Nuki Smart Lock - Push state changes to Node-RED (no polling)
Node-Red-Nuki-Push on GitHub
version size issues Twitter URL
This Node-RED flow shows how to react on Nuki Smart Lock state changes via push without constantly polling the API. The flow uses the Nuki Bridge API to get the trigger for the changed state and afterwards the Nuki Web API to request the current state for the Nuki Smart Lock. flow
Visit the github repository Node-Red-Nuki-Push for further explanations and assistance.
[{"id":"650e7c81.102bb4","type":"tab","label":"Nuki push state changes","disabled":false,"info":""},{"id":"4f8e3104.574f1","type":"switch","z":"650e7c81.102bb4","name":"Door unlocked?","property":"response.state.state","propertyType":"msg","rules":[{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"5","vt":"str"},{"t":"eq","v":"7","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":5,"x":180,"y":420,"wires":[[],[],[],[],["7e70627b.f08c6c"]]},{"id":"70048d9c.18f574","type":"http in","z":"650e7c81.102bb4","name":"Nuki Bridge API HTTP Callback Endpoint","url":"/nuki","method":"post","upload":false,"swaggerDoc":"","x":240,"y":100,"wires":[["b292b974.c942e8","8c2f0346.e870c"]]},{"id":"b292b974.c942e8","type":"http response","z":"650e7c81.102bb4","name":"send empty response","statusCode":"","headers":{},"x":560,"y":100,"wires":[]},{"id":"7565f770.71dfc8","type":"comment","z":"650e7c81.102bb4","name":"Get incoming state changes using the Nuki Callback Bridge API","info":"","x":350,"y":60,"wires":[]},{"id":"fd156475.c77da8","type":"comment","z":"650e7c81.102bb4","name":"Request Nuki lock state via Nuki Web API","info":"","x":580,"y":180,"wires":[]},{"id":"578cd7c0.a07468","type":"comment","z":"650e7c81.102bb4","name":"React on the status change","info":"","x":260,"y":360,"wires":[]},{"id":"2feeeaae.f4a326","type":"http request","z":"650e7c81.102bb4","name":"Send Nuki Web API HTTP Get-Request","method":"GET","ret":"obj","paytoqs":false,"url":"","tls":"","persist":false,"proxy":"","authType":"","x":240,"y":280,"wires":[["cbcd5436.7ca548"]]},{"id":"ff07ef80.9321c","type":"change","z":"650e7c81.102bb4","name":"Prepare Nuki Web API HTTP Request https://api.nuki.io/smartlock","rules":[{"t":"set","p":"url","pt":"msg","to":"\"https://api.nuki.io/smartlock/\" & msg.smartlockId","tot":"jsonata"},{"t":"delete","p":"token","pt":"msg"},{"t":"delete","p":"smartlockId","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":220,"wires":[["2feeeaae.f4a326"]]},{"id":"cbcd5436.7ca548","type":"change","z":"650e7c81.102bb4","name":"Write Nuki lock state to the payload","rules":[{"t":"set","p":"response","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"response.state.state","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":280,"wires":[["6f81deb7.277cc"]]},{"id":"6f81deb7.277cc","type":"function","z":"650e7c81.102bb4","name":"Check whether the state changed or not","func":"var oldNukiStatus = global.get(\"oldNukiStatus\");\n\nif (msg.payload != oldNukiStatus) {\n    global.set(\"oldNukiStatus\", msg.payload);\n    return msg;\n}","outputs":1,"noerr":0,"x":900,"y":280,"wires":[["4f8e3104.574f1"]]},{"id":"7e70627b.f08c6c","type":"switch","z":"650e7c81.102bb4","name":"Door locked?","property":"response.state.state","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"4","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":380,"y":500,"wires":[[],[]]},{"id":"8c2f0346.e870c","type":"credentials","z":"650e7c81.102bb4","name":"Credentials Nuki Web API","props":[{"value":"smartlockId","type":"msg"},{"value":"token","type":"msg"}],"x":190,"y":220,"wires":[["c7413f7e.f51cb"]]},{"id":"c7413f7e.f51cb","type":"function","z":"650e7c81.102bb4","name":"Request Header set authorization","func":"msg.headers = {\n    Authorization: \"Bearer \" + msg.token\n}\nreturn msg;","outputs":1,"noerr":0,"x":480,"y":220,"wires":[["ff07ef80.9321c"]]},{"id":"620b3a1.f8968c4","type":"comment","z":"650e7c81.102bb4","name":"Actions to perform when the door gets unlocked","info":"","x":460,"y":420,"wires":[]},{"id":"d179b6dd.dbea38","type":"comment","z":"650e7c81.102bb4","name":"Actions to perform when the door gets locked","info":"","x":650,"y":500,"wires":[]}]
Created 7 years, 1 month ago
Rating: 4 1
  • change (x2)
  • comment (x5)
  • function (x2)
  • http in (x1)
  • http request (x1)
  • http response (x1)
  • switch (x2)
  • Nuki
  • Smartlock
  • Push
  • Polling
  • Lock
  • Lockstate
  • State
