Alecto weatherstation
This subflow node is for retrieving the weather information from an Alecto weatherstation. It does this by listening for post requests.
In order to get this working, you need to add a customized service to the weather station. This can be done in the WS View app, under device list. Under Customized add:
  • Enable - set the Customized service to accept incomming POST requests.
  • Protocol type - Only Ecowitt is supported.
  • Server IP / Hostname - needst to be set to the internal IP of the running Node-RED instance.
  • Path - needs to be set to /Alecto
  • Port - needs to be set to the port that Node-RED is running on (usually 1880)
  • Update interval - can be set to the number of seconds between updates. 60 seconds is a normal interval.
If you set "store to global context", the node will store the latest input into the global context under the "alecto" object.
Output
The node outputs the incoming messages from the weather station. As the Alecto weatherstation only sends the temperature in fahrenheit the node adds a conversion to Celsius to make it more convenient to parse.
Status
The status turns green when listening. With incoming messages, it updates the text to show the timestamp of the last incoming message (in readable format).
[{"id":"ba0560ad671f5f80","type":"subflow","name":"Alecto","info":"This subflow node is for retrieving the weather information from an Alecto weatherstation. \nIt does this by listening for post requests.\n\nIn order to get this working, you need to \nadd a customized service to the weather station.\nThis can be done in the _WS View_ app, under \n_device list_. Under _Customized_ add:\n\n- _Enable_ - set the Customized service to\naccept incomming POST requests.\n- _Protocol type_ - Only _Ecowitt_ is supported.\n- _Server IP / Hostname_ - needst to be set\nto the internal IP of the running Node-RED\ninstance.\n- _Path_ - needs to be set to `/Alecto`\n- _Port_ - needs to be set to the port that\nNode-RED is running on (usually `1880`)\n- _Update interval_ - can be set to the number\nof seconds between updates. `60` seconds is a\nnormal interval.\n\n# Configuration\n\nIf you set \"store to global context\", the node will store\nthe latest input into the global context under the \"alecto\" object.\n\n# Output\n\nThe node outputs the incoming messages from the weather\nstation. Some conversions are being made to make the parsing of the data easier.\n\n# Status\n\nThe status turns green when listening. With \nincoming messages, it updates the text to\nshow the timestamp of the last incoming \nmessage (in readable format).","category":"Weather","in":[],"out":[{"x":780,"y":140,"wires":[{"id":"4b17af6d0361cfaa","port":0}]}],"env":[{"name":"context_store","type":"bool","value":"true","ui":{"label":{"en-US":"Save to global context"},"type":"checkbox"}}],"meta":{"module":"Alecto","version":"0.0.5","author":"Dirk-Jan Faber <[email protected]>","desc":"Retrieve info from the Alecto WS 5500 weather station","keywords":"alecto, weatherstation, node-red, ws5500","license":"MIT"},"color":"#3FADB5","icon":"font-awesome/fa-cloud","status":{"x":680,"y":220,"wires":[{"id":"fcfb63da787cf68b","port":0},{"id":"5c042399dc9cef98","port":0}]}},{"id":"60cc8426ac213ba1","type":"http in","z":"ba0560ad671f5f80","name":"Weatherstation - EcoWitt","url":"/Alecto","method":"post","upload":false,"swaggerDoc":"","x":170,"y":80,"wires":[["2869fd8c3fd4b249","4b17af6d0361cfaa","5c042399dc9cef98"]]},{"id":"4add5ac157a9818c","type":"http response","z":"ba0560ad671f5f80","name":"","statusCode":"200","headers":{},"x":740,"y":80,"wires":[]},{"id":"2869fd8c3fd4b249","type":"template","z":"ba0560ad671f5f80","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Ok","output":"str","x":460,"y":80,"wires":[["4add5ac157a9818c"]]},{"id":"fcfb63da787cf68b","type":"function","z":"ba0560ad671f5f80","name":"Set status","func":"msg.payload = ({ fill: \"green\", text: \"Listening\" });\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":440,"y":220,"wires":[[]]},{"id":"5c042399dc9cef98","type":"function","z":"ba0560ad671f5f80","name":"Update status","func":"const now = new Date();\nlet fill = \"red\";\n\nif (msg.payload.tempf || msg.payload.tempinf) {\n    fill = \"green\";\n}\n\nmsg.payload = ({ fill: fill, text: now.toTimeString()});\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":460,"y":180,"wires":[[]]},{"id":"36b37ca7e2e3d17f","type":"inject","z":"ba0560ad671f5f80","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":270,"y":220,"wires":[["fcfb63da787cf68b"]]},{"id":"4b17af6d0361cfaa","type":"function","z":"ba0560ad671f5f80","name":"Parse data","func":"if (msg.payload.tempf || msg.payload.tempinf) {\n  // Use tempinf if available, otherwise fall back to tempf\n  const tempValue = msg.payload.tempinf !== undefined ? msg.payload.tempinf : msg.payload.tempf;\n  msg.payload.tempc = String(((Number(tempValue) - 32) * 5/9).toFixed(1));\n}\n\nif (msg.payload.baromabsin) {\n    msg.payload.baromabshpa =  msg.payload.baromabsin * 33.6585\n}\n\nif (msg.payload.baromrelin) {\n    msg.payload.baromrelhpa =  msg.payload.baromrelin * 33.6585\n}\n\nif (msg.payload.windspeedmph) {\n    msg.payload.windspeedms = msg.payload.windspeedmph * 0.44704\n}\n\nif (msg.payload.windgustmph) {\n    msg.payload.windgustms = msg.payload.windgustmph * 0.44704\n}\n\nfor (let item in msg.payload) {\n  if ( ! Number.isNaN(Number(msg.payload[item]))) {\n     msg.payload[item] = Number(msg.payload[item])\n  }\n}\n\nmsg.payload[\"dateutc\"] = Date.parse(msg.payload[\"dateutc\"])\n\nif (env.get('context_store')) {\n  global.set(\"alecto\", msg.payload)\n}\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":450,"y":140,"wires":[[]]},{"id":"5e274fe783c892f0","type":"subflow:ba0560ad671f5f80","z":"de710832a415f877","name":"Alecto weather station","x":160,"y":120,"wires":[["4f09a0bb5474a0da","cb5b55ea34d29c06","c8109b6132f16289","508d0eabc1eb130c","156c4dd298958bf5","c7af05d00271b886","d79774102f63fbad"]]}]
Created 3 years, 10 months ago
Updated 1 year, 5 months ago
Rating: 5 2
  • function (x3)
  • http in (x1)
  • http response (x1)
  • template (x1)
  • subflow (x1)
  • subflow:ba0560ad671f5f80 (x1)
  • Alecto
  • weatherstation
  • ws5000
  • weather
