LG Webos IR remote
lgremote This is my flow for when I cant find the remote for the TV. Basically I used an IR receiver connected to a node mcu esp8266 on a breadboard. the node mcu was running the tasmota full IR firmware. I captured each button press on the remote and saved the data, All the hard work of copying and pasting the data for each button press is done. You can use an esp8266 running tasmota ir to replay those commands through a 2n2222 transistor and a high output ir led. However, it should work with any mqtt enabled IR Blaster. You will need the node red dashboard and an mqtt enabled IR Blaster. the LG webos nodes are installed on my node red server. I did my best to make it look just like the actual remote.
[{"id":"bf270c98.02df2","type":"change","z":"59caad4b.795ad4","name":"Input Select","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF3EC1\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":140,"wires":[["cb3b354b.4a7148"]]},{"id":"deab3807.fa3cf8","type":"change","z":"59caad4b.795ad4","name":"Ok/Enter","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF22DD\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":340,"wires":[["cb3b354b.4a7148"]]},{"id":"129628db.aad7b7","type":"change","z":"59caad4b.795ad4","name":"Up Arrow","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF02FD\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":180,"wires":[["cb3b354b.4a7148"]]},{"id":"28eb538b.89fc9c","type":"change","z":"59caad4b.795ad4","name":"Down Arrow","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF827D\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":220,"wires":[["cb3b354b.4a7148"]]},{"id":"979cae63.846d7","type":"change","z":"59caad4b.795ad4","name":"Left Arrow","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DFE01F\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":260,"wires":[["cb3b354b.4a7148"]]},{"id":"eaf0e0a5.010a7","type":"change","z":"59caad4b.795ad4","name":"Right Arrow","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF609F\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":300,"wires":[["cb3b354b.4a7148"]]},{"id":"e864eee8.bad8a","type":"change","z":"59caad4b.795ad4","name":"Back","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF14EB\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":420,"wires":[["cb3b354b.4a7148"]]},{"id":"61110f2d.68b","type":"change","z":"59caad4b.795ad4","name":"exit","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DFDA25\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":380,"wires":[["cb3b354b.4a7148"]]},{"id":"2f958f0c.b7dd","type":"change","z":"59caad4b.795ad4","name":"Channel up","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF00FF\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":230,"y":260,"wires":[["cb3b354b.4a7148"]]},{"id":"135f655b.d50e2b","type":"change","z":"59caad4b.795ad4","name":"Channel Down","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF807F\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":220,"wires":[["cb3b354b.4a7148"]]},{"id":"54e64b95.686d84","type":"change","z":"59caad4b.795ad4","name":"Power","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF10EF\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":460,"wires":[["cb3b354b.4a7148"]]},{"id":"66579eab.62a75","type":"change","z":"59caad4b.795ad4","name":"Volume up","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF40BF\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":230,"y":140,"wires":[["cb3b354b.4a7148"]]},{"id":"1c379ac7.88f5f5","type":"change","z":"59caad4b.795ad4","name":"Volume Down","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DFC03F\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":180,"wires":[["cb3b354b.4a7148"]]},{"id":"159048d6.04e047","type":"change","z":"59caad4b.795ad4","name":"Play","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF0DF2\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":250,"y":300,"wires":[["cb3b354b.4a7148"]]},{"id":"78181cd5.f4d5d4","type":"change","z":"59caad4b.795ad4","name":"Pause","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF5DA2\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":250,"y":340,"wires":[["cb3b354b.4a7148"]]},{"id":"c8b1a1d2.fd23b","type":"change","z":"59caad4b.795ad4","name":"Stop","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF8D72\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":250,"y":380,"wires":[["cb3b354b.4a7148"]]},{"id":"ff6042c8.e2f7e","type":"change","z":"59caad4b.795ad4","name":"Rewind","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DFF10E\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":240,"y":420,"wires":[["cb3b354b.4a7148"]]},{"id":"e5d1b55c.e330b8","type":"change","z":"59caad4b.795ad4","name":"F Forward","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF718E\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":230,"y":460,"wires":[["cb3b354b.4a7148"]]},{"id":"7680b31a.41950c","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":3,"width":"2","height":"1","passthru":false,"label":"Input","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"input","payloadType":"str","topic":"","x":390,"y":140,"wires":[["bf270c98.02df2"]]},{"id":"a2e50b0.b748ff8","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":6,"width":"4","height":"1","passthru":false,"label":"Up","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"up","payloadType":"str","topic":"","x":390,"y":180,"wires":[["129628db.aad7b7"]]},{"id":"692a8cf.9f03974","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":14,"width":"4","height":"1","passthru":false,"label":"Down","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"down","payloadType":"str","topic":"","x":390,"y":220,"wires":[["28eb538b.89fc9c"]]},{"id":"9c2b3042.00859","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":9,"width":"1","height":"2","passthru":false,"label":"Left","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"left","payloadType":"str","topic":"","x":390,"y":260,"wires":[["979cae63.846d7"]]},{"id":"8011d94b.11b038","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":11,"width":"1","height":"2","passthru":false,"label":"Right","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"right","payloadType":"str","topic":"","x":390,"y":300,"wires":[["eaf0e0a5.010a7"]]},{"id":"d89e0d4b.d7b33","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":10,"width":"2","height":"2","passthru":false,"label":"Ok/Enter","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"ok","payloadType":"str","topic":"","x":400,"y":340,"wires":[["deab3807.fa3cf8"]]},{"id":"d2eff59c.f29708","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":5,"width":"1","height":"1","passthru":false,"label":"Exit","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"exit","payloadType":"str","topic":"","x":390,"y":380,"wires":[["61110f2d.68b"]]},{"id":"cae76a13.0d85d8","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":7,"width":"1","height":"1","passthru":false,"label":"Back","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"back","payloadType":"str","topic":"","x":390,"y":420,"wires":[["e864eee8.bad8a"]]},{"id":"1c1cc773.e745d9","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":1,"width":"6","height":"1","passthru":false,"label":"Power","tooltip":"","color":"","bgcolor":"red","icon":"","payload":"power","payloadType":"str","topic":"","x":390,"y":460,"wires":[["54e64b95.686d84"]]},{"id":"99cea5d3.f67b18","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":8,"width":"1","height":"2","passthru":false,"label":"Vol +","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"volup","payloadType":"str","topic":"","x":70,"y":140,"wires":[["66579eab.62a75"]]},{"id":"2da1b434.db60cc","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":12,"width":"1","height":"2","passthru":false,"label":"Vol -","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"voldn","payloadType":"str","topic":"","x":70,"y":180,"wires":[["1c379ac7.88f5f5"]]},{"id":"a0ba2e2a.0a11b","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":13,"width":"1","height":"2","passthru":false,"label":"Ch +","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"chup","payloadType":"str","topic":"","x":70,"y":220,"wires":[["135f655b.d50e2b"]]},{"id":"67ae13d6.03f0bc","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":15,"width":"1","height":"2","passthru":false,"label":"Ch -","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"chdn","payloadType":"str","topic":"","x":70,"y":260,"wires":[["2f958f0c.b7dd"]]},{"id":"6287ad4b.c55e94","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":16,"width":"1","height":"1","passthru":false,"label":"Play","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"play","payloadType":"str","topic":"","x":70,"y":300,"wires":[["159048d6.04e047"]]},{"id":"ba64317e.e0b6a","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":20,"width":"6","height":"1","passthru":false,"label":"Pause","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"pause","payloadType":"str","topic":"","x":70,"y":340,"wires":[["78181cd5.f4d5d4"]]},{"id":"859952bb.6fac5","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":17,"width":"1","height":"1","passthru":false,"label":"Stop","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"stop","payloadType":"str","topic":"","x":70,"y":380,"wires":[["c8b1a1d2.fd23b"]]},{"id":"b109ff1e.37fc","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":18,"width":"1","height":"1","passthru":false,"label":"Rew","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"rew","payloadType":"str","topic":"","x":70,"y":420,"wires":[["ff6042c8.e2f7e"]]},{"id":"af4c9938.091148","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":19,"width":"1","height":"1","passthru":false,"label":"FFwd","tooltip":"","color":"","bgcolor":"black","icon":"","payload":"ffwd","payloadType":"str","topic":"","x":70,"y":460,"wires":[["e5d1b55c.e330b8"]]},{"id":"39b3939a.314fec","type":"change","z":"59caad4b.795ad4","name":"Netflix","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF6A95\",\"DataLSB\":\"0x04FB56A9\",\"Repeat\":0}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":500,"wires":[["cb3b354b.4a7148"]]},{"id":"f08a16bc.435678","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":2,"width":"2","height":"1","passthru":false,"label":"Netflix","tooltip":"","color":"red","bgcolor":"white","icon":"","payload":"Netflix","payloadType":"str","topic":"","x":390,"y":500,"wires":[["39b3939a.314fec"]]},{"id":"5a93058a.0b3f9c","type":"change","z":"59caad4b.795ad4","name":"Prime","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF10EF\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":250,"y":500,"wires":[["cb3b354b.4a7148"]]},{"id":"d02ff049.ac869","type":"ui_button","z":"59caad4b.795ad4","name":"","group":"56cfd87.1ce4528","order":4,"width":"2","height":"1","passthru":false,"label":"Prime","tooltip":"","color":"green","bgcolor":"white","icon":"","payload":"Prime","payloadType":"str","topic":"","x":70,"y":500,"wires":[["5a93058a.0b3f9c"]]},{"id":"cb3b354b.4a7148","type":"mqtt out","z":"59caad4b.795ad4","name":"living room irsend","topic":"house/irsender/cmnd/irsend","qos":"0","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"e1845c36.b4f2b","x":790,"y":320,"wires":[]},{"id":"b026afc440269d2c","type":"ui_button","z":"59caad4b.795ad4","name":"Mute","group":"56cfd87.1ce4528","order":22,"width":"2","height":"1","passthru":false,"label":"Mute","tooltip":"","color":"red","bgcolor":"black","className":"","icon":"","payload":"Mute","payloadType":"str","topic":"","topicType":"str","x":70,"y":540,"wires":[["fd4ecb3f11014569"]]},{"id":"fd4ecb3f11014569","type":"change","z":"59caad4b.795ad4","name":"Mute","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"Protocol\":\"NEC\",\"Bits\":32,\"Data\":\"0x20DF906F\",\"DataLSB\":\"0x04FB09F6\",\"Repeat\":0}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":250,"y":540,"wires":[["cb3b354b.4a7148"]]},{"id":"8b20d66d2442068c","type":"lgtv-app","z":"59caad4b.795ad4","tv":"f973dc16.7f3b1","name":"Hulu","passthru":true,"x":550,"y":540,"wires":[[]]},{"id":"3142665a4ca5d7e6","type":"ui_button","z":"59caad4b.795ad4","name":"Hulu","group":"56cfd87.1ce4528","order":23,"width":"2","height":"1","passthru":false,"label":"Hulu","tooltip":"","color":"green","bgcolor":"white","className":"","icon":"","payload":"hulu","payloadType":"str","topic":"","topicType":"str","x":390,"y":540,"wires":[["8b20d66d2442068c"]]},{"id":"56cfd87.1ce4528","type":"ui_group","name":"Sitting Room tv remote","tab":"8205a196.b44ac","order":1,"disp":true,"width":"6","collapse":true},{"id":"e1845c36.b4f2b","type":"mqtt-broker","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"f973dc16.7f3b1","type":"lgtv-config","host":"192.168.10.100"},{"id":"8205a196.b44ac","type":"ui_tab","name":"Virtual Remote","icon":"dashboard","disabled":false,"hidden":false}]
Created 2 years, 8 months ago
  • change (x21)
  • mqtt out (x1)
  • mqtt-broker (x1)
  • lgtv-app (x1)
  • lgtv-config (x1)
  • ui_button (x22)
  • ui_group (x1)
  • LG
  • Webos
  • IR
  • Remote
