Yoksetio
Yoksetio
[{"id":"41d10160.e53ba8","type":"tab","label":"Datos sensores","disabled":false,"info":""},{"id":"b1e7f66a.5f1258","type":"tab","label":"Gestión de errores","disabled":false,"info":""},{"id":"244bdfbb.58bcb","type":"tab","label":"Botones de Usuario","disabled":false,"info":""},{"id":"12a47bad.1bc6dc","type":"tab","label":"Estacion base","disabled":false,"info":""},{"id":"ac0436b7.6b1618","type":"subflow","name":"Subflow 1","info":"","in":[],"out":[]},{"id":"506606c5.1898b8","type":"ui_base","theme":{"name":"theme-light","lightTheme":{"default":"#0094CE","baseColor":"#0094CE","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#097479","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#0094CE","value":"#0094CE","edited":false},"page-titlebar-backgroundColor":{"value":"#0094CE","edited":false},"page-backgroundColor":{"value":"#fafafa","edited":false},"page-sidebar-backgroundColor":{"value":"#ffffff","edited":false},"group-textColor":{"value":"#1bbfff","edited":false},"group-borderColor":{"value":"#ffffff","edited":false},"group-backgroundColor":{"value":"#ffffff","edited":false},"widget-textColor":{"value":"#111111","edited":false},"widget-backgroundColor":{"value":"#0094ce","edited":false},"widget-borderColor":{"value":"#ffffff","edited":false},"base-font":{"value":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"}}},"site":{"name":"Huertica","hideToolbar":"false","allowSwipe":"false","dateFormat":"DD/MM/YYYY","sizes":{"sx":48,"sy":48,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"76c1c200.77b34","type":"ui_group","z":"","name":"Sensor DHT22","tab":"","order":2,"disp":true,"width":"6"},{"id":"6be5d57f.6c609c","type":"mongodb","z":"","hostname":"127.0.0.1","port":"27017","db":"demo","name":""},{"id":"93177231.4afb3","type":"ui_group","z":"","name":"Historial BD (mongodb)","tab":"","order":1,"disp":true,"width":"7"},{"id":"6f686040.6c3ab","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"490647d7.3b584","type":"mqtt-broker","z":"","broker":"","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"f1b55d8f.99f088","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"ba450570.8c5f6","type":"ui_group","z":"","name":"Prueba","tab":"","order":1,"disp":true,"width":"6"},{"id":"154b2d34.dac373","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"b7b40b93.af6ff8","type":"ui_group","z":"","name":"Ambiente","tab":"","disp":true,"width":"6"},{"id":"4a81968f.8ad9b8","type":"ui_group","z":"","name":"Nodo","tab":"","order":3,"disp":true,"width":"6"},{"id":"3c5d2965.708d76","type":"mongodb","z":"","hostname":"localhost","port":"27017","db":"huertica","name":""},{"id":"2d6435ab.b7cfba","type":"ui_group","z":"","name":"Suelo","tab":"","order":2,"disp":true,"width":"6"},{"id":"f8977108.fd9f78","type":"ui_group","z":"","name":"Configuracion","tab":"","order":3,"disp":true,"width":"6"},{"id":"95fcc498.a998a8","type":"ui_group","z":"","name":"Actuador","tab":"","order":4,"disp":true,"width":"6"},{"id":"d7530433.ce1bd8","type":"ui_group","z":"","name":"Configuracion actual","tab":"","order":2,"disp":true,"width":"6"},{"id":"4942f9fe.157ab8","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"4dd47ef.51e048","type":"ui_group","z":"","name":"Registro de errores","tab":"b05301d5.50299","order":5,"disp":true,"width":"6"},{"id":"983d4956.9c84e","type":"mongodb","z":"","hostname":"localhost","port":"27017","db":"huertica","name":""},{"id":"b4cc2ac0.bdcd28","type":"ui_tab","z":"","name":"Raspberry Pi","icon":"dashboard"},{"id":"b484d335.132078","type":"ui_group","z":"","name":"Sensor DHT22","tab":"","order":2,"disp":true,"width":"6"},{"id":"9ed14fed.253908","type":"mongodb","z":"","hostname":"127.0.0.1","port":"27017","db":"demo","name":""},{"id":"5c948ea9.863168","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"bdb4c262.2a4ae8","type":"mqtt-broker","z":"","broker":"","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"8553a50e.55c8e","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"58b04259.c78b74","type":"ui_group","z":"","name":"Prueba","tab":"","order":1,"disp":true,"width":"6"},{"id":"b6f524eb.3b36c","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""},{"id":"b0af091f.f6c65","type":"ui_group","z":"","name":"Ambiente","tab":"b05301d5.50299","order":2,"disp":true,"width":"6"},{"id":"a0c3b539.21d498","type":"ui_group","z":"","name":"Nodo","tab":"b05301d5.50299","order":4,"disp":true,"width":"6"},{"id":"61ec6f13.2d4cb8","type":"mongodb","z":"","hostname":"localhost","port":"27017","db":"huertica","name":""},{"id":"6729f3c1.67525c","type":"ui_group","z":"","name":"Suelo","tab":"b05301d5.50299","order":3,"disp":true,"width":"6"},{"id":"b05301d5.50299","type":"ui_tab","z":"","name":"Nodo1","icon":"dashboard","order":2},{"id":"a8d9c809.feb78","type":"ui_group","z":"","name":"Configuracion","tab":"b4cc2ac0.bdcd28","order":3,"disp":true,"width":"6"},{"id":"528ecc28.61d4dc","type":"ui_group","z":"","name":"Actuador","tab":"b4cc2ac0.bdcd28","order":4,"disp":true,"width":"6"},{"id":"abf138f6.3eb88","type":"ui_group","z":"","name":"Configuracion actual","tab":"b4cc2ac0.bdcd28","order":2,"disp":true,"width":"6"},{"id":"bea9a8d1.a58b6","type":"ui_group","z":"","name":"Peticion de lecturas","tab":"b05301d5.50299","order":1,"disp":true,"width":"6"},{"id":"96d8ffdc.a8dd08","type":"debug","z":"41d10160.e53ba8","name":"","active":true,"console":"false","complete":"payload","x":780,"y":100,"wires":[]},{"id":"4017cd3e.7d4d24","type":"mqtt in","z":"41d10160.e53ba8","name":"","topic":"huertica/nodo1/datos","qos":"2","broker":"b6f524eb.3b36c","x":180,"y":400,"wires":[["c37b8be7.6d744"]]},{"id":"bfe05941.645c","type":"ui_gauge","z":"41d10160.e53ba8","name":"","group":"b0af091f.f6c65","order":1,"width":0,"height":0,"gtype":"gage","title":"Temperatura aire","label":"ºC","format":"{{value}}","min":0,"max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1050,"y":180,"wires":[]},{"id":"e2eaecda.f7d738","type":"change","z":"41d10160.e53ba8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.temperaturaA","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":805,"y":187,"wires":[["bfe05941.645c"]]},{"id":"c37b8be7.6d744","type":"json","z":"41d10160.e53ba8","name":"","pretty":false,"x":430,"y":400,"wires":[["e2eaecda.f7d738","6cb5146a.b0776c","962b256d.d1bc5","f610c5d2.aab7a","66e87def.4e47fc","d8d4d38a.eab428","c2637785.331728","29d6401a.3e94b","a9f1555e.a5e4c8","96d8ffdc.a8dd08","89ea9f46.34249","1c47e2a5.3867bd"]]},{"id":"6cb5146a.b0776c","type":"ui_text","z":"41d10160.e53ba8","group":"a0c3b539.21d498","order":2,"width":0,"height":0,"name":"","label":"Fecha","format":"{{msg.payload.fecha}}","layout":"row-spread","x":770,"y":560,"wires":[]},{"id":"962b256d.d1bc5","type":"ui_text","z":"41d10160.e53ba8","group":"a0c3b539.21d498","order":3,"width":0,"height":0,"name":"","label":"Hora","format":"{{msg.payload.hora}}","layout":"row-spread","x":770,"y":620,"wires":[]},{"id":"f610c5d2.aab7a","type":"change","z":"41d10160.e53ba8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.humedadA","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":811,"y":316,"wires":[["97e6426b.b7e578"]]},{"id":"97e6426b.b7e578","type":"ui_gauge","z":"41d10160.e53ba8","name":"","group":"b0af091f.f6c65","order":2,"width":0,"height":0,"gtype":"gage","title":"Humedad aire","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1061,"y":296,"wires":[]},{"id":"66e87def.4e47fc","type":"mongodb out","z":"41d10160.e53ba8","mongodb":"61ec6f13.2d4cb8","name":"","collection":"datos","payonly":true,"upsert":false,"multi":false,"operation":"store","x":850,"y":800,"wires":[]},{"id":"b87da196.6dabc","type":"ui_gauge","z":"41d10160.e53ba8","name":"","group":"6729f3c1.67525c","order":1,"width":0,"height":0,"gtype":"gage","title":"Temperatura suelo","label":"ºC","format":"{{value}}","min":0,"max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1061,"y":236,"wires":[]},{"id":"d8d4d38a.eab428","type":"change","z":"41d10160.e53ba8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.temperaturaS","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":806,"y":243,"wires":[["b87da196.6dabc"]]},{"id":"4901f1a6.5468c","type":"ui_gauge","z":"41d10160.e53ba8","name":"","group":"6729f3c1.67525c","order":2,"width":0,"height":0,"gtype":"gage","title":"Humedad suelo","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1071,"y":356,"wires":[]},{"id":"c2637785.331728","type":"change","z":"41d10160.e53ba8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.humedadS","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":811,"y":376,"wires":[["4901f1a6.5468c"]]},{"id":"29d6401a.3e94b","type":"change","z":"41d10160.e53ba8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.luz","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":810,"y":440,"wires":[["a7910c3a.e268b"]]},{"id":"a7910c3a.e268b","type":"ui_gauge","z":"41d10160.e53ba8","name":"","group":"b0af091f.f6c65","order":3,"width":0,"height":0,"gtype":"gage","title":"Luz","label":"lm","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1031,"y":436,"wires":[]},{"id":"a9f1555e.a5e4c8","type":"change","z":"41d10160.e53ba8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.bateria","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":810,"y":500,"wires":[["25fe8557.1ffa32"]]},{"id":"25fe8557.1ffa32","type":"ui_gauge","z":"41d10160.e53ba8","name":"","group":"a0c3b539.21d498","order":1,"width":0,"height":0,"gtype":"gage","title":"Bateria","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1041,"y":496,"wires":[]},{"id":"2bbce20d.6ddff6","type":"mqtt out","z":"12a47bad.1bc6dc","name":"","topic":"huertica/nodo1/configuracion","qos":"","retain":"","broker":"5c948ea9.863168","x":950,"y":180,"wires":[]},{"id":"b05e4c5a.ede16","type":"json","z":"12a47bad.1bc6dc","name":"","pretty":false,"x":650,"y":180,"wires":[["2bbce20d.6ddff6"]]},{"id":"8e247f32.a9cba","type":"ui_form","z":"12a47bad.1bc6dc","name":"Config hibernacion","label":"","group":"a8d9c809.feb78","order":1,"width":0,"height":0,"options":[{"label":"Hibernacion","value":"hibernacion","type":"number","required":true},{"label":"Periodos","value":"envio","type":"number","required":false}],"formValue":{"hibernacion":"","envio":""},"payload":"","topic":"","x":430,"y":180,"wires":[["b05e4c5a.ede16","809006d3.26aba8","cc8004d7.53384"]]},{"id":"ce9e9720.ccc388","type":"mqtt out","z":"12a47bad.1bc6dc","name":"","topic":"huertica/nodo2/peticion","qos":"","retain":"","broker":"5c948ea9.863168","x":930,"y":380,"wires":[]},{"id":"27512c09.f1ac44","type":"ui_form","z":"12a47bad.1bc6dc","name":"Activacion actuador","label":"","group":"528ecc28.61d4dc","order":1,"width":0,"height":0,"options":[{"label":"Actuador","value":"encendido","type":"switch","required":true},{"label":"Duracion","value":"duracion","type":"number","required":true}],"formValue":{"encendido":false,"duracion":""},"payload":"","topic":"","x":430,"y":380,"wires":[["86b72ffc.a47528"]]},{"id":"86b72ffc.a47528","type":"json","z":"12a47bad.1bc6dc","name":"","pretty":false,"x":650,"y":380,"wires":[["ce9e9720.ccc388"]]},{"id":"5b524eac.b2d08","type":"mqtt in","z":"12a47bad.1bc6dc","name":"","topic":"huertica/nodo2/confirmacion","qos":"2","broker":"b6f524eb.3b36c","x":360,"y":560,"wires":[["e219c006.223e8"]]},{"id":"e219c006.223e8","type":"json","z":"12a47bad.1bc6dc","name":"","pretty":false,"x":630,"y":560,"wires":[["f0418343.e96e3"]]},{"id":"f0418343.e96e3","type":"change","z":"12a47bad.1bc6dc","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.encendido","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":560,"wires":[["bc6eb4d.b3de148","3719bcaf.cd5cc4"]]},{"id":"bc6eb4d.b3de148","type":"ui_toast","z":"12a47bad.1bc6dc","position":"top right","displayTime":"3","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"Estado del actuador","name":"","x":1090,"y":560,"wires":[]},{"id":"809006d3.26aba8","type":"ui_text","z":"12a47bad.1bc6dc","group":"abf138f6.3eb88","order":1,"width":0,"height":0,"name":"","label":"Hibernacion","format":"{{msg.payload.hibernacion}}","layout":"row-spread","x":890,"y":80,"wires":[]},{"id":"cc8004d7.53384","type":"ui_text","z":"12a47bad.1bc6dc","group":"abf138f6.3eb88","order":2,"width":0,"height":0,"name":"","label":"Envio","format":"{{msg.payload.envio}}","layout":"row-spread","x":870,"y":120,"wires":[]},{"id":"3719bcaf.cd5cc4","type":"ui_switch","z":"12a47bad.1bc6dc","name":"","label":"Actuador","group":"abf138f6.3eb88","order":0,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":1060,"y":500,"wires":[[]]},{"id":"7e61546a.9d0d1c","type":"mqtt in","z":"b1e7f66a.5f1258","name":"","topic":"huertica/nodo1/error","qos":"2","broker":"4942f9fe.157ab8","x":120,"y":340,"wires":[["ee411c35.f0d72"]]},{"id":"ee411c35.f0d72","type":"json","z":"b1e7f66a.5f1258","name":"","pretty":false,"x":310,"y":340,"wires":[["57ebb20f.c96a4c","8d6a4400.fe09","6ebc0ebc.7bd4f8","fa9fa395.a4a6c8","c99168b1.98c46","e4591ef8.3e9a88","3b54f67f.8920fa"]]},{"id":"57ebb20f.c96a4c","type":"mongodb out","z":"b1e7f66a.5f1258","mongodb":"983d4956.9c84e","name":"","collection":"errores","payonly":true,"upsert":false,"multi":false,"operation":"store","x":640,"y":540,"wires":[]},{"id":"8d6a4400.fe09","type":"debug","z":"b1e7f66a.5f1258","name":"","active":true,"console":"false","complete":"payload","x":580,"y":160,"wires":[]},{"id":"fa9fa395.a4a6c8","type":"ui_text","z":"b1e7f66a.5f1258","group":"4dd47ef.51e048","order":4,"width":0,"height":0,"name":"","label":"Fecha","format":"{{msg.payload.fecha}}","layout":"row-spread","x":550,"y":340,"wires":[]},{"id":"6ebc0ebc.7bd4f8","type":"ui_text","z":"b1e7f66a.5f1258","group":"4dd47ef.51e048","order":2,"width":0,"height":0,"name":"","label":"Error","format":"{{msg.payload.codigo}}","layout":"row-spread","x":550,"y":280,"wires":[]},{"id":"c99168b1.98c46","type":"ui_text","z":"b1e7f66a.5f1258","group":"4dd47ef.51e048","order":3,"width":0,"height":0,"name":"","label":"Hora","format":"{{msg.payload.hora}}","layout":"row-spread","x":550,"y":400,"wires":[]},{"id":"fb07bd5b.7e7bc8","type":"ui_button","z":"244bdfbb.58bcb","name":"","group":"bea9a8d1.a58b6","order":1,"width":0,"height":0,"passthru":false,"label":"DHT","color":"","bgcolor":"","icon":"","payload":"{\"sensor\":\"DHT\"}","payloadType":"json","topic":"","x":430,"y":260,"wires":[["8a4d9393.88fca8"]]},{"id":"8a4d9393.88fca8","type":"mqtt out","z":"244bdfbb.58bcb","name":"","topic":"huertica/nodo1/peticiones","qos":"","retain":"","broker":"6f686040.6c3ab","x":850,"y":320,"wires":[]},{"id":"e4591ef8.3e9a88","type":"ui_text","z":"b1e7f66a.5f1258","group":"4dd47ef.51e048","order":1,"width":0,"height":0,"name":"","label":"Sensor","format":"{{msg.payload.tipo}}","layout":"row-spread","x":560,"y":220,"wires":[]},{"id":"d2db32fa.861c1","type":"ui_button","z":"244bdfbb.58bcb","name":"","group":"bea9a8d1.a58b6","order":2,"width":0,"height":0,"passthru":false,"label":"Luz","color":"","bgcolor":"","icon":"","payload":"{\"sensor\":\"luz\"}","payloadType":"json","topic":"","x":430,"y":300,"wires":[["8a4d9393.88fca8"]]},{"id":"25d36d88.f924ba","type":"ui_button","z":"244bdfbb.58bcb","name":"","group":"bea9a8d1.a58b6","order":4,"width":0,"height":0,"passthru":false,"label":"Sonda Temperatura","color":"","bgcolor":"","icon":"","payload":"{\"sensor\":\"senTem\"}","payloadType":"json","topic":"","x":480,"y":340,"wires":[["8a4d9393.88fca8"]]},{"id":"9fd7ed49.d5e688","type":"ui_button","z":"244bdfbb.58bcb","name":"","group":"bea9a8d1.a58b6","order":3,"width":0,"height":0,"passthru":false,"label":"Sonda Humedad","color":"","bgcolor":"","icon":"","payload":"{\"sensor\":\"senHum\"}","payloadType":"json","topic":"","x":470,"y":380,"wires":[["8a4d9393.88fca8"]]},{"id":"f5ccd0f7.0814b8","type":"ui_button","z":"244bdfbb.58bcb","name":"","group":"bea9a8d1.a58b6","order":5,"width":0,"height":0,"passthru":false,"label":"Bateria","color":"","bgcolor":"","icon":"","payload":"{\"sensor\":\"bateria\"}","payloadType":"json","topic":"","x":440,"y":420,"wires":[["8a4d9393.88fca8"]]},{"id":"62d9016.251568","type":"mqtt in","z":"12a47bad.1bc6dc","name":"","topic":"huertica/nodo1/despierto","qos":"2","broker":"b6f524eb.3b36c","x":410,"y":280,"wires":[["abc82ac2.d85e","37775b76.88d844"]]},{"id":"abc82ac2.d85e","type":"mqtt out","z":"12a47bad.1bc6dc","name":"","topic":"huertica/nodo1/timer","qos":"","retain":"","broker":"5c948ea9.863168","x":940,"y":280,"wires":[]},{"id":"37775b76.88d844","type":"debug","z":"12a47bad.1bc6dc","name":"","active":true,"console":"false","complete":"payload","x":730,"y":240,"wires":[]},{"id":"eb74cd60.b787c","type":"mqtt in","z":"12a47bad.1bc6dc","name":"","topic":"huertica/nodo1/despierto","qos":"2","broker":"b6f524eb.3b36c","x":350,"y":660,"wires":[["3c38b501.f9c93a"]]},{"id":"3c38b501.f9c93a","type":"json","z":"12a47bad.1bc6dc","name":"","pretty":false,"x":630,"y":660,"wires":[["533f281a.169bb8","d0c8c19e.9b73e8","916ca4d5.040ea","886d38a1.4c2c78","3e3c26ac.e6b09a"]]},{"id":"3b54f67f.8920fa","type":"ui_text","z":"b1e7f66a.5f1258","group":"4dd47ef.51e048","order":3,"width":0,"height":0,"name":"","label":"ID Nodo","format":"{{msg.payload.id}}","layout":"row-spread","x":560,"y":460,"wires":[]},{"id":"89ea9f46.34249","type":"ui_text","z":"41d10160.e53ba8","group":"a0c3b539.21d498","order":3,"width":0,"height":0,"name":"","label":"ID Nodo","format":"{{msg.payload.proximo}}","layout":"row-spread","x":780,"y":680,"wires":[]},{"id":"1c47e2a5.3867bd","type":"ui_text","z":"41d10160.e53ba8","group":"a0c3b539.21d498","order":3,"width":0,"height":0,"name":"","label":"Proximo","format":"{{msg.payload.proximo}}","layout":"row-spread","x":780,"y":740,"wires":[]},{"id":"533f281a.169bb8","type":"ui_text","z":"12a47bad.1bc6dc","group":"4dd47ef.51e048","order":4,"width":0,"height":0,"name":"","label":"Fecha","format":"{{msg.payload.fecha}}","layout":"row-spread","x":830,"y":640,"wires":[]},{"id":"d0c8c19e.9b73e8","type":"ui_text","z":"12a47bad.1bc6dc","group":"4dd47ef.51e048","order":3,"width":0,"height":0,"name":"","label":"Hora","format":"{{msg.payload.hora}}","layout":"row-spread","x":830,"y":700,"wires":[]},{"id":"916ca4d5.040ea","type":"ui_text","z":"12a47bad.1bc6dc","group":"4dd47ef.51e048","order":3,"width":0,"height":0,"name":"","label":"ID Nodo","format":"{{msg.payload.id}}","layout":"row-spread","x":840,"y":760,"wires":[]},{"id":"886d38a1.4c2c78","type":"ui_text","z":"12a47bad.1bc6dc","group":"4dd47ef.51e048","order":3,"width":0,"height":0,"name":"","label":"Proximo","format":"{{msg.payload.proximo}}","layout":"row-spread","x":840,"y":820,"wires":[]},{"id":"3e3c26ac.e6b09a","type":"mongodb out","z":"12a47bad.1bc6dc","mongodb":"61ec6f13.2d4cb8","name":"","collection":"Control","payonly":true,"upsert":false,"multi":false,"operation":"store","x":920,"y":880,"wires":[]}]
Created 8 years, 11 months ago
  • change (x7)
  • debug (x3)
  • json (x6)
  • mqtt in (x5)
  • mqtt out (x4)
  • mqtt-broker (x9)
  • mongodb (x5)
  • mongodb out (x3)
  • subflow (x1)
  • tab (x4)
  • ui_base (x1)
  • ui_button (x5)
  • ui_form (x2)
  • ui_gauge (x6)
  • ui_group (x19)
  • ui_switch (x1)
  • ui_tab (x2)
  • ui_text (x15)
  • ui_toast (x1)
  • yoksetio
