Telegram to whatsapp gateway.
This simple flow shows how to integrate Telegram and Whatsapp, you will be able to forward Telegram messages received by a bot, based on the logic defined on a function.
It uses 3 nodes:
  • node-red-contrib-telegrambot Telegram Receiver node, you get a message sent to a Telegram-bot,
  • a core function node, which filters the messages you want to forward,
  • node-red-contrib-whin node, this node will forward to whatsapp the messages that match the criteria you set on the function node.
check the video: https://www.youtube.com/watch?v=VRjZfvmh9m0
[{"id":"57013c8b545bc2dc","type":"debug","z":"cb358f93.bea12","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":750,"y":800,"wires":[]},{"id":"d5655d56e697b876","type":"whin","z":"cb358f93.bea12","name":"","auth":"f160031f44835f95","x":625,"y":725,"wires":[["57013c8b545bc2dc"]]},{"id":"a9272f4154f9959f","type":"telegram receiver","z":"cb358f93.bea12","name":"","bot":"ec5858a9c63b375b","saveDataDir":"","filterCommands":false,"x":215,"y":725,"wires":[["504756466193f217"],[]]},{"id":"504756466193f217","type":"function","z":"cb358f93.bea12","name":"","func":"msg.payload = \"Telegram message from: \" + msg.originalMessage.from.username + \" --> \" + msg.payload.content;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":435,"y":725,"wires":[["d5655d56e697b876"]]},{"id":"f160031f44835f95","type":"whin-config","name":"whin","phone":"Your_Phone_Number","token":"Your_Whin_Token"},{"id":"ec5858a9c63b375b","type":"telegram bot","botname":"Name_of_Bot","usernames":"","chatids":"","baseapiurl":"","updatemode":"polling","pollinterval":"300","usesocks":false,"sockshost":"","socksport":"6667","socksusername":"anonymous","sockspassword":"","bothost":"","botpath":"","localbotport":"8443","publicbotport":"8443","privatekey":"","certificate":"","useselfsignedcertificate":false,"sslterminated":false,"verboselogging":false}]
Created 5 years, 3 months ago
Updated 5 years, 2 months ago
Rating: 5 2
  • WhatsApp
  • telegram
  • gateway
  • Telegram_to_whatsapp
  • whin
