node-red-contrib-motion-pose-body-home-training-flow
This flow shows how to enhance a home training exprience using node-red-contrib-motion-pose and node-red-contrib-samsung-automation-studio-nodes.
This flow can do the follows.
  • start by Bixby utterances.
  • connect a webcam or Samsung Smartthings IoT camera to recognize the motion.
  • count how many squats you did.
  • register custom motion to recognize and count.
  • check if there is similar motion already registered.
[{"id":"aae948ea8dfda96b","type":"tab","label":"Body - Iot Control Flow","disabled":true,"info":""},{"id":"676f7e2b99a96214","type":"websocket in","z":"aae948ea8dfda96b","name":"","server":"e9b870a1bbf9569d","client":"","x":230,"y":420,"wires":[["1106de59d9d2d808"]]},{"id":"8ef77438cf68b80e","type":"switch","z":"aae948ea8dfda96b","name":"","property":"payload.regist","propertyType":"msg","rules":[{"t":"false"},{"t":"true"}],"checkall":"true","repair":false,"outputs":2,"x":580,"y":420,"wires":[["2a682544f748b61a"],["835f8aaac28ba9a1"]]},{"id":"1106de59d9d2d808","type":"json","z":"aae948ea8dfda96b","name":"","property":"payload","action":"","pretty":false,"x":420,"y":420,"wires":[["8ef77438cf68b80e","453e51db7839c968"]]},{"id":"b8b4066dca8e6827","type":"function","z":"aae948ea8dfda96b","name":"Buffer Reset","func":"if (msg.payload.result != null) {\n    flow.set('keypointsBuffer', [])\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1290,"y":400,"wires":[["dddaae72cd936c7c"]]},{"id":"dddaae72cd936c7c","type":"switch","z":"aae948ea8dfda96b","name":"","property":"poseName","propertyType":"msg","rules":[{"t":"eq","v":"up","vt":"str"},{"t":"eq","v":"down","vt":"str"},{"t":"eq","v":"lightOn","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":1530,"y":380,"wires":[["fc61dadbdb5e3293"],["efcd80fd2e242c63"],["90514d32787d03ec"]]},{"id":"fc61dadbdb5e3293","type":"command-device","z":"aae948ea8dfda96b","name":"","alias":"on","deviceNodeId":"fc73d2e1b718698b","deviceType":"installed-device","deviceId":"a139fbe2-cc14-421e-8e49-b933a16ed120","componentId":"","capabilityId":"switch_v1","attributeId":"on","rules":[],"logging":false,"loggingEditor":false,"loggingConsole":false,"outputs":1,"x":1790,"y":300,"wires":[[]]},{"id":"efcd80fd2e242c63","type":"command-device","z":"aae948ea8dfda96b","name":"","alias":"off","deviceNodeId":"fc73d2e1b718698b","deviceType":"installed-device","deviceId":"a139fbe2-cc14-421e-8e49-b933a16ed120","componentId":"","capabilityId":"switch_v1","attributeId":"off","rules":[],"logging":false,"loggingEditor":false,"loggingConsole":false,"outputs":1,"x":1790,"y":340,"wires":[[]]},{"id":"7ef1830d854af7ef","type":"http in","z":"aae948ea8dfda96b","name":"","url":"/body/webcam","method":"get","upload":false,"swaggerDoc":"","x":290,"y":140,"wires":[["559e4595ab586d37","62bde0c2388a5fdf"]]},{"id":"393e80a166802ea6","type":"http response","z":"aae948ea8dfda96b","name":"","statusCode":"200","headers":{},"x":940,"y":200,"wires":[]},{"id":"559e4595ab586d37","type":"change","z":"aae948ea8dfda96b","name":"Initialize","rules":[{"t":"delete","p":"payload","pt":"flow"},{"t":"delete","p":"registeredPoses","pt":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":140,"wires":[["c2e042389ca325aa"]]},{"id":"4524414f78cc39f0","type":"function","z":"aae948ea8dfda96b","name":"Array Setting","func":"flow.set(\"registeredPoses\", msg.payload || []);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\nglobal.payload = [];","finalize":"","libs":[],"x":1100,"y":140,"wires":[["43b2670ee3ca40f2"]]},{"id":"43b2670ee3ca40f2","type":"debug","z":"aae948ea8dfda96b","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1290,"y":140,"wires":[]},{"id":"c2e042389ca325aa","type":"mongodb in","z":"aae948ea8dfda96b","mongodb":"1358ea9c6c074371","name":"Pose Load","collection":"bodytraining","operation":"find","x":760,"y":140,"wires":[["a42a74ba31cffbd6"]]},{"id":"a42a74ba31cffbd6","type":"json","z":"aae948ea8dfda96b","name":"","property":"payload","action":"obj","pretty":false,"x":920,"y":140,"wires":[["4524414f78cc39f0"]]},{"id":"78abe4dbf2285844","type":"http in","z":"aae948ea8dfda96b","name":"","url":"/body/iotcam","method":"get","upload":false,"swaggerDoc":"","x":280,"y":260,"wires":[["f05d81a38631ba63"]]},{"id":"38e106f1c8519e89","type":"http response","z":"aae948ea8dfda96b","name":"","statusCode":"200","headers":{},"x":1120,"y":260,"wires":[]},{"id":"fc73d2e1b718698b","type":"installed-device","z":"aae948ea8dfda96b","name":"","alias":"token:20e09e17","device":"","devices":["4d192f0d-596d-4654-a5fa-45cae8a95250","5f9a4811-6ec1-4e4f-801b-b45c2aa87cda","fc05f376-216c-36a0-c583-4c3e5d211fcb","d3009ee6-bddf-5458-9160-1e0382da3184","21242d0b-c555-144c-27f6-b00bef816007","83024186-5f6d-8cc5-a54f-9eee02045142","645ed6c4-156f-8ce1-bbd2-a2decf6be35b","702ce8be-5a1f-3bfc-af25-c5648337aa08","be821182-7452-40f7-84c8-a101aafbcadd","77cbf87b-2b7b-b7bf-d602-4d4597941d2d","1d88fbdb-d105-43bd-9b63-be4037b3c640","a139fbe2-cc14-421e-8e49-b933a16ed120","b5d536c2-4341-09e2-e138-836a9a9332c6","c0a6fd54-bbae-4f75-a7d8-5dbea7785c52","373209a7-6a6d-40ef-b5b7-5ebc7db1d87d","2b3efe5e-c7b9-44c5-a462-de84612447a6","2456412c-1b24-6ad5-a062-9675797961c2","e6145123-0b1b-f70d-fa9e-61d7f794e965","ff64d11d-7cf0-5541-c2bb-c25bac7ce041","b01d02c5-ecd7-a826-dd7e-54f1d380c923","446bf4d2-13bf-0427-3fc3-0330dd59700c","eaeac12f-690b-3e6e-54b8-aa48d47f565c","390f7a19-8fc2-831b-1bd3-cd49b6ed885e","f0a25de1-3dd0-5ba4-15cd-e7af12221c6f","9ea3f390-cb70-30a4-03e7-a445a635477c","e1416da3-a111-cfeb-0c7c-713b3deffda0","5285349b-5606-9640-104f-9ae3dd65c1ca","1d7e30db-1939-d080-72a5-802b754db412","d0e7d832-f069-f138-5463-0c64c378a67d","ec58c60a-cd91-9b13-78dd-53b81c16af3b","70e6e297-d012-e44b-0858-d0cc3184581d","78872b97-92f6-0244-1568-025c6af8b2d4","8ea60849-a7b8-d6cb-8e02-767e0d214706","385ffa71-5a4b-565d-f3e5-1e3a1d0d1701","461fc969-bbcd-c8f3-716d-3505ac30d8c4","c776f294-98b0-632f-1658-1cfc6f39d2cb","65d4878e-48f6-0b17-cac5-bd6ee4b95da8","2d6728ea-94d9-ee1f-5dc7-291cd4a9fcbc","1ba0007f-d9ed-3f68-56f2-dfd3605424f9","af896e1b-f48c-0d79-cb1e-f2b54ba3dff3","e3535e1c-9992-e702-f257-b190f5a6b6d1"],"profileId":"fc73d2e1b718698b","x":290,"y":200,"wires":[]},{"id":"3d29485f13a3b84b","type":"status-device","z":"aae948ea8dfda96b","name":"","alias":"홈카메라 360","deviceNodeId":"fc73d2e1b718698b","deviceType":"installed-device","deviceId":"c0a6fd54-bbae-4f75-a7d8-5dbea7785c52","componentId":"","capabilityId":"videoStream_v1","attributeId":"stream","rules":[],"logging":true,"loggingEditor":true,"loggingConsole":true,"outputs":1,"x":690,"y":260,"wires":[["3970c231bb2fc77b"]]},{"id":"2a682544f748b61a","type":"function","z":"aae948ea8dfda96b","name":"Pose Similarity Function","func":"// Now keypoints Data\nlet keypointsBuffer = flow.get('keypointsBuffer') || []\nconst bufferlength = 30\nkeypointsBuffer.push(msg.payload.poseLandmarks)\nif (keypointsBuffer.length > bufferlength) {\n        keypointsBuffer.shift()\n}\nflow.set('keypointsBuffer', keypointsBuffer)\n\n// Saved Keypoints Data\nconst registeredPoses = flow.get(\"registeredPoses\")\nlet savedKeypoints = {}\nfor (let i = 0; i < registeredPoses.length; i ++) {\n    savedKeypoints[registeredPoses[i].poseName] = registeredPoses[i].poseLandmarks\n}\n\nif (keypointsBuffer.length < bufferlength) {\n\n    msg.inputKeypoints = []\n    msg.savedKeypoints = savedKeypoints\n\n} else {\n\n    msg.inputKeypoints = keypointsBuffer\n    msg.savedKeypoints = savedKeypoints\n}\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":400,"wires":[["4b8d21deec06e2cd"]]},{"id":"835f8aaac28ba9a1","type":"function","z":"aae948ea8dfda96b","name":"Pose Register Function","func":"const registeredPoses = flow.get(\"registeredPoses\")\nlet savedKeypoints = {}\nfor (let i = 0; i < registeredPoses.length; i ++) {\n    savedKeypoints[registeredPoses[i].poseName] = registeredPoses[i].poseLandmarks\n}\n\nmsg.inputData = msg.payload \n\n\nmsg.inputKeypoint = msg.payload.poseLandmarks\nmsg.savedKeypoints = savedKeypoints\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":810,"y":520,"wires":[["d5a5b24511f7aa40"]]},{"id":"6739b409ee9e68e7","type":"function","z":"aae948ea8dfda96b","name":"Data Preprocess","func":"let registeredPoses = flow.get(\"registeredPoses\") || []\nregisteredPoses.push(msg.inputData)\nflow.set(\"registeredPoses\", registeredPoses)\n\nmsg.payload = msg.inputData\n    \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1610,"y":500,"wires":[["086f1f4dcfef29f3"]]},{"id":"fcf60a9443fad93b","type":"function","z":"aae948ea8dfda96b","name":"Error msg","func":"if (msg.isAccurate) {\n    msg.error = msg.poseName + ' 자세와 유사합니다. 다시 등록 해주세요'\n} else {\n    msg.error = '자세가 정확하지 않습니다. 다시 등록 해주세요'\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1600,"y":560,"wires":[["32b9d4e2f6f71651"]]},{"id":"086f1f4dcfef29f3","type":"mongodb out","z":"aae948ea8dfda96b","mongodb":"1358ea9c6c074371","name":"Pose Save","collection":"bodytraining","payonly":true,"upsert":false,"multi":false,"operation":"insert","x":1810,"y":500,"wires":[]},{"id":"32b9d4e2f6f71651","type":"debug","z":"aae948ea8dfda96b","name":"msg.error","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"error","targetType":"msg","statusVal":"","statusType":"auto","x":1780,"y":560,"wires":[]},{"id":"af474b4c3d6debfb","type":"switch","z":"aae948ea8dfda96b","name":"","property":"status","propertyType":"msg","rules":[{"t":"false"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1290,"y":520,"wires":[["6739b409ee9e68e7"],["fcf60a9443fad93b"]]},{"id":"90514d32787d03ec","type":"command-device","z":"aae948ea8dfda96b","name":"","alias":"off","deviceNodeId":"fc73d2e1b718698b","deviceType":"installed-device","deviceId":"a139fbe2-cc14-421e-8e49-b933a16ed120","componentId":"","capabilityId":"switch_v1","attributeId":"off","rules":[{"capaId":"switch_v1","attrId":"off","args":[]}],"logging":false,"loggingEditor":false,"loggingConsole":false,"outputs":1,"x":1790,"y":380,"wires":[[]]},{"id":"453e51db7839c968","type":"debug","z":"aae948ea8dfda96b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":610,"y":620,"wires":[]},{"id":"f05d81a38631ba63","type":"command-device","z":"aae948ea8dfda96b","name":"","alias":"startStream","deviceNodeId":"fc73d2e1b718698b","deviceType":"installed-device","deviceId":"c0a6fd54-bbae-4f75-a7d8-5dbea7785c52","componentId":"","capabilityId":"videoStream_v1","attributeId":"startStream","rules":[{"capaId":"videoStream_v1","attrId":"startStream","args":[]}],"logging":false,"loggingEditor":false,"loggingConsole":false,"outputs":1,"x":490,"y":260,"wires":[["3d29485f13a3b84b"]]},{"id":"62bde0c2388a5fdf","type":"pose-detect-webcam","z":"aae948ea8dfda96b","name":"","serverUrl":"localhost","monitorPort":1881,"dataSocketUrl":"ws://localhost:1880/ws/data","x":620,"y":200,"wires":[["393e80a166802ea6"]]},{"id":"3970c231bb2fc77b","type":"pose-detect-iotcam","z":"aae948ea8dfda96b","name":"","serverUrl":"localhost","monitorPort":1882,"rtspPort":1886,"dataSocketUrl":"ws://localhost:1880/ws/data","x":910,"y":260,"wires":[["38e106f1c8519e89"]]},{"id":"d5a5b24511f7aa40","type":"pose-register","z":"aae948ea8dfda96b","name":"","similarSensitivity":80,"x":1070,"y":520,"wires":[["af474b4c3d6debfb"]]},{"id":"4b8d21deec06e2cd","type":"pose-find","z":"aae948ea8dfda96b","name":"","similarSensitivity":80,"x":1060,"y":400,"wires":[["b8b4066dca8e6827"]]},{"id":"e9b870a1bbf9569d","type":"websocket-listener","path":"/ws/data","wholemsg":"false"},{"id":"1358ea9c6c074371","type":"mongodb","hostname":"127.0.0.1","topology":"direct","connectOptions":"","port":"27017","db":"5fn","name":""}]
  • change (x1)
  • debug (x3)
  • function (x6)
  • http in (x2)
  • http response (x2)
  • json (x2)
  • switch (x3)
  • websocket in (x1)
  • websocket-listener (x1)
  • node-red-contrib-motion-pose
  • node-red-contrib-samsung-automation-studio-nodes
  • motion
  • mediapipe
  • body
