Carbon dioxide (CO2) Dashboard with NodeRed, MQTT, CSV and Pushover
See http://www.wenzlaff.info in german.
[{"id":"1833a4d8.7d988b","type":"tab","label":"CO2","disabled":false,"info":""},{"id":"440c9260.d72904","type":"debug","z":"1833a4d8.7d988b","name":"CSV Wert","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1100,"y":180,"wires":[]},{"id":"f1bf2c63.d0b35","type":"mqtt in","z":"1833a4d8.7d988b","name":"MQTT empfang von CO2-Messungen","topic":"co2","qos":"2","datatype":"json","broker":"abc88836.28e918","x":230,"y":180,"wires":[["f2b053c6.5cf198","bf02fb2b.712218","a793616a.80fb78"]]},{"id":"2e52bc64.25350c","type":"file","z":"1833a4d8.7d988b","name":"In Datei co2.csv speichern","filename":"/home/openhabian/co2.csv","appendNewline":true,"createDir":false,"overwriteFile":"false","encoding":"none","x":880,"y":180,"wires":[["440c9260.d72904"]]},{"id":"f2b053c6.5cf198","type":"function","z":"1833a4d8.7d988b","name":"JSON to CSV Format erzeugen","func":"var nachricht=msg.payload.messung.satz[0].zeitpunkt + \n\",\" + \nmsg.payload.messung.satz[1].temperature  + \n\",\" + \nmsg.payload.messung.satz[1].co2;\n\nmsg.payload = nachricht;\n\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":180,"wires":[["2e52bc64.25350c"]]},{"id":"d39df43.4b2c608","type":"comment","z":"1833a4d8.7d988b","name":"Schreibe CO2 und Temperarur Messung in eine CSV-Datei und ins Dashboard","info":"","x":350,"y":100,"wires":[]},{"id":"79fb268c.db9288","type":"comment","z":"1833a4d8.7d988b","name":"(c) 2020 Thomas Wenzlaff   www.wenzlaff.info","info":"","x":1030,"y":100,"wires":[]},{"id":"78fdd64.d47e128","type":"ui_gauge","z":"1833a4d8.7d988b","name":"","group":"92ac457c.0b6e2","order":1,"width":0,"height":0,"gtype":"gage","title":"CO2","label":"ppm","format":"{{msg.payload | number:0}}","min":"0","max":"5000","colors":["#00b500","#e6e600","#ca3838"],"seg1":"600","seg2":"1000","x":790,"y":320,"wires":[]},{"id":"bcbaa182.36835","type":"debug","z":"1833a4d8.7d988b","name":"CO2 Wert","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":800,"y":260,"wires":[]},{"id":"bf02fb2b.712218","type":"function","z":"1833a4d8.7d988b","name":"JSON to CO2","func":"msg.payload = msg.payload.messung.satz[1].co2\n\nreturn msg;","outputs":1,"noerr":0,"x":540,"y":320,"wires":[["78fdd64.d47e128","bcbaa182.36835","416f4723.a612f8","6acb5e0a.2ae6b"]]},{"id":"416f4723.a612f8","type":"ui_chart","z":"1833a4d8.7d988b","name":"","group":"92ac457c.0b6e2","order":2,"width":0,"height":0,"label":"Trend","chartType":"line","legend":"false","xformat":"dd HH:mm","interpolate":"linear","nodata":"Noch keine Daten erhalten","dot":false,"ymin":"0","ymax":"2000","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"604800","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":790,"y":380,"wires":[[]]},{"id":"a793616a.80fb78","type":"function","z":"1833a4d8.7d988b","name":"JSON to Temperatur","func":"msg.payload = msg.payload.messung.satz[1].temperature\n\nreturn msg;","outputs":1,"noerr":0,"x":560,"y":720,"wires":[["bbdd00bc.49289","630f620b.5f4abc","f000f694.64c23"]]},{"id":"bbdd00bc.49289","type":"ui_gauge","z":"1833a4d8.7d988b","name":"","group":"5469a886.aafe5","order":1,"width":0,"height":0,"gtype":"gage","title":"Temperatur","label":"Grad Celsius","format":"{{msg.payload | number:0}}","min":"0","max":"40","colors":["#00b500","#e6e600","#ca3838"],"seg1":"25","seg2":"30","x":810,"y":720,"wires":[]},{"id":"630f620b.5f4abc","type":"ui_chart","z":"1833a4d8.7d988b","name":"","group":"5469a886.aafe5","order":2,"width":0,"height":0,"label":"Trend","chartType":"line","legend":"false","xformat":"dd HH:mm","interpolate":"linear","nodata":"Noch keine Daten erhalten","dot":false,"ymin":"0","ymax":"40","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"604800","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":790,"y":780,"wires":[[]]},{"id":"f000f694.64c23","type":"debug","z":"1833a4d8.7d988b","name":"Temperatur Wert","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":820,"y":660,"wires":[]},{"id":"7ed6b66b.953e4","type":"pushover","z":"1833a4d8.7d988b","name":"CO2 Warnung senden","device":"","title":"CO2 Messung im Arbeitszimmer","priority":0,"sound":"","url":"","url_title":"","html":false,"x":1200,"y":500,"wires":[]},{"id":"6acb5e0a.2ae6b","type":"switch","z":"1833a4d8.7d988b","name":"Auswertung","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"1000","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":810,"y":440,"wires":[["1bc11a17.c983ce"]]},{"id":"1bc11a17.c983ce","type":"throttle","z":"1833a4d8.7d988b","name":"Nur eine Warnung pro Stunde","throttleType":"time","timeLimit":"1","timeLimitType":"hours","countLimit":"1","blockSize":0,"locked":false,"x":930,"y":500,"wires":[["7ed6b66b.953e4","315f6f10.da8708"]]},{"id":"315f6f10.da8708","type":"debug","z":"1833a4d8.7d988b","name":"Warnung","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1160,"y":560,"wires":[]},{"id":"abc88836.28e918","type":"mqtt-broker","z":"","name":"co2","broker":"pi-bplus","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"co2","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"92ac457c.0b6e2","type":"ui_group","z":"","name":"CO2-Messung","tab":"af39e9ca.cc925","disp":true,"width":"6","collapse":false},{"id":"5469a886.aafe5","type":"ui_group","z":"","name":"Temperatur Messung","tab":"7735e668.50187","disp":true,"width":"6","collapse":false},{"id":"af39e9ca.cc925","type":"ui_tab","z":"","name":"CO2","icon":"dashboard","disabled":false,"hidden":false},{"id":"7735e668.50187","type":"ui_tab","z":"","name":"Temperatur","icon":"dashboard","disabled":false,"hidden":false}]
Collection Info
Created 4 years ago
Rating: 4.75 4
  • comment (x2)
  • debug (x4)
  • file (x1)
  • function (x3)
  • mqtt in (x1)
  • mqtt-broker (x1)
  • switch (x1)
  • pushover (x1)
  • throttle (x1)
  • ui_chart (x2)
  • ui_gauge (x2)
  • ui_group (x2)
  • ui_tab (x2)
  • co2
  • dashboard
  • mqtt
  • ppm
  • wenzlaff
  • wenzlaff.de
  • wenzlaff.info
  • co2 MH-Z19B MH-Z19 uart
  • MH-Z19B MH-Z19 uart
  • MH-Z19B
  • pushover
  • Raspberry
  • Pi
  • Raspi
  • CO2-Dashboard
