EXAMPLE - using an external javascript in a function node
This example show how to use an eternal NPM javascript in a function node. This example uses tinycolor.js to test an RGB color to see if it is 'light' or 'dark'.
** Setup **
  1. Go to the node-red directory
  • cd .node-red
  1. Install tinycolor.js
  • npm install tinycolor2.js
  1. Backup your settings file incase something goes wrong.
  • cp settings.js settings.bkup
  1. Edit settings.js and find the section functionGlobalContext: { it should look like this
        // os:require('os'),
        // jfive:require("johnny-five"),
        // j5board:require("johnny-five").Board({repl:false})
add the following tinycolor: require('tinycolor2'), to the begining so you will have:
NOTE: if you have more than one entry, all but the last need a comma at the end.
  1. Save the file and restart NR. If the restart get an error, re-edit settings.js and make sure you don't have a typo.
In ** Node-RED ** in a function node you can now use the file
var tinycolor = global.get('tinycolor')
var color1 = tinycolor(msg.payload);
var t1 = color1.isDark(); // false
msg.payload = ("Is "+ color1 + " dark? "+ t1);
here is a sample flow with two inject nodes sending #000 and #FFF
flow_using_tinycolor-js
There are other things you can use in the function node like isLight() and isReadable() feel free to read about what you can do at https://github.com/bgrins/TinyColor
[{"id":"a61a8c88.442398","type":"inject","z":"cdaab1fb.ab33a","name":"","topic":"","payload":"#000000","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":200,"y":140,"wires":[["e8f2fcfe.764c3"]]},{"id":"d987f969.79c86","type":"debug","z":"cdaab1fb.ab33a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":690,"y":180,"wires":[]},{"id":"e8f2fcfe.764c3","type":"function","z":"cdaab1fb.ab33a","name":"Check if color is light or dark","func":"var tinycolor = global.get('tinycolor')\n\nvar color1 = tinycolor(msg.payload);\nvar t1 = color1.isDark(); // false\nmsg.payload = (\"Is \"+ color1 + \" dark? \"+ t1);\nreturn msg;\n","outputs":1,"noerr":0,"x":440,"y":180,"wires":[["d987f969.79c86"]]},{"id":"5cfc8e7.a5d60f","type":"inject","z":"cdaab1fb.ab33a","name":"","topic":"","payload":"#ffffff","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":220,"wires":[["e8f2fcfe.764c3"]]}]
Created 8 years ago
Rating: 5 1
  • inject (x2)
  • color
  • external
  • javascript
  • function
  • npm
  • module
  • example
