Simple Time and Date Formatter
Hola!
This flow is a simple flow to help get started with node red. All it does is format the current UTC date and display it with Node-RED-Dashboard.
You must have Node-RED-Dashboard installed to use all of the nodes and view the UI.
Have a nice day.
[{"id":"b283eef3.e91d1","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"4b6ac005.c6281","type":"inject","z":"b283eef3.e91d1","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":true,"onceDelay":0.1,"x":190,"y":180,"wires":[["ee27edae.2a9f","903b4cae.13137"]]},{"id":"ee27edae.2a9f","type":"debug","z":"b283eef3.e91d1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":370,"y":180,"wires":[]},{"id":"28cd651b.d766ea","type":"ui_text","z":"b283eef3.e91d1","group":"3ba37fd4.6558f","order":0,"width":0,"height":0,"name":"","label":"Date: ","format":"{{msg.payload}}","layout":"row-spread","x":510,"y":220,"wires":[]},{"id":"903b4cae.13137","type":"function","z":"b283eef3.e91d1","name":"Format Time","func":"var d = new Date();\nvar options = { timeZone: 'UTC', timeZoneName: 'long', year: 'numeric', month: '2-digit', day: '2-digit', hour: `2-digit`, minute: `2-digit`, second: `2-digit`};\nvar _resultDate = d.toLocaleDateString('en-US', options);\nmsg.payload = _resultDate;\nreturn msg;","outputs":1,"noerr":0,"x":370,"y":220,"wires":[["28cd651b.d766ea"]]},{"id":"b6bd7bc.6bc6d88","type":"comment","z":"b283eef3.e91d1","name":"Example Flow","info":"This is an example flow created by Mac and Huche.\nThis flow runs once every second because of the Inject \"timestamp\" node.\nThe timestamp is fed to the debug node and outputted in milliseconds since 1/1/1970.\nClick the debug tab to view these debug messages.\nThe function node is simple javascript to retrieve the time and date in a specific format.\nThis formatted date is given to the text dashboard node.\nTo view this dashboard, click the dashboard tab or go to\nhttp://localhost:1880/ui","x":190,"y":120,"wires":[]},{"id":"3ba37fd4.6558f","type":"ui_group","z":"","name":"Example Flow","tab":"72415252.b2cadc","disp":true,"width":"8","collapse":false},{"id":"72415252.b2cadc","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Created 7 years, 7 months ago
Rating: 5 1
  • ui_group (x1)
  • ui_text (x1)
  • time
  • date
  • formatter
  • beginner
  • flow
