Test flow for new project
This is a preview flow for a new project.
[{"id":"a1b2c3d4e5f6","type":"tab","label":"Dashboard Flow","disabled":false,"info":""},{"id":"file-in-node","type":"file in","z":"a1b2c3d4e5f6","name":"Neueste .tab Datei lesen","filename":"","format":"utf8","chunk":false,"sendError":false,"encoding":"none","allProps":false,"x":270,"y":180,"wires":[["parse-function-node"]]},{"id":"inject-node","type":"inject","z":"a1b2c3d4e5f6","name":"Alle 1 Sekunde","props":[],"repeat":"1","crontab":"","once":true,"onceDelay":"1","topic":"","x":150,"y":40,"wires":[["find-latest-file-function"]]},{"id":"parse-function-node","type":"function","z":"a1b2c3d4e5f6","name":"Datei parsen","func":"// Code wird unten bereitgestellt","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":470,"y":180,"wires":[["prepare-channel-selection"]]},{"id":"channel-selection-node","type":"ui_form","z":"a1b2c3d4e5f6","name":"Kanäle auswählen","label":"Verfügbare Kanäle","group":"dashboard-group","order":2,"width":0,"height":0,"options":[],"formValue":{},"payload":"","submit":"submit","cancel":"cancel","topic":"","x":210,"y":360,"wires":[["filter-selected-channels"]]},{"id":"display-data-node","type":"ui_chart","z":"a1b2c3d4e5f6","name":"Daten anzeigen","group":"dashboard-group","order":3,"width":0,"height":0,"label":"Messwerte","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"Keine Daten","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#ff7f0e","#2ca02c","#d62728","#9467bd","#8c564b","#e377c2","#7f7f7f","#bcbd22","#17becf"],"useOldStyle":false,"outputs":1,"x":430,"y":360,"wires":[[]]},{"id":"find-latest-file-function","type":"function","z":"a1b2c3d4e5f6","name":"Neueste .tab Datei finden","func":"// Code wird unten bereitgestellt","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":40,"wires":[["file-in-node"]]},{"id":"prepare-channel-selection","type":"function","z":"a1b2c3d4e5f6","name":"Kanalauswahl vorbereiten","func":"// Code wird unten bereitgestellt","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":670,"y":180,"wires":[["channel-selection-node"]]},{"id":"filter-selected-channels","type":"function","z":"a1b2c3d4e5f6","name":"Ausgewählte Kanäle filtern","func":"// Code wird unten bereitgestellt","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":230,"y":440,"wires":[["display-data-node"]]},{"id":"path-input-node","type":"ui_text_input","z":"a1b2c3d4e5f6","name":"Pfad Eingabe","label":"Pfad zu den .tab Dateien","group":"dashboard-group","order":1,"width":0,"height":0,"passthru":true,"mode":"text","delay":"0","topic":"","x":160,"y":100,"wires":[["set-path-function"]]},{"id":"set-path-function","type":"function","z":"a1b2c3d4e5f6","name":"Pfad setzen","func":"flow.set('tabFilePath', msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":100,"wires":[[]]},{"id":"dashboard-group","type":"ui_group","name":"Standardgruppe","tab":"dashboard-tab","order":1,"disp":true,"width":"12","collapse":false},{"id":"dashboard-tab","type":"ui_tab","name":"Dashboard","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Created 8 months, 2 weeks ago
  • file in (x1)
  • function (x5)
  • ui_chart (x1)
  • ui_form (x1)
  • ui_group (x1)
  • ui_text_input (x1)
