Connect S7 TIA Siemens Simatic PLC Apple Homekit Hey Siri COVER
Connect your Siemens Simatic S7 PLC to Apple Homekit Here is an example of a COVER
[{"id":"876ec3bc7c5616cc","type":"homekit-service","z":"e0554a9f.d11038","isParent":true,"hostType":"0","bridge":"e315f460.4979d8","accessoryId":"","parentService":"","name":"Test Cover","serviceName":"Lightbulb","topic":"","filter":false,"manufacturer":"Default Manufacturer","model":"Default Model","serialNo":"Default Serial Number","firmwareRev":"1.0.0","hardwareRev":"1.0.0","softwareRev":"1.0.0","cameraConfigVideoProcessor":"ffmpeg","cameraConfigSource":"","cameraConfigStillImageSource":"","cameraConfigMaxStreams":2,"cameraConfigMaxWidth":1280,"cameraConfigMaxHeight":720,"cameraConfigMaxFPS":10,"cameraConfigMaxBitrate":300,"cameraConfigVideoCodec":"libx264","cameraConfigAudioCodec":"libfdk_aac","cameraConfigAudio":false,"cameraConfigPacketSize":1316,"cameraConfigVerticalFlip":false,"cameraConfigHorizontalFlip":false,"cameraConfigMapVideo":"0:0","cameraConfigMapAudio":"0:1","cameraConfigVideoFilter":"scale=1280:720","cameraConfigAdditionalCommandLine":"-tune zerolatency","cameraConfigDebug":false,"cameraConfigSnapshotOutput":"disabled","cameraConfigInterfaceName":"","characteristicProperties":"{}","waitForSetupMsg":false,"outputs":2,"x":850,"y":2820,"wires":[["bdc793acd4cba03f"],[]]},{"id":"cb1309f5add083ce","type":"s7 out","z":"e0554a9f.d11038","endpoint":"ba4f422c5ebd94e8","variable":"DB3.DBB1","name":"","x":1150,"y":2820,"wires":[]},{"id":"bdc793acd4cba03f","type":"function","z":"e0554a9f.d11038","name":"func","func":"\n\nreturn {payload: msg.payload.On};","outputs":1,"noerr":0,"x":990,"y":2820,"wires":[["cb1309f5add083ce"]]},{"id":"8700d75e70ca059d","type":"s7 in","z":"e0554a9f.d11038","endpoint":"ba4f422c5ebd94e8","mode":"single","variable":"DB3.DBB1","diff":true,"name":"","x":300,"y":2820,"wires":[["a22bf7e63f5eed98"]]},{"id":"f94e25b68cc2142e","type":"change","z":"e0554a9f.d11038","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"On\":1,\"OutletInUse\":1}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":2800,"wires":[["876ec3bc7c5616cc"]]},{"id":"a22bf7e63f5eed98","type":"switch","z":"e0554a9f.d11038","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":430,"y":2820,"wires":[["f94e25b68cc2142e"],["5100444a3978c1eb"]]},{"id":"5100444a3978c1eb","type":"change","z":"e0554a9f.d11038","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"On\":0,\"OutletInUse\":0}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":2840,"wires":[["876ec3bc7c5616cc"]]},{"id":"e315f460.4979d8","type":"homekit-bridge","bridgeName":"Zuhause","pinCode":"111-11-111","port":"","allowInsecureRequest":false,"manufacturer":"Default Manufacturer","model":"Default Model","serialNo":"Default Serial Number","firmwareRev":"","hardwareRev":"","softwareRev":"","customMdnsConfig":false,"mdnsMulticast":true,"mdnsInterface":"","mdnsPort":"","mdnsIp":"","mdnsTtl":"","mdnsLoopback":true,"mdnsReuseAddr":true,"allowMessagePassthrough":true},{"id":"ba4f422c5ebd94e8","type":"s7 endpoint","transport":"iso-on-tcp","address":"192.168.123.1","port":"102","rack":"0","slot":"2","localtsaphi":"01","localtsaplo":"00","remotetsaphi":"01","remotetsaplo":"00","connmode":"rack-slot","adapter":"","busaddr":"2","cycletime":"200","timeout":"2000","name":"Test","vartable":[{"addr":"M10.0","name":"M10.0 "},{"addr":"DB3,B1","name":"DB3.DBB1"}]}]
Created 2 years, 6 months ago
Rating: 5 1
  • change (x2)
  • switch (x1)
  • homekit-bridge (x1)
  • homekit-service (x1)
  • s7 endpoint (x1)
  • s7 in (x1)
  • s7 out (x1)
  • SPS
  • Siemens
  • PLC
  • S7
  • Simatic
  • Homekit
  • Apple
  • TIA
  • SIRI
  • Heysiri
  • COVER
