SparkplugB Certificate Handler
Node-RED flow that enhances a standard MQTT broker with basic SparkplugB certificate awareness.
Problem:
SparkplugB specification requires brokers to retain the latest NBIRTH/DBIRTH (birth) messages and make them available on special $sparkplug/certificates/... topics with retain=true.
However, standard MQTT brokers (that are not SparkplugB-aware) do not provide this behavior out of the box.
Solution:
This Node-RED flow subscribes to SparkplugB topics (spBv1.0/...) for birth and death messages and republishes them under the correct certificate topics with retention enabled.
This allows SCADA systems and clients to reliably retrieve the latest known device and node states when connecting.
[{"id":"bdfd6beaba1b87f0","type":"tab","label":"SparkplugB Certificate Implementation","disabled":false,"info":"","env":[]},{"id":"4142a4f6f4ddfdff","type":"mqtt sparkplug in","z":"bdfd6beaba1b87f0","name":"","topic":"spBv1.0/+/NBIRTH/+","qos":"2","broker":"0dfdb9cf298c42ec","x":190,"y":100,"wires":[["d8666d081cf283cc"]]},{"id":"bca327979435a362","type":"mqtt sparkplug in","z":"bdfd6beaba1b87f0","name":"","topic":"spBv1.0/+/DBIRTH/+/+","qos":"2","broker":"0dfdb9cf298c42ec","x":180,"y":160,"wires":[["d8666d081cf283cc"]]},{"id":"4b193f0c5b70ac68","type":"mqtt sparkplug in","z":"bdfd6beaba1b87f0","name":"","topic":"spBv1.0/+/NDEATH/+","qos":"2","broker":"0dfdb9cf298c42ec","x":180,"y":240,"wires":[["d8666d081cf283cc"]]},{"id":"07979ec2f5ddea71","type":"mqtt sparkplug in","z":"bdfd6beaba1b87f0","name":"","topic":"spBv1.0/+/DDEATH/+/+","qos":"2","broker":"0dfdb9cf298c42ec","x":180,"y":300,"wires":[["d8666d081cf283cc"]]},{"id":"d8666d081cf283cc","type":"function","z":"bdfd6beaba1b87f0","name":"handle certificates","func":"if (!msg.topic) {\n    node.error(\"Missing topic in incoming message\", msg);\n    return null;\n}\n\nvar topicParts = msg.topic.split('/');\nif (topicParts.length < 4) {\n    node.error(\"Invalid topic structure. Expected at least 4 parts (namespace/group/messageType/edgeNode)\", msg);\n    return null;\n}\n\nvar namespace = topicParts[0]; // spBv1.0\nvar groupId = topicParts[1];\nvar messageType = topicParts[2];\nvar edgeNodeId = topicParts[3];\nvar deviceId = topicParts.length > 4 ? topicParts[4] : null;\n\n// List of recognized message types\nvar validBirthTypes = [\"NBIRTH\", \"DBIRTH\"];\nvar validDeathTypes = [\"NDEATH\", \"DDEATH\"];\n\nif (validBirthTypes.includes(messageType)) {\n    if (!edgeNodeId) {\n        node.error(\"Missing edgeNodeId for Birth message\", msg);\n        return null;\n    }\n    msg.retain = true;\n    msg.qos = 1;\n\n    if (messageType === \"NBIRTH\") {\n        msg.topic = `${namespace}/certificates/${groupId}/NBIRTH/${edgeNodeId}`;\n    } else if (messageType === \"DBIRTH\") {\n        if (!deviceId) {\n            node.error(\"Missing deviceId for DBIRTH message\", msg);\n            return null;\n        }\n        msg.topic = `${namespace}/certificates/${groupId}/DBIRTH/${edgeNodeId}/${deviceId}`;\n    }\n\n} else if (validDeathTypes.includes(messageType)) {\n    if (!edgeNodeId) {\n        node.error(\"Missing edgeNodeId for Death message\", msg);\n        return null;\n    }\n    msg.retain = true;\n    msg.qos = 1;\n\n    if (messageType === \"NDEATH\") {\n        msg.topic = `${namespace}/certificates/${groupId}/NBIRTH/${edgeNodeId}`;\n    } else if (messageType === \"DDEATH\") {\n        if (!deviceId) {\n            node.error(\"Missing deviceId for DDEATH message\", msg);\n            return null;\n        }\n        msg.topic = `${namespace}/certificates/${groupId}/DBIRTH/${edgeNodeId}/${deviceId}`;\n    }\n    // Empty payload to clear retained certificate\n    msg.payload = {};\n} else {\n    node.warn(`Unsupported SparkplugB message type: ${messageType}`);\n    return null;\n}\n\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":490,"y":200,"wires":[["2dcbd5a5a9438f14"]]},{"id":"2dcbd5a5a9438f14","type":"mqtt sparkplug out","z":"bdfd6beaba1b87f0","name":"","topic":"","qos":"","retain":"","broker":"a81984704b7ab256","x":690,"y":200,"wires":[]},{"id":"0dfdb9cf298c42ec","type":"mqtt-sparkplug-broker","name":"sparkplug","deviceGroup":"Fresco","eonName":"","broker":"uns-mqtt","port":1883,"clientid":"","usetls":false,"protocolVersion":4,"keepalive":60,"cleansession":true,"enableStoreForward":false,"compressAlgorithm":"","aliasMetrics":false,"useTemplates":true,"manualEoNBirth":true,"primaryScada":""},{"id":"a81984704b7ab256","type":"mqtt-sparkplug-broker","name":"mqtt","deviceGroup":"","eonName":"","broker":"loclhost","port":1883,"clientid":"","usetls":false,"protocolVersion":4,"keepalive":60,"cleansession":true,"enableStoreForward":false,"compressAlgorithm":"","aliasMetrics":false,"useTemplates":true,"manualEoNBirth":false,"primaryScada":""}]
Created 1 year, 6 months ago
Rating: 5 1
  • mqtt
  • sparkplugb
  • industry4.0
  • digitalfactory
  • digitalmanufacturing
