Slew rate limit
Given messages with a value in the payload this limits the maximum rate of change of the output, generating intermediate messages so that the output slews at the specified rate between values passed in.
[{"id":"95daacd1.0e09f8","type":"debug","z":"514a90a5.c7bae8","name":"","active":true,"console":"false","complete":"false","x":570,"y":530,"wires":[]},{"id":"c136d3fd.21da78","type":"inject","z":"514a90a5.c7bae8","name":"","topic":"","payload":"0","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":99,"y":492,"wires":[["fc58524d.34f02"]]},{"id":"fc58524d.34f02","type":"function","z":"514a90a5.c7bae8","name":"Slew rate limit 1 unit/second","func":"// Limits the slew rate incoming payload values\n// optionally sending intermediate values at specified rate\nlet maxRate = 1;            // max slew rate units/second\nlet sendIntermediates = true;   // whether to send intermediate values\nlet period = 100;           // period in millisecs to send new values (if sendIntermediates)\nlet jumpThreshold = 2;      // if the step asked for is more that this then goes immediately to that value\n\nvar newValue = Number(msg.payload);\nvar timer = context.get('timer') || 0;\n// check the value is  a number\nif (!isNaN(newValue) && isFinite(newValue)) {\n    var target = msg.payload;\n    context.set('target', target);\n    // set last value to new one if first time through\n    var lastValue = context.get('lastValue');\n    if (typeof lastValue == \"undefined\" || lastValue === null) {\n        lastValue = newValue;\n        context.set('lastValue', newValue);\n    }\n    // calc new value\n    msg.payload = calcOutput();\n    // stop the timer\n    if (timer) {\n        clearTimeout(timer);\n        context.set('timer', null);\n    }\n    // restart it if required to send intermediate values\n    if (sendIntermediates) {\n        timer = setInterval(function(){\n            // the timer has run down calculate next value and send it\n            var newValue = calcOutput();\n            if (newValue != context.get('lastValueSent')) {\n                context.set('lastValueSent', newValue);\n                node.send({payload: newValue});\n            }\n        },period);\n        context.set('timer', timer);\n    }\n    context.set('lastValueSent', msg.payload);\n} else {\n    // payload is not a number so ignore it\n    // also stop the timer as we don't know what to send any more\n    if (timer) {\n        clearTimeout(timer);\n        context.set('timer', null);\n    }\n    msg = null;\n}\nreturn msg;\n\n// determines the required output value\nfunction calcOutput() {\n    var lastValue = context.get('lastValue');\n    var target = context.get('target');\n    // set to current value if first time through or step > threshold\n    if (typeof lastValue == \"undefined\" || lastValue === null) lastValue = target;\n    var now = new Date();\n    var lastTime = context.get('lastTime') || now;\n    // limit value to last value +- rate * time\n    var maxDelta = (now.getTime() - lastTime.getTime()) * maxRate/1000;\n    if (Math.abs(target - lastValue) > jumpThreshold) {\n        // step > threshold so go there imediately\n        newValue = target;\n    } else if (target > lastValue) {\n        newValue = Math.min( lastValue + maxDelta, target);\n    } else {\n        newValue = Math.max( lastValue - maxDelta, target);\n    }\n    context.set('lastValue', newValue);\n    context.set('lastTime', now);   \n    return newValue;\n}","outputs":1,"noerr":0,"x":351,"y":530,"wires":[["95daacd1.0e09f8"]]},{"id":"1501600b.8cd8d","type":"inject","z":"514a90a5.c7bae8","name":"","topic":"","payload":"1","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":99,"y":569,"wires":[["fc58524d.34f02"]]}]
Created 8 years ago
  • inject (x2)
  • slew
  • rate
