Time (sunset and sunrise) calculations
enter image description here You could use bigtimer node to play with time, or you can use JS time methods and open source API to calculate your own based on coordinates!
Complete instructions
Features:
  • tell you if it's night or day
  • tell you the sunrise and sunset time
  • tell you the day length
  • provide you with astronomical, nautical, civil dusk and dawn times
  • use these values to create timers
  • all that good stuff in your local time!
Settings
Configure Set Coords Subflow with your Lat and Long and the time variables will be available as globals.
More about me:
[{"id":"3c1a9880.5362b8","type":"subflow","name":"Set Coords","info":"","category":"","in":[{"x":540,"y":100,"wires":[{"id":"e4984393.2e0f"}]}],"out":[{"x":840,"y":100,"wires":[{"id":"e4984393.2e0f","port":0}]}],"env":[],"color":"#DDAA99"},{"id":"e4984393.2e0f","type":"function","z":"3c1a9880.5362b8","name":"set coords","func":"var lat = env.get(\"Latitude\"); \nvar long = env.get(\"Longitude\");\n\n\nflow.set(\"$parent.Latitude\", lat);    \nflow.set(\"$parent.Longitude\", long);\n\n\nmsg.payload = \"Your postition has been saved to: Latitude: \" + lat + \", Longitude: \" + long;\n\nreturn msg;\n\n\n","outputs":1,"noerr":0,"x":670,"y":100,"wires":[[]]},{"id":"b4f27448.856258","type":"tab","label":"Time (sunset and sunrise) calculations","disabled":false,"info":"![enter image description here](https://notenoughtech.com/wp-content/uploads/2019/02/YouTube_NEW1-2.jpg)\r\nYou could use bigtimer node to play with time, or you can use JS time methods and open source API to calculate your own based on coordinates! \r\n\r\n  [Complete instructions](https://notenoughtech.com/home-automation/nodered-home-automation/nodered-sun-and-time/)\r\n\r\n\r\n**Features**:\r\n-   tell you if it's **night** or **day**\r\n-   tell you the **sunrise** and **sunset time**\r\n-   tell you the **day length**\r\n-   provide you with **astronomical, nautical, civil dusk and dawn times**\r\n-   use these values to create timers\r\n-   **all that good stuff in your local time!**\r\n\r\n## Settings\r\nConfigure **Set Coords** Subflow with your Lat and Long and the time variables will be available as globals.\r\n\r\n## More about me:\r\n\r\nIf you want to get the latest updates to this project you can follow me via your preferred social media:\r\n\r\n-   [Facebook](https://www.facebook.com/NotEnoughTECH/)\r\n-   [Twitter](https://twitter.com/NotEnoughTECH)\r\n-   [Instagram](https://www.instagram.com/notenoughtech/)\r\n-   [YouTube](https://www.youtube.com/user/Polepositionpage)\r\n\r\nAnd if you feeling like buying me a coffee or supporting me in a more continuous way:\r\n\r\n-   [Paypal](https://www.paypal.me/notenoughtech)\r\n-   [Patreon](https://www.patreon.com/NotEnoughTECH)\r\n\r\nI hope you have enjoyed the project!"},{"id":"47d5e6ec.2151b8","type":"comment","z":"b4f27448.856258","name":"Get Sun Info (the easy way)","info":"","x":220,"y":120,"wires":[]},{"id":"68046019.da2bd","type":"function","z":"b4f27448.856258","name":"Is it night time yet? ","func":"var time = new Date();\nvar timeNow = time.getTime();\n\nvar sunsetToday  = global.get('Time_sunset');\nvar sunriseToday = global.get('Time_sunrise');\n\n\nif(timeNow < sunsetToday && timeNow > sunriseToday){\n    msg.payload = \"it's daytime\"\n    var x = \"day\";\n    global.set(\"TimeOfDay\", x)\n    \n}\n\nif(timeNow > sunriseToday && timeNow < sunsetToday){\n    msg.payload = \"it's night\";\n    x = \"night\";\n    global.set(\"TimeOfDay\", x)\n    \n}\n\nif(timeNow > sunsetToday){\n    msg.payload = \"it's day\"\n    x = \"day\";\n    global.set(\"TimeOfDay\", x)\n}\nif(timeNow < sunriseToday){\n    msg.payload = \"it's night\"\n    x = \"night\";\n    global.set(\"TimeOfDay\", x)\n}\n\n\nmsg.times = {\n    \"sunset\": sunsetToday,\n    \"sunrise\": sunriseToday,\n    \"time\": timeNow\n}\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":395,"y":335,"wires":[["f273179e.3b8c88"]]},{"id":"556196f6.0aae48","type":"inject","z":"b4f27448.856258","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":335,"wires":[["68046019.da2bd"]]},{"id":"f273179e.3b8c88","type":"debug","z":"b4f27448.856258","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":580,"y":335,"wires":[]},{"id":"76b7ffa3.d3a2f","type":"function","z":"b4f27448.856258","name":"Save Recalculated times (the easy way)","func":"let date = new Date()\ntimeZoneOffset = date.getTimezoneOffset() *60;\n\nfunction recalculateTime(x){\n    var z = new Date(x).valueOf();\n    var adjustedTime = (z/1000 + (-1* timeZoneOffset))*1000;\n    return new Date(adjustedTime);\n}\n\nfunction secondsToHms(d) {\n    d = Number(d);\n\n    var h = Math.floor(d / 3600);\n    var m = Math.floor(d % 3600 / 60);\n\n    return ('0' + h).slice(-2) + \"h \" + ('0' + m).slice(-2)+\"min\";\n}\n\nfunction stringtodate(timenow){\n    let date1 = Date.parse(timenow);\n    return date1;\n    \n}\n\n\n\n//sunrise\nvar sunrise = recalculateTime(msg.payload.results.sunrise);\nglobal.set('Time_sunrise', stringtodate(sunrise));\n\n\n//sunset\nvar sunset = recalculateTime(msg.payload.results.sunset);\nglobal.set('Time_sunset', stringtodate(sunset));\n\n//solar_noon\nvar solar_noon = recalculateTime(msg.payload.results.solar_noon);\nglobal.set('Time_solar_noon', solar_noon);\n\n//day_length\nvar day_length =  secondsToHms(msg.payload.results.day_length);\nglobal.set('Time_day_length', day_length);\n\n//civil_twilight_begin\nvar civil_twilight_begin = recalculateTime(msg.payload.results.civil_twilight_begin);\nglobal.set('Time_civil_twilight_begin', civil_twilight_begin);\n\n//civil_twilight_end\nvar civil_twilight_end = recalculateTime(msg.payload.results.civil_twilight_end);\nglobal.set('Time_civil_twilight_end', civil_twilight_end);\n\n//nautical_twilight_begin\nvar nautical_twilight_begin = recalculateTime(msg.payload.results.nautical_twilight_begin);\nglobal.set('Time_nautical_twilight_begin', nautical_twilight_begin);\n\n//nautical_twilight_end\nvar nautical_twilight_end = recalculateTime(msg.payload.results.nautical_twilight_end);\nglobal.set('Time_nautical_twilight_end', nautical_twilight_end);\n\n//astronomical_twilight_begin\nvar astronomical_twilight_begin = recalculateTime(msg.payload.results.astronomical_twilight_begin);\nglobal.set('Time_astronomical_twilight_begin', astronomical_twilight_begin);\n\n//astronomical_twilight_end\nvar astronomical_twilight_end = recalculateTime(msg.payload.results.astronomical_twilight_end);\nglobal.set('Time_astronomical_twilight_end', astronomical_twilight_end);\n\n\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":200,"wires":[["a792452e.0b27c8"]]},{"id":"587817ba.2103d8","type":"inject","z":"b4f27448.856258","name":"Get Sun info","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":200,"y":210,"wires":[["d9e937ee.73a7c8"]]},{"id":"d9e937ee.73a7c8","type":"function","z":"b4f27448.856258","name":"Get Sunset info","func":"var latitude = flow.get('Latitude');\nvar longitude = flow.get('Longitude');\n\n\nmsg.url = \"https://api.sunrise-sunset.org/json?&formatted=0&lat=\"+ latitude +\"&lng=\"+ longitude;\n\nreturn msg;\n\n//https://sunrise-sunset.org/api\n\n\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":375,"y":210,"wires":[["2b681956.c78bd6"]]},{"id":"2b681956.c78bd6","type":"http request","z":"b4f27448.856258","name":"","method":"GET","ret":"obj","paytoqs":false,"url":"","tls":"","persist":false,"proxy":"","authType":"","x":545,"y":210,"wires":[["76b7ffa3.d3a2f"]]},{"id":"1a2319d2.2a7926","type":"comment","z":"b4f27448.856258","name":"Is it night time yet","info":"","x":205,"y":290,"wires":[]},{"id":"a792452e.0b27c8","type":"debug","z":"b4f27448.856258","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1220,"y":210,"wires":[]},{"id":"ce90dae6.7520f8","type":"subflow:3c1a9880.5362b8","z":"b4f27448.856258","name":"","env":[{"name":"Latitude","value":"54.5232866","type":"num"},{"name":"Longitude","value":"-1.3063204","type":"num"}],"x":360,"y":160,"wires":[["e6cea506.9a7e68"]],"icon":"node-red/cog.svg"},{"id":"ab1eeb84.8d6308","type":"inject","z":"b4f27448.856258","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":210,"y":160,"wires":[["ce90dae6.7520f8"]]},{"id":"e6cea506.9a7e68","type":"debug","z":"b4f27448.856258","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":530,"y":160,"wires":[]}]
Created 7 years ago
Updated 6 years, 8 months ago
  • comment (x2)
  • debug (x3)
  • function (x4)
  • http request (x1)
  • inject (x3)
  • subflow (x1)
  • subflow:3c1a9880.5362b8 (x1)
  • time
  • sunset
  • sunrise
  • timezones
  • coordinates
  • nautical
  • twilight
  • astronomical
  • civil
