Send eSIOS lowcost electricity price of the day
Here the possibility of sending the lowcost price of the day to Telegram or any other messaging system is reported.
This is an adaptation of the Domotuto.com script that uses the eSIOS API to get the data.
Flow image
  1. Import the flow into Node-RED.
  2. Modify the name of the calibrated and new devices.
  3. Change the node LowCost Hour to indicate your rateType.
  4. Deploy the flow.
Licensed under the Apache-2.0 License
Read LICENSE for more information
[{"id":"a128fe85.dd941","type":"http request","z":"f03b6707.14dc98","name":"eSIOS","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.esios.ree.es/archives/70/download_json?locale=es","tls":"","persist":false,"proxy":"","authType":"","x":230,"y":60,"wires":[["19a8d63.1ba3c2a"]],"info":"Sistema de información del operador del sistema"},{"id":"11bcb482.4c4e8b","type":"inject","z":"f03b6707.14dc98","name":"Daily","props":[],"repeat":"","crontab":"01 00 * * *","once":false,"onceDelay":0.1,"topic":"","x":90,"y":60,"wires":[["a128fe85.dd941"]]},{"id":"19a8d63.1ba3c2a","type":"function","z":"f03b6707.14dc98","name":"Parse Data","func":"function stringFromDate(date) {\n    let dateStr = date.toLocaleDateString(\n        \"en-GB\",\n        {\n            day: '2-digit',\n            month: '2-digit',\n            year: 'numeric'\n        }\n    )\n    \n    let arr = dateStr.split(\"/\")\n    let d = arr[0]; \n    let m = arr[1];\n    let y = arr[2];\n    \n    return y + '-' + m + '-' + d;\n}\n\nfunction stringToPrice(text) {\n    var price = text.replace(',', '.');\n    price = parseFloat(price);\n    price = price / 1000;\n    price = price.toFixed(5);\n    \n    return parseFloat(price);\n}\n\nvar pvpc = msg.payload.PVPC;\n\nvar date = new Date(pvpc[0].Dia);\nvar day = stringFromDate(date);\n\nvar payload = {\n    day: day,\n    intervals: []\n}\n\nfor (var hour = 0; hour < 24; hour++) {\n    var interval = pvpc[hour];\n    \n    payload.intervals.push({\n        hour: hour.toString().padStart(2, '0'),\n        prices: {\n            A: stringToPrice(interval.GEN),\n            DHA: stringToPrice(interval.NOC),\n            VH: stringToPrice(interval.VHC)\n        }\n    });\n}\n\nreturn {\n    payload: payload\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":60,"wires":[["7cc2c6da.4d2b88"]],"info":"GEN: Precio de la energía para viviendas con tarifa 2.0 A\nNOC: Precio de la energía para viviendas con tarifa 2.0 DHA\nVHC: Precio de la energía para viviendas con tarifa 2.0 VH\n"},{"id":"7cc2c6da.4d2b88","type":"function","z":"f03b6707.14dc98","name":"LowCost Hour","func":"var rateType = 'A'; // A, DHA, VH\n\nvar lowCostHour = 0;\nvar lowCostPrice = 999;\n\nvar intervals = msg.payload.intervals;\nfor (var hour = 0; hour < 24; hour++) {\n    var interval = intervals[hour];\n    \n    if (interval.prices[rateType] < lowCostPrice) {\n        lowCostHour = hour;\n        lowCostPrice = interval.prices[rateType];\n    }\n}\n\nmsg.payload.lowCost = {\n    rateType: rateType,\n    hour: lowCostHour,\n    price: lowCostPrice\n}\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":160,"y":120,"wires":[["8fa087e6.624548"]]},{"id":"8fa087e6.624548","type":"function","z":"f03b6707.14dc98","name":"Generate Message","func":"var message = '*¡Precio más bajo!*\\n' +\n    'De las *' +\n    msg.payload.lowCost.hour + ':00* a *' +\n    msg.payload.lowCost.hour + ':59* horas con un importe de *' +\n    (msg.payload.lowCost.price * 100) + '* centimos/kWh en tarifa *' +\n    msg.payload.lowCost.rateType +'*'\n\nreturn {\n    payload: {\n        type: \"message\",\n        content: message,\n        options: {\n            parse_mode: \"Markdown\"\n        }\n    }\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":120,"wires":[["e1b94625.d543c8"]]},{"id":"e1b94625.d543c8","type":"telegram sender","z":"f03b6707.14dc98","name":"Telegram Bot","bot":"592da116.c785b","haserroroutput":false,"outputs":1,"x":570,"y":120,"wires":[[]]},{"id":"592da116.c785b","type":"telegram bot","botname":"Telegram Bot","usernames":"","chatids":"","baseapiurl":"","updatemode":"polling","pollinterval":"300","usesocks":false,"sockshost":"","socksport":"6667","socksusername":"anonymous","sockspassword":"","bothost":"","botpath":"","localbotport":"8443","publicbotport":"8443","privatekey":"","certificate":"","useselfsignedcertificate":false,"sslterminated":false,"verboselogging":false}]
Created 5 years, 10 months ago
  • function (x3)
  • http request (x1)
  • electricity
  • lowcost
  • esios
  • telegram
