opcxml subflow
Nodered OPC XML Client. Built as a subflow purely with core nodes.
[{"id":"f6f2187d.f17ca8","type":"tab","label":"Example","disabled":false,"info":""},{"id":"a0568e71.72952","type":"subflow","name":"opcxml","info":"OPC XML Client  \n\n### Inputs\n---\n## _`url`_  \n If not configured in the node, this optional property sets the url of the request.  \n\n## _`action`_   <string>  \n If not configured in the node, ths optional property sets the OPC XML Action of the request. Must be one of \n `GetStatus`, `Read`, `Write`, ``Subscribe, `SubscriptionPolledrefresh`, `SubscriptionCancel`, `Browse` or `GetProperties`\n\n## _`payload`_  \n The payload defines the details of the action. Each action has different payload structure which is transformed to a Soap Envelope as required by the OPC XML server.  \n - Read\n ```\n payload = {\n   \"ItemPath\": <string>, optional, server dependent\n   \"ItemList\": [\n        {\n            \"ItemName\": <string>, required\n            \"ItemPath\": <string>, optional, server dependent\n            \"ClientItemHandle\": <string> optional\n        },\n        ...\n ]}\n ```\n - Write\n ```\n payload = {\n   \"ItemPath\": <string>, optional, server dependent\n   \"ItemList\": [\n        {\n            \"ItemName\": <string>, required\n            \"ItemPath\": <string>, optional, server dependent\n            \"ClientItemHandle\": <string>, optional\n            \"value\": <>, required\n            \"dataType\": <string> required as retrieved from GetProperties action  \n        },\n        ...\n ]}\n ```\n - Subscribe\n ```\n payload = {\n   \"SubscriptionPingRate\": <number>, optional defaults to 60000 ms  \n   \"requestedSamplingRate\": <number>, optional defaults to 1000 ms  \n   \"ClientRequestHandle\": <string>, optional\n   \"ItemPath\": <string>,\n   \"ItemList\": [\n        {\n            \"ItemName\": <string>, required\n            \"ItemPath\": <string>, optional, server dependent\n            \"ClientItemHandle\": <string> optional\n        },\n        ...\n ]}\n ```\n - SubscriptionPolledRefresh\n ```\n payload = {'ServerSubHandle': <string>}\n ```\n - SubscriptionCancel\n ```\n payload = {'ServerSubHandle': <string>}\n ```\n - Browse\n ```\n payload = {'ItemName': <string>}\n ```  \n - GetProperties\n ```\n payload = {'ItemName': <string>}\n ```  \n\n ---\n\n### Example  \nBrowse Advosol public server  \n```  \nmsg.url = 'http://info.advosol.com/XMLDADemo/XML_Sim/OpcXmlDaServer.asmx'  \nmsg.action = 'Browse'\nmsg.payload = {\"ItemName\": \"\"}\n```\n\n# Details\nUse this at your own risk. This client is not certified, nor based on any documentation. Its just loosely a result of testing communication with a couple of OPC XML servers that happen to be within reach.\n\n\n","category":"","in":[{"x":40,"y":180,"wires":[{"id":"63e32c20.b76e94"}]}],"out":[{"x":1260,"y":920,"wires":[{"id":"12f2c851.6e7428","port":0}]}],"env":[{"name":"action","type":"str","value":"GetStatus","ui":{"type":"select","opts":{"opts":[{"l":{"en-US":"GetStatus"},"v":"GetStatus"},{"l":{"en-US":"Read"},"v":"Read"},{"l":{"en-US":"Write"},"v":"Write"},{"l":{"en-US":"Subscribe"},"v":"Subscribe"},{"l":{"en-US":"SubscriptionPolledRefresh"},"v":"SubscriptionPolledRefresh"},{"l":{"en-US":"SubscriptionCancel"},"v":"SubscriptionCancel"},{"l":{"en-US":"Browse"},"v":"Browse"},{"l":{"en-US":"GetProperties"},"v":"GetProperties"},{"l":{"en-US":"<msg.action>"},"v":""}]}}},{"name":"url","type":"str","value":"","ui":{"type":"input","opts":{"types":["str","env"]}}}],"meta":{"keywords":"OPC, opcxml, client"},"color":"#da9","outputLabels":["payload"]},{"id":"d06bded4.355dc","type":"template","z":"a0568e71.72952","name":"GetStatus","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<soap:Envelope \nxmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\" \nxmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" \nxmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\">\n<soap:Body>\n<GetStatus xmlns=\"http://opcfoundation.org/webservices/XMLDA/1.0/\"/>\n</soap:Body>\n</soap:Envelope>\n","output":"str","x":620,"y":60,"wires":[["8daff6d4.368e78"]]},{"id":"88ea2c40.56b0a","type":"http request","z":"a0568e71.72952","name":"","method":"POST","ret":"txt","paytoqs":false,"url":"","tls":"","persist":false,"proxy":"","authType":"","x":1010,"y":160,"wires":[["705fabcb.519744"]]},{"id":"236450f8.a7b8a","type":"xml","z":"a0568e71.72952","name":"","property":"payload","attr":"","chr":"","x":310,"y":540,"wires":[["ed80557e.beba28"]]},{"id":"57f9a1f9.97185","type":"template","z":"a0568e71.72952","name":"Read","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<soap:Envelope \nxmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\" \nxmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" \nxmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\">\n<soap:Body>\n <Read xmlns=\"http://opcfoundation.org/webservices/XMLDA/1.0/\">\n  <Options\n    ReturnErrorText=\"true\"\n    ReturnItemTime=\"true\"\n    ReturnItemName=\"true\"\n    LocaleID=\"en\"/>\n  <ItemList{{#payload.ItemPathExists}} ItemPath=\"{{{payload.ItemPath}}}\"{{/payload.ItemPathExists}}>\n    {{#payload.ItemList}}\n       <Items{{#ItemPathExists}} ItemPath=\"{{{ItemPath}}}\"{{/ItemPathExists}} ItemName=\"{{{ItemName}}}\"{{#ClientItemHandle}} ClientItemHandle=\"{{{ClientItemHandle}}}\"{{/ClientItemHandle}}/>\n    {{/payload.ItemList}}\n  </ItemList>\n </Read>\t  \n</soap:Body></soap:Envelope>\n","output":"str","x":730,"y":100,"wires":[["8daff6d4.368e78"]]},{"id":"60c6ce6.1d42f3","type":"switch","z":"a0568e71.72952","name":"action","property":"action","propertyType":"msg","rules":[{"t":"eq","v":"GetStatus","vt":"str"},{"t":"eq","v":"Read","vt":"str"},{"t":"eq","v":"Write","vt":"str"},{"t":"eq","v":"Subscribe","vt":"str"},{"t":"eq","v":"SubscriptionPolledRefresh","vt":"str"},{"t":"eq","v":"SubscriptionCancel","vt":"str"},{"t":"eq","v":"Browse","vt":"str"},{"t":"eq","v":"GetProperties","vt":"str"},{"t":"else"}],"checkall":"false","repair":false,"outputs":9,"x":390,"y":180,"wires":[["d06bded4.355dc"],["3692f15954804177"],["14b7deacbb35defc"],["6335ea21.ad4a54"],["957a24a0.800c58"],["9ffb90ef.88ccd"],["1c5abe9c.425c31"],["67d14704.f3e058"],["7c0160cd.337dd"]]},{"id":"1c5abe9c.425c31","type":"template","z":"a0568e71.72952","name":"Browse","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<soap:Envelope \nxmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\" \nxmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" \nxmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\">\n<soap:Body>\n<Browse xmlns=\"http://opcfoundation.org/webservices/XMLDA/1.0/\"\n\tItemName=\"{{{payload.ItemName}}}\"  \n\tBrowseFilter=\"all\" \n\tReturnPropertyValues=\"true\"\n>\n            <PropertyNames>dataType</PropertyNames>\n            <PropertyNames>accessRights</PropertyNames>\n</Browse>\t  \n</soap:Body>\n</soap:Envelope>\n","output":"str","x":600,"y":300,"wires":[["8daff6d4.368e78"]]},{"id":"7c0160cd.337dd","type":"function","z":"a0568e71.72952","name":"Error","func":"node.error('Unknown SOAP action', msg)\n","outputs":0,"noerr":0,"x":570,"y":380,"wires":[]},{"id":"8f627fde.e3c0f","type":"switch","z":"a0568e71.72952","name":"action","property":"action","propertyType":"msg","rules":[{"t":"eq","v":"GetStatus","vt":"str"},{"t":"eq","v":"Read","vt":"str"},{"t":"eq","v":"Write","vt":"str"},{"t":"eq","v":"Subscribe","vt":"str"},{"t":"eq","v":"SubscriptionPolledRefresh","vt":"str"},{"t":"eq","v":"SubscriptionCancel","vt":"str"},{"t":"eq","v":"Browse","vt":"str"},{"t":"eq","v":"GetProperties","vt":"str"}],"checkall":"false","repair":false,"outputs":8,"x":230,"y":820,"wires":[["35897351.3c2adc"],["7e8d6d76.e0a0c4"],["2e7040d.343cbc"],["b865212e.e1d0b"],["8e60984d.cfcf18"],["6f1e64f4.bcbcac"],["e2e40866.9ce498"],["c93f193f.e756b8"]]},{"id":"4ac0e773.fc42f8","type":"link out","z":"a0568e71.72952","name":"Response","links":["2a3004a5.86317c"],"x":1295,"y":140,"wires":[]},{"id":"7e8d6d76.e0a0c4","type":"change","z":"a0568e71.72952","name":"ReadResponse","rules":[{"t":"set","p":"payload","pt":"msg","to":"**.ReadResponse.RItemList.Items.{\t\"ItemName\":$.\"$\".ItemName,\t\"ClientItemHandle\":$.\"$\".ClientItemHandle,\t\"Timestamp\":$.\"$\".Timestamp,\t\"value\": Value.\"_\",\t\"type\": Value.\"$\".\"xsi:type\",\t\"Quality\": Quality[0].\"$\".QualityField\t}[]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":760,"wires":[["6d7a466.2d910b8"]]},{"id":"6d7a466.2d910b8","type":"split","z":"a0568e71.72952","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":710,"y":760,"wires":[["4dc9e078.2774"]]},{"id":"4dc9e078.2774","type":"switch","z":"a0568e71.72952","name":"","property":"payload.type","propertyType":"msg","rules":[{"t":"eq","v":"xsd:float","vt":"str"},{"t":"eq","v":"xsd:double","vt":"str"},{"t":"eq","v":"xsd:int","vt":"str"},{"t":"eq","v":"xsd:unsignedInt","vt":"str"},{"t":"eq","v":"xsd:string","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":6,"x":830,"y":760,"wires":[["d232b24f.36022"],["d232b24f.36022"],["d232b24f.36022"],["d232b24f.36022"],["f79accb.58b8b3"],["b87f32a3.f1562","bf0f1ea6.1ef93"]]},{"id":"b87f32a3.f1562","type":"join","z":"a0568e71.72952","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":"false","timeout":"","count":"","reduceRight":false,"x":1150,"y":780,"wires":[["bfb860b4.f3ac9"]]},{"id":"d232b24f.36022","type":"change","z":"a0568e71.72952","name":"number","rules":[{"t":"set","p":"payload.value","pt":"msg","to":"$number(payload.value)","tot":"jsonata"},{"t":"delete","p":"payload.type","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":720,"wires":[["b87f32a3.f1562"]]},{"id":"f79accb.58b8b3","type":"change","z":"a0568e71.72952","name":"string","rules":[{"t":"delete","p":"payload.type","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":760,"wires":[["b87f32a3.f1562"]]},{"id":"cda10e22.075af","type":"function","z":"a0568e71.72952","name":"Warn","func":"node.warn(msg.payload)\n","outputs":1,"noerr":0,"x":1150,"y":820,"wires":[[]]},{"id":"f713686b.a04448","type":"link out","z":"a0568e71.72952","name":"","links":["12f2c851.6e7428"],"x":655,"y":720,"wires":[]},{"id":"12f2c851.6e7428","type":"link in","z":"a0568e71.72952","name":"Done","links":["f713686b.a04448","bfb860b4.f3ac9","c7d068d5.6d5d08","d9af02c5.7f4f6","1ebc5fbf.98ebf","5e695cd6.f557f4","667f0f18.9d189","f3cc9a14.e34458","a93b46ec.4c71e8","7d15a46f.55944c","2854f3b9.1b98fc","2ff36629.b3c0aa"],"x":1145,"y":920,"wires":[[]]},{"id":"bfb860b4.f3ac9","type":"link out","z":"a0568e71.72952","name":"","links":["12f2c851.6e7428"],"x":1235,"y":780,"wires":[]},{"id":"c7d068d5.6d5d08","type":"link out","z":"a0568e71.72952","name":"","links":["12f2c851.6e7428"],"x":695,"y":960,"wires":[]},{"id":"2a3004a5.86317c","type":"link in","z":"a0568e71.72952","name":"Transform","links":["4ac0e773.fc42f8"],"x":55,"y":540,"wires":[["eb250a13.029f88"]]},{"id":"bf0f1ea6.1ef93","type":"change","z":"a0568e71.72952","name":"type","rules":[{"t":"set","p":"payload","pt":"msg","to":"'Read. Unhandled type: ' & payload.type","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":820,"wires":[["cda10e22.075af"]]},{"id":"705fabcb.519744","type":"switch","z":"a0568e71.72952","name":"statusCode","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"num"},{"t":"jsonata_exp","v":"statusCode in ['ECONNREFUSED', 'ETIMEDOUT', \"EAI_AGAIN\"]","vt":"jsonata"},{"t":"else"}],"checkall":"false","repair":false,"outputs":3,"x":1170,"y":160,"wires":[["4ac0e773.fc42f8"],[],["d8ec6e2f.a08d7"]]},{"id":"d8ec6e2f.a08d7","type":"function","z":"a0568e71.72952","name":"Error","func":"node.error(\"Http Error. statusCode=\"+msg.statusCode, msg);\n","outputs":0,"noerr":0,"x":1330,"y":200,"wires":[]},{"id":"1e5b953.aa6bf6b","type":"comment","z":"a0568e71.72952","name":"Status codes","info":"msg.statusCode =   \n= 200, ok  \n= 500, Internal error, no error thrown from http request node. Throw error with function node.  \n= ECONNREFUSED, Error already thrown from http request node. Dont produce additional errors  ","x":1170,"y":100,"wires":[]},{"id":"b050323f.b395f","type":"comment","z":"a0568e71.72952","name":"Dropping namespace","info":"https://stackoverflow.com/questions/4505103/how-to-remove-xml-namespaces-using-javascript\n","x":200,"y":480,"wires":[]},{"id":"eb250a13.029f88","type":"function","z":"a0568e71.72952","name":"namespace","func":"// Options to drop namespace for xml node\n// from xml2js lib/processors.js\nprefixMatch = new RegExp(/(?!xmlns)^.*:/);\nfunction stripPrefix(str){\n    return str.replace(prefixMatch, '');\n}\nmsg.options = {\"tagNameProcessors\": [stripPrefix]}\nreturn msg;\n\n/*msg.options = {\"xmlns\":true,}*/\n","outputs":1,"noerr":0,"x":170,"y":540,"wires":[["236450f8.a7b8a"]],"info":"Dropping namespace\n\nSetting options to xml2js\n\nhttps://github.com/Leonidas-from-XIV/node-xml2js/blob/master/README.md#options\n"},{"id":"e2e40866.9ce498","type":"change","z":"a0568e71.72952","name":"BrowseResponse","rules":[{"t":"set","p":"payload","pt":"msg","to":"/* Return Item attributes and requested properties */\t(\t   **.Body.BrowseResponse.Elements.\t   $merge(\t       $append(\t           $.\"$\",\t           [\t               Properties.{\"$\".Name: \"Value\".\"_\"}\t            ]\t       )\t   )\t)\t\t\t\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":960,"wires":[["c7d068d5.6d5d08"]]},{"id":"67d14704.f3e058","type":"template","z":"a0568e71.72952","name":"GetProperties","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<soap:Envelope \nxmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\" \nxmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" \nxmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\">\n<soap:Body>\n\t<GetProperties xmlns=\"http://opcfoundation.org/webservices/XMLDA/1.0/\"\n\tReturnAllProperties=\"true\" ReturnPropertyValues=\"true\" ItemPath=\"\">\n\t\t<ItemIDs ItemPath=\"\" ItemName=\"{{{payload.ItemName}}}\" />\n\t\t<PropertyNames>accessRights</PropertyNames>\n\t\t<PropertyNames>dataType</PropertyNames>\n\t</GetProperties>\n</soap:Body>\n</soap:Envelope>\n","output":"str","x":620,"y":340,"wires":[["8daff6d4.368e78"]]},{"id":"8daff6d4.368e78","type":"change","z":"a0568e71.72952","name":"","rules":[],"action":"","property":"","from":"","to":"","reg":false,"x":895,"y":160,"wires":[["88ea2c40.56b0a"]],"l":false},{"id":"667f0f18.9d189","type":"link out","z":"a0568e71.72952","name":"","links":["12f2c851.6e7428"],"x":815,"y":1000,"wires":[]},{"id":"c93f193f.e756b8","type":"change","z":"a0568e71.72952","name":"GetPropertiesResponse","rules":[{"t":"set","p":"payload","pt":"msg","to":"/*\t(\t   $Lists := **.Envelope.Body.GetPropertiesResponse.PropertyLists;\t   $0 := $Lists{\t       \"ItemPath\": \"$\".ItemPath,\t       \"ItemName\": \"$\".ItemName\t    };\t   $1 := $Lists.Properties.{\"$\".Name: \"Value\".\"_\"};\t   $merge($append($0, $1))\t)\t*/\t\t/* Return Item attributes and requested properties */\t(\t   **.GetPropertiesResponse.PropertyLists.\t   $merge(\t       $append(\t           $.\"$\",\t           [\t               Properties.{\"$\".Name: \"Value\".\"_\"}\t            ]\t       )\t   )\t)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":1000,"wires":[["667f0f18.9d189"]]},{"id":"ed80557e.beba28","type":"switch","z":"a0568e71.72952","name":"Errors?","property":"$exists(**.Errors)","propertyType":"jsonata","rules":[{"t":"true"},{"t":"else"}],"checkall":"false","repair":false,"outputs":2,"x":440,"y":540,"wires":[["4771771.0d32c88"],["d3a2a2e0.14737"]]},{"id":"4771771.0d32c88","type":"change","z":"a0568e71.72952","name":"","rules":[{"t":"set","p":"errorsID","pt":"msg","to":"**.Errors.*.ID","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":520,"wires":[["b821e0a3.f58ac"]]},{"id":"b821e0a3.f58ac","type":"function","z":"a0568e71.72952","name":"Error","func":"node.error(\"OPC XML Error: \" + msg.errorsID, msg);\n","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":770,"y":520,"wires":[]},{"id":"d3a2a2e0.14737","type":"link out","z":"a0568e71.72952","name":"","mode":"link","links":["f635cca.b0f323"],"x":575,"y":560,"wires":[]},{"id":"f635cca.b0f323","type":"link in","z":"a0568e71.72952","name":"","links":["d3a2a2e0.14737"],"x":60,"y":820,"wires":[["8f627fde.e3c0f"]]},{"id":"3e321531.96860a","type":"catch","z":"a0568e71.72952","name":"","scope":["c93f193f.e756b8"],"uncaught":false,"x":370,"y":1040,"wires":[["6a21b5f2.bcb84c"]]},{"id":"ad008474.6637b8","type":"change","z":"a0568e71.72952","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"**.GetPropertiesResponse.PropertyLists","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":1040,"wires":[["667f0f18.9d189"]]},{"id":"6a21b5f2.bcb84c","type":"function","z":"a0568e71.72952","name":"Warning","func":"node.warn(\"Unexpected GetPropertiesResponse\")\nreturn msg;","outputs":1,"noerr":0,"x":500,"y":1040,"wires":[["ad008474.6637b8"]]},{"id":"4e95808c.a3252","type":"template","z":"a0568e71.72952","name":"Subscribe","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<soap:Envelope \nxmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\" \nxmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" \nxmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\">\n<soap:Body>\n<Subscribe xmlns=\"http://opcfoundation.org/webservices/XMLDA/1.0/\"\n    ReturnValuesOnReply=\"true\" \n    SubscriptionPingRate=\"{{payload.SubscriptionPingRate}}\"\n    >\n    <Options\n        ReturnErrorText=\"true\"\n        ReturnItemTime=\"true\"\n        ReturnItemName=\"true\"\n        />\n    <ItemList\n        {{#payload.ItemPath}} ItemPath=\"{{{payload.ItemPath}}}\"{{/payload.ItemPath}}\n        {{#payload.requestedSamplingRate}} requestedSamplingRate=\"{{{payload.requestedSamplingRate}}}\"{{/payload.requestedSamplingRate}}\n        >\n        {{#payload.ItemList}}\n        <Items\n            ItemName=\"{{{ItemName}}}\"{{#ItemPath}} \n            ItemPath=\"{{{ItemPath}}}\"{{/ItemPath}}{{#ClientItemHandle}}\n            ClientItemHandle=\"{{{ClientItemHandle}}}\"{{/ClientItemHandle}}\n            />\n        {{/payload.ItemList}}\n    </ItemList>\n</Subscribe>\t  \n</soap:Body>\n</soap:Envelope>\n","output":"str","x":720,"y":180,"wires":[["8daff6d4.368e78"]]},{"id":"63e32c20.b76e94","type":"change","z":"a0568e71.72952","name":"env","rules":[{"t":"set","p":"action","pt":"msg","to":"($boolean($env('action'))) ? $env('action'): $boolean(action) ? action : \"GetStatus\"\t","tot":"jsonata"},{"t":"set","p":"url","pt":"msg","to":"($boolean($env(\"url\"))) ? $env(\"url\"): $boolean(url) ? url : \"\"\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":130,"y":180,"wires":[["700dcd8e.8e42d4"]]},{"id":"6335ea21.ad4a54","type":"change","z":"a0568e71.72952","name":"default","rules":[{"t":"set","p":"payload.SubscriptionPingRate","pt":"msg","to":"(\"SubscriptionPingRate\" in $keys(payload)) ? payload.SubscriptionPingRate: 60000\t","tot":"jsonata"},{"t":"set","p":"payload.requestedSamplingRate","pt":"msg","to":"(\"requestedSamplingRate\" in $keys(payload)) ? payload.requestedSamplingRate: 1000\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":180,"wires":[["4e95808c.a3252"]]},{"id":"b865212e.e1d0b","type":"change","z":"a0568e71.72952","name":"SubscribeResponse","rules":[{"t":"set","p":"payload","pt":"msg","to":"**.SubscribeResponse.{\t\"ServerSubHandle\":$.\"$\".ServerSubHandle\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":840,"wires":[["7d15a46f.55944c"]]},{"id":"7d15a46f.55944c","type":"link out","z":"a0568e71.72952","name":"","links":["12f2c851.6e7428"],"x":615,"y":840,"wires":[]},{"id":"957a24a0.800c58","type":"template","z":"a0568e71.72952","name":"SubscriptionPolledRefresh","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<soap:Envelope \nxmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\" \nxmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" \nxmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\">\n<soap:Body>\n<SubscriptionPolledRefresh xmlns=\"http://opcfoundation.org/webservices/XMLDA/1.0/\" \n    ReturnAllItems=\"true\"> \n\t<Options ReturnErrorText=\"true\" ReturnItemTime=\"true\" ReturnItemName=\"true\" LocaleID=\"en\" /> \n\t<ServerSubHandles>{{{payload.ServerSubHandle}}}</ServerSubHandles>\n</SubscriptionPolledRefresh> \n</soap:Body>\n</soap:Envelope>\n","output":"str","x":660,"y":220,"wires":[["8daff6d4.368e78"]]},{"id":"9ffb90ef.88ccd","type":"template","z":"a0568e71.72952","name":"SubscriptionCancel","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<soap:Envelope \nxmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\" \nxmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" \nxmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\">\n<soap:Body>\n<SubscriptionCancel xmlns=\"http://opcfoundation.org/webservices/XMLDA/1.0/\"\n\tServerSubHandle=\"{{{payload.ServerSubHandle}}}\"/> \n</soap:Body>\n</soap:Envelope>\n","output":"str","x":630,"y":260,"wires":[["8daff6d4.368e78"]]},{"id":"29092e47.e835a2","type":"template","z":"a0568e71.72952","name":"Write","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<soap:Envelope \nxmlns:soap=\"http://schemas.xmlsoap.org/soap/envelope/\" \nxmlns:xsd=\"http://www.w3.org/2001/XMLSchema\" \nxmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\">\n<soap:Body>\n <Write xmlns=\"http://opcfoundation.org/webservices/XMLDA/1.0/\"  ReturnValuesOnReply=\"true\">\n  <Options\n    ReturnErrorText=\"true\"\n    ReturnItemTime=\"true\"\n    ReturnItemName=\"true\"\n    ReturnItemPath=\"true\"\n    LocaleID=\"en\" \n    />\n  <ItemList{{#payload.ItemPathExists}} ItemPath=\"{{{payload.ItemPath}}}\"{{/payload.ItemPathExists}}>\n    {{#payload.ItemList}}\n       <Items  ItemName=\"{{{ItemName}}}\"{{#ItemPathExists}} ItemPath=\"{{{ItemPath}}}\"{{/ItemPathExists}}{{#ClientItemHandle}} ClientItemHandle=\"{{{ClientItemHandle}}}\"{{/ClientItemHandle}}>\n            <Value xsi:type=\"{{dataType}}\">{{value}}</Value>\n        </Items>\n    {{/payload.ItemList}}\n  </ItemList>\n </Write>\t  \n</soap:Body>\n</soap:Envelope>\n","output":"str","x":730,"y":140,"wires":[["8daff6d4.368e78"]]},{"id":"700dcd8e.8e42d4","type":"change","z":"a0568e71.72952","name":"header","rules":[{"t":"set","p":"headers","pt":"msg","to":"{\t   \"SOAPAction\":\"http://opcfoundation.org/webservices/XMLDA/1.0/\" & action,\t   \"Content-Type\":\"text/xml\"\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":180,"wires":[["60c6ce6.1d42f3"]]},{"id":"8e60984d.cfcf18","type":"change","z":"a0568e71.72952","name":"SubscriptionPolledRefreshResult","rules":[{"t":"set","p":"payload","pt":"msg","to":"**.SubscriptionPolledRefreshResponse.RItemList.Items.{\t\"ItemName\":$.\"$\".ItemName,\t\"ClientItemHandle\":$.\"$\".ClientItemHandle,\t\"Timestamp\":$.\"$\".Timestamp,\t\"value\": Value.\"_\",\t\"type\": Value.\"$\".\"xsi:type\",\t\"Quality\": Quality[0]\t}[]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":880,"wires":[["6d7a466.2d910b8"]]},{"id":"6f1e64f4.bcbcac","type":"change","z":"a0568e71.72952","name":"SubscriptionCancelResponse","rules":[{"t":"set","p":"payload","pt":"msg","to":"**.SubscriptionCancelResponse.*.ClientRequestHandle{\t\"ClientRequestHandle\":$\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":490,"y":920,"wires":[["2854f3b9.1b98fc"]]},{"id":"2854f3b9.1b98fc","type":"link out","z":"a0568e71.72952","name":"","links":["12f2c851.6e7428"],"x":675,"y":920,"wires":[]},{"id":"2e7040d.343cbc","type":"change","z":"a0568e71.72952","name":"WriteResponse","rules":[{"t":"set","p":"payload","pt":"msg","to":"**.WriteResponse.RItemList.Items.{\t\"ItemName\":$.\"$\".ItemName,\t\"Timestamp\":$.\"$\".Timestamp,\t\"value\": Value.\"_\",\t\"type\": Value.\"$\".\"xsi:type\"\t}[]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":800,"wires":[["6d7a466.2d910b8"]]},{"id":"35897351.3c2adc","type":"change","z":"a0568e71.72952","name":"Status","rules":[{"t":"set","p":"payload","pt":"msg","to":"**.Status{\t\"StatusInfo\":StatusInfo,\t\"VendorInfo\":VendorInfo,\t\"SupportedLocaleIDs\":SupportedLocaleIDs,\t\"SupportedInterfaceVersions\":SupportedInterfaceVersions,\t\"StartTime\":*.StartTime,\t\"ProductVersion\":*.ProductVersion,\t\"ServerState\":$$.**.ServerState\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":720,"wires":[["a38f31fa.bd3fc"]]},{"id":"a38f31fa.bd3fc","type":"change","z":"a0568e71.72952","name":"string cleanup","rules":[{"t":"set","p":"payload","pt":"msg","to":"/* Straight strings or \"xsd:string\" */\t(\t$clean := function($o) {$join([\t$filter($o, function($v,$i,$a) {\"xsi:type\" in $keys($v.\"$\") ? true: false}).\"_\",\t$filter($o, function($v,$i,$a) {\"xsi:type\" in $keys($v.\"$\") ? false: true})\t], \",\")};\t{\t\"StatusInfo\": $clean(payload.StatusInfo),\t\"VendorInfo\": $clean(payload.VendorInfo),\t\"SupportedLocaleIDs\": $clean(payload.SupportedLocaleIDs),\t\"SupportedInterfaceVersions\": $clean(payload.SupportedInterfaceVersions),\t\"StartTime\":payload.StartTime,\t\"ProductVersion\":payload.ProductVersion,\t\"ServerState\":payload.ServerState\t}\t\t)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":720,"wires":[["f713686b.a04448"]]},{"id":"14b7deacbb35defc","type":"change","z":"a0568e71.72952","name":"ItemPath","rules":[{"t":"set","p":"payload","pt":"msg","to":"/*Global ItemPath*/ \t/*Add info about existing ItemPath for compatability with following template node mustache syntax */\t(\t    $merge(\t       [\t           { \"ItemPathExists\": \"ItemPath\" in $keys(payload) },\t           payload\t]\t)\t)","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"/* Single Item's ItemPath */ \t/*Add info about existing ItemPath for compatability with following template node mustache syntax */\t(\t   payload  ~> | ItemList |  {\"ItemPathExists\": \"ItemPath\" in $keys()} | ;\t)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":140,"wires":[["29092e47.e835a2"]]},{"id":"b1208d512d65cbf5","type":"comment","z":"a0568e71.72952","name":"Soap Envelope","info":"Construct SOAP Envelope depending on opcxml action\n\nNote:\nServer sometimes are quity specific on how to handle the ItemPath property. An empty ItemPath is not always treated the same as a non existing. Use GetProperties action to find what is correct in a specific use case.\n","x":420,"y":60,"wires":[]},{"id":"aad2bdb495d0b9ff","type":"comment","z":"a0568e71.72952","name":"Parse Response","info":"","x":200,"y":720,"wires":[]},{"id":"3692f15954804177","type":"change","z":"a0568e71.72952","name":"ItemPath","rules":[{"t":"set","p":"payload","pt":"msg","to":"/*Global ItemPath*/ \t/*Add info about existing ItemPath for compatability with following template node mustache syntax */\t(\t    $merge(\t       [\t           { \"ItemPathExists\": \"ItemPath\" in $keys(payload) },\t           payload\t]\t)\t)","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"/* Single Item's ItemPath */ \t/*Add info about existing ItemPath for compatability with following template node mustache syntax */\t(\t   payload  ~> | ItemList |  {\"ItemPathExists\": \"ItemPath\" in $keys()} | ;\t)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":100,"wires":[["57f9a1f9.97185"]]},{"id":"03dd49412e5cd404","type":"comment","z":"a0568e71.72952","name":"updated 2023-05-19","info":"2019-10-16\n-Published\n\n2023-05-19\n-Fix transform to Soap Envelope for correct handling of empty ItemPath\n-GetProperties parsing all returned properties\n-Tested with .NET server implementation","x":110,"y":60,"wires":[]},{"id":"6e4bf104204f9aa3","type":"subflow:a0568e71.72952","z":"f6f2187d.f17ca8","name":"Write","env":[{"name":"action","value":"Write","type":"str"}],"x":350,"y":300,"wires":[["7fa8e71f09c9d06a"]]},{"id":"7fa8e71f09c9d06a","type":"debug","z":"f6f2187d.f17ca8","name":"debug 23","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":520,"y":300,"wires":[]},{"id":"3a6336ea551b4ca9","type":"inject","z":"f6f2187d.f17ca8","name":".NET Write Int","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"url","v":"http://opcxml.demo-this.com/XmlDaSampleServer/Service.asmx","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":".NET Write Int","payload":"{\"ItemList\":[{\"ItemPath\":\"\",\"ItemName\":\"Static/Analog Types/Int\",\"dataType\":\"xsd:int\",\"value\":17}]}","payloadType":"json","x":170,"y":300,"wires":[["6e4bf104204f9aa3"]]},{"id":"4ed8937a610e4be3","type":"inject","z":"f6f2187d.f17ca8","name":".NET Browse","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"url","v":"http://opcxml.demo-this.com/XmlDaSampleServer/Service.asmx","vt":"str"},{"p":"action","v":"Browse","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":".NET Browse","payload":"{\"ItemName\":\"Dynamic/Analog Types\"}","payloadType":"json","x":170,"y":100,"wires":[["bea53f5322453c94"]]},{"id":"bea53f5322453c94","type":"subflow:a0568e71.72952","z":"f6f2187d.f17ca8","name":"","env":[{"name":"action","value":"","type":"str"}],"x":440,"y":100,"wires":[["4b9be65ae2378baa"]]},{"id":"92aef6f0714573ce","type":"inject","z":"f6f2187d.f17ca8","name":"Advosol Browse","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"url","v":"http://info.advosol.com/XMLDADemo/TS_Sim/OpcDAGateway.asmx","vt":"str"},{"p":"action","v":"Browse","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Advosol Browse","payload":"{\"ItemName\":\"Dynamic.Analog Types\"}","payloadType":"json","x":180,"y":140,"wires":[["bea53f5322453c94"]]},{"id":"b34fb3cfc357a685","type":"inject","z":"f6f2187d.f17ca8","name":".NET GetProperties","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"url","v":"http://opcxml.demo-this.com/XmlDaSampleServer/Service.asmx","vt":"str"},{"p":"action","v":"GetProperties","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":".NET GetProperties","payload":"{\"ItemPath\":\"\",\"ItemName\":\"Dynamic/Analog Types/Double\"}","payloadType":"json","x":190,"y":180,"wires":[["bea53f5322453c94"]]},{"id":"3d0009309f37a86f","type":"inject","z":"f6f2187d.f17ca8","name":".NET Read Int","props":[{"p":"payload"},{"p":"topic","vt":"str"},{"p":"url","v":"http://opcxml.demo-this.com/XmlDaSampleServer/Service.asmx","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":".NET Read Int","payload":"{\"ItemList\":[{\"ItemPath\":\"\",\"ItemName\":\"Static/Analog Types/Int\"}]}","payloadType":"json","x":170,"y":260,"wires":[["83e030279f6f0938"]]},{"id":"83e030279f6f0938","type":"subflow:a0568e71.72952","z":"f6f2187d.f17ca8","name":"Read","env":[{"name":"action","value":"Read","type":"str"}],"x":350,"y":260,"wires":[["5d06a5c01db06f3f"]]},{"id":"5d06a5c01db06f3f","type":"debug","z":"f6f2187d.f17ca8","name":"debug 35","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload[0]","targetType":"msg","statusVal":"","statusType":"auto","x":520,"y":260,"wires":[]},{"id":"02a536aa1b08d42e","type":"comment","z":"f6f2187d.f17ca8","name":"OPC XML Client Examples","info":"","x":190,"y":40,"wires":[]},{"id":"4b9be65ae2378baa","type":"debug","z":"f6f2187d.f17ca8","name":"debug 34","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":600,"y":100,"wires":[]}]
Created 7 years, 7 months ago
Updated 3 years, 8 months ago
  • catch (x1)
  • change (x20)
  • comment (x6)
  • debug (x3)
  • function (x6)
  • http request (x1)
  • inject (x5)
  • join (x1)
  • link in (x3)
  • link out (x8)
  • split (x1)
  • switch (x5)
  • template (x8)
  • xml (x1)
  • subflow (x1)
  • subflow:a0568e71.72952 (x3)
  • opcxml
