Honeywell XNX Gas-Detector with Modbus RTU to MySQL
Connect to sensor XNX with Modbus RTU and write data into MySQL database
[{"id":"a36ea496.cd66e8","type":"modbus-server","z":"bd325811.2e8cc","name":"Modbus Server","logEnabled":false,"serverPort":10502,"responseDelay":100,"delayUnit":"ms","coilsBufferSize":1024,"holdingBufferSize":1024,"inputBufferSize":1024,"x":378.70056343078613,"y":165.37563467025757,"wires":[["cdc09c20.7d7ea"],["cdc09c20.7d7ea"],["cdc09c20.7d7ea"]]},{"id":"cdc09c20.7d7ea","type":"debug","z":"bd325811.2e8cc","name":"","active":false,"console":"false","complete":"payload","x":650.7005615234375,"y":168.37564086914062,"wires":[]},{"id":"92ab3295.dae4f","type":"inject","z":"bd325811.2e8cc","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":178.70056343078613,"y":165.37563467025757,"wires":[["a36ea496.cd66e8"]]},{"id":"def55565.ecab48","type":"comment","z":"bd325811.2e8cc","name":"Modbus Server","info":"","x":195.40057373046875,"y":122.37563705444336,"wires":[]},{"id":"980fc180.00b66","type":"comment","z":"bd325811.2e8cc","name":"Read modbus register(s)","info":"","x":156,"y":388.0000066757202,"wires":[]},{"id":"5bcd37c0.5c179","type":"ui_chart","z":"bd325811.2e8cc","name":"","group":"74f90edd.da6d9","order":1,"width":"0","height":"0","label":"Holding Register Chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"-25","ymax":"150","removeOlder":"30","removeOlderPoints":"","removeOlderUnit":"60","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":true,"x":994.6156539916992,"y":581.0068531036377,"wires":[[],[]]},{"id":"6f4e4e75.612478","type":"ui_text","z":"bd325811.2e8cc","group":"74f90edd.da6d9","order":2,"width":0,"height":0,"name":"","label":"Holding Register Sensor1","format":"{{msg.payload}}","layout":"row-spread","x":1004.6717071533203,"y":613.3999691009521,"wires":[]},{"id":"3163fd34.a0b532","type":"mysql","z":"bd325811.2e8cc","mydb":"af877d5.64cac","name":"","x":747.464282989502,"y":734.8928909301758,"wires":[[]]},{"id":"8b1f69b3.9e4c98","type":"debug","z":"bd325811.2e8cc","name":"","active":true,"console":"false","complete":"payload","x":1039.1857814788818,"y":798.5739135742188,"wires":[]},{"id":"a6ea80e5.bc0cf8","type":"function","z":"bd325811.2e8cc","name":"Update Mess","func":"data = (msg.payload);\nvar m = {\n topic : \"UPDATE `tbl_sensor` SET `messwert` = '\" + data + \"' WHERE `idsensor` = '5';\"     \n};\nreturn m;","outputs":1,"noerr":0,"x":606.8465919494629,"y":711.3897581100464,"wires":[["3163fd34.a0b532","12524721.dd4d09"]]},{"id":"247d52b6.2f7d7e","type":"function","z":"bd325811.2e8cc","name":"Select Messwert","func":"m = {\n topic : \"SELECT `messwert` FROM `ha`.`tbl_sensor`;\"     \n};\nreturn m;","outputs":1,"noerr":0,"x":455.3736801147461,"y":846.1104907989502,"wires":[["26fd2561.d54d3a"]]},{"id":"d31b670b.706238","type":"ui_text","z":"bd325811.2e8cc","group":"6bee444e.5c983c","order":4,"width":0,"height":0,"name":"","label":"Messwert[0]","format":"{{msg.payload}}","layout":"row-spread","x":1034.4812545776367,"y":841.1352100372314,"wires":[]},{"id":"d37cd2c4.06905","type":"inject","z":"bd325811.2e8cc","name":"","topic":"","payload":"","payloadType":"num","repeat":"2","crontab":"","once":false,"x":108.10000610351562,"y":480,"wires":[["6f28e888.3e7668"]]},{"id":"6f28e888.3e7668","type":"function","z":"bd325811.2e8cc","name":"FC[3] dev1","func":"msg.payload = { \n    'fc': 3, \n    'unitid': 1, \n    'address': 2 , \n    'quantity': 2\n};\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":480,"wires":[["a52c2bf5.eeeb58"]]},{"id":"a52c2bf5.eeeb58","type":"modbus-flex-getter","z":"bd325811.2e8cc","name":"","showStatusActivities":false,"showErrors":false,"server":"7c04dc0e.08f05c","useIOFile":false,"ioFile":"","useIOForPayload":false,"x":523.3381881713867,"y":480.23053538799286,"wires":[[],["e61602f1.655b5","9e287b95.f16708","3405273c.8f2af8"]]},{"id":"e61602f1.655b5","type":"modbus-response","z":"bd325811.2e8cc","name":"","registerShowMax":"","x":768.0000228881836,"y":499.0000629425049,"wires":[]},{"id":"7ab107bf.52fdd8","type":"comment","z":"bd325811.2e8cc","name":"Messwert XNX id1","info":"","x":132.5,"y":434,"wires":[]},{"id":"9e287b95.f16708","type":"function","z":"bd325811.2e8cc","name":"float(CD AB)","func":"var rawData = new ArrayBuffer(4);\nvar intView = new Uint16Array(rawData);\nvar fltView = new Float32Array(rawData);\nvar rawData = msg.values;\n//Read input in format \"CD_AB\" [reg2, reg1]\nintView[0] = msg.values[1]; //low\nintView[1] = msg.values[0]; //high\nmsg.payload = fltView[0];\nreturn msg;","outputs":1,"noerr":0,"x":751.4285736083984,"y":577.1428642272949,"wires":[["4173497.d0b5cb8","5bcd37c0.5c179","6f4e4e75.612478","a6ea80e5.bc0cf8"]]},{"id":"4173497.d0b5cb8","type":"debug","z":"bd325811.2e8cc","name":"","active":false,"console":"false","complete":"payload","x":973.0001258850098,"y":542.0000162124634,"wires":[]},{"id":"3405273c.8f2af8","type":"debug","z":"bd325811.2e8cc","name":"","active":false,"console":"false","complete":"values","x":756.100118637085,"y":463.0000171661377,"wires":[]},{"id":"12524721.dd4d09","type":"debug","z":"bd325811.2e8cc","name":"","active":false,"console":"false","complete":"false","x":767.814323425293,"y":692.5428829193115,"wires":[]},{"id":"8d44f9bd.b93518","type":"inject","z":"bd325811.2e8cc","name":"","topic":"","payload":"","payloadType":"num","repeat":"2","crontab":"","once":false,"x":180.14286851882935,"y":847.1428928375244,"wires":[["247d52b6.2f7d7e"]]},{"id":"6449d9a1.9f6548","type":"ui_gauge","z":"bd325811.2e8cc","name":"Messwert[0]","group":"6bee444e.5c983c","order":0,"width":0,"height":0,"gtype":"gage","title":"Gauge","label":"%UEG","format":"","min":"-25","max":"125","colors":["#00b500","#e6e600","#ca3838"],"seg1":"25","seg2":"50","x":1038.696460723877,"y":888.428674697876,"wires":[]},{"id":"26fd2561.d54d3a","type":"mysql","z":"bd325811.2e8cc","mydb":"af877d5.64cac","name":"","x":630.8928604125977,"y":846.7858228683472,"wires":[["5cd69aa1.6efd64"]]},{"id":"5cd69aa1.6efd64","type":"function","z":"bd325811.2e8cc","name":"Messwert[0]","func":"//Auswahl Array[].messwert\nmsg.payload = msg.payload[0].messwert;\nreturn msg;","outputs":1,"noerr":0,"x":807.2857704162598,"y":847.1428937911987,"wires":[["d31b670b.706238","8b1f69b3.9e4c98","6449d9a1.9f6548"]]},{"id":"74f90edd.da6d9","type":"ui_group","z":"","name":"Sensor","tab":"854fe68d.ac995","order":3,"disp":true,"width":"6"},{"id":"af877d5.64cac","type":"MySQLdatabase","z":"","host":"127.0.0.1","port":"3306","db":"ha","tz":""},{"id":"6bee444e.5c983c","type":"ui_group","z":"","name":"Messwert","tab":"12743c8.1877a44","disp":true,"width":"6"},{"id":"7c04dc0e.08f05c","type":"modbus-client","z":"","name":"USB0","clienttype":"serial","bufferCommands":true,"stateLogEnabled":true,"tcpHost":"127.0.0.1","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB0","serialType":"RTU","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"even","serialConnectionDelay":"100","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectTimeout":"2000"},{"id":"854fe68d.ac995","type":"ui_tab","z":"","name":"Modbus Honeywell","icon":"dashboard"},{"id":"12743c8.1877a44","type":"ui_tab","z":"","name":"Test MySQL ","icon":"dashboard"}]
Created 9 years, 1 month ago
  • comment (x3)
  • debug (x5)
  • function (x5)
  • inject (x3)
  • MySQLdatabase (x1)
  • modbus-client (x1)
  • modbus-flex-getter (x1)
  • modbus-response (x1)
  • modbus-server (x1)
  • mysql (x2)
  • ui_chart (x1)
  • ui_gauge (x1)
  • ui_group (x2)
  • ui_tab (x2)
  • ui_text (x2)
  • ModBus
  • MySQL
