PM1.0, PM2.5, PM10 detector, air quality sensor: smart custom device
tuyaDEAMON is a rich framework for IoT, offering to the user-programmer a powerful event processor, and many ways to implement their own projects.
In this case, the objectify was the integration of a standalone device, a PM detector that uses the USB-serial, i.e. the design and realization of a custom smart device for the tuyaDEAMON IOT server using that, not MQTT, HW device.
device
The process steps, fully documented in the case study, are:
  1. Install the native app in WIN10 and test the device.
  2. Reverse engineering of the serial protocol.
  3. Custom device capabilities definitions (i.e. DPs).
  4. node-red implementation:
flow
  • For a documentation sheet about the custom device PM_detector see github
  • For PM_detector details, protocol, etc: see here.
  • For tuyaDAEMON capabilities, see Wiki.
[{"id":"ee953c15.ada29","type":"subflow","name":"static retry","info":"Handles tuya device status changes.\r\n\r\nProcesses the status of a real device , if the connection status changes:\r\n   - Creates a log msg (deviceId, \"_connected\", true/false) for standard processing\r\n \r\nIMPORTANT: set the ** deviceID ** parameter with the correct ID value.","category":"","in":[{"x":80,"y":80,"wires":[{"id":"6160136.f5f99ec"}]}],"out":[{"x":440,"y":80,"wires":[{"id":"6160136.f5f99ec","port":0}]}],"env":[{"name":"deviceId","type":"str","value":""}],"color":"#DDAA99","inputLabels":["in staus"],"outputLabels":["to log"],"icon":"font-awesome/fa-rss-square"},{"id":"6160136.f5f99ec","type":"function","z":"ee953c15.ada29","name":"connected message - static","func":"// to set global.tuyasyatus.xxxx._connected \n// creates a response for the dp \"_connected\"\n// store value and filter events\n\nvar CONN = \"_connected\";  //  tuyadaemon internal define\n// see also tuyaDAEMON.\"connection check\" function\n// local function\nfunction _sendReal(idevice,  value){\n// builds a fake OUT message \nvar newMsg = { \"payload\":{\n      \"deviceId\": idevice,\n      \"data\": {\n          \"dps\":{\n            [CONN]:value\n          }}}};\nreturn newMsg;  \n}\n\n// user set parameter device id\nvar deviceId = env.get(\"deviceId\");\nvar nowconnected =  (msg.status.text == \"connected\");        // can change\n// filering \nlet old = flow.get(deviceId+\"_con\");\nif (old === nowconnected) return null;\nflow.set(deviceId+\"_con\", nowconnected);\n\nreturn(_sendReal(deviceId, nowconnected));\n\n\n\n\n\n","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// set the default status _connected to null in tuyastatus\n// creates tuyastatus entry to null.\nvar alldevices = global.get(\"alldevices\");\nif (alldevices === undefined) return null;\nvar deviceId = env.get(\"deviceId\");\n// only for REAL devices\nvar d = alldevices.real.find(device => device.id === deviceId);\nif (d === undefined) return null;\n//\nvar tuyastatus = global.get(\"tuyastatus\");\n    if (tuyastatus === undefined)\n        tuyastatus = {};\n    var dev = (d.name?d.name:d.id);\n    if (tuyastatus[dev] === undefined) {\n        tuyastatus[dev] = {_connected:null};\n        global.set(\"tuyastatus\", tuyastatus);\n    }\n    ","finalize":"","x":260,"y":80,"wires":[[]]},{"id":"ee008879.f5adc8","type":"tab","label":"custom.PM detector","disabled":false,"info":"**custom device PM detector\n\nFlow to use a USB-serial PM detector with tuyaDAEMON. \n\nsee: https://github.com/msillano/tuyaDAEMON/wiki/custom-device-'PM-detector':-case-study"},{"id":"e37f5692.37de78","type":"serial in","z":"ee008879.f5adc8","name":"*COM19","serial":"45a4b402.6f7e4c","x":820,"y":380,"wires":[["170c898c.35c906","3787ab01.6ee494"]]},{"id":"28f4d04b.ed1b7","type":"serial out","z":"ee008879.f5adc8","name":"*COM19","serial":"45a4b402.6f7e4c","x":820,"y":300,"wires":[]},{"id":"fa5e5a63.b11488","type":"function","z":"ee008879.f5adc8","name":"pick and execute","func":"// converts the msg (dp/set) to serial format required by PM2.5USB\nfunction formatI(n) { // local function\n    return (n > 99 ? \"\" + n : (n > 9 ? \"0\" + n : \"00\" + n));\n}\n\n// returns now(), formatted for mySQL, never fails\nfunction _mySQLdatetime() {\n    //datetime format for mySQL: '2020-12-18 20:45:02'\n    // using 'sv' for date format (but local timezone)\n    return (new Date().toLocaleString('sv'));\n}\n\nfunction isNone(value) { // for resetCycle\n    if (value) {\n        if (typeof(value) === \"string\") {\n            if (value.toUpperCase() === 'OFF')\n                return true;\n            if (value.toUpperCase() === 'NO')\n                return true;\n            if (value.toUpperCase() === 'NONE')\n                return true;\n        }\n        return false;\n    }\n    return true;\n}\n\n// test: idDev SET command?\nfunction _isSetCommand(msx) {\n    return ((msx.payload.property !== undefined) && (msx.payload.value !== undefined));\n}\n\n// test: idDev GET command?\nfunction _isGetCommand(msx) {\n    return ((msx.payload.property !== undefined) && (msx.payload.value === undefined));\n}\n\nconst FASTDP = \"_refreshCycle\"; // set: 'off'| time [s]\nconst REFDP = \"_refresh\"; // set: any (trigger)\nconst DEVIDPM1 = \"_PM1_USB\";\n//base message to log\nvar newMsg = {\n    payload: {\n        deviceId: DEVIDPM1,\n        data: {\n            dps: {}\n        }\n    }\n};\n\n// ---------------  main\n// fast exit\nif (msg.to !== DEVIDPM1)\n    return ([null]);\n\n// from property/value to serial for PM detector\nif (_isSetCommand(msg)) { // test: is SET\n    // node.warn([\"INPUT cmd\", msg ]);\n    var data = \"\";\n    switch (msg.infodp) {\n    case REFDP:\n        data = {\n            fun: \"05\",\n            flag: flow.set(\"pm_1\")\n        }\n        msg.payload.value = \"done\";\n        break;\n    case \"1\":\n        flow.set(\"pm_\" + msg.infodp, msg.payload.value);\n        data = {\n            fun: \"01\",\n            sendtime: formatI(msg.payload.value)\n        }\n        break;\n    case FASTDP:\n        if (isNone(msg.payload.value)) {\n            data = {\n                fun: \"05\",\n                flag: \"0\"\n            };\n            flow.set(\"pm_5\", \"0\");\n            msg.payload.value = \"stop\";\n            break;\n        }\n        flow.set(\"pm_1\", msg.payload.value);\n        data = {\n            fun: \"01\",\n            sendtime: formatI(msg.payload.value)\n        };\n        msg.payload = JSON.stringify(data);\n        node.send([msg]);\n        flow.set(\"pm_5\", \"1\");\n        data = {\n                fun: \"05\",\n                flag: \"1\"\n            };\n        break;\n    case \"2\":\n        flow.set(\"pm_\" + msg.payload.dp, msg.payload.value);\n        data = {\n            fun: \"02\",\n            storetime: formatI(msg.payload.value)\n        }\n        break;\n    case \"3\":\n        if ((msg.payload.value === undefined) || (msg.payload.value == false))\n            msg.payload.value = _mySQLdatetime().substring(2);\n        data = {\n            fun: \"03\",\n            clock: msg.payload.value\n        }\n        break;\n    case \"4\":\n        data = {\n            fun: \"04\"\n        }\n        msg.payload.value = \"done\"; // is trigger\n        break;\n    case \"5\":\n        msg.payload.value = msg.payload.value ? \"1\" : \"0\";\n        flow.set(\"pm_\" + msg.infodp, msg.payload.value);\n        data = {\n            fun: \"05\",\n            flag: (msg.payload.value ? \"1\" : \"0\")\n        }\n        break;\n    case \"6\":\n        data = {\n            fun: \"06\"\n        }\n        msg.payload.value = \"done\"; // is trigger\n        break;\n    default:\n        node.warn(\"The SET command '\" + msg.payload.property + \"'(\" + msg.infodp + \") => '\" + msg.payload.value + \"' is not allowed for PM detector device '\");\n        return;\n    }\n    newMsg.payload.data.dps[msg.infodp] = msg.payload.value;\n    msg.payload = JSON.stringify(data);\n    return [msg, newMsg];\n}\n\nif (_isGetCommand(msg)) { // test: is GET\n    switch (msg.infodp) {\n    case \"1\":\n    case \"2\":\n    case \"3\":\n    case \"5\":\n        newMsg.payload.data.dps[msg.infodp] = flow.get(\"pm_\" + msg.infodp);\n        return [null, newMsg];\n    case \"80\":\n        msg.payload = '{\"fun\":\"80\"}';\n        return [msg];\n    case FASTDP:\n        newMsg.payload.data.dps[msg.infodp] = flow.get(\"pm_1\");\n        return [null, newMsg];\n\n    }\n    node.warn(\"The GET command '\" + msg.payload.property + \"'(\" + msg.infodp + \") is not allowed for PM detector device '\");\n    return;\n}\n","outputs":2,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is deployed.\nflow.set(\"skipdata\", false);\n// set as connected\n// --------------- locals\nfunction _callJSONMethod(obj, fname, a, b, c, d) {\n    var wrap = s => \"{ return \" + obj[fname] + \" };\" //return the block having function expression\n    var func = new Function(wrap(obj[fname]));       // ignore ⚠\n    return func.call(null).call(obj, a, b, c, d);    //invoke the function using arguments\n}\n\n// ---------------- main\nvar PMd = \"_PM1_USB\"; // can have friendly name\n// stuff to access data\nvar alld = global.get(\"alldevices\");\nif (alld === undefined)\n    return null;\n// find object dp\nvar oDev = _callJSONMethod(alld, \"__getODev\", PMd, \"fake\");\nvar pmDevName = _callJSONMethod(alld, \"__getDevName\", oDev);\n//\ntuyastatus = global.get(\"tuyastatus\");\nif (tuyastatus === undefined)\n    tuyastatus = {};\nif (tuyastatus[pmDevName] === undefined)\n    tuyastatus[pmDevName] = {};\n// init\ntuyastatus[pmDevName][\"_connected\"] = true;\nglobal.set(\"tuyastatus\", tuyastatus);\n","finalize":"","x":170,"y":320,"wires":[["8ce5e629.3c5ef8"],["e914f703.e257b8"]]},{"id":"170c898c.35c906","type":"function","z":"ee008879.f5adc8","name":"RT data processing","func":"// convert serial data from PM2.5 to usual format\n// payload: object\n//     deviceId: \"123455aa196ae5******\"\n//     data: object\n//        t: 1609234903\n//        dps: object\n//           102: 1020\n//\nvar answ = {\n    deviceId: \"_PM1_USB\",\n    data : {\n          t : Math.floor(Date.now() / 1000),\n          dps : {\n              \n          }\n       }\n    }\n\nvar data = JSON.parse(msg.payload.replace(\",}\",\"}\")); \n\nswitch (data.res) {\n        case \"1\":\n        case \"2\":\n        case \"3\":\n              answ.data.dps[data.res] = flow.get(\"pm_\"+data.res);\n              break;\n        case \"5\":\n              answ.data.dps[data.res] =  \" done \";\n              break;\n        case \"4\":\n              if (flow.get(\"skipdata\")) return;\n              if (Number(data[\"cpm1.0\"]) == 0) return;  // bad data\n              answ.data.dps = {\n                 200: Number(data[\"cpm1.0\"]),\n                 201: Number(data[\"cpm2.5\"]),\n                 202: Number(data[\"cpm10\"]),\n                 203: Number(data[\"apm1.0\"]),\n                 204: Number(data[\"apm2.5\"]),\n                 205: Number(data[\"apm10\"]),\n                 206: Number(data[\"aqi\"]),\n                 207: data[\"t\"],\n                 208: Number(data[\"r\"])\n              }\n              break;\n        case \"6\":\n              answ.data.dps[data.res] = \"done \";\n              break;\n        case \"10\":       // start historical data\n              flow.set(\"skipdata\", true);\n              return;\n        case \"80\":\n              answ.data.dps = {\n                 1 : Number(data[\"SendInteralTime\"]),\n                 2 : Number(data[\"StoreInteralTime\"]),\n                 80: Number(data[\"WritePoint\"]),\n                 81: Number(data[\"ReadPoint\"]),\n                 82: Number(data[\"SendInteralFlag\"])\n              }\n              break;\n\n   }\nmsg.payload = answ;    \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1070,"y":420,"wires":[["c72cf7d0.7ff3c8"]]},{"id":"bf4e83f7.f5f21","type":"link in","z":"ee008879.f5adc8","name":"from core.fake_cmds","links":["18817677.061b9a","96b99b98.5c7788"],"x":35,"y":320,"wires":[["fa5e5a63.b11488"]]},{"id":"c72cf7d0.7ff3c8","type":"link out","z":"ee008879.f5adc8","name":"to core.logging","links":["9fe80f7e.f3f7e"],"x":1275,"y":420,"wires":[]},{"id":"7a6b37c.31c36c8","type":"timerswitch","z":"ee008879.f5adc8","name":"every hour","ontopic":"","offtopic":"","onpayload":"{\"fun\":\"05\",\"flag\":\"0\"}","offpayload":"null","disabled":false,"schedules":[{"on_h":"00","on_m":"58","on_s":"00","off_h":"00","off_m":"59","off_s":"00","valid":true},{"on_h":"01","on_m":"58","on_s":"00","off_h":"01","off_m":"59","off_s":"00","valid":true},{"on_h":"02","on_m":"58","on_s":"00","off_h":"02","off_m":"59","off_s":"00","valid":true},{"on_h":"03","on_m":"58","on_s":"00","off_h":"03","off_m":"59","off_s":"00","valid":true},{"on_h":"04","on_m":"58","on_s":"00","off_h":"04","off_m":"59","off_s":"00","valid":true},{"on_h":"05","on_m":"58","on_s":"00","off_h":"05","off_m":"59","off_s":"00","valid":true},{"on_h":"06","on_m":"58","on_s":"00","off_h":"06","off_m":"59","off_s":"00","valid":true},{"on_h":"07","on_m":"58","on_s":"00","off_h":"07","off_m":"59","off_s":"00","valid":true},{"on_h":"08","on_m":"58","on_s":"00","off_h":"08","off_m":"59","off_s":"00","valid":true},{"on_h":"09","on_m":"58","on_s":"00","off_h":"09","off_m":"59","off_s":"00","valid":true},{"on_h":"10","on_m":"58","on_s":"00","off_h":"10","off_m":"59","off_s":"00","valid":true},{"on_h":"11","on_m":"58","on_s":"00","off_h":"11","off_m":"59","off_s":"00","valid":true},{"on_h":"12","on_m":"58","on_s":"00","off_h":"12","off_m":"59","off_s":"00","valid":true},{"on_h":"13","on_m":"58","on_s":"00","off_h":"13","off_m":"59","off_s":"00","valid":true},{"on_h":"14","on_m":"58","on_s":"00","off_h":"14","off_m":"59","off_s":"00","valid":true},{"on_h":"15","on_m":"58","on_s":"00","off_h":"15","off_m":"59","off_s":"00","valid":true},{"on_h":"16","on_m":"58","on_s":"00","off_h":"16","off_m":"59","off_s":"00","valid":true},{"on_h":"17","on_m":"58","on_s":"00","off_h":"17","off_m":"59","off_s":"00","valid":true},{"on_h":"18","on_m":"58","on_s":"00","off_h":"18","off_m":"59","off_s":"00","valid":true},{"on_h":"19","on_m":"58","on_s":"00","off_h":"19","off_m":"59","off_s":"00","valid":true},{"on_h":"20","on_m":"58","on_s":"00","off_h":"20","off_m":"59","off_s":"00","valid":true},{"on_h":"21","on_m":"58","on_s":"00","off_h":"21","off_m":"59","off_s":"00","valid":true},{"on_h":"22","on_m":"58","on_s":"00","off_h":"22","off_m":"59","off_s":"00","valid":true},{"on_h":"23","on_m":"58","on_s":"00","off_h":"23","off_m":"59","off_s":"00","valid":true}],"x":415,"y":280,"wires":[["bb7ed790.b50db8","8ce5e629.3c5ef8"]],"l":false},{"id":"bb7ed790.b50db8","type":"delay","z":"ee008879.f5adc8","name":"","pauseType":"delay","timeout":"200","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":590,"y":240,"wires":[["5a5d640b.67b15c"]]},{"id":"5a5d640b.67b15c","type":"function","z":"ee008879.f5adc8","name":"start dump","func":"var sum = {\n    \"cpm1.0\":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],\n    \"cpm2.5\":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],\n    \"cpm10\" :[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],\n    \"apm1.0\":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],\n    \"apm2.5\":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],\n    \"apm10\" :[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],\n    \"aqi\"   :[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],\n    \"t\"     :[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],\n    \"r\"     :[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],\n}\nvar count =  [0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0];\n\nflow.set(\"sum\",sum);\nflow.set(\"count\",count);\nmsg.payload ={\"fun\":\"04\"};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":830,"y":240,"wires":[["8ce5e629.3c5ef8"]]},{"id":"3787ab01.6ee494","type":"function","z":"ee008879.f5adc8","name":"Historical data processing","func":"\nif(flow.get(\"skipdata\") === false) return;\n\n// out: cmd/histo\nvar data = JSON.parse(msg.payload);\n\nvar answ = {\n    deviceId: \"_PM1_USB\",\n    data: {\n        t: Math.floor(Date.now() / 1000),\n        dps: {}\n    }\n}\n\nvar cmd = {\n    payload: {\n        \"fun\":\"05\", \n        \"flag\":\"1\"\n    }\n}\n\nswitch (data.res) {\n\ncase \"0\":   // end historical data\n    sum = flow.get(\"sum\");\n    count = flow.get(\"count\");\n    for (i = 0; i < 24; i++) {\n        if (count[i] > 0) {\n            sum[\"cpm1.0\"][i] = Math.round(sum[\"cpm1.0\"][i] / count[i]);\n            sum[\"cpm2.5\"][i] = Math.round(sum[\"cpm2.5\"][i] / count[i]);\n            sum[\"cpm10\"][i]  = Math.round(sum[\"cpm10\"][i] / count[i]);\n            sum[\"apm1.0\"][i] = Math.round(sum[\"apm1.0\"][i] / count[i]);\n            sum[\"apm2.5\"][i] = Math.round(sum[\"apm2.5\"][i] / count[i]);\n            sum[\"apm10\"][i]  = Math.round(sum[\"apm10\"][i] / count[i]);\n            sum[\"aqi\"][i]    = Math.round(sum[\"aqi\"][i] / count[i]);\n            sum[\"t\"][i]      = (sum[\"t\"][i] / count[i]).toFixed(1);\n            sum[\"r\"][i]      = (sum[\"r\"][i] / count[i]).toFixed(1);\n        }\n    }\n    answ.data.dps[300] = \"[\"+sum[\"cpm1.0\"].toString() + \"]\";\n    answ.data.dps[301] = \"[\"+sum[\"cpm2.5\"].toString() + \"]\";\n    answ.data.dps[302] = \"[\"+sum[\"cpm10\"].toString() + \"]\";\n    answ.data.dps[303] = \"[\"+sum[\"apm1.0\"].toString() + \"]\";\n    answ.data.dps[304] = \"[\"+sum[\"apm2.5\"].toString() + \"]\";\n    answ.data.dps[305] = \"[\"+sum[\"apm10\"].toString() + \"]\";\n    answ.data.dps[306] = \"[\"+sum[\"aqi\"].toString() + \"]\";\n    answ.data.dps[307] = \"[\"+sum[\"t\"].toString() + \"]\";\n    answ.data.dps[308] = \"[\"+sum[\"r\"].toString() + \"]\";\n    msg.payload = answ;\n    flow.set(\"skipdata\", false);\n    return [cmd, msg];\n\ncase \"4\":\n    sum = flow.get(\"sum\");\n    count = flow.get(\"count\");\n    count[Number(data[\"h\"])]++;\n    sum[\"cpm1.0\"][Number(data[\"h\"])] += Number(data[\"cpm1.0\"]);\n    sum[\"cpm2.5\"][Number(data[\"h\"])] += Number(data[\"cpm2.5\"]);\n    sum[\"cpm10\"][Number(data[\"h\"])]  += Number(data[\"cpm10\"]);\n    sum[\"apm1.0\"][Number(data[\"h\"])] += Number(data[\"apm1.0\"]);\n    sum[\"apm2.5\"][Number(data[\"h\"])] += Number(data[\"apm2.5\"]);\n    sum[\"apm10\"][Number(data[\"h\"])]  += Number(data[\"apm10\"]);\n    sum[\"aqi\"][Number(data[\"h\"])]    += Number(data[\"aqi\"]);\n    sum[\"t\"][Number(data[\"h\"])]      += Number(data[\"t\"]);\n    sum[\"r\"][Number(data[\"h\"])]      += Number(data[\"r\"]);\n\n    flow.set(\"sum\", sum);\n    flow.set(\"count\", count);\n    return;\n\ncase \"10\":\n    return;\n}\nreturn;\n","outputs":2,"noerr":0,"initialize":"","finalize":"","x":1090,"y":380,"wires":[["8ce5e629.3c5ef8"],["c72cf7d0.7ff3c8"]]},{"id":"260f2555.1d5ffa","type":"status","z":"ee008879.f5adc8","name":"spy status","scope":["e37f5692.37de78","28f4d04b.ed1b7"],"x":820,"y":480,"wires":[["bcf0461e.c12788"]]},{"id":"bcf0461e.c12788","type":"subflow:ee953c15.ada29","z":"ee008879.f5adc8","name":"","env":[{"name":"deviceId","value":"_PM1_USB","type":"str"},{"name":"deviceID","value":"bfb073b1b789b5994cro7p","type":"str"}],"x":1050,"y":480,"wires":[["4fb32195.592ef"]]},{"id":"4fb32195.592ef","type":"link out","z":"ee008879.f5adc8","name":"to core.more_devices_in","links":["c90b7eb2.07595"],"x":1275,"y":480,"wires":[]},{"id":"21a669e.61ac096","type":"inject","z":"ee008879.f5adc8","name":"CLEAR MEMORY","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"01 00 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"{\"fun\":\"06\"}","payloadType":"json","x":415,"y":380,"wires":[["8ce5e629.3c5ef8"]],"icon":"node-red-contrib-eztimer/datetime.png","l":false},{"id":"ce13d88d.13bf18","type":"inject","z":"ee008879.f5adc8","name":"TEST Historical","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"fun\":\"05\",\"flag\":\"0\"}","payloadType":"json","x":180,"y":280,"wires":[["bb7ed790.b50db8","8ce5e629.3c5ef8"]]},{"id":"608b2442.af601c","type":"comment","z":"ee008879.f5adc8","name":"custom 'PM detector '","info":"Flow to control the 'PM detector' via USB-serial\n\nsee: https://github.com/msillano/tuyaDAEMON/wiki/custom-device-'PM-detector':-case-study","x":160,"y":60,"wires":[]},{"id":"7454f585.417bcc","type":"link in","z":"ee008879.f5adc8","name":"from system.start_DAEMON","links":["37306de6.0a7f42"],"x":355,"y":100,"wires":[["d53018ba.5b1448"]]},{"id":"1282a87d.494a98","type":"change","z":"ee008879.f5adc8","name":"init sendtime","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"device\":\"PM detector\",\"property\":\"sendtime\",\"value\":\"120\"}","tot":"json"},{"t":"set","p":"to","pt":"msg","to":"_PM1_USB","tot":"str"},{"t":"set","p":"infodp","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":40,"wires":[["96b99b98.5c7788","271a5b46.b66224"]]},{"id":"271a5b46.b66224","type":"change","z":"ee008879.f5adc8","name":"Init storetime","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"device\":\"PM detector\",\"property\":\"storetime\",\"value\":\"700\"}","tot":"json"},{"t":"set","p":"to","pt":"msg","to":"_PM1_USB","tot":"str"},{"t":"set","p":"infodp","pt":"msg","to":"2","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":80,"wires":[["96b99b98.5c7788","b9e8d491.2f8e58"]]},{"id":"136ad89e.c0d117","type":"change","z":"ee008879.f5adc8","name":"Init RT","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"device\":\"PM detector\",\"property\":\"startRT\",\"value\":\"1\"}","tot":"json"},{"t":"set","p":"to","pt":"msg","to":"_PM1_USB","tot":"str"},{"t":"set","p":"infodp","pt":"msg","to":"5","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":160,"wires":[["96b99b98.5c7788"]]},{"id":"2ebe64d5.26754c","type":"link out","z":"ee008879.f5adc8","name":"to core.std_cmd","links":["8a1da02d.424ae"],"x":355,"y":520,"wires":[]},{"id":"eefb4a7d.922138","type":"inject","z":"ee008879.f5adc8","name":"STOP RT","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"device\":\"_PM1_USB\",\"property\":\"5\",\"value\":\"OFF\"}","payloadType":"json","x":160,"y":460,"wires":[["2ebe64d5.26754c"]]},{"id":"db6536d1.c90638","type":"inject","z":"ee008879.f5adc8","name":"START RT","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"device\":\"_PM1_USB\",\"property\":\"5\",\"value\":\"ON\"}","payloadType":"json","x":160,"y":500,"wires":[["2ebe64d5.26754c"]]},{"id":"b9e8d491.2f8e58","type":"change","z":"ee008879.f5adc8","name":"Init clock","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"device\":\"PM detector\",\"property\":\"set clock\",\"value\":\"\"}","tot":"json"},{"t":"set","p":"to","pt":"msg","to":"_PM1_USB","tot":"str"},{"t":"set","p":"infodp","pt":"msg","to":"3","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":120,"wires":[["96b99b98.5c7788","136ad89e.c0d117"]]},{"id":"96b99b98.5c7788","type":"link out","z":"ee008879.f5adc8","name":"to in cmd","links":["bf4e83f7.f5f21"],"x":915,"y":140,"wires":[],"icon":"font-awesome/fa-expand"},{"id":"a4c72b18.762b68","type":"inject","z":"ee008879.f5adc8","name":"FAST RT","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"device\":\"_PM1_USB\",\"property\":\"1\",\"value\":20}","payloadType":"json","x":160,"y":540,"wires":[["2ebe64d5.26754c"]]},{"id":"43e311a3.08147","type":"inject","z":"ee008879.f5adc8","name":"SLOW RT","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"device\":\"_PM1_USB\",\"property\":\"1\",\"value\":120}","payloadType":"json","x":160,"y":580,"wires":[["2ebe64d5.26754c"]]},{"id":"e914f703.e257b8","type":"link out","z":"ee008879.f5adc8","name":"to core.logging","links":["9fe80f7e.f3f7e"],"x":355,"y":340,"wires":[]},{"id":"b163f8df.fd9278","type":"inject","z":"ee008879.f5adc8","name":"PM detector SET REFRESH","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"device\":\"PM detector\",\"property\":\"_refresh\",\"value\":\"now\"}","payloadType":"json","x":220,"y":720,"wires":[["78b729bf.554958"]]},{"id":"78b729bf.554958","type":"link out","z":"ee008879.f5adc8","name":"to core.std_cmd","links":["8a1da02d.424ae"],"x":435,"y":720,"wires":[]},{"id":"87fd0e9c.cb79","type":"inject","z":"ee008879.f5adc8","name":"PM detector GET REFRESH","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"device\":\"PM detector\",\"property\":\"_refresh\"}","payloadType":"json","x":220,"y":760,"wires":[["78b729bf.554958"]]},{"id":"8bf3f614.b791d8","type":"inject","z":"ee008879.f5adc8","name":"PM detector SET _refreshCycle 10s","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"device\":\"PM detector\",\"property\":\"_refreshCycle\",\"value\":10}","payloadType":"json","x":680,"y":760,"wires":[["270607f1.95ddd8"]]},{"id":"270607f1.95ddd8","type":"link out","z":"ee008879.f5adc8","name":"to core.std_cmd","links":["8a1da02d.424ae"],"x":935,"y":820,"wires":[]},{"id":"68d77188.dcd4c","type":"inject","z":"ee008879.f5adc8","name":"PM detector SET _refreshCycle 120s","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"device\":\"PM detector\",\"property\":\"_refreshCycle\",\"value\":120}","payloadType":"json","x":690,"y":720,"wires":[["270607f1.95ddd8"]]},{"id":"1107bea7.312231","type":"inject","z":"ee008879.f5adc8","name":"PM detector GET _refreshCycle","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"device\":\"PM detector\",\"property\":\"_refreshCycle\"}","payloadType":"json","x":670,"y":860,"wires":[["270607f1.95ddd8"]]},{"id":"ab2b3522.0fae28","type":"inject","z":"ee008879.f5adc8","name":"PM detector SET _refreshCycle STOP","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"device\":\"PM detector\",\"property\":\"_refreshCycle\",\"value\":\"off\"}","payloadType":"json","x":690,"y":820,"wires":[["270607f1.95ddd8"]]},{"id":"8ce5e629.3c5ef8","type":"delay","z":"ee008879.f5adc8","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"20","nbRateUnits":"10","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":600,"y":320,"wires":[["28f4d04b.ed1b7"]]},{"id":"42829377.f058dc","type":"inject","z":"ee008879.f5adc8","name":"PM detector GET RUN","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"device\":\"PM detector\",\"property\":\"startRT\"}","payloadType":"json","x":240,"y":820,"wires":[["78b729bf.554958"]]},{"id":"d53018ba.5b1448","type":"delay","z":"ee008879.f5adc8","name":"","pauseType":"delay","timeout":"750","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":480,"y":100,"wires":[["1282a87d.494a98"]]},{"id":"45a4b402.6f7e4c","type":"serial-port","serialport":"COM19","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","waitfor":"{","dtr":"none","rts":"none","cts":"none","dsr":"none","newline":"}","bin":"false","out":"char","addchar":"\\n","responsetimeout":"10000"}]
Created 5 years, 10 months ago
  • change (x4)
  • delay (x3)
  • function (x5)
  • inject (x13)
  • link in (x2)
  • link out (x7)
  • status (x1)
  • serial in (x1)
  • serial out (x1)
  • serial-port (x1)
  • subflow (x1)
  • subflow:ee953c15.ada29 (x1)
  • timerswitch (x1)
  • tuyaDAEMON
  • tuya
  • smart-device
  • custom
  • device
  • PM-detector
  • air-quality
  • USB-serial
