Adventskalender mit Telegram
Kleiner einfacher Adventskalender der den Telegram-Bot nutzt.
[{"id":"81945e5e.29fd7","type":"tab","label":"Adventskalender","disabled":false,"info":""},{"id":"acc9a497.885858","type":"telegram command","z":"81945e5e.29fd7","name":"","command":"/start","bot":"","strict":false,"hasresponse":true,"useregex":false,"removeregexcommand":false,"outputs":2,"x":90,"y":140,"wires":[["5d3c92e1.65c0bc"],[]]},{"id":"5d3c92e1.65c0bc","type":"function","z":"81945e5e.29fd7","name":"Keyboard erstellen","func":"var opts = {\n  reply_markup: JSON.stringify({\n    keyboard: [\n      ['10' , '4', '15', '22', '13', '5'],\n      ['20' , '17', '9', '6', '24', '16'],\n      ['3' , '14', '8', '1', '21', '23'],\n      ['7' , '2', '12', '18', '11', '19']],\n      'resize_keyboard' : true,\n      'one_time_keyboard' : true\n  })\n};\n\nmsg.payload.content = 'Start-Text...';\nmsg.payload.options = opts;\n\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":140,"wires":[["7c815ed.72eeca"]]},{"id":"7c815ed.72eeca","type":"telegram sender","z":"81945e5e.29fd7","name":"","bot":"","haserroroutput":false,"outputs":1,"x":850,"y":180,"wires":[[]]},{"id":"30ac90d5.7fc8b","type":"telegram receiver","z":"81945e5e.29fd7","name":"","bot":"","saveDataDir":"","filterCommands":false,"x":130,"y":240,"wires":[["516775e1.c50bdc"],[]]},{"id":"46494ce3.155b74","type":"function","z":"81945e5e.29fd7","name":"Adventskalender Türchen öffnen","func":"//Funktionen um Zeiten umzuwandeln\nfunction dateConvert(UNIX_timestamp) {\n  var dateObject = new Date((UNIX_timestamp) * 1000);\n  return dateObject.toLocaleString('de-DE', {  hour12: false, day: '2-digit', month: '2-digit', year: 'numeric', hour: 'numeric', minute: '2-digit'});\n}\nfunction dayConvert(UNIX_timestamp) {\n  var dateObject = new Date((UNIX_timestamp) * 1000);\n  return dateObject.toLocaleString('de-DE', { day: 'numeric'});\n}\nfunction unixConvert(DATUM){\n    return Math.floor(new Date(DATUM).getTime()/1000);\n}\n\n//Abspeichern welches Türchen geöffnet wird\ntuerchen = msg.payload.content;\n\n//Textbausteine die ausgegeben werden\ndatum_start       = \"2021-12-01 00:00:00\";\ndatum_ende        = \"2021-12-31 23:59:59\"; //Zeitraum, wie lange die Türchen noch geöffnet werden können. MAX: 2021-12-31\ntext_start        = \"Mensch, du bist aber neugierig. Das erste Türchen darst du erst am 01.12.2021 öffnen ;-). Hab noch etwas Geduld...\";\ntext_zukunft      = \"Du hast auf Türchen \" + tuerchen + \" geklickt, aber heute darfst du erst Türchen \" + dayConvert(msg.payload.date).toString() + \" öffnen...\\n\\nMöchtest du also schummeln und das Türchen früher öffnen? :-p\"\ntext_ende         = \"Die Türchen des Adventskalenders können leider nicht mehr geöffnet werden.\"\ntext_tuerchen     = [];\ntext_tuerchen[1]  = \"Text 1\";\ntext_tuerchen[2]  = \"Text 2\";\ntext_tuerchen[3]  = \"Text 3\";\ntext_tuerchen[4]  = \"Text 4\";\ntext_tuerchen[5]  = \"Text 5\";\ntext_tuerchen[6]  = \"Text 6\";\ntext_tuerchen[7]  = \"Text 7\";\ntext_tuerchen[8]  = \"Text 8\";\ntext_tuerchen[9]  = \"Text 9\";\ntext_tuerchen[10] = \"Text 10\";\ntext_tuerchen[11] = \"Text 11\";\ntext_tuerchen[12] = \"Text 12\";\ntext_tuerchen[13] = \"Text 13\";\ntext_tuerchen[14] = \"Text 14\";\ntext_tuerchen[15] = \"Text 15\";\ntext_tuerchen[16] = \"Text 16\";\ntext_tuerchen[17] = \"Text 17\";\ntext_tuerchen[18] = \"Text 18\";\ntext_tuerchen[19] = \"Text 19\";\ntext_tuerchen[20] = \"Text 20\";\ntext_tuerchen[21] = \"Text 21\";\ntext_tuerchen[22] = \"Text 22\";\ntext_tuerchen[23] = \"Text 23\";\ntext_tuerchen[24] = \"Text 24\";\n\n\nmsg.payload.type = 'message';\nmsg.payload.options = {parse_mode : \"Markdown\"};\n\n//Steuerung der Ausgabe\nif(msg.payload.date < unixConvert(datum_start)){\n    msg.payload.content = text_start;\n} else if (msg.payload.date > unixConvert(datum_ende)){\n    msg.payload.content = text_ende;\n} else {\n    aktuellerTag = dayConvert(msg.payload.date).toString();\n    if (Number(tuerchen) <= Number(aktuellerTag)){\n        msg.payload.content  = '*Türchen ' + tuerchen + ':*\\n';\n        msg.payload.content += text_tuerchen[tuerchen];\n        if (Number(tuerchen) < Number(aktuellerTag)){\n            msg.payload.content += '\\n\\n_(Das Türchen hättest du aber schon früher öffnen dürfen)_\\n';\n        }\n    } else {\n        msg.payload.content = text_zukunft;\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":240,"wires":[["7c815ed.72eeca"]]},{"id":"516775e1.c50bdc","type":"switch","z":"81945e5e.29fd7","name":"Check","property":"$number(msg.payload.content)","propertyType":"jsonata","rules":[{"t":"btwn","v":"1","vt":"num","v2":"24","v2t":"num"}],"checkall":"true","repair":false,"outputs":1,"x":310,"y":240,"wires":[["46494ce3.155b74"]]}]
Created 3 years, 11 months ago
Rating: 4.5 2
  • function (x2)
  • switch (x1)
  • Telegram
  • Adventskalender
  • christmas
