Get City Info Subflow
This subflow gets data for a specific city name. To input the city name you can set it on the UI of this node or in msg.city_name (message will have priority).
This subflow takes data from teleport, openstreetmap, and openmeteo API.
The result contains city rankings, latitude and longitude, country and weather forecast for the next 7 days.
Example Result:
      "city": "perth",
      "lat": -31.9558933,
      "lng": 115.8605855,
      "rank": {
        "housing": 5.233,
        "cost_of_living": 4.795,
        "startups": 5.127000000000001,
        "venture_capital": 3.102,
        "travel_connectivity": 2.1104999999999996,
        "commute": 4.695,
        "business_freedom": 9.399666666666667,
        "safety": 7.1045,
        "healthcare": 9.312666666666665,
        "education": 5.143,
        "environmental_quality": 8.132500000000002,
        "economy": 6.0695000000000014,
        "taxation": 4.5885,
        "internet_access": 4.1785,
        "leisure_culture": 4.5115,
        "tolerance": 7.470500000000001,
        "outdoors": 5.6835
      "forecast": [
          "time": "2023-06-03",
          "weathercode": 3,
          "temperature": 13.15,
          "uv_index_max": 3.9,
          "uv_index_clear_sky_max": 3.9,
          "rain_sum": 0,
          "snowfall_sum": 0,
          "windspeed_10m_max": 8.7,
          "winddirection_10m_dominant": 78,
          "shortwave_radiation_sum": 12.21
      "photos": {
        "mobile": "https://d13k13wj6adfdf.cloudfront.net/urban_areas/perth-1e220f50f9.jpg",
        "web": "https://d13k13wj6adfdf.cloudfront.net/urban_areas/perth_web-99a082a61e.jpg"
[{"id":"9820978c22086c87","type":"subflow","name":"Get City Data","info":"<!DOCTYPE html>\n<html>\n<head>\n  <title>Subflow Summary</title>\n</head>\n<body>\n  <h2>Subflow Summary</h2>\n  <p>This subflow gets data for a specific city name. To input the city name you can set it on the UI of this node or in msg.city_name (message will have priority). This subflow takes data from teleport, openstreetmap, and openeteo API.</p>\n  The result contains city rankings, latitude and longitude, country and weather forecast for the next 7 days.\n  <h3>Example Result:</h3>\n  <pre>\n    {\n      \"city\": \"perth\",\n      \"lat\": -31.9558933,\n      \"lng\": 115.8605855,\n      \"rank\": {\n        \"housing\": 5.233,\n        \"cost_of_living\": 4.795,\n        \"startups\": 5.127000000000001,\n        \"venture_capital\": 3.102,\n        \"travel_connectivity\": 2.1104999999999996,\n        \"commute\": 4.695,\n        \"business_freedom\": 9.399666666666667,\n        \"safety\": 7.1045,\n        \"healthcare\": 9.312666666666665,\n        \"education\": 5.143,\n        \"environmental_quality\": 8.132500000000002,\n        \"economy\": 6.0695000000000014,\n        \"taxation\": 4.5885,\n        \"internet_access\": 4.1785,\n        \"leisure_culture\": 4.5115,\n        \"tolerance\": 7.470500000000001,\n        \"outdoors\": 5.6835\n      },\n      \"forecast\": [\n        {\n          \"time\": \"2023-06-03\",\n          \"weathercode\": 3,\n          \"temperature\": 13.15,\n          \"uv_index_max\": 3.9,\n          \"uv_index_clear_sky_max\": 3.9,\n          \"rain_sum\": 0,\n          \"snowfall_sum\": 0,\n          \"windspeed_10m_max\": 8.7,\n          \"winddirection_10m_dominant\": 78,\n          \"shortwave_radiation_sum\": 12.21\n        },\n        ...\n      ],\n      \"photos\": {\n        \"mobile\": \"https://d13k13wj6adfdf.cloudfront.net/urban_areas/perth-1e220f50f9.jpg\",\n        \"web\": \"https://d13k13wj6adfdf.cloudfront.net/urban_areas/perth_web-99a082a61e.jpg\"\n      }\n    }\n  </pre>\n</body>\n</html>\n","category":"","in":[{"x":40,"y":80,"wires":[{"id":"9f1bff4fcd2084db"}]}],"out":[{"x":900,"y":540,"wires":[{"id":"0fcb4e4e29c8e757","port":0}]}],"env":[{"name":"CITY","type":"str","value":"city_name"}],"meta":{},"color":"#DDAA99"},{"id":"9f1bff4fcd2084db","type":"function","z":"9820978c22086c87","name":"get basic data for city","func":"if (msg.city_name){\n    msg.url = `https://nominatim.openstreetmap.org/search?format=json&q=${msg.city_name}&addressdetails=1`;\n} else {\n    let city_name = env.get(\"CITY\").toLowerCase();\n    msg.city_name = city_name;\n    msg.url = `https://nominatim.openstreetmap.org/search?format=json&q=${city_name}&addressdetails=1`;\n    // console.log(msg.url);\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":220,"y":80,"wires":[["5dca3979a04ca36b"]]},{"id":"b8bb4745b7754be6","type":"http request","z":"9820978c22086c87","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":450,"y":260,"wires":[["a92354b730776eb0","df23645badb077e4"]]},{"id":"f3a576dbfa60c67a","type":"debug","z":"9820978c22086c87","name":"debug 87","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":880,"y":260,"wires":[]},{"id":"a92354b730776eb0","type":"function","z":"9820978c22086c87","name":"organize ranking","func":"var options = {};\n\ntry {\n    // console.log(msg.city);\n    var payload = msg.payload;\n    // msg.payload = JSON.parse(msg.payload);\n    if (payload.status === 404) {\n        return [null, msg];\n    }\n    // console.log(payload);\n    var url = payload._links.self.href;\n\n    var start = url.indexOf(\"slug:\") + 5; // Get the index of \"slug:\" and add 5 to skip over it\n    var end = url.indexOf(\"/\", start); // Get the index of the next \"/\" after \"slug:\"\n    var city_name = url.substring(start, end);\n\n    // console.log(citySlug);\n\n    //options.city_summary = payload.summary.replace(/(<([^>]+)>)/gi, \"\").trim();\n    var city_summary = payload.summary  // Remove HTML tags using regex\n        .replace(/<\\/?[^>]+(>|$)/g, \"\")\n        // Replace newline characters with empty string\n        .replace(/\\n/g, \"\")\n        .replace(/['\"]/g, \"\")\n        // Trim any remaining whitespace from beginning and end\n        .trim();\n\n    var city_rank = {};\n    for (var i = 0; i < payload.categories.length; i++) {\n        var categ = payload.categories[i];\n        var key = categ.name.replace(/[\\s&]+/g, '_').replace(/_{2,}/g, '_');\n        city_rank[key.toLowerCase()] = categ.score_out_of_10;\n        // console.log(key.toLowerCase()+\", \"+city_rank[key.toLowerCase()])\n    }\n\n    let lat = msg.city_lat;\n    let lng = msg.city_lng;\n    //options.geonameId = city_saved.geonameId;\n    //options.country_code = city_saved.country_code;\n    //options.continent_code = city_saved.continent_code;\n    msg.payload = { \"city\": city_name, \"lat\": lat, \"lng\": lng, \"rank\":city_rank};\n    return [msg, null];\n} catch (error) {\n    // does nothing\n    return [null, msg];\n}","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":670,"y":260,"wires":[["f3a576dbfa60c67a","55ba38960f7c3167"],[]]},{"id":"df23645badb077e4","type":"debug","z":"9820978c22086c87","name":"debug 88","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":640,"y":180,"wires":[]},{"id":"414654a93613b25f","type":"function","z":"9820978c22086c87","name":"get rankings","func":"msg.city_lat = parseFloat(msg.payload[0].lat);\nmsg.city_lng = parseFloat(msg.payload[0].lon);\nmsg.country = msg.payload[0].address.country_code.toUpperCase();;\nmsg.url = \"https://api.teleport.org/api/urban_areas/slug:\" + msg.city_name.toLowerCase() + \"/scores/\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":250,"y":260,"wires":[["b8bb4745b7754be6"]]},{"id":"5dca3979a04ca36b","type":"http request","z":"9820978c22086c87","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":250,"y":160,"wires":[["414654a93613b25f","d8a03eb8da0de489"]]},{"id":"d8a03eb8da0de489","type":"debug","z":"9820978c22086c87","name":"debug 89","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":460,"y":160,"wires":[]},{"id":"4d088ac286862301","type":"function","z":"9820978c22086c87","name":"gets weather forecast","func":"var options = [];\n// console.log(msg.city_name);\ntry {\n    var payload = msg.payload;\n    //console.log('payload.daily.city:', payload.city);\n    for (var i = 0; i < payload.daily.time.length; i++) {\n        var obj = {};\n        obj.time = payload.daily.time[i];\n        obj.weathercode = payload.daily.weathercode[i];\n        obj.temperature = parseFloat((payload.daily.temperature_2m_max[i] + payload.daily.temperature_2m_min[i]) / 2).toFixed(2);\n        obj.uv_index_max = payload.daily.uv_index_max[i];\n        obj.uv_index_clear_sky_max = payload.daily.uv_index_clear_sky_max[i];\n        obj.rain_sum = payload.daily.rain_sum[i];\n        obj.snowfall_sum = payload.daily.snowfall_sum[i];\n        obj.windspeed_10m_max = payload.daily.windspeed_10m_max[i];\n        obj.winddirection_10m_dominant = payload.daily.winddirection_10m_dominant[i];\n        obj.shortwave_radiation_sum = payload.daily.shortwave_radiation_sum[i];\n        //console.log(obj.city_name);\n        obj.temperature = parseFloat(obj.temperature);\n        options.push(obj);\n    }\n    msg.city.forecast = options;\n    msg.url = `https://api.teleport.org/api/urban_areas/slug:${msg.city.city}/images/`\n    return [msg, null];\n} catch (error) {\n    // does nothing\n    return [null, msg];\n}\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":640,"y":420,"wires":[["f5b897cc39dba4ea"]]},{"id":"60aa2057b15d162c","type":"http request","z":"9820978c22086c87","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":390,"y":420,"wires":[["4d088ac286862301"]]},{"id":"55ba38960f7c3167","type":"function","z":"9820978c22086c87","name":"req weather","func":"var city = msg.payload;\nmsg.url = `https://api.open-meteo.com/v1/forecast?latitude=${city.lat}&longitude=${city.lng}&daily=weathercode,temperature_2m_max,temperature_2m_min,uv_index_max,uv_index_clear_sky_max,rain_sum,snowfall_sum,windspeed_10m_max,winddirection_10m_dominant,shortwave_radiation_sum&current_weather=true&timezone=auto`\nmsg.city = msg.payload;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":530,"y":340,"wires":[["60aa2057b15d162c"]]},{"id":"f5b897cc39dba4ea","type":"http request","z":"9820978c22086c87","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":730,"y":480,"wires":[["0fcb4e4e29c8e757"]]},{"id":"0fcb4e4e29c8e757","type":"function","z":"9820978c22086c87","name":"sets to payload","func":"let photos = msg.payload.photos[0].image;\nmsg.city.photos = photos;\nmsg.payload = msg.city;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":540,"wires":[[]]}]
Created 2 years, 4 months ago
  • debug (x3)
  • function (x6)
  • http request (x4)
  • subflow (x1)
  • city
  • info
  • rank
  • weather
  • forecast
  • geo
