Camunda Nodes Examples
Flow containing examples with all Camunda Nodes.
- worker / complete
- create process instance
- correlate message
- deploy
- variables helper
[{"id":"803341dd.dea93","type":"tab","label":"Camunda","disabled":false,"info":""},{"id":"d5ca3e82.a51b","type":"camunda-task-worker","z":"803341dd.dea93","name":"","camunda":"14c44783.f1f468","topic":"worker1","x":150,"y":580,"wires":[["eefe5c5f.f18d7"]]},{"id":"eefe5c5f.f18d7","type":"function","z":"803341dd.dea93","name":"do some work","func":"msg.payload.processVariables.set(\"ok\", true);\nreturn msg;","outputs":1,"noerr":0,"x":320,"y":580,"wires":[["64a41cbf.bc2364"]]},{"id":"64a41cbf.bc2364","type":"camunda-complete-task","z":"803341dd.dea93","name":"","x":500,"y":580,"wires":[]},{"id":"80f60da1.cbe95","type":"camunda-workflow-instance","z":"803341dd.dea93","name":"","camunda":"14c44783.f1f468","x":930,"y":340,"wires":[[]]},{"id":"36a9668d.e1501a","type":"inject","z":"803341dd.dea93","name":"inject","topic":"","payload":"{}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":340,"wires":[["48b8d134.fb241"]]},{"id":"48b8d134.fb241","type":"change","z":"803341dd.dea93","name":"prepare","rules":[{"t":"set","p":"payload.processDefinitionKey","pt":"msg","to":"process1","tot":"str"},{"t":"set","p":"payload.processBusinessKey","pt":"msg","to":"businessKey1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":340,"wires":[["952308c4.bb8a98"]]},{"id":"67f6b1e2.b2611","type":"camunda-publish-message","z":"803341dd.dea93","name":"","camunda":"14c44783.f1f468","x":510,"y":420,"wires":[[]]},{"id":"f6edccec.f4e7a","type":"change","z":"803341dd.dea93","name":"prepare","rules":[{"t":"set","p":"payload.messageName","pt":"msg","to":"start","tot":"str"},{"t":"set","p":"payload.processBusinessKey","pt":"msg","to":"businessKey1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":420,"wires":[["67f6b1e2.b2611"]]},{"id":"4deb67bd.c91628","type":"inject","z":"803341dd.dea93","name":"inject","topic":"","payload":"{}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":420,"wires":[["f6edccec.f4e7a"]]},{"id":"952308c4.bb8a98","type":"camunda-variables-helper","z":"803341dd.dea93","name":"","x":500,"y":340,"wires":[["bd2eee05.8aae8"]]},{"id":"bd2eee05.8aae8","type":"function","z":"803341dd.dea93","name":"set variables","func":"msg.payload.processVariables = new msg.variables();\nmsg.payload.processVariables.set(\"string\", \"string\");\nmsg.payload.processVariables.set(\"integer\", 10);\nmsg.payload.processVariables.set(\"double\", 1.1);\nmsg.payload.processVariables.set(\"boolean\", true);\nmsg.payload.processVariables.set(\"json\", {});\nmsg.payload.processVariables.set(\"date\", new Date());\nreturn msg;","outputs":1,"noerr":0,"x":710,"y":340,"wires":[["80f60da1.cbe95"]]},{"id":"c9d4eeed.81134","type":"camunda-publish-message","z":"803341dd.dea93","name":"","camunda":"14c44783.f1f468","x":510,"y":500,"wires":[[]]},{"id":"7b49bf9.e6d084","type":"change","z":"803341dd.dea93","name":"prepare","rules":[{"t":"set","p":"payload.messageName","pt":"msg","to":"continue","tot":"str"},{"t":"set","p":"payload.processBusinessKey","pt":"msg","to":"businessKey1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":500,"wires":[["c9d4eeed.81134"]]},{"id":"a986b24d.a9899","type":"inject","z":"803341dd.dea93","name":"inject","topic":"","payload":"{}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":500,"wires":[["7b49bf9.e6d084"]]},{"id":"838a9fab.e7839","type":"change","z":"803341dd.dea93","name":"prepare","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload.source","tot":"msg"},{"t":"set","p":"payload.deploymentName","pt":"msg","to":"process1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":260,"wires":[["83fea7b2.95d328"]]},{"id":"d978fdbe.e9d4e","type":"inject","z":"803341dd.dea93","name":"inject","topic":"","payload":"{}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":260,"wires":[["81be6545.ef0f08"]]},{"id":"83fea7b2.95d328","type":"camunda-deploy","z":"803341dd.dea93","name":"","camunda":"14c44783.f1f468","x":630,"y":260,"wires":[[]]},{"id":"81be6545.ef0f08","type":"file in","z":"803341dd.dea93","name":"bpmn file","filename":"process1.bpmn","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":320,"y":260,"wires":[["838a9fab.e7839"]]},{"id":"14c44783.f1f468","type":"camunda-config","z":"","name":"","baseUrl":"http://localhost:8080/engine-rest","basicAuth":true,"username":"admin","password":"admin"}]
