Siemens S5Time converter
Simply convert Seconds to Siemens S5Time format and backwards.
If you want to read siemens s5time format with the node-red-contrib-s7 node you will get back a number. Because s5time is not saving informations in seconds. You can see the s5time format here: Link
i.e. DB100 DBW34 (S5Time) youse DB100,I34 within the s7 node to get back the time.
Need to install:
  • node-red-contrib-calc
  • node-red-contrib-buffer-parser
Yousefull to install:
  • node-red-contrib-s7
Input:
  • Input must be an number!
  • set msg.topic to S5TimeToSec or
  • set msg.topic to SecToS5Time
Output:
  • Output 1 = Seconds
  • Output 2 = S5Time
[{"id":"1e1c3849.dc4d3","type":"subflow","name":"S5Time converter","info":"### **Simply convert Seconds to Siemens S5Time format and backwards.**\n\nIf you want to read siemens s5time format with the _node-red-contrib-s7_ node you will get back a number. Because s5time is not saving informations in seconds. You can see the s5time format here: [Link](http://www.plctalk.net/qanda/uploads/s5time.JPG)\n\ni.e. DB100 DBW34 (S5Time) youse DB100,I34 within the s7 node to get back the time.\n\n# Need to install:\n - node-red-contrib-calc\n - node-red-contrib-buffer-parser\n\n# Yousefull to install:\n - node-red-contrib-s7\n\n# Input:\n * Input must be an number!\n * set _msg.topic_ to **S5TimeToSec** or\n * set _msg.topic_ to **SecToS5Time**\n \n# Output:\n *  Output 1 = Seconds\n *  Output 2 = S5Time","category":"plc","in":[{"x":60,"y":460,"wires":[{"id":"1df6ddc6.1d444a"}]}],"out":[{"x":2220,"y":940,"wires":[{"id":"603744d0.c26ab4","port":0}]},{"x":3980,"y":1460,"wires":[{"id":"7d4c9c56.d5b49c","port":0}]}],"env":[],"meta":{"version":"1.0.0","author":"Sojer Philipp","desc":"Simply convert Seconds to Siemens S5Time format and backwards."},"color":"#F3B567","outputLabels":["S5Time > Sec","Sec > S5time"],"icon":"node-red/swap.svg","status":{"x":620,"y":100,"wires":[{"id":"8bc2a48.19386d8","port":0},{"id":"d7dda54d.17c498","port":0}]}},{"id":"b70396c0.35d128","type":"switch","z":"1e1c3849.dc4d3","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"S5TimeToSec","vt":"str"},{"t":"eq","v":"SecToS5Time","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":390,"y":420,"wires":[["7d0f6f84.eab2f8","36102e02.c60c32"],["ef9008d.7e2faf8","36102e02.c60c32"]]},{"id":"954995ab.4bdbb","type":"buffer-maker","z":"1e1c3849.dc4d3","name":"Number to Buffer","specification":"spec","specificationType":"ui","items":[{"name":"item1","type":"int16be","length":1,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":250,"y":800,"wires":[["b44978f.cac1e88"]]},{"id":"b44978f.cac1e88","type":"buffer-parser","z":"1e1c3849.dc4d3","name":"Buffer to Bool","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"bool","name":"Zeitbasis","offset":0,"length":2,"offsetbit":4,"scale":"0","mask":"48"},{"type":"bool","name":"Hunderterstelle","offset":0,"length":4,"offsetbit":0,"scale":"0","mask":"15"},{"type":"bool","name":"Zehnerstelle","offset":1,"length":4,"offsetbit":4,"scale":"0","mask":"240"},{"type":"bool","name":"Einerstelle","offset":1,"length":4,"offsetbit":0,"scale":"0","mask":"15"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":460,"y":800,"wires":[["9bc51649.992a08","50730e23.4c2c2","cf38547d.9e66f","8ec8c897.6a6f7"]]},{"id":"7ed01fa6.b9ae9","type":"buffer-maker","z":"1e1c3849.dc4d3","name":"","specification":"spec","specificationType":"ui","items":[{"name":"item1","type":"bool","length":1,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":930,"y":740,"wires":[["9cfe61c4.53b778"]]},{"id":"9bc51649.992a08","type":"change","z":"1e1c3849.dc4d3","name":"Zeitbasis","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.Zeitbasis","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":740,"wires":[["7ed01fa6.b9ae9"]]},{"id":"50730e23.4c2c2","type":"change","z":"1e1c3849.dc4d3","name":"Hunderterstelle","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.Hunderterstelle","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":780,"wires":[["81443a32.1a0878"]]},{"id":"cf38547d.9e66f","type":"change","z":"1e1c3849.dc4d3","name":"Zehnerstelle","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.Zehnerstelle","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":820,"wires":[["9bf34755.5c798"]]},{"id":"8ec8c897.6a6f7","type":"change","z":"1e1c3849.dc4d3","name":"Einerstelle","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.Einerstelle","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":860,"wires":[["438f85c4.547acc"]]},{"id":"81443a32.1a0878","type":"buffer-maker","z":"1e1c3849.dc4d3","name":"","specification":"spec","specificationType":"ui","items":[{"name":"item1","type":"bool","length":1,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":930,"y":780,"wires":[["96612980.c0c3e8"]]},{"id":"9bf34755.5c798","type":"buffer-maker","z":"1e1c3849.dc4d3","name":"","specification":"spec","specificationType":"ui","items":[{"name":"item1","type":"bool","length":1,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":930,"y":820,"wires":[["d1f4b836.d4ce98"]]},{"id":"438f85c4.547acc","type":"buffer-maker","z":"1e1c3849.dc4d3","name":"","specification":"spec","specificationType":"ui","items":[{"name":"item1","type":"bool","length":1,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":930,"y":860,"wires":[["d59db912.55d86"]]},{"id":"14dc6f4a.4976b1","type":"switch","z":"1e1c3849.dc4d3","name":"Zeitbasis filtern","property":"payload.item1","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"3","vt":"str"}],"checkall":"true","repair":false,"outputs":4,"x":1420,"y":680,"wires":[["e1a3368.e700748"],["71cd7ffc.46e4a8"],["25f7a084.7f29a8"],["b7c02ec6.4cf6b8"]]},{"id":"e1a3368.e700748","type":"change","z":"1e1c3849.dc4d3","name":"0,01sec","rules":[{"t":"set","p":"Zeitbasis","pt":"flow","to":"0.01","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1620,"y":620,"wires":[[]]},{"id":"71cd7ffc.46e4a8","type":"change","z":"1e1c3849.dc4d3","name":"0,1sec","rules":[{"t":"set","p":"Zeitbasis","pt":"flow","to":"0.1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1610,"y":660,"wires":[[]]},{"id":"25f7a084.7f29a8","type":"change","z":"1e1c3849.dc4d3","name":"1sec","rules":[{"t":"set","p":"Zeitbasis","pt":"flow","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1610,"y":700,"wires":[[]]},{"id":"b7c02ec6.4cf6b8","type":"change","z":"1e1c3849.dc4d3","name":"10sec","rules":[{"t":"set","p":"Zeitbasis","pt":"flow","to":"10","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1610,"y":740,"wires":[[]]},{"id":"d28d6c23.64f7a","type":"change","z":"1e1c3849.dc4d3","name":"speichere Hunderterstelle","rules":[{"t":"set","p":"Hunderterstelle","pt":"flow","to":"payload.item1","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1670,"y":780,"wires":[[]]},{"id":"f8b413d6.7c23e","type":"change","z":"1e1c3849.dc4d3","name":"speichere Zehnerstelle","rules":[{"t":"set","p":"Zehnerstelle","pt":"flow","to":"payload.item1","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1670,"y":820,"wires":[[]]},{"id":"17c9132f.29218d","type":"change","z":"1e1c3849.dc4d3","name":"speichere Einerstelle","rules":[{"t":"set","p":"Einerstelle","pt":"flow","to":"payload.item1","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1660,"y":860,"wires":[[]]},{"id":"e3438aaa.a6136","type":"function","z":"1e1c3849.dc4d3","name":"Genrate Time in Sec","func":"var Hunderterstelle = flow.get('Hunderterstelle');\nvar Zehnerstelle = flow.get('Zehnerstelle');\nvar Einerstelle = flow.get('Einerstelle');\nvar Zeitbasis = flow.get('Zeitbasis');\n\nHunderterstelle = Hunderterstelle.toString();\nZehnerstelle = Zehnerstelle.toString();\nEinerstelle = Einerstelle.toString();\n\nvar Zeitwert = Hunderterstelle + Zehnerstelle + Einerstelle;\n\nZeitwert = parseInt(Zeitwert);\n\nvar Zeit;\n\nZeit = Zeitwert * Zeitbasis;\n\n\n\nmsg.payload = Zeit;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1650,"y":940,"wires":[["387cefc8.ab01a8"]]},{"id":"d1f4b836.d4ce98","type":"buffer-parser","z":"1e1c3849.dc4d3","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"item1","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":1130,"y":820,"wires":[["f8b413d6.7c23e"]]},{"id":"96612980.c0c3e8","type":"buffer-parser","z":"1e1c3849.dc4d3","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"item1","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":1130,"y":780,"wires":[["d28d6c23.64f7a"]]},{"id":"d59db912.55d86","type":"buffer-parser","z":"1e1c3849.dc4d3","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"item1","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":1130,"y":860,"wires":[["17c9132f.29218d","a05e13ab.8c83a"]]},{"id":"9cfe61c4.53b778","type":"buffer-parser","z":"1e1c3849.dc4d3","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int8","name":"item1","offset":0,"length":1,"offsetbit":0,"scale":"0","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":1130,"y":680,"wires":[["14dc6f4a.4976b1"]]},{"id":"a05e13ab.8c83a","type":"delay","z":"1e1c3849.dc4d3","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1360,"y":940,"wires":[["e3438aaa.a6136"]]},{"id":"1df6ddc6.1d444a","type":"switch","z":"1e1c3849.dc4d3","name":"check number","property":"payload","propertyType":"msg","rules":[{"t":"istype","v":"number","vt":"number"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":200,"y":460,"wires":[["b70396c0.35d128"],["1ce01377.2b29ad"]]},{"id":"1ce01377.2b29ad","type":"function","z":"1e1c3849.dc4d3","name":"set status","func":"msg.payload = { fill:\"red\", shape:\"dot\", text:\"Input must be a number\" };\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":400,"y":500,"wires":[["294435ce.3fa932"]]},{"id":"294435ce.3fa932","type":"link out","z":"1e1c3849.dc4d3","name":"","links":["8bc2a48.19386d8"],"x":495,"y":500,"wires":[]},{"id":"8bc2a48.19386d8","type":"link in","z":"1e1c3849.dc4d3","name":"","links":["294435ce.3fa932","6403c593.88fbdc","325f3b7a.91bd64","7813da53.403c1c","8bcfc577.bb1a98","d8283ef3.b28698"],"x":515,"y":140,"wires":[[]]},{"id":"7d0f6f84.eab2f8","type":"link out","z":"1e1c3849.dc4d3","name":"","links":["5237b30d.4ed324"],"x":495,"y":400,"wires":[]},{"id":"ef9008d.7e2faf8","type":"link out","z":"1e1c3849.dc4d3","name":"","links":["4e02cc21.65aba4"],"x":495,"y":440,"wires":[]},{"id":"5237b30d.4ed324","type":"link in","z":"1e1c3849.dc4d3","name":"","links":["7d0f6f84.eab2f8"],"x":115,"y":800,"wires":[["954995ab.4bdbb"]]},{"id":"d7dda54d.17c498","type":"function","z":"1e1c3849.dc4d3","name":"set status","func":"msg.payload = { fill:\"green\", shape:\"ring\", text:\"Ready for Input\" };\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":480,"y":100,"wires":[[]]},{"id":"5d2cfc81.2395f4","type":"inject","z":"1e1c3849.dc4d3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":320,"y":100,"wires":[["d7dda54d.17c498"]]},{"id":"603744d0.c26ab4","type":"function","z":"1e1c3849.dc4d3","name":"clean msg","func":"delete msg._event;\ndelete msg.originalPayload;\ndelete msg.specification;\ndelete msg.values;\ndelete msg.objectResults;\ndelete msg.keyvalues;\ndelete msg.arrayResults;\ndelete msg.buffer;\n\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2080,"y":940,"wires":[[]]},{"id":"24be4f66.f2eb58","type":"function","z":"1e1c3849.dc4d3","name":"set status","func":"msg.payload = { fill:\"green\", shape:\"dot\", text:\"S5Time > Sec = \" +msg.payload +\"sec\" };\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2080,"y":980,"wires":[["6403c593.88fbdc"]]},{"id":"6403c593.88fbdc","type":"link out","z":"1e1c3849.dc4d3","name":"","links":["8bc2a48.19386d8"],"x":2215,"y":980,"wires":[]},{"id":"36102e02.c60c32","type":"function","z":"1e1c3849.dc4d3","name":"set status","func":"msg.payload = { fill:\"blue \", shape:\"ring\", text:\"coverting ...\" };\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":360,"wires":[["325f3b7a.91bd64"]]},{"id":"325f3b7a.91bd64","type":"link out","z":"1e1c3849.dc4d3","name":"","links":["8bc2a48.19386d8"],"x":635,"y":360,"wires":[]},{"id":"a7dc0c4c.e12158","type":"comment","z":"1e1c3849.dc4d3","name":"S5Time To SEC","info":"","x":300,"y":720,"wires":[]},{"id":"f066956e.7317b","type":"comment","z":"1e1c3849.dc4d3","name":"SEC To S5Time","info":"","x":270,"y":1140,"wires":[]},{"id":"f9c5029c.457e58","type":"switch","z":"1e1c3849.dc4d3","name":"Zeitbasis","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"0.01","vt":"num"},{"t":"btwn","v":"0.01","vt":"num","v2":"9.99","v2t":"num"},{"t":"btwn","v":"10","vt":"num","v2":"99.9","v2t":"num"},{"t":"btwn","v":"99.9","vt":"num","v2":"999","v2t":"num"},{"t":"btwn","v":"999","vt":"num","v2":"9990","v2t":"num"},{"t":"gt","v":"9990","vt":"num"}],"checkall":"true","repair":false,"outputs":6,"x":220,"y":1300,"wires":[["4c4f3c4e.a02e84"],["75da0e61.d030f","3bb165d6.e71fea"],["d6eee81b.91099","c4503d47.b3a96"],["6c8ea952.7e914","96c30ce.a27d67"],["a56cf59a.db10a8","f0061a89.1c6fa"],["2369c741.30c47"]],"outputLabels":["Wert zu klein","0.01s = 10ms","0.1s = 100ms","1s","10s","Wert zu groß"]},{"id":"75da0e61.d030f","type":"change","z":"1e1c3849.dc4d3","name":"Zeitbasis 10ms = Dec. 0","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":1180,"wires":[["408eea54.4dc75c"]]},{"id":"d6eee81b.91099","type":"change","z":"1e1c3849.dc4d3","name":"Zeitbasis 100ms = Dec. 1","rules":[{"t":"set","p":"payload","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":1280,"wires":[["408eea54.4dc75c"]]},{"id":"6c8ea952.7e914","type":"change","z":"1e1c3849.dc4d3","name":"Zeitbasis 1s = Dec. 2","rules":[{"t":"set","p":"payload","pt":"msg","to":"2","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":1380,"wires":[["408eea54.4dc75c"]]},{"id":"a56cf59a.db10a8","type":"change","z":"1e1c3849.dc4d3","name":"Zeitbasis 10s = Dec. 3","rules":[{"t":"set","p":"payload","pt":"msg","to":"3","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":1460,"wires":[["408eea54.4dc75c"]]},{"id":"408eea54.4dc75c","type":"buffer-maker","z":"1e1c3849.dc4d3","name":"","specification":"spec","specificationType":"ui","items":[{"name":"item1","type":"int16be","length":1,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":890,"y":1280,"wires":[["50e99f6a.7ae2e"]]},{"id":"50e99f6a.7ae2e","type":"buffer-parser","z":"1e1c3849.dc4d3","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"bool","name":"Zeitbasis","offset":1,"length":4,"offsetbit":0,"scale":"0","mask":"0"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":1070,"y":1280,"wires":[["bddf803c.4b4928"]]},{"id":"a6da88b2.5fa338","type":"split","z":"1e1c3849.dc4d3","name":"","splt":"1","spltType":"len","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":1090,"y":1360,"wires":[["7fae84b.1d7c3fc"]]},{"id":"96c30ce.a27d67","type":"convert","z":"1e1c3849.dc4d3","name":"","convertTo":"string","x":910,"y":1360,"wires":[["a6da88b2.5fa338"]]},{"id":"7fae84b.1d7c3fc","type":"convert","z":"1e1c3849.dc4d3","name":"","convertTo":"number","x":1270,"y":1360,"wires":[["1ce9fd70.0e106b"]]},{"id":"a910a8a5.fcf33","type":"switch","z":"1e1c3849.dc4d3","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"}],"checkall":"true","repair":false,"outputs":3,"x":2010,"y":1380,"wires":[["85c247b8.d0eb"],["e8f55fa5.70f36"],["fafb9233.04db48"]]},{"id":"3bb165d6.e71fea","type":"calculator","z":"1e1c3849.dc4d3","name":"*100","inputMsgField":"payload","outputMsgField":"payload","operation":"mult","constant":"100","round":true,"decimals":0,"x":490,"y":1220,"wires":[["96c30ce.a27d67"]]},{"id":"c4503d47.b3a96","type":"calculator","z":"1e1c3849.dc4d3","name":"*10","inputMsgField":"payload","outputMsgField":"payload","operation":"mult","constant":"10","round":true,"decimals":0,"x":490,"y":1320,"wires":[["96c30ce.a27d67"]]},{"id":"f0061a89.1c6fa","type":"calculator","z":"1e1c3849.dc4d3","name":"/ 10","inputMsgField":"payload","outputMsgField":"payload","operation":"div","constant":"10","round":true,"decimals":0,"x":490,"y":1500,"wires":[["96c30ce.a27d67"]]},{"id":"85c247b8.d0eb","type":"buffer-maker","z":"1e1c3849.dc4d3","name":"","specification":"spec","specificationType":"ui","items":[{"name":"item1","type":"int16be","length":1,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":2170,"y":1340,"wires":[["52a88633.d46e38"]]},{"id":"52a88633.d46e38","type":"buffer-parser","z":"1e1c3849.dc4d3","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"bool","name":"Hunderterstelle","offset":1,"length":4,"offsetbit":0,"scale":"0","mask":"0"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":2350,"y":1340,"wires":[["96cf03bf.89f07"]]},{"id":"e8f55fa5.70f36","type":"buffer-maker","z":"1e1c3849.dc4d3","name":"","specification":"spec","specificationType":"ui","items":[{"name":"item1","type":"int16be","length":1,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":2170,"y":1380,"wires":[["caeeaa67.2bb0a8"]]},{"id":"caeeaa67.2bb0a8","type":"buffer-parser","z":"1e1c3849.dc4d3","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"bool","name":"Zehnerstelle","offset":1,"length":4,"offsetbit":0,"scale":"0","mask":"0"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":2350,"y":1380,"wires":[["6e4c18da.e93c8"]]},{"id":"fafb9233.04db48","type":"buffer-maker","z":"1e1c3849.dc4d3","name":"","specification":"spec","specificationType":"ui","items":[{"name":"item1","type":"int16be","length":1,"dataType":"msg","data":"payload"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","x":2170,"y":1420,"wires":[["915e9fa9.2b76"]]},{"id":"915e9fa9.2b76","type":"buffer-parser","z":"1e1c3849.dc4d3","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"bool","name":"Einerstelle","offset":1,"length":4,"offsetbit":0,"scale":"0","mask":"0"}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":2350,"y":1420,"wires":[["37979341.4eb96c","312d9e4e.b4d9fa"]]},{"id":"96cf03bf.89f07","type":"change","z":"1e1c3849.dc4d3","name":"Speichern","rules":[{"t":"set","p":"HunderterBool","pt":"flow","to":"payload.Hunderterstelle","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":2550,"y":1340,"wires":[[]]},{"id":"6e4c18da.e93c8","type":"change","z":"1e1c3849.dc4d3","name":"Speichern","rules":[{"t":"set","p":"ZehnerBool","pt":"flow","to":"payload.Zehnerstelle","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":2550,"y":1380,"wires":[[]]},{"id":"37979341.4eb96c","type":"change","z":"1e1c3849.dc4d3","name":"Speichern","rules":[{"t":"set","p":"EinerBool","pt":"flow","to":"payload.Einerstelle","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":2550,"y":1420,"wires":[[]]},{"id":"be7b589a.fe685","type":"function","z":"1e1c3849.dc4d3","name":"Bool Zusammenstellen","func":"var Hunderterstelle = flow.get('HunderterBool');\nvar Zehnerstelle = flow.get('ZehnerBool');\nvar Einerstelle = flow.get('EinerBool');\nvar Zeitbasis = flow.get('ZeitbasisBool');\n\n\nvar Ergebnis = Einerstelle +',' + Zehnerstelle +',' + Hunderterstelle +',' + Zeitbasis;\n\nmsg.payload = Ergebnis;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2830,"y":1460,"wires":[["663f81de.1cff4"]]},{"id":"312d9e4e.b4d9fa","type":"delay","z":"1e1c3849.dc4d3","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":2580,"y":1460,"wires":[["be7b589a.fe685"]]},{"id":"bddf803c.4b4928","type":"change","z":"1e1c3849.dc4d3","name":"Speichern","rules":[{"t":"set","p":"ZeitbasisBool","pt":"flow","to":"payload.Zeitbasis","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1250,"y":1280,"wires":[[]]},{"id":"663f81de.1cff4","type":"split","z":"1e1c3849.dc4d3","name":"","splt":",","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":3030,"y":1460,"wires":[["735e8679.80663"]]},{"id":"735e8679.80663","type":"change","z":"1e1c3849.dc4d3","name":"to Bool","rules":[{"t":"change","p":"payload","pt":"msg","from":"true","fromt":"str","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":3180,"y":1460,"wires":[["b9fcfb53.9b8868"]]},{"id":"b9fcfb53.9b8868","type":"change","z":"1e1c3849.dc4d3","name":"to Bool","rules":[{"t":"change","p":"payload","pt":"msg","from":"false","fromt":"str","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":3320,"y":1460,"wires":[["a2c7476e.8e8bc"]]},{"id":"a2c7476e.8e8bc","type":"join","z":"1e1c3849.dc4d3","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":3450,"y":1460,"wires":[["26075836.3185f"]]},{"id":"26075836.3185f","type":"function","z":"1e1c3849.dc4d3","name":"Bool to S5Time","func":"var Ergebnis;\n\nif (msg.payload[0] == true){\n    Ergebnis = 1;\n} else {\n    Ergebnis = 0;\n}\n\nif (msg.payload[1] == true){\n    Ergebnis = Ergebnis + 2;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\n\nif (msg.payload[2] == true){\n    Ergebnis = Ergebnis + 4;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\n\nif (msg.payload[3] == true){\n    Ergebnis = Ergebnis + 8;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[4] == true){\n    Ergebnis = Ergebnis + 16;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[5] == true){\n    Ergebnis = Ergebnis + 32;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[6] == true){\n    Ergebnis = Ergebnis + 64;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[7] == true){\n    Ergebnis = Ergebnis + 128;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[8] == true){\n    Ergebnis = Ergebnis + 256;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[9] == true){\n    Ergebnis = Ergebnis + 512;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[10] == true){\n    Ergebnis = Ergebnis + 1024;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[11] == true){\n    Ergebnis = Ergebnis + 2048;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[12] == true){\n    Ergebnis = Ergebnis + 4096;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[13] == true){\n    Ergebnis = Ergebnis + 8192;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[14] == true){\n    Ergebnis = Ergebnis + 16384;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\nif (msg.payload[15] == true){\n    Ergebnis = Ergebnis + 32768;\n} else {\n    Ergebnis = Ergebnis + 0;\n}\n\nmsg.payload = Ergebnis;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3630,"y":1460,"wires":[["d5ed0773.e658","7d4c9c56.d5b49c"]]},{"id":"d5ed0773.e658","type":"function","z":"1e1c3849.dc4d3","name":"set status","func":"msg.payload = { fill:\"green\", shape:\"dot\", text:\"Sec. > S5Time = \" +msg.payload };\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3840,"y":1520,"wires":[["7813da53.403c1c"]]},{"id":"7813da53.403c1c","type":"link out","z":"1e1c3849.dc4d3","name":"","links":["8bc2a48.19386d8"],"x":3975,"y":1520,"wires":[]},{"id":"7d4c9c56.d5b49c","type":"function","z":"1e1c3849.dc4d3","name":"clean msg","func":"delete msg._event;\ndelete msg.originalPayload;\ndelete msg.specification;\ndelete msg.values;\ndelete msg.objectResults;\ndelete msg.keyvalues;\ndelete msg.arrayResults;\ndelete msg.buffer;\ndelete msg.parts;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":3840,"y":1460,"wires":[[]]},{"id":"4e02cc21.65aba4","type":"link in","z":"1e1c3849.dc4d3","name":"","links":["ef9008d.7e2faf8"],"x":115,"y":1300,"wires":[["f9c5029c.457e58"]]},{"id":"387cefc8.ab01a8","type":"calculator","z":"1e1c3849.dc4d3","name":"","inputMsgField":"payload","outputMsgField":"payload","operation":"rdec","constant":"2","round":false,"decimals":0,"x":1860,"y":940,"wires":[["603744d0.c26ab4","24be4f66.f2eb58"]]},{"id":"4c4f3c4e.a02e84","type":"function","z":"1e1c3849.dc4d3","name":"set status","func":"msg.payload = { fill:\"red\", shape:\"dot\", text:\"Input musst be greater than 0.01sec\" };\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":1140,"wires":[["8bcfc577.bb1a98"]]},{"id":"8bcfc577.bb1a98","type":"link out","z":"1e1c3849.dc4d3","name":"","links":["8bc2a48.19386d8"],"x":635,"y":1140,"wires":[]},{"id":"2369c741.30c47","type":"function","z":"1e1c3849.dc4d3","name":"set status","func":"msg.payload = { fill:\"red\", shape:\"dot\", text:\"Input musst be less then 9990sec\" };\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":1560,"wires":[["d8283ef3.b28698"]]},{"id":"d8283ef3.b28698","type":"link out","z":"1e1c3849.dc4d3","name":"","links":["8bc2a48.19386d8"],"x":635,"y":1560,"wires":[]},{"id":"89f284a.b01bdf8","type":"inject","z":"1e1c3849.dc4d3","name":"Init 0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":2370,"y":1260,"wires":[["32b0905b.3a114"]]},{"id":"32b0905b.3a114","type":"change","z":"1e1c3849.dc4d3","name":"Speichern","rules":[{"t":"set","p":"HunderterBool","pt":"flow","to":"0","tot":"num"},{"t":"set","p":"ZehnerBool","pt":"flow","to":"0","tot":"num"},{"t":"set","p":"EinerBool","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":2550,"y":1260,"wires":[[]]},{"id":"1ce9fd70.0e106b","type":"switch","z":"1e1c3849.dc4d3","name":"check parts","property":"parts.count","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":1450,"y":1360,"wires":[["5b34820d.26d714"],["bd1358fb.65218"],["a910a8a5.fcf33"]],"outputLabels":["Einerstelle","Einerstelle + Zehnersteller","Einerstelle + Zehnersteller + Hunderterstelle"]},{"id":"5b34820d.26d714","type":"change","z":"1e1c3849.dc4d3","name":"Set parts","rules":[{"t":"change","p":"parts.count","pt":"msg","from":"1","fromt":"num","to":"3","tot":"num"},{"t":"change","p":"parts.index","pt":"msg","from":"0","fromt":"num","to":"2","tot":"num"},{"t":"set","p":"HunderterBool","pt":"flow","to":"0","tot":"num"},{"t":"set","p":"ZehnerBool","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1840,"y":1280,"wires":[["a910a8a5.fcf33"]]},{"id":"9fe4c007.03892","type":"change","z":"1e1c3849.dc4d3","name":"Set parts","rules":[{"t":"change","p":"parts.count","pt":"msg","from":"2","fromt":"num","to":"3","tot":"num"},{"t":"change","p":"parts.index","pt":"msg","from":"0","fromt":"num","to":"1","tot":"num"},{"t":"set","p":"HunderterBool","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1840,"y":1320,"wires":[["a910a8a5.fcf33"]]},{"id":"bd1358fb.65218","type":"switch","z":"1e1c3849.dc4d3","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":1670,"y":1340,"wires":[["9fe4c007.03892"],["94f8128b.76685"]]},{"id":"94f8128b.76685","type":"change","z":"1e1c3849.dc4d3","name":"Set parts","rules":[{"t":"change","p":"parts.count","pt":"msg","from":"2","fromt":"num","to":"3","tot":"num"},{"t":"change","p":"parts.index","pt":"msg","from":"1","fromt":"num","to":"2","tot":"num"},{"t":"set","p":"HunderterBool","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1840,"y":1360,"wires":[["a910a8a5.fcf33"]]},{"id":"88d1781c.ad0158","type":"subflow:1e1c3849.dc4d3","z":"48fd5cb.e483a24","name":"","env":[],"x":770,"y":300,"wires":[[],["b4d0e082.6188a8"]]}]
Created 5 years, 7 months ago
  • change (x25)
  • comment (x2)
  • delay (x2)
  • function (x12)
  • inject (x2)
  • join (x1)
  • link in (x3)
  • link out (x8)
  • split (x2)
  • switch (x7)
  • Siemens
  • S5Time
  • Converter
  • S7Time
  • Time
  • PLC
