telegram light controler without coding
this is a very simple telegram controller without any coding just with plugins
[{"id":"d7ec6c9d.437f5","type":"telegram command","z":"dab3af18.12054","name":"off","command":"/offlight","bot":"a12e7dee.72d1a","x":76,"y":177,"wires":[["9a626669.74b54","2520b57a.996c8a","9414214c.53ddf"],[]]},{"id":"c03bc345.41c82","type":"telegram command","z":"dab3af18.12054","name":"on","command":"/onlight","bot":"a12e7dee.72d1a","x":55,"y":233,"wires":[["fd13bb82.a914c8","e6ab24ab.3a8678","2b29b88a.20b8b8"],[]]},{"id":"9a626669.74b54","type":"trigger","z":"dab3af18.12054","op1":"1","op2":"0","op1type":"num","op2type":"str","duration":"0","extend":false,"units":"s","reset":"","name":"","x":407,"y":156,"wires":[["f585eeef.2f49f","76ecab7c.772c1c"]]},{"id":"fd13bb82.a914c8","type":"trigger","z":"dab3af18.12054","op1":"0","op2":"0","op1type":"str","op2type":"str","duration":"0","extend":false,"units":"ms","reset":"","name":"","x":476,"y":251,"wires":[["f585eeef.2f49f","76ecab7c.772c1c"]]},{"id":"2520b57a.996c8a","type":"template","z":"dab3af18.12054","name":"reset on command","field":"reset","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"This is the payload: {{payload}} !","x":255,"y":203,"wires":[["fd13bb82.a914c8"]]},{"id":"e6ab24ab.3a8678","type":"template","z":"dab3af18.12054","name":"reset off command","field":"reset","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"This is the payload: {{payload}} !","x":229,"y":338,"wires":[["9a626669.74b54"]]},{"id":"f585eeef.2f49f","type":"debug","z":"dab3af18.12054","name":"this is arduino on 13 pin","active":true,"console":"false","complete":"payload","x":705,"y":161,"wires":[]},{"id":"a89c5a3b.fe6d48","type":"telegram sender","z":"dab3af18.12054","name":"","bot":"a12e7dee.72d1a","x":705,"y":119,"wires":[[]]},{"id":"2b29b88a.20b8b8","type":"template","z":"dab3af18.12054","name":"on message","field":"payload.content","fieldType":"msg","format":"text","syntax":"mustache","template":"Lights has been on!","x":390,"y":303,"wires":[["a89c5a3b.fe6d48"]]},{"id":"9414214c.53ddf","type":"template","z":"dab3af18.12054","name":"off message","field":"payload.content","fieldType":"msg","format":"text","syntax":"mustache","template":"Lights has been off!","x":233,"y":115,"wires":[["a89c5a3b.fe6d48"]]},{"id":"76ecab7c.772c1c","type":"gpio out","z":"dab3af18.12054","name":"","state":"OUTPUT","pin":"3","i2cDelay":"0","i2cAddress":"","i2cRegister":"","outputs":0,"board":"afe730f9.b748a","x":674,"y":203,"wires":[]},{"id":"a12e7dee.72d1a","type":"telegram bot","z":"","botname":"iot test","usernames":"","chatids":"306389480"},{"id":"afe730f9.b748a","type":"nodebot","z":"","name":"","username":"","password":"","boardType":"raspi-io","serialportName":"","connectionType":"local","mqttServer":"","socketServer":"","pubTopic":"","subTopic":"","tcpHost":"","tcpPort":"","sparkId":"","sparkToken":"","beanId":"","impId":"","meshbluServer":"https://meshblu.octoblu.com","uuid":"","token":"","sendUuid":""}]
Created 9 years, 6 months ago
Updated 8 years, 7 months ago
  • template (x4)
  • trigger (x2)
  • raspberry
  • telegram
  • johhny-five
  • simple
  • with-out-code
