\n                        <td>\n                            <span class=\"expandButton expanded\">-</span>\n                            ${createTable(value)}\n                        </td>\n                    </tr>\n                `;\n            } \n            \n            return `\n                <tr>\n                    <td>${key}</td>\n                    <td class=\"endValue ${(isString(json[key]) ? 'string' : 'notString')}\">${json[key]}</td>\n                </tr>\n            `;\n        }\n        \n        return createNewTableIfObjectOrArray(json[key]);\n    });\n    \n    return `\n        <table class=\"table-collapse\">\n            <tbody>${tableData.join('')}</tbody>\n        </table>\n    `;\n}\n\nmsg.payload = `\n<div class=\"tableContainer\">\n    ${createTable(msg.payload)}\n</div>\n`;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":420,"y":1180,"wires":[["e2bc8730ca71a33d"]]},{"id":"b634a06d2f1cf975","type":"inject","z":"7ea6fdd8cb895021","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"squadName\":\"Super hero squad\",\"homeTown\":\"Metro City\",\"formed\":2016,\"secretBase\":\"Super tower\",\"active\":true,\"members\":[{\"index\":0,\"isActive\":false,\"age\":21,\"eyeColor\":\"blue\",\"name\":\"Bentley Clayton\",\"gender\":\"male\",\"registered\":\"2018-05-02T05:35:41 +04:00\"},{\"index\":1,\"isActive\":false,\"age\":23,\"eyeColor\":\"blue\",\"name\":\"Lela Ramos\",\"gender\":\"female\",\"registered\":\"2014-02-24T03:13:50 +05:00\"},{\"index\":2,\"isActive\":true,\"age\":38,\"eyeColor\":\"green\",\"name\":\"Milagros Becker\",\"gender\":\"female\",\"registered\":\"2016-10-22T12:18:50 +04:00\"},{\"index\":3,\"isActive\":false,\"age\":30,\"eyeColor\":\"brown\",\"name\":\"Mccoy Barrera\",\"gender\":\"male\",\"registered\":\"2016-12-03T03:44:57 +05:00\"},{\"index\":4,\"isActive\":false,\"age\":35,\"eyeColor\":\"brown\",\"name\":\"Morton Bennett\",\"gender\":\"male\",\"registered\":\"2015-10-06T09:48:03 +04:00\"},{\"index\":5,\"isActive\":true,\"age\":20,\"eyeColor\":\"blue\",\"name\":\"Acosta Bird\",\"gender\":\"male\",\"registered\":\"2019-02-11T09:59:58 +05:00\"},{\"index\":6,\"isActive\":false,\"age\":35,\"eyeColor\":\"blue\",\"name\":\"Mcleod Keith\",\"gender\":\"male\",\"registered\":\"2014-04-24T07:50:11 +04:00\"},{\"index\":7,\"isActive\":false,\"age\":27,\"eyeColor\":\"brown\",\"name\":\"Magdalena Burgess\",\"gender\":\"female\",\"registered\":\"2015-03-19T09:28:55 +04:00\"},{\"index\":8,\"isActive\":false,\"age\":37,\"eyeColor\":\"blue\",\"name\":\"Cline Castaneda\",\"gender\":\"male\",\"registered\":\"2016-02-29T09:49:37 +05:00\"},{\"index\":9,\"isActive\":false,\"age\":39,\"eyeColor\":\"green\",\"name\":\"Garcia Baker\",\"gender\":\"male\",\"registered\":\"2018-05-26T02:54:22 +04:00\"},{\"index\":10,\"isActive\":true,\"age\":40,\"eyeColor\":\"blue\",\"name\":\"Lenora Keller\",\"gender\":\"female\",\"registered\":\"2017-12-19T05:12:17 +05:00\"},{\"index\":11,\"isActive\":false,\"age\":33,\"eyeColor\":\"green\",\"name\":\"Kathryn Donovan\",\"gender\":\"female\",\"registered\":\"2014-03-21T12:33:36 +04:00\"},{\"index\":12,\"isActive\":true,\"age\":40,\"eyeColor\":\"blue\",\"name\":\"Opal Hinton\",\"gender\":\"female\",\"registered\":\"2014-05-03T02:14:25 +04:00\"},{\"index\":13,\"isActive\":false,\"age\":25,\"eyeColor\":\"green\",\"name\":\"Mayer Gray\",\"gender\":\"male\",\"registered\":\"2016-04-01T05:52:21 +04:00\"},{\"index\":14,\"isActive\":true,\"age\":22,\"eyeColor\":\"green\",\"name\":\"Josefina Quinn\",\"gender\":\"female\",\"registered\":\"2015-02-07T12:04:14 +05:00\"}]}","payloadType":"json","x":190,"y":1180,"wires":[["dfa6f8ae37760595"]]},{"id":"f8acfcf9bb97cb20","type":"ui_group","name":"Tablegroup","tab":"fb202f2b9c4ea98f","order":1,"disp":true,"width":"32","collapse":false,"className":""},{"id":"fb202f2b9c4ea98f","type":"ui_tab","name":"Table","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Created 3 years, 7 months ago
  • ui_group (x1)
  • ui_template (x1)
  • json
  • table
  • dashboard
  • ui
  • html
