Node.RED setup to export favs and retweets that contain URLs to pinboard.in
Export favs and retweets that contain URLs to pinboard.in
The tweet itself (minus the URL) will become the description.
The flow tries to download the URL to extract a title. If that fails, it will use "Twitter" as the title.
This flow needs the pinboard node
[{"id":"b8e5580d.f6e7f8","type":"pinboard out","z":"36c32101.772e1e","user":"11b5da1e.9ee906","tags":"from:twitter","private":false,"toread":true,"name":"","x":1360,"y":280,"wires":[]},{"id":"f6aa3b2b.c74158","type":"change","z":"36c32101.772e1e","name":"Format HTTP Response for pinboard.in","rules":[{"t":"move","p":"payload","pt":"msg","to":"title","tot":"msg"},{"t":"move","p":"url","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"headers","pt":"msg"},{"t":"delete","p":"statusCode","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1220,"y":180,"wires":[["b8e5580d.f6e7f8"]]},{"id":"f8ebdf0.b0a162","type":"change","z":"36c32101.772e1e","name":"Format failed HTTP response","rules":[{"t":"move","p":"url","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"title","pt":"msg","to":"Twitter","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":940,"y":260,"wires":[["b8e5580d.f6e7f8"]]},{"id":"2e6d3afd.baae16","type":"html","z":"36c32101.772e1e","name":"Extract title","property":"payload","tag":"head title","ret":"text","as":"multi","x":890,"y":180,"wires":[["f6aa3b2b.c74158"]]},{"id":"8da01fbd.9ac0e","type":"switch","z":"36c32101.772e1e","name":"Check if URL request was successful","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":530,"y":240,"wires":[["2e6d3afd.baae16"],["f8ebdf0.b0a162"]]},{"id":"df447f54.218f","type":"http request","z":"36c32101.772e1e","name":"Get URL","method":"GET","ret":"txt","url":"","tls":"","x":120,"y":240,"wires":[["8da01fbd.9ac0e"]]},{"id":"4f2769ca.836a48","type":"function","z":"36c32101.772e1e","name":"Extract URLs from tweet, one msg each","func":"if ( !msg.tweet || \n !msg.tweet.target_object || \n !msg.tweet.target_object.entities ||\n !msg.tweet.target_object.entities.urls ||\n msg.tweet.target_object.entities.urls.length === 0 ) {\n return null;\n }\nvar messages = [],\n text = msg.tweet.target_object.text,\n urls = msg.tweet.target_object.entities.urls;\nfor ( var i = 0; i < urls.length; i++ ) {\n messages.push( {\n payload: urls[i].expanded_url,\n url: urls[i].expanded_url,\n description: text.substring( 0, urls[i].indices[0] ) + text.substr( urls[i].indices[1] ),\n tweet: msg.tweet\n } );\n}\nreturn [ messages ];","outputs":1,"noerr":0,"x":220,"y":140,"wires":[["df447f54.218f"]]},{"id":"35538e2a.388dd2","type":"twitter in","z":"36c32101.772e1e","twitter":"","tags":"","user":"event","name":"","topic":"tweets","inputs":0,"x":120,"y":40,"wires":[["4f2769ca.836a48"]]},{"id":"11b5da1e.9ee906","type":"pinboard-user","z":"","user":"archangel"}]
