Casambi over MQTT (local)
Control an Casambi Network over MQTT.
With the Lithernet Casambi Gateway (https://casambi.intelligent-lighting.de/).
Possible to:
  • Set Lux Level
  • Set PIR state
  • Set Level
  • Set Level in Group
  • Set Level with Scene
  • Set PushButton
  • Set PushButton Level
More Features will be added.
[{"id":"4e4e0dc3.84afc4","type":"tab","label":"Casambi MQTT","disabled":false,"info":""},{"id":"f985b414.9d4b78","type":"mqtt in","z":"4e4e0dc3.84afc4","name":"scene","topic":"casambi/0/get/scene_call","qos":"1","datatype":"auto","broker":"27f5cd2e.01b4a2","nl":false,"rap":true,"rh":0,"x":1170,"y":100,"wires":[["1aa44b5f.62c135"]]},{"id":"1aa44b5f.62c135","type":"json","z":"4e4e0dc3.84afc4","name":"","property":"payload","action":"","pretty":false,"x":1340,"y":100,"wires":[["1c5cc494.27c8db"]]},{"id":"1c5cc494.27c8db","type":"change","z":"4e4e0dc3.84afc4","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.scene","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1600,"y":100,"wires":[["d2c319a8.a46718","f32acf1f.0c914"]]},{"id":"d2c319a8.a46718","type":"debug","z":"4e4e0dc3.84afc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1880,"y":100,"wires":[]},{"id":"f32acf1f.0c914","type":"ui_text","z":"4e4e0dc3.84afc4","group":"50ba6ce4.dfe374","order":0,"width":0,"height":0,"name":"","label":"Scene","format":"{{msg.payload}}","layout":"row-spread","x":1860,"y":140,"wires":[]},{"id":"5d9959b7.128c98","type":"mqtt out","z":"4e4e0dc3.84afc4","name":"","topic":"casambi/0/set/level","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"27f5cd2e.01b4a2","x":790,"y":100,"wires":[]},{"id":"e7991533.87aea8","type":"ui_slider","z":"4e4e0dc3.84afc4","name":"","label":"Level","tooltip":"","group":"44f63b3a.5a1c44","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"level","topicType":"str","min":0,"max":"254","step":1,"x":170,"y":100,"wires":[["2ff3c9f1.669756"]]},{"id":"1d53b9ea.fd0826","type":"ui_numeric","z":"4e4e0dc3.84afc4","name":"","label":"Duration","tooltip":"","group":"44f63b3a.5a1c44","order":2,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"duration","topicType":"str","format":"{{value}}","min":0,"max":"4000","step":1,"x":180,"y":160,"wires":[["2ff3c9f1.669756"]]},{"id":"2ff3c9f1.669756","type":"join","z":"4e4e0dc3.84afc4","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":370,"y":100,"wires":[["5db62d79.378ec4"]]},{"id":"5e43c30c.30a71c","type":"debug","z":"4e4e0dc3.84afc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":770,"y":160,"wires":[]},{"id":"5db62d79.378ec4","type":"json","z":"4e4e0dc3.84afc4","name":"","property":"payload","action":"str","pretty":false,"x":510,"y":100,"wires":[["5e43c30c.30a71c","5d9959b7.128c98"]]},{"id":"712284a2.47c23c","type":"comment","z":"4e4e0dc3.84afc4","name":"Receive actual Scene","info":"","x":1220,"y":40,"wires":[]},{"id":"5fc7878a.e3b5f8","type":"comment","z":"4e4e0dc3.84afc4","name":"Set Level","info":"","x":180,"y":40,"wires":[]},{"id":"3f36e8f.23ebe18","type":"comment","z":"4e4e0dc3.84afc4","name":"Set Scene Level","info":"","x":200,"y":260,"wires":[]},{"id":"49e1e5be.b9dfbc","type":"mqtt out","z":"4e4e0dc3.84afc4","name":"","topic":"casambi/0/set/scene_level","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"27f5cd2e.01b4a2","x":840,"y":320,"wires":[]},{"id":"adf10b76.998e68","type":"ui_slider","z":"4e4e0dc3.84afc4","name":"","label":"Level","tooltip":"","group":"f34d0f45.4197e","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"level","topicType":"str","min":0,"max":"254","step":1,"x":170,"y":320,"wires":[["f235af41.d574f"]]},{"id":"ff275836.706258","type":"ui_numeric","z":"4e4e0dc3.84afc4","name":"","label":"Duration","tooltip":"","group":"f34d0f45.4197e","order":2,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"duration","topicType":"str","format":"{{value}}","min":0,"max":"4000","step":1,"x":180,"y":440,"wires":[["f235af41.d574f"]]},{"id":"f235af41.d574f","type":"join","z":"4e4e0dc3.84afc4","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":390,"y":320,"wires":[["99445dfa.32869"]]},{"id":"97942535.7615b8","type":"debug","z":"4e4e0dc3.84afc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":380,"wires":[]},{"id":"99445dfa.32869","type":"json","z":"4e4e0dc3.84afc4","name":"","property":"payload","action":"str","pretty":false,"x":530,"y":320,"wires":[["97942535.7615b8","49e1e5be.b9dfbc"]]},{"id":"82ba6519.517ac8","type":"ui_numeric","z":"4e4e0dc3.84afc4","name":"","label":"Scene","tooltip":"","group":"f34d0f45.4197e","order":1,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"scene","topicType":"str","format":"{{value}}","min":0,"max":"200","step":1,"x":170,"y":380,"wires":[["f235af41.d574f"]]},{"id":"cede10a7.0bf7","type":"comment","z":"4e4e0dc3.84afc4","name":"Set Group Level","info":"","x":200,"y":520,"wires":[]},{"id":"dd51c40c.e2de68","type":"mqtt out","z":"4e4e0dc3.84afc4","name":"","topic":"casambi/0/set/group_level","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"27f5cd2e.01b4a2","x":830,"y":580,"wires":[]},{"id":"e0f001e7.1ec97","type":"ui_slider","z":"4e4e0dc3.84afc4","name":"","label":"Level","tooltip":"","group":"e4ea0018.3e29c","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"level","topicType":"str","min":0,"max":"254","step":1,"x":170,"y":580,"wires":[["c4b94516.e03ec8"]]},{"id":"af1b1f25.c66d2","type":"ui_numeric","z":"4e4e0dc3.84afc4","name":"","label":"Duration","tooltip":"","group":"e4ea0018.3e29c","order":2,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"duration","topicType":"str","format":"{{value}}","min":0,"max":"4000","step":1,"x":180,"y":700,"wires":[["c4b94516.e03ec8"]]},{"id":"c4b94516.e03ec8","type":"join","z":"4e4e0dc3.84afc4","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":390,"y":580,"wires":[["f9e1c902.3b1608"]]},{"id":"bc42cbb0.050628","type":"debug","z":"4e4e0dc3.84afc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":640,"wires":[]},{"id":"f9e1c902.3b1608","type":"json","z":"4e4e0dc3.84afc4","name":"","property":"payload","action":"str","pretty":false,"x":530,"y":580,"wires":[["bc42cbb0.050628","dd51c40c.e2de68"]]},{"id":"7dfb9671.3370c8","type":"ui_numeric","z":"4e4e0dc3.84afc4","name":"","label":"Group","tooltip":"","group":"e4ea0018.3e29c","order":1,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"group","topicType":"str","format":"{{value}}","min":0,"max":"200","step":1,"x":170,"y":640,"wires":[["c4b94516.e03ec8"]]},{"id":"5952026.80c55fc","type":"comment","z":"4e4e0dc3.84afc4","name":"Set Button Pressed","info":"","x":210,"y":980,"wires":[]},{"id":"1dadd601.897dfa","type":"mqtt out","z":"4e4e0dc3.84afc4","name":"","topic":"casambi/0/set/push_button_pressed","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"27f5cd2e.01b4a2","x":870,"y":1040,"wires":[]},{"id":"e915ddc3.b69ee","type":"join","z":"4e4e0dc3.84afc4","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":390,"y":1040,"wires":[["d3e9aaae.820a88"]]},{"id":"f93685df.4a17f8","type":"debug","z":"4e4e0dc3.84afc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":1100,"wires":[]},{"id":"d3e9aaae.820a88","type":"json","z":"4e4e0dc3.84afc4","name":"","property":"payload","action":"str","pretty":false,"x":530,"y":1040,"wires":[["f93685df.4a17f8","1dadd601.897dfa"]]},{"id":"ba392ecf.ead0d","type":"comment","z":"4e4e0dc3.84afc4","name":"Set Button Level","info":"","x":200,"y":780,"wires":[]},{"id":"8dd2a074.45a39","type":"mqtt out","z":"4e4e0dc3.84afc4","name":"","topic":"casambi/0/set/button_level","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"27f5cd2e.01b4a2","x":840,"y":840,"wires":[]},{"id":"d0d6a5ce.a98a98","type":"ui_slider","z":"4e4e0dc3.84afc4","name":"","label":"Level","tooltip":"","group":"cf7e76ef.3a5c48","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"level","topicType":"str","min":0,"max":"254","step":1,"x":170,"y":840,"wires":[["3075cb97.f554c4"]]},{"id":"3075cb97.f554c4","type":"join","z":"4e4e0dc3.84afc4","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":390,"y":840,"wires":[["15fca424.4cd6dc"]]},{"id":"3438045f.c4310c","type":"debug","z":"4e4e0dc3.84afc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":900,"wires":[]},{"id":"15fca424.4cd6dc","type":"json","z":"4e4e0dc3.84afc4","name":"","property":"payload","action":"str","pretty":false,"x":530,"y":840,"wires":[["3438045f.c4310c","8dd2a074.45a39"]]},{"id":"dc65dffb.6678e","type":"ui_numeric","z":"4e4e0dc3.84afc4","name":"","label":"Button","tooltip":"","group":"cf7e76ef.3a5c48","order":1,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"button","topicType":"str","format":"{{value}}","min":0,"max":"200","step":1,"x":170,"y":900,"wires":[["3075cb97.f554c4"]]},{"id":"2b6262d.6fd029e","type":"comment","z":"4e4e0dc3.84afc4","name":"Set Button Released","info":"","x":210,"y":1160,"wires":[]},{"id":"8bf598b7.c8f688","type":"mqtt out","z":"4e4e0dc3.84afc4","name":"","topic":"casambi/0/set/push_button_released","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"27f5cd2e.01b4a2","x":870,"y":1220,"wires":[]},{"id":"1b0a160c.fc6a2a","type":"join","z":"4e4e0dc3.84afc4","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":390,"y":1220,"wires":[["39a01df1.347732"]]},{"id":"da9d60ae.eb776","type":"debug","z":"4e4e0dc3.84afc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":1280,"wires":[]},{"id":"39a01df1.347732","type":"json","z":"4e4e0dc3.84afc4","name":"","property":"payload","action":"str","pretty":false,"x":530,"y":1220,"wires":[["da9d60ae.eb776","8bf598b7.c8f688"]]},{"id":"193f043f.af157c","type":"comment","z":"4e4e0dc3.84afc4","name":"Set Lux Level","info":"","x":190,"y":1340,"wires":[]},{"id":"b50b9bd7.d1bc68","type":"mqtt out","z":"4e4e0dc3.84afc4","name":"","topic":"casambi/0/set/light_sensor","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"27f5cd2e.01b4a2","x":840,"y":1400,"wires":[]},{"id":"d10a0eeb.497df","type":"join","z":"4e4e0dc3.84afc4","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":390,"y":1400,"wires":[["c10f38e9.d2e028"]]},{"id":"64cc9b49.3020b4","type":"debug","z":"4e4e0dc3.84afc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":1460,"wires":[]},{"id":"c10f38e9.d2e028","type":"json","z":"4e4e0dc3.84afc4","name":"","property":"payload","action":"str","pretty":false,"x":530,"y":1400,"wires":[["64cc9b49.3020b4","b50b9bd7.d1bc68"]]},{"id":"38326d99.b3beb2","type":"comment","z":"4e4e0dc3.84afc4","name":"Set PIR Level","info":"","x":190,"y":1540,"wires":[]},{"id":"40487ed5.8e4b2","type":"mqtt out","z":"4e4e0dc3.84afc4","name":"","topic":"casambi/0/set/pir_sensor","qos":"1","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"27f5cd2e.01b4a2","x":830,"y":1600,"wires":[]},{"id":"44bc974d.656648","type":"join","z":"4e4e0dc3.84afc4","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"1","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":390,"y":1600,"wires":[["6cea2c98.1a4884"]]},{"id":"6395310b.ad24a","type":"debug","z":"4e4e0dc3.84afc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":790,"y":1660,"wires":[]},{"id":"6cea2c98.1a4884","type":"json","z":"4e4e0dc3.84afc4","name":"","property":"payload","action":"str","pretty":false,"x":530,"y":1600,"wires":[["6395310b.ad24a","40487ed5.8e4b2"]]},{"id":"3e6c68e2.5d7a38","type":"ui_dropdown","z":"4e4e0dc3.84afc4","name":"","label":"pir_sensor","tooltip":"","place":"Select option","group":"5099512.b4b74b","order":1,"width":0,"height":0,"passthru":true,"multiple":false,"options":[{"label":"no","value":0,"type":"num"},{"label":"yes","value":"1","type":"str"}],"payload":"","topic":"pir_sensor","topicType":"str","x":190,"y":1600,"wires":[["44bc974d.656648"]]},{"id":"c7af8071.14314","type":"comment","z":"4e4e0dc3.84afc4","name":"AEDES MQTT Broker","info":"","x":1220,"y":220,"wires":[]},{"id":"92f9683.bd2e298","type":"aedes broker","z":"4e4e0dc3.84afc4","name":"MQTT Broker","mqtt_port":1883,"mqtt_ws_bind":"port","mqtt_ws_port":"","mqtt_ws_path":"","cert":"","key":"","certname":"","keyname":"","dburl":"","usetls":false,"x":1190,"y":280,"wires":[["24a7c178.d32f8e"]]},{"id":"24a7c178.d32f8e","type":"debug","z":"4e4e0dc3.84afc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1370,"y":280,"wires":[]},{"id":"43ac56cd.f8ac78","type":"ui_numeric","z":"4e4e0dc3.84afc4","name":"","label":"Button","tooltip":"","group":"8da45cb3.cdc78","order":1,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"button","topicType":"str","format":"{{value}}","min":0,"max":10,"step":1,"x":170,"y":1040,"wires":[["e915ddc3.b69ee"]]},{"id":"3afd8fcf.3b16c","type":"ui_numeric","z":"4e4e0dc3.84afc4","name":"","label":"Button","tooltip":"","group":"b8636f21.072bd","order":1,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"button","topicType":"str","format":"{{value}}","min":0,"max":10,"step":1,"x":170,"y":1220,"wires":[["1b0a160c.fc6a2a"]]},{"id":"25c5be8d.ccd032","type":"ui_numeric","z":"4e4e0dc3.84afc4","name":"","label":"lux_level","tooltip":"","group":"2c52dafe.6499f6","order":1,"width":0,"height":0,"wrap":false,"passthru":true,"topic":"lux_level","topicType":"str","format":"{{value}}","min":0,"max":10,"step":1,"x":180,"y":1400,"wires":[["d10a0eeb.497df"]]},{"id":"27f5cd2e.01b4a2","type":"mqtt-broker","name":"aedes (node red)","broker":"192.168.1.120","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"50ba6ce4.dfe374","type":"ui_group","name":"Aktuelle Szene","tab":"be4c2a32.941b58","order":1,"disp":true,"width":"6","collapse":false},{"id":"44f63b3a.5a1c44","type":"ui_group","name":"Set Level","tab":"be4c2a32.941b58","order":2,"disp":true,"width":"6","collapse":false},{"id":"f34d0f45.4197e","type":"ui_group","name":"Set Scene Level","tab":"be4c2a32.941b58","order":3,"disp":true,"width":"6","collapse":false},{"id":"e4ea0018.3e29c","type":"ui_group","name":"Set Group Level","tab":"be4c2a32.941b58","order":4,"disp":true,"width":"6","collapse":false},{"id":"cf7e76ef.3a5c48","type":"ui_group","name":"Set Button Level","tab":"be4c2a32.941b58","order":5,"disp":true,"width":"6","collapse":false},{"id":"5099512.b4b74b","type":"ui_group","name":"Set PIR","tab":"be4c2a32.941b58","order":9,"disp":true,"width":"6","collapse":false},{"id":"8da45cb3.cdc78","type":"ui_group","name":"Set Button Pressed","tab":"be4c2a32.941b58","order":6,"disp":true,"width":"6","collapse":false},{"id":"b8636f21.072bd","type":"ui_group","name":"Set Button Released","tab":"be4c2a32.941b58","order":7,"disp":true,"width":"6","collapse":false},{"id":"2c52dafe.6499f6","type":"ui_group","name":"Set Lux Level","tab":"be4c2a32.941b58","order":8,"disp":true,"width":"6","collapse":false},{"id":"be4c2a32.941b58","type":"ui_tab","name":"Casambi","icon":"dashboard","disabled":false,"hidden":false}]
Created 5 years, 4 months ago
  • change (x1)
  • comment (x10)
  • debug (x10)
  • join (x8)
  • json (x9)
  • mqtt in (x1)
  • mqtt out (x8)
  • mqtt-broker (x1)
  • MQTT
  • Casambi
  • Ethernet
  • LightingControl
  • Bluetooth
  • local
  • Lithernet
