EmotivBCI - Mental Commands keyboard
EmotivBCI - Mental Commands keyboard example:
This flow allows you to use Mental Commands to simulate pressing a keystroke.
How to import example:
To import this example to Node-RED:
  1. Start Node-RED in your Terminal or cmd window
  2. On your web-browser, go to http://127.0.0.1:1880 to open Node-RED
  3. On the top-right screen, go to Menu/Import/Clipboard and paste the contents of the JSON file below in "example directory".
  4. This examples requires: On cmd/terminal, go to ~/.node-red and enter these commands (local install):
    a. EmotivBCI Node-RED Toolbox: $ npm install node-red-contrib-emotiv-emotiv-bci
    b. EMOTIV keyboard node: $ npm install node-red-contrib-emotiv-keyboard
Since all BCI Node-Red flows and other Emotiv applications share one instance of Cortex Service, so you should only run/deploy one flow at a time.
[{"id":"75df1c9c.f9f274","type":"debug","z":"eeda7784.3e2cd8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":870,"y":300,"wires":[]},{"id":"29334321.88b60c","type":"switch","z":"eeda7784.3e2cd8","name":"Threshold 50","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"50","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":650,"y":120,"wires":[["7caa2f8d.6347","9e46319b.ec7f"]]},{"id":"7caa2f8d.6347","type":"debug","z":"eeda7784.3e2cd8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":870,"y":160,"wires":[]},{"id":"7c2aa7c.b960158","type":"switch","z":"eeda7784.3e2cd8","name":"Threshold 50","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"50","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":650,"y":260,"wires":[["75df1c9c.f9f274","81c13104.b38a9"]]},{"id":"337378d7.7c7328","type":"EMOTIV","z":"eeda7784.3e2cd8","name":"EMOTIV","x":120,"y":120,"wires":[["13b9e855.55e2b8"]]},{"id":"13b9e855.55e2b8","type":"Profile-Name","z":"eeda7784.3e2cd8","name":"Profile Name","profileName":"","x":200,"y":180,"wires":[["3de480bf.41b19","98aa2d1e.0320c"]]},{"id":"3de480bf.41b19","type":"Mental-Command","z":"eeda7784.3e2cd8","name":"Mental Commands","actionName":"push","mcSen":"10","x":430,"y":120,"wires":[["29334321.88b60c"]]},{"id":"98aa2d1e.0320c","type":"Mental-Command","z":"eeda7784.3e2cd8","name":"Mental Commands","actionName":"pull","mcSen":"10","x":430,"y":260,"wires":[["7c2aa7c.b960158"]]},{"id":"9e46319b.ec7f","type":"Keyboards","z":"eeda7784.3e2cd8","name":"Keyboards","key":"a","typePress":"press","x":890,"y":80,"wires":[]},{"id":"81c13104.b38a9","type":"Keyboards","z":"eeda7784.3e2cd8","name":"Keyboards","key":"w","typePress":"press","x":890,"y":220,"wires":[]}]
Created 9 years ago
  • debug (x2)
  • switch (x2)
  • emotiv
