CRC16 modbus rtu
Funtion block that adds CRC 16 checksum to modbus rtu command. Example:
input: 010600010100 output: 010600010100D99A
[{"id":"e6126f89.fbab88","type":"tab","label":"modbus rtu crc","disabled":false,"info":""},{"id":"7812b725.54f17","type":"function","z":"e6126f89.fbab88","name":"CRC16-modbus","func":"var CRCMaster = {\n    StringToCheck: \"\",\n    CleanedString: \"\",\n    CRCTableDNP: [],\n    init: function() {\n        this.CRCDNPInit();\n    },\n    CleanString: function(inputType) {\n        if (inputType == \"ASCII\") {\n            this.CleanedString = this.StringToCheck;\n        } else {\n            if (this.StringToCheck.match(/^[0-9A-F \\t]+$/gi) !== null) {\n                this.CleanedString = this._hexStringToString(this.StringToCheck.toUpperCase().replace(/[\\t ]/g, ''));\n            } else {\n                window.alert(\"String doesn't seem to be a valid Hex input.\");\n                return false;\n            }\n        }\n        return true;\n    },\n    CRCDNPInit: function() {\n        var i, j, crc, c;\n        for (i = 0; i < 256; i++) {\n            crc = 0;\n            c = i;\n            for (j = 0; j < 8; j++) {\n                if ((crc ^ c) & 0x0001) crc = (crc >> 1) ^ 0xA6BC;\n                else crc = crc >> 1;\n                c = c >> 1;\n            }\n            this.CRCTableDNP[i] = crc;\n        }\n    },\n    CRC16Modbus: function() {\n        var crc = 0xFFFF;\n        var str = this.CleanedString;\n        for (var pos = 0; pos < str.length; pos++) {\n            crc ^= str.charCodeAt(pos);\n            for (var i = 8; i !== 0; i--) {\n                if ((crc & 0x0001) !== 0) {\n                    crc >>= 1;\n                    crc ^= 0xA001;\n                } else\n                    crc >>= 1;\n            }\n        }\n        return crc;\n    },\n    _stringToBytes: function(str) {\n        var ch, st, re = [];\n        for (var i = 0; i < str.length; i++) {\n            ch = str.charCodeAt(i); // get char\n            st = []; // set up \"stack\"\n            do {\n                st.push(ch & 0xFF); // push byte to stack\n                ch = ch >> 8; // shift value down by 1 byte\n            }\n            while (ch);\n            // add stack contents to result\n            // done because chars have \"wrong\" endianness\n            re = re.concat(st.reverse());\n        }\n        // return an array of bytes\n        return re;\n    },\n    _hexStringToString: function(inputstr) {\n        var hex = inputstr.toString(); //force conversion\n        var str = '';\n        for (var i = 0; i < hex.length; i += 2)\n            str += String.fromCharCode(parseInt(hex.substr(i, 2), 16));\n        return str;\n    },\n    Calculate: function(str, inputType) {\n        this.StringToCheck = str;\n        if (this.CleanString(inputType)) {\n            crcinputcrc16modbus=this.CRC16Modbus().toString(16).toUpperCase();\n            crcinputcrc16modbus=crcinputcrc16modbus.substr(2) + crcinputcrc16modbus.substr(0, 2); //swap bytes\n   \n        }\n    }\n};\n\nCRCMaster.init();\n\nvar inputType = \"HEX\";\nvar crcinputcrc16modbus;\nvar crcinput = msg.payload;\n\nCRCMaster.Calculate(crcinput, inputType);\n\nmsg.payload = crcinput + crcinputcrc16modbus;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":660,"y":380,"wires":[["da260a66.2e0fb"]]},{"id":"265c58e5.dc37a","type":"inject","z":"e6126f89.fbab88","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"010600010100","payloadType":"str","x":400,"y":380,"wires":[["7812b725.54f17"]]},{"id":"da260a66.2e0fb","type":"debug","z":"e6126f89.fbab88","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":900,"y":380,"wires":[]}]
Created 5 years, 11 months ago
Rating: 5 2
  • modbus
  • rtu
  • crc
