Sending a self whatsapp through WHIN API
This example flow leverages WHIN API service (hosted at RapidAPI) to send a simple hello world text message to yourself.
In order to use the flow, you need to be registered on the service. It won't work otherwise at ir requires one's rapidAPI user key.
The message format will be a JSON with the following basic structure:
{"text" : "Hello world"}
[{"id":"c2ecd9c5537b7e23","type":"inject","z":"e3a7b97ea7cac6ff","name":"","props":[{"p":"key","v":"<your_rapidapi_key>","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"text\":\"Hello\"}","payloadType":"json","x":420,"y":440,"wires":[["830a8088d8b2ab06"]]},{"id":"830a8088d8b2ab06","type":"function","z":"e3a7b97ea7cac6ff","name":"Whin2-Send","func":"msg.method = \"POST\";\nmsg.url = \"https://whin2.p.rapidapi.com/send\";\nmsg.headers = {\n    'content-type': 'application/json',\n    'X-RapidAPI-Host': \"whin2.p.rapidapi.com\",\n    'X-RapidAPI-Key': msg.key\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":610,"y":440,"wires":[["7b665da13ee54d70"]]},{"id":"7b665da13ee54d70","type":"http request","z":"e3a7b97ea7cac6ff","name":"","method":"use","ret":"obj","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"headers":[],"x":790,"y":440,"wires":[["719f37bdbd9a5779"]]},{"id":"64d503062d9251ea","type":"debug","z":"e3a7b97ea7cac6ff","name":"debug 25","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1120,"y":440,"wires":[]},{"id":"719f37bdbd9a5779","type":"function","z":"e3a7b97ea7cac6ff","name":"MSG","func":"msg.payload = msg.payload.msg;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":970,"y":440,"wires":[["64d503062d9251ea"]]},{"id":"47f86b741dfef201","type":"comment","z":"e3a7b97ea7cac6ff","name":"Send","info":"","x":370,"y":400,"wires":[]}]
Created 4 years, 5 months ago
Rating: 5 1
  • function (x2)
  • http request (x1)
