Download Meteoswiss Station Data
Example flow to download weatherdata from meteoswiss.ch with node-red-contrib-swissforecast
You don't need the influxdb node at the end of the flow, this is just an example. If you need the 3 letter ID for a certain weatherstation and don't know how to get one, just have a look in the function node. All the station names and ids are written in there.
[{"id":"2dc999ec.7a18d6","type":"swissforecast","z":"2a5ccfd3.08f3f","name":"Swissforecast","location":"LAE","x":2340,"y":230,"wires":[["d0030d62.343e58"]]},{"id":"1b563862.e58dd","type":"rbe","z":"2a5ccfd3.08f3f","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload.time","x":2631,"y":230,"wires":[["89f7ee04.8d91b"]]},{"id":"e0af2840.8244e8","type":"inject","z":"2a5ccfd3.08f3f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"600","crontab":"","once":true,"onceDelay":"1","topic":"","payload":"","payloadType":"date","x":2171,"y":230,"wires":[["2dc999ec.7a18d6","c5b93ae5.65ec48"]]},{"id":"c5b93ae5.65ec48","type":"swissforecast","z":"2a5ccfd3.08f3f","name":"Swissforecast","location":"REH","x":2340,"y":270,"wires":[["6ff0304b.fdacf8"]]},{"id":"6e3eeb8.2607614","type":"rbe","z":"2a5ccfd3.08f3f","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload.time","x":2631,"y":270,"wires":[["89f7ee04.8d91b"]]},{"id":"d0030d62.343e58","type":"switch","z":"2a5ccfd3.08f3f","name":"null?","property":"payload","propertyType":"msg","rules":[{"t":"nnull"},{"t":"null"}],"checkall":"true","repair":false,"outputs":2,"x":2471,"y":230,"wires":[["1b563862.e58dd"],["bbf973e9.cff48"]]},{"id":"6ff0304b.fdacf8","type":"switch","z":"2a5ccfd3.08f3f","name":"null?","property":"payload","propertyType":"msg","rules":[{"t":"nnull"},{"t":"null"}],"checkall":"true","repair":false,"outputs":2,"x":2471,"y":270,"wires":[["6e3eeb8.2607614"],["bbf973e9.cff48"]]},{"id":"bbf973e9.cff48","type":"debug","z":"2a5ccfd3.08f3f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":2631,"y":310,"wires":[]},{"id":"89f7ee04.8d91b","type":"switch","z":"2a5ccfd3.08f3f","name":"temp 32767","property":"payload.temperature","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2829,"y":250,"wires":[["2ec9c480.49e2cc"],["a11ca262.4e037"]]},{"id":"2ec9c480.49e2cc","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.temperature","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3200,"y":250,"wires":[["a11ca262.4e037"]]},{"id":"a11ca262.4e037","type":"switch","z":"2a5ccfd3.08f3f","name":"windSpeed 32767","property":"payload.windSpeed","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2849,"y":300,"wires":[["333666f3.648452"],["ff585c09.322678"]]},{"id":"333666f3.648452","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.windSpeed","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3200,"y":300,"wires":[["ff585c09.322678"]]},{"id":"ff585c09.322678","type":"switch","z":"2a5ccfd3.08f3f","name":"windDirection 32767","property":"payload.windDirection","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2859,"y":350,"wires":[["d3f008d4.f53128"],["526c18e0.60945"]]},{"id":"526c18e0.60945","type":"switch","z":"2a5ccfd3.08f3f","name":"windGust 32767","property":"payload.windGust","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2849,"y":400,"wires":[["a4a76c2.831f11"],["563fd751.e923e8"]]},{"id":"563fd751.e923e8","type":"switch","z":"2a5ccfd3.08f3f","name":"precipitation 32767","property":"payload.precipitation","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2849,"y":450,"wires":[["e8e50d98.0b2778"],["9366b7d7.751728"]]},{"id":"9366b7d7.751728","type":"switch","z":"2a5ccfd3.08f3f","name":"humidity 32767","property":"payload.humidity","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2839,"y":500,"wires":[["3da673e9.c03e74"],["95762899.1b3168"]]},{"id":"95762899.1b3168","type":"switch","z":"2a5ccfd3.08f3f","name":"pressureStandard 32767","property":"payload.pressureStandard","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2869,"y":550,"wires":[["c9930f2.b00467"],["1d26c0cc.ec22e7"]]},{"id":"1d26c0cc.ec22e7","type":"switch","z":"2a5ccfd3.08f3f","name":" pressureStation 32767","property":"payload.pressureStation","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2869,"y":600,"wires":[["c39dd01e.1c1e6"],["54ed9bba.178354"]]},{"id":"54ed9bba.178354","type":"switch","z":"2a5ccfd3.08f3f","name":"pressureSea 32767","property":"payload.pressureSea","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2859,"y":650,"wires":[["3d8290ec.cc282"],["9ad7663c.359f1"]]},{"id":"9ad7663c.359f1","type":"switch","z":"2a5ccfd3.08f3f","name":"sunshine 32767","property":"payload.sunshine","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2839,"y":700,"wires":[["a57163e.ac42c2"],["a0e78c3f.aaf708"]]},{"id":"a0e78c3f.aaf708","type":"switch","z":"2a5ccfd3.08f3f","name":"dewPoint 32767","property":"payload.dewPoint","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2839,"y":750,"wires":[["660b60e9.9fe798"],["30a61b9f.5515cc"]]},{"id":"30a61b9f.5515cc","type":"switch","z":"2a5ccfd3.08f3f","name":"snowNew 32767","property":"payload.snowNew","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2849,"y":800,"wires":[["7adb5d67.a0edd4"],["b9d4955f.8ef988"]]},{"id":"b9d4955f.8ef988","type":"switch","z":"2a5ccfd3.08f3f","name":"snowTotal 32767","property":"payload.snowTotal","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2849,"y":850,"wires":[["a6409fee.759e7"],["953b07f7.5037a8"]]},{"id":"d3f008d4.f53128","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.windDirection","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3210,"y":350,"wires":[["526c18e0.60945"]]},{"id":"a4a76c2.831f11","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.windGust","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3190,"y":400,"wires":[["563fd751.e923e8"]]},{"id":"e8e50d98.0b2778","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.precipitation","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3200,"y":450,"wires":[["9366b7d7.751728"]]},{"id":"3da673e9.c03e74","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.humidity","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3190,"y":500,"wires":[["95762899.1b3168"]]},{"id":"c9930f2.b00467","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.pressureStandard","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3220,"y":550,"wires":[["1d26c0cc.ec22e7"]]},{"id":"c39dd01e.1c1e6","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.pressureStation","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3210,"y":600,"wires":[["54ed9bba.178354"]]},{"id":"3d8290ec.cc282","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.pressureSea","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3200,"y":650,"wires":[["9ad7663c.359f1"]]},{"id":"a57163e.ac42c2","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.sunshine","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3190,"y":700,"wires":[["a0e78c3f.aaf708"]]},{"id":"660b60e9.9fe798","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.dewPoint","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3190,"y":750,"wires":[["30a61b9f.5515cc"]]},{"id":"7adb5d67.a0edd4","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.snowNew","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3190,"y":800,"wires":[["b9d4955f.8ef988"]]},{"id":"a6409fee.759e7","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.snowTotal","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3200,"y":850,"wires":[["953b07f7.5037a8"]]},{"id":"953b07f7.5037a8","type":"switch","z":"2a5ccfd3.08f3f","name":"foehn 32767","property":"payload.foehn","propertyType":"msg","rules":[{"t":"eq","v":"32767","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":2829,"y":890,"wires":[["e58aaae0.dcd708"],["8792b3f4.ef84c"]]},{"id":"e58aaae0.dcd708","type":"change","z":"2a5ccfd3.08f3f","name":"","rules":[{"t":"delete","p":"payload.foehn","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":3180,"y":890,"wires":[["8792b3f4.ef84c"]]},{"id":"5147e61d.cdacc","type":"comment","z":"2a5ccfd3.08f3f","name":"falls einzelne Messwerte == 32767 sind","info":"","x":2900,"y":210,"wires":[]},{"id":"9b51a5a5.5c5b38","type":"comment","z":"2a5ccfd3.08f3f","name":"lösche die Messwerte == 32767","info":"","x":3190,"y":210,"wires":[]},{"id":"8792b3f4.ef84c","type":"function","z":"2a5ccfd3.08f3f","name":"Stationsname einfügen \\n 2020-11-10","func":"if(msg.payload.stationId==\"TAE\") { msg.payload.stationName = \"Aadorf / Tänikon\"; msg.payload.kanton = \"TG\"; msg.payload.altitude = 539; msg.payload.breite = 47.479892; msg.payload.laenge = 8.904928;}\nif(msg.payload.stationId==\"COM\") { msg.payload.stationName = \"Acquarossa / Comprovasco\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 575; msg.payload.breite = 46.459517; msg.payload.laenge = 8.935486;}\nif(msg.payload.stationId==\"ABO\") { msg.payload.stationName = \"Adelboden\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 1321; msg.payload.breite = 46.491703; msg.payload.laenge = 7.560703;}\nif(msg.payload.stationId==\"AIE\") { msg.payload.stationName = \"Affoltern i. E.\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 755; msg.payload.breite = 47.063125; msg.payload.laenge = 7.740614;}\nif(msg.payload.stationId==\"AIG\") { msg.payload.stationName = \"Aigle\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 381; msg.payload.breite = 46.326647; msg.payload.laenge = 6.924472;}\nif(msg.payload.stationId==\"AIR\") { msg.payload.stationName = \"Airolo\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 1139; msg.payload.breite = 46.525986; msg.payload.laenge = 8.597444;}\nif(msg.payload.stationId==\"ALT\") { msg.payload.stationName = \"Altdorf\"; msg.payload.kanton = \"UR\"; msg.payload.altitude = 438; msg.payload.breite = 46.887069; msg.payload.laenge = 8.621894;}\nif(msg.payload.stationId==\"ARH\") { msg.payload.stationName = \"Altenrhein\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 398; msg.payload.breite = 47.483669; msg.payload.laenge = 9.566803;}\nif(msg.payload.stationId==\"ALS\") { msg.payload.stationName = \"Altstätten, SG\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 430; msg.payload.breite = 47.383225; msg.payload.laenge = 9.556531;}\nif(msg.payload.stationId==\"AMW\") { msg.payload.stationName = \"Amriswil\"; msg.payload.kanton = \"TG\"; msg.payload.altitude = 420; msg.payload.breite = 47.550136; msg.payload.laenge = 9.322475;}\nif(msg.payload.stationId==\"AND\") { msg.payload.stationName = \"Andeer\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 987; msg.payload.breite = 46.610139; msg.payload.laenge = 9.431981;}\nif(msg.payload.stationId==\"ANT\") { msg.payload.stationName = \"Andermatt\"; msg.payload.kanton = \"UR\"; msg.payload.altitude = 1438; msg.payload.breite = 46.630914; msg.payload.laenge = 8.580553;}\nif(msg.payload.stationId==\"VSANZ\") { msg.payload.stationName = \"Anzère\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1614; msg.payload.breite = 46.305244; msg.payload.laenge = 7.407569;}\nif(msg.payload.stationId==\"APP\") { msg.payload.stationName = \"Appenzell\"; msg.payload.kanton = \"AI\"; msg.payload.altitude = 750; msg.payload.breite = 47.339592; msg.payload.laenge = 9.397314;}\nif(msg.payload.stationId==\"VSARO\") { msg.payload.stationName = \"Arolla\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2005; msg.payload.breite = 46.014028; msg.payload.laenge = 7.483919;}\nif(msg.payload.stationId==\"ARO\") { msg.payload.stationName = \"Arosa\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1878; msg.payload.breite = 46.792619; msg.payload.laenge = 9.679014;}\nif(msg.payload.stationId==\"AGATT\") { msg.payload.stationName = \"Attelwil\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 475; msg.payload.breite = 47.265233; msg.payload.laenge = 8.050519;}\nif(msg.payload.stationId==\"RAG\") { msg.payload.stationName = \"Bad Ragaz\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 497; msg.payload.breite = 47.016631; msg.payload.laenge = 9.502594;}\nif(msg.payload.stationId==\"VSBAS\") { msg.payload.stationName = \"Baltschiedertal\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1318; msg.payload.breite = 46.342317; msg.payload.laenge = 7.879325;}\nif(msg.payload.stationId==\"BAN\") { msg.payload.stationName = \"Bantiger\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 942; msg.payload.breite = 46.977806; msg.payload.laenge = 7.528667;}\nif(msg.payload.stationId==\"BAW\") { msg.payload.stationName = \"Barmelweid\"; msg.payload.kanton = \"SO\"; msg.payload.altitude = 777; msg.payload.breite = 47.421456; msg.payload.laenge = 7.969492;}\nif(msg.payload.stationId==\"VSGDX\") { msg.payload.stationName = \"Barrage Grande Dixence\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2162; msg.payload.breite = 46.083728; msg.payload.laenge = 7.403142;}\nif(msg.payload.stationId==\"BAS\") { msg.payload.stationName = \"Basel / Binningen\"; msg.payload.kanton = \"BL\"; msg.payload.altitude = 316; msg.payload.breite = 47.541142; msg.payload.laenge = 7.583525;}\nif(msg.payload.stationId==\"BEY\") { msg.payload.stationName = \"Bellelay\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 923; msg.payload.breite = 47.264514; msg.payload.laenge = 7.169133;}\nif(msg.payload.stationId==\"BLZ\") { msg.payload.stationName = \"Bellinzona\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 224; msg.payload.breite = 46.189886; msg.payload.laenge = 9.004881;}\nif(msg.payload.stationId==\"BEP\") { msg.payload.stationName = \"Belp\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 510; msg.payload.breite = 46.906094; msg.payload.laenge = 7.505339;}\nif(msg.payload.stationId==\"DOB\") { msg.payload.stationName = \"Benken / Doggen\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 408; msg.payload.breite = 47.188733; msg.payload.laenge = 8.961211;}\nif(msg.payload.stationId==\"LAT\") { msg.payload.stationName = \"Bergün / Latsch\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1408; msg.payload.breite = 46.627275; msg.payload.laenge = 9.753706;}\nif(msg.payload.stationId==\"BER\") { msg.payload.stationName = \"Bern / Zollikofen\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 553; msg.payload.breite = 46.990744; msg.payload.laenge = 7.464061;}\nif(msg.payload.stationId==\"BEC\") { msg.payload.stationName = \"Bernina / Curtinatsch\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 2090; msg.payload.breite = 46.441094; msg.payload.laenge = 9.986886;}\nif(msg.payload.stationId==\"BEX\") { msg.payload.stationName = \"Bex\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 402; msg.payload.breite = 46.244167; msg.payload.laenge = 6.995286;}\nif(msg.payload.stationId==\"BEZ\") { msg.payload.stationName = \"Beznau\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 326; msg.payload.breite = 47.557256; msg.payload.laenge = 8.233325;}\nif(msg.payload.stationId==\"BIA\") { msg.payload.stationName = \"Biasca\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 278; msg.payload.breite = 46.336117; msg.payload.laenge = 8.9784;}\nif(msg.payload.stationId==\"BIN\") { msg.payload.stationName = \"Binn\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1479; msg.payload.breite = 46.367661; msg.payload.laenge = 8.192306;}\nif(msg.payload.stationId==\"BIZ\") { msg.payload.stationName = \"Bischofszell\"; msg.payload.kanton = \"TG\"; msg.payload.altitude = 507; msg.payload.breite = 47.508797; msg.payload.laenge = 9.266892;}\nif(msg.payload.stationId==\"BIV\") { msg.payload.stationName = \"Bivio\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1856; msg.payload.breite = 46.462494; msg.payload.laenge = 9.668639;}\nif(msg.payload.stationId==\"BIE\") { msg.payload.stationName = \"Bière\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 684; msg.payload.breite = 46.524908; msg.payload.laenge = 6.342386;}\nif(msg.payload.stationId==\"BLA\") { msg.payload.stationName = \"Blatten, Lötschental\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1538; msg.payload.breite = 46.420453; msg.payload.laenge = 7.823194;}\nif(msg.payload.stationId==\"VSBLI\") { msg.payload.stationName = \"Blinnen\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1530; msg.payload.breite = 46.456992; msg.payload.laenge = 8.259792;}\nif(msg.payload.stationId==\"BOL\") { msg.payload.stationName = \"Boltigen\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 820; msg.payload.breite = 46.623519; msg.payload.laenge = 7.384206;}\nif(msg.payload.stationId==\"BOS\") { msg.payload.stationName = \"Bosco/Gurin\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 1486; msg.payload.breite = 46.316767; msg.payload.laenge = 8.488706;}\nif(msg.payload.stationId==\"VSBSP\") { msg.payload.stationName = \"Bourg-St-Pierre\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1822; msg.payload.breite = 45.927597; msg.payload.laenge = 7.198214;}\nif(msg.payload.stationId==\"BOU\") { msg.payload.stationName = \"Bouveret\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 374; msg.payload.breite = 46.393447; msg.payload.laenge = 6.857006;}\nif(msg.payload.stationId==\"BRW\") { msg.payload.stationName = \"Braunwald\"; msg.payload.kanton = \"GL\"; msg.payload.altitude = 1299; msg.payload.breite = 46.937469; msg.payload.laenge = 8.98765;}\nif(msg.payload.stationId==\"VSBRI\") { msg.payload.stationName = \"Bricola\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2431; msg.payload.breite = 46.046328; msg.payload.laenge = 7.566356;}\nif(msg.payload.stationId==\"BRZ\") { msg.payload.stationName = \"Brienz\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 567; msg.payload.breite = 46.740719; msg.payload.laenge = 8.060864;}\nif(msg.payload.stationId==\"BRI\") { msg.payload.stationName = \"Brig\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 665; msg.payload.breite = 46.311794; msg.payload.laenge = 7.965264;}\nif(msg.payload.stationId==\"BRT\") { msg.payload.stationName = \"Bristen\"; msg.payload.kanton = \"UR\"; msg.payload.altitude = 784; msg.payload.breite = 46.767578; msg.payload.laenge = 8.698389;}\nif(msg.payload.stationId==\"VSBRU\") { msg.payload.stationName = \"Bruchji\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2300; msg.payload.breite = 46.379378; msg.payload.laenge = 7.971533;}\nif(msg.payload.stationId==\"BRP\") { msg.payload.stationName = \"Brusio\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 856; msg.payload.breite = 46.264358; msg.payload.laenge = 10.117231;}\nif(msg.payload.stationId==\"BUS\") { msg.payload.stationName = \"Buchs / Aarau\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 387; msg.payload.breite = 47.384381; msg.payload.laenge = 8.07955;}\nif(msg.payload.stationId==\"BUF\") { msg.payload.stationName = \"Buffalora\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1971; msg.payload.breite = 46.648408; msg.payload.laenge = 10.2672;}\nif(msg.payload.stationId==\"FRE\") { msg.payload.stationName = \"Bullet / La Frétaz\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 1205; msg.payload.breite = 46.840622; msg.payload.laenge = 6.576369;}\nif(msg.payload.stationId==\"UBB\") { msg.payload.stationName = \"Bözberg\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 536; msg.payload.breite = 47.481697; msg.payload.laenge = 8.131847;}\nif(msg.payload.stationId==\"CEV\") { msg.payload.stationName = \"Cevio\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 417; msg.payload.breite = 46.320486; msg.payload.laenge = 8.603161;}\nif(msg.payload.stationId==\"CHZ\") { msg.payload.stationName = \"Cham\"; msg.payload.kanton = \"ZG\"; msg.payload.altitude = 443; msg.payload.breite = 47.188278; msg.payload.laenge = 8.464642;}\nif(msg.payload.stationId==\"VSCHY\") { msg.payload.stationName = \"Champéry\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1055; msg.payload.breite = 46.162733; msg.payload.laenge = 6.861122;}\nif(msg.payload.stationId==\"CHA\") { msg.payload.stationName = \"Chasseral\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 1594; msg.payload.breite = 47.131761; msg.payload.laenge = 7.054367;}\nif(msg.payload.stationId==\"CHM\") { msg.payload.stationName = \"Chaumont\"; msg.payload.kanton = \"NE\"; msg.payload.altitude = 1136; msg.payload.breite = 47.049169; msg.payload.laenge = 6.978825;}\nif(msg.payload.stationId==\"VSCHO\") { msg.payload.stationName = \"Choëx\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 891; msg.payload.breite = 46.232136; msg.payload.laenge = 6.961356;}\nif(msg.payload.stationId==\"CHU\") { msg.payload.stationName = \"Chur\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 556; msg.payload.breite = 46.870367; msg.payload.laenge = 9.530511;}\nif(msg.payload.stationId==\"CHD\") { msg.payload.stationName = \"Château-d'Oex\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 1028; msg.payload.breite = 46.479819; msg.payload.laenge = 7.139656;}\nif(msg.payload.stationId==\"CIM\") { msg.payload.stationName = \"Cimetta\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 1661; msg.payload.breite = 46.200467; msg.payload.laenge = 8.79165;}\nif(msg.payload.stationId==\"VSCLU\") { msg.payload.stationName = \"Clusanfe\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1926; msg.payload.breite = 46.135931; msg.payload.laenge = 6.885281;}\nif(msg.payload.stationId==\"CDM\") { msg.payload.stationName = \"Col des Mosses\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 1412; msg.payload.breite = 46.391525; msg.payload.laenge = 7.098239;}\nif(msg.payload.stationId==\"GSB\") { msg.payload.stationName = \"Col du Grand St-Bernard\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2472; msg.payload.breite = 45.869092; msg.payload.laenge = 7.170683;}\nif(msg.payload.stationId==\"COL\") { msg.payload.stationName = \"Coldrerio\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 347; msg.payload.breite = 45.853914; msg.payload.laenge = 8.997431;}\nif(msg.payload.stationId==\"COS\") { msg.payload.stationName = \"Cossonay\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 590; msg.payload.breite = 46.609519; msg.payload.laenge = 6.493083;}\nif(msg.payload.stationId==\"COY\") { msg.payload.stationName = \"Courtelary\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 695; msg.payload.breite = 47.180811; msg.payload.laenge = 7.090656;}\nif(msg.payload.stationId==\"COU\") { msg.payload.stationName = \"Couvet\"; msg.payload.kanton = \"NE\"; msg.payload.altitude = 728; msg.payload.breite = 46.933542; msg.payload.laenge = 6.658683;}\nif(msg.payload.stationId==\"CMA\") { msg.payload.stationName = \"Crap Masegn\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 2480; msg.payload.breite = 46.842292; msg.payload.laenge = 9.179997;}\nif(msg.payload.stationId==\"CRM\") { msg.payload.stationName = \"Cressier\"; msg.payload.kanton = \"NE\"; msg.payload.altitude = 430; msg.payload.breite = 47.047581; msg.payload.laenge = 7.059147;}\nif(msg.payload.stationId==\"DAV\") { msg.payload.stationName = \"Davos\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1594; msg.payload.breite = 46.812969; msg.payload.laenge = 9.843558;}\nif(msg.payload.stationId==\"DEM\") { msg.payload.stationName = \"Delémont\"; msg.payload.kanton = \"JU\"; msg.payload.altitude = 439; msg.payload.breite = 47.351706; msg.payload.laenge = 7.349567;}\nif(msg.payload.stationId==\"VSDER\") { msg.payload.stationName = \"Derborence\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1366; msg.payload.breite = 46.288503; msg.payload.laenge = 7.232506;}\nif(msg.payload.stationId==\"DIT\") { msg.payload.stationName = \"Dietikon\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 384; msg.payload.breite = 47.413558; msg.payload.laenge = 8.404472;}\nif(msg.payload.stationId==\"DIS\") { msg.payload.stationName = \"Disentis\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1197; msg.payload.breite = 46.706569; msg.payload.laenge = 8.853478;}\nif(msg.payload.stationId==\"VSDUR\") { msg.payload.stationName = \"Durnand\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1214; msg.payload.breite = 46.051722; msg.payload.laenge = 7.084258;}\nif(msg.payload.stationId==\"EBK\") { msg.payload.stationName = \"Ebnat-Kappel\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 623; msg.payload.breite = 47.273389; msg.payload.laenge = 9.108494;}\nif(msg.payload.stationId==\"EGR\") { msg.payload.stationName = \"Eggersriet\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 770; msg.payload.breite = 47.438753; msg.payload.laenge = 9.467903;}\nif(msg.payload.stationId==\"EGH\") { msg.payload.stationName = \"Eggishorn\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2892; msg.payload.breite = 46.426528; msg.payload.laenge = 8.092728;}\nif(msg.payload.stationId==\"EGO\") { msg.payload.stationName = \"Egolzwil\"; msg.payload.kanton = \"LU\"; msg.payload.altitude = 522; msg.payload.breite = 47.179428; msg.payload.laenge = 8.004758;}\nif(msg.payload.stationId==\"OED\") { msg.payload.stationName = \"Ehrendingen\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 428; msg.payload.breite = 47.508125; msg.payload.laenge = 8.339047;}\nif(msg.payload.stationId==\"EIN\") { msg.payload.stationName = \"Einsiedeln\"; msg.payload.kanton = \"SZ\"; msg.payload.altitude = 911; msg.payload.breite = 47.133042; msg.payload.laenge = 8.756556;}\nif(msg.payload.stationId==\"ELM\") { msg.payload.stationName = \"Elm\"; msg.payload.kanton = \"GL\"; msg.payload.altitude = 958; msg.payload.breite = 46.923747; msg.payload.laenge = 9.17535;}\nif(msg.payload.stationId==\"VSEMO\") { msg.payload.stationName = \"Emosson\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1923; msg.payload.breite = 46.0656; msg.payload.laenge = 6.930278;}\nif(msg.payload.stationId==\"ENG\") { msg.payload.stationName = \"Engelberg\"; msg.payload.kanton = \"OW\"; msg.payload.altitude = 1036; msg.payload.breite = 46.821639; msg.payload.laenge = 8.410514;}\nif(msg.payload.stationId==\"ENT\") { msg.payload.stationName = \"Entlebuch\"; msg.payload.kanton = \"LU\"; msg.payload.altitude = 768; msg.payload.breite = 46.986814; msg.payload.laenge = 8.068747;}\nif(msg.payload.stationId==\"VSERG\") { msg.payload.stationName = \"Ergisch\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1133; msg.payload.breite = 46.293008; msg.payload.laenge = 7.716292;}\nif(msg.payload.stationId==\"ESZ\") { msg.payload.stationName = \"Eschenz\"; msg.payload.kanton = \"TG\"; msg.payload.altitude = 414; msg.payload.breite = 47.645811; msg.payload.laenge = 8.874211;}\nif(msg.payload.stationId==\"EVI\") { msg.payload.stationName = \"Evionnaz\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 482; msg.payload.breite = 46.182953; msg.payload.laenge = 7.026747;}\nif(msg.payload.stationId==\"EVO\") { msg.payload.stationName = \"Evolène / Villa\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1825; msg.payload.breite = 46.112211; msg.payload.laenge = 7.508631;}\nif(msg.payload.stationId==\"FAH\") { msg.payload.stationName = \"Fahy\"; msg.payload.kanton = \"JU\"; msg.payload.altitude = 596; msg.payload.breite = 47.423814; msg.payload.laenge = 6.941194;}\nif(msg.payload.stationId==\"FAI\") { msg.payload.stationName = \"Faido\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 747; msg.payload.breite = 46.477486; msg.payload.laenge = 8.805294;}\nif(msg.payload.stationId==\"FIT\") { msg.payload.stationName = \"Fieschertal\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1175; msg.payload.breite = 46.427906; msg.payload.laenge = 8.141022;}\nif(msg.payload.stationId==\"VSFIN\") { msg.payload.stationName = \"Findelen\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2170; msg.payload.breite = 46.010958; msg.payload.laenge = 7.778389;}\nif(msg.payload.stationId==\"FIO\") { msg.payload.stationName = \"Fionnay\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1500; msg.payload.breite = 46.03135; msg.payload.laenge = 7.308961;}\nif(msg.payload.stationId==\"FLW\") { msg.payload.stationName = \"Flawil\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 571; msg.payload.breite = 47.414142; msg.payload.laenge = 9.202886;}\nif(msg.payload.stationId==\"FLU\") { msg.payload.stationName = \"Flühli, LU\"; msg.payload.kanton = \"LU\"; msg.payload.altitude = 940; msg.payload.breite = 46.889436; msg.payload.laenge = 8.020336;}\nif(msg.payload.stationId==\"GRA\") { msg.payload.stationName = \"Fribourg / Posieux\"; msg.payload.kanton = \"FR\"; msg.payload.altitude = 651; msg.payload.breite = 46.7714; msg.payload.laenge = 7.113736;}\nif(msg.payload.stationId==\"FRU\") { msg.payload.stationName = \"Frutigen\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 756; msg.payload.breite = 46.599003; msg.payload.laenge = 7.657542;}\nif(msg.payload.stationId==\"GVE\") { msg.payload.stationName = \"Genève / Cointrin\"; msg.payload.kanton = \"GE\"; msg.payload.altitude = 411; msg.payload.breite = 46.247519; msg.payload.laenge = 6.127742;}\nif(msg.payload.stationId==\"GES\") { msg.payload.stationName = \"Gersau\"; msg.payload.kanton = \"SZ\"; msg.payload.altitude = 521; msg.payload.breite = 46.996069; msg.payload.laenge = 8.523442;}\nif(msg.payload.stationId==\"GIH\") { msg.payload.stationName = \"Giswil\"; msg.payload.kanton = \"OW\"; msg.payload.altitude = 471; msg.payload.breite = 46.84945; msg.payload.laenge = 8.190225;}\nif(msg.payload.stationId==\"GLA\") { msg.payload.stationName = \"Glarus\"; msg.payload.kanton = \"GL\"; msg.payload.altitude = 517; msg.payload.breite = 47.034586; msg.payload.laenge = 9.066961;}\nif(msg.payload.stationId==\"GOR\") { msg.payload.stationName = \"Gornergrat\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 3129; msg.payload.breite = 45.983633; msg.payload.laenge = 7.785742;}\nif(msg.payload.stationId==\"GRE\") { msg.payload.stationName = \"Grenchen\"; msg.payload.kanton = \"SO\"; msg.payload.altitude = 428; msg.payload.breite = 47.179097; msg.payload.laenge = 7.415144;}\nif(msg.payload.stationId==\"GRH\") { msg.payload.stationName = \"Grimsel Hospiz\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 1980; msg.payload.breite = 46.571689; msg.payload.laenge = 8.333256;}\nif(msg.payload.stationId==\"GRO\") { msg.payload.stationName = \"Grono\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 324; msg.payload.breite = 46.255075; msg.payload.laenge = 9.163758;}\nif(msg.payload.stationId==\"GRC\") { msg.payload.stationName = \"Grächen\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1605; msg.payload.breite = 46.195314; msg.payload.laenge = 7.836822;}\nif(msg.payload.stationId==\"GSG\") { msg.payload.stationName = \"Gsteig, Gstaad\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 1196; msg.payload.breite = 46.376533; msg.payload.laenge = 7.278592;}\nif(msg.payload.stationId==\"GTT\") { msg.payload.stationName = \"Guttannen\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 1055; msg.payload.breite = 46.656444; msg.payload.laenge = 8.291717;}\nif(msg.payload.stationId==\"GOS\") { msg.payload.stationName = \"Göschenen\"; msg.payload.kanton = \"UR\"; msg.payload.altitude = 950; msg.payload.breite = 46.692678; msg.payload.laenge = 8.595364;}\nif(msg.payload.stationId==\"GOA\") { msg.payload.stationName = \"Göscheneralp\"; msg.payload.kanton = \"UR\"; msg.payload.altitude = 1745; msg.payload.breite = 46.647525; msg.payload.laenge = 8.500025;}\nif(msg.payload.stationId==\"GOE\") { msg.payload.stationName = \"Gösgen\"; msg.payload.kanton = \"SO\"; msg.payload.altitude = 380; msg.payload.breite = 47.363147; msg.payload.laenge = 7.973733;}\nif(msg.payload.stationId==\"GUE\") { msg.payload.stationName = \"Gütsch, Andermatt\"; msg.payload.kanton = \"UR\"; msg.payload.altitude = 2286; msg.payload.breite = 46.652475; msg.payload.laenge = 8.615531;}\nif(msg.payload.stationId==\"GUT\") { msg.payload.stationName = \"Güttingen\"; msg.payload.kanton = \"TG\"; msg.payload.altitude = 440; msg.payload.breite = 47.601733; msg.payload.laenge = 9.279428;}\nif(msg.payload.stationId==\"HLL\") { msg.payload.stationName = \"Hallau\"; msg.payload.kanton = \"SH\"; msg.payload.altitude = 419; msg.payload.breite = 47.697275; msg.payload.laenge = 8.470472;}\nif(msg.payload.stationId==\"HUT\") { msg.payload.stationName = \"Huttwil\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 633; msg.payload.breite = 47.114003; msg.payload.laenge = 7.837364;}\nif(msg.payload.stationId==\"HOE\") { msg.payload.stationName = \"Hörnli\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 1133; msg.payload.breite = 47.370864; msg.payload.laenge = 8.941644;}\nif(msg.payload.stationId==\"ILZ\") { msg.payload.stationName = \"Ilanz\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 698; msg.payload.breite = 46.775039; msg.payload.laenge = 9.215353;}\nif(msg.payload.stationId==\"INN\") { msg.payload.stationName = \"Innerthal\"; msg.payload.kanton = \"SZ\"; msg.payload.altitude = 903; msg.payload.breite = 47.106439; msg.payload.laenge = 8.915283;}\nif(msg.payload.stationId==\"INT\") { msg.payload.stationName = \"Interlaken\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 577; msg.payload.breite = 46.672233; msg.payload.laenge = 7.870194;}\nif(msg.payload.stationId==\"VSISE\") { msg.payload.stationName = \"Isérables\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1237; msg.payload.breite = 46.160928; msg.payload.laenge = 7.248742;}\nif(msg.payload.stationId==\"VSJEI\") { msg.payload.stationName = \"Jeizinen\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1556; msg.payload.breite = 46.328389; msg.payload.laenge = 7.722472;}\nif(msg.payload.stationId==\"JON\") { msg.payload.stationName = \"Jona\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 410; msg.payload.breite = 47.223908; msg.payload.laenge = 8.848289;}\nif(msg.payload.stationId==\"JUN\") { msg.payload.stationName = \"Jungfraujoch\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 3571; msg.payload.breite = 46.547556; msg.payload.laenge = 7.985444;}\nif(msg.payload.stationId==\"KAI\") { msg.payload.stationName = \"Kaiserstuhl, AG\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 361; msg.payload.breite = 47.570603; msg.payload.laenge = 8.413231;}\nif(msg.payload.stationId==\"KAS\") { msg.payload.stationName = \"Kandersteg\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 1178; msg.payload.breite = 46.493842; msg.payload.laenge = 7.677167;}\nif(msg.payload.stationId==\"KIE\") { msg.payload.stationName = \"Kiental\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 930; msg.payload.breite = 46.582575; msg.payload.laenge = 7.727097;}\nif(msg.payload.stationId==\"KIS\") { msg.payload.stationName = \"Kiesen\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 535; msg.payload.breite = 46.820811; msg.payload.laenge = 7.573036;}\nif(msg.payload.stationId==\"KLA\") { msg.payload.stationName = \"Klosters\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1186; msg.payload.breite = 46.865153; msg.payload.laenge = 9.889703;}\nif(msg.payload.stationId==\"KOP\") { msg.payload.stationName = \"Koppigen\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 485; msg.payload.breite = 47.11885; msg.payload.laenge = 7.605503;}\nif(msg.payload.stationId==\"AUB\") { msg.payload.stationName = \"L' Auberson\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 1096; msg.payload.breite = 46.82345; msg.payload.laenge = 6.440692;}\nif(msg.payload.stationId==\"BRL\") { msg.payload.stationName = \"La Brévine\"; msg.payload.kanton = \"NE\"; msg.payload.altitude = 1050; msg.payload.breite = 46.983844; msg.payload.laenge = 6.610297;}\nif(msg.payload.stationId==\"CDF\") { msg.payload.stationName = \"La Chaux-de-Fonds\"; msg.payload.kanton = \"NE\"; msg.payload.altitude = 1017; msg.payload.breite = 47.082947; msg.payload.laenge = 6.792314;}\nif(msg.payload.stationId==\"DOL\") { msg.payload.stationName = \"La Dôle\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 1670; msg.payload.breite = 46.424794; msg.payload.laenge = 6.099453;}\nif(msg.payload.stationId==\"VSFLY\") { msg.payload.stationName = \"La Fouly\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1564; msg.payload.breite = 45.936628; msg.payload.laenge = 7.096361;}\nif(msg.payload.stationId==\"VST\") { msg.payload.stationName = \"La Valsainte\"; msg.payload.kanton = \"FR\"; msg.payload.altitude = 1044; msg.payload.breite = 46.647767; msg.payload.laenge = 7.178561;}\nif(msg.payload.stationId==\"LAC\") { msg.payload.stationName = \"Lachen / Galgenen\"; msg.payload.kanton = \"SZ\"; msg.payload.altitude = 468; msg.payload.breite = 47.179197; msg.payload.laenge = 8.858686;}\nif(msg.payload.stationId==\"LAB\") { msg.payload.stationName = \"Langenbruck\"; msg.payload.kanton = \"BL\"; msg.payload.altitude = 731; msg.payload.breite = 47.352886; msg.payload.laenge = 7.759594;}\nif(msg.payload.stationId==\"LAG\") { msg.payload.stationName = \"Langnau i.E.\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 744; msg.payload.breite = 46.939633; msg.payload.laenge = 7.806425;}\nif(msg.payload.stationId==\"LSN\") { msg.payload.stationName = \"Lausanne\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 601; msg.payload.breite = 46.527819; msg.payload.laenge = 6.643267;}\nif(msg.payload.stationId==\"LTB\") { msg.payload.stationName = \"Lauterbrunnen\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 815; msg.payload.breite = 46.592917; msg.payload.laenge = 7.906464;}\nif(msg.payload.stationId==\"MLS\") { msg.payload.stationName = \"Le Moléson\"; msg.payload.kanton = \"FR\"; msg.payload.altitude = 1974; msg.payload.breite = 46.546197; msg.payload.laenge = 7.017753;}\nif(msg.payload.stationId==\"LEI\") { msg.payload.stationName = \"Leibstadt\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 341; msg.payload.breite = 47.597361; msg.payload.laenge = 8.1882;}\nif(msg.payload.stationId==\"ATT\") { msg.payload.stationName = \"Les Attelas\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2734; msg.payload.breite = 46.0991; msg.payload.laenge = 7.26865;}\nif(msg.payload.stationId==\"AVA\") { msg.payload.stationName = \"Les Avants\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 1036; msg.payload.breite = 46.45685; msg.payload.laenge = 6.942444;}\nif(msg.payload.stationId==\"CHB\") { msg.payload.stationName = \"Les Charbonnières\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 1045; msg.payload.breite = 46.67015; msg.payload.laenge = 6.312428;}\nif(msg.payload.stationId==\"VSCOL\") { msg.payload.stationName = \"Les Collons\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1770; msg.payload.breite = 46.178975; msg.payload.laenge = 7.387361;}\nif(msg.payload.stationId==\"DIA\") { msg.payload.stationName = \"Les Diablerets\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2964; msg.payload.breite = 46.32675; msg.payload.laenge = 7.203781;}\nif(msg.payload.stationId==\"MAR\") { msg.payload.stationName = \"Les Marécottes\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 990; msg.payload.breite = 46.118903; msg.payload.laenge = 7.016597;}\nif(msg.payload.stationId==\"LEU\") { msg.payload.stationName = \"Leukerbad\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1286; msg.payload.breite = 46.367036; msg.payload.laenge = 7.621639;}\nif(msg.payload.stationId==\"OTL\") { msg.payload.stationName = \"Locarno / Monti\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 367; msg.payload.breite = 46.172256; msg.payload.laenge = 8.787494;}\nif(msg.payload.stationId==\"LOH\") { msg.payload.stationName = \"Lohn, SH\"; msg.payload.kanton = \"SH\"; msg.payload.altitude = 585; msg.payload.breite = 47.751944; msg.payload.laenge = 8.677636;}\nif(msg.payload.stationId==\"LON\") { msg.payload.stationName = \"Longirod\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 900; msg.payload.breite = 46.496139; msg.payload.laenge = 6.258281;}\nif(msg.payload.stationId==\"LUG\") { msg.payload.stationName = \"Lugano\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 273; msg.payload.breite = 46.004217; msg.payload.laenge = 8.960322;}\nif(msg.payload.stationId==\"LUZ\") { msg.payload.stationName = \"Luzern\"; msg.payload.kanton = \"LU\"; msg.payload.altitude = 454; msg.payload.breite = 47.036439; msg.payload.laenge = 8.301022;}\nif(msg.payload.stationId==\"LAE\") { msg.payload.stationName = \"Lägern\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 845; msg.payload.breite = 47.481933; msg.payload.laenge = 8.397222;}\nif(msg.payload.stationId==\"MAG\") { msg.payload.stationName = \"Magadino / Cadenazzo\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 203; msg.payload.breite = 46.160025; msg.payload.laenge = 8.933672;}\nif(msg.payload.stationId==\"MGL\") { msg.payload.stationName = \"Magglingen\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 883; msg.payload.breite = 47.1408; msg.payload.laenge = 7.215022;}\nif(msg.payload.stationId==\"MAL\") { msg.payload.stationName = \"Malbun\"; msg.payload.kanton = \"FL\"; msg.payload.altitude = 1610; msg.payload.breite = 47.103139; msg.payload.laenge = 9.608633;}\nif(msg.payload.stationId==\"MAS\") { msg.payload.stationName = \"Marsens\"; msg.payload.kanton = \"FR\"; msg.payload.altitude = 715; msg.payload.breite = 46.656486; msg.payload.laenge = 7.069669;}\nif(msg.payload.stationId==\"MAB\") { msg.payload.stationName = \"Martigny\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 461; msg.payload.breite = 46.109789; msg.payload.laenge = 7.062517;}\nif(msg.payload.stationId==\"MAT\") { msg.payload.stationName = \"Martina\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1041; msg.payload.breite = 46.884011; msg.payload.laenge = 10.463031;}\nif(msg.payload.stationId==\"MAH\") { msg.payload.stationName = \"Mathod\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 435; msg.payload.breite = 46.736978; msg.payload.laenge = 6.567983;}\nif(msg.payload.stationId==\"MTR\") { msg.payload.stationName = \"Matro\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 2171; msg.payload.breite = 46.410103; msg.payload.laenge = 8.924742;}\nif(msg.payload.stationId==\"VSMAT\") { msg.payload.stationName = \"Mattsand\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1230; msg.payload.breite = 46.143439; msg.payload.laenge = 7.791289;}\nif(msg.payload.stationId==\"MER\") { msg.payload.stationName = \"Meiringen\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 589; msg.payload.breite = 46.732222; msg.payload.laenge = 8.169247;}\nif(msg.payload.stationId==\"MEV\") { msg.payload.stationName = \"Mervelier\"; msg.payload.kanton = \"JU\"; msg.payload.altitude = 540; msg.payload.breite = 47.346619; msg.payload.laenge = 7.490042;}\nif(msg.payload.stationId==\"VSMOI\") { msg.payload.stationName = \"Moiry\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2127; msg.payload.breite = 46.137717; msg.payload.laenge = 7.570217;}\nif(msg.payload.stationId==\"MOB\") { msg.payload.stationName = \"Montagnier, Bagnes\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 839; msg.payload.breite = 46.071019; msg.payload.laenge = 7.225272;}\nif(msg.payload.stationId==\"MVE\") { msg.payload.stationName = \"Montana\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1423; msg.payload.breite = 46.298806; msg.payload.laenge = 7.460814;}\nif(msg.payload.stationId==\"GEN\") { msg.payload.stationName = \"Monte Generoso\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 1600; msg.payload.breite = 45.927592; msg.payload.laenge = 9.017875;}\nif(msg.payload.stationId==\"MRP\") { msg.payload.stationName = \"Monte Rosa-Plattje\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2885; msg.payload.breite = 45.956628; msg.payload.laenge = 7.814575;}\nif(msg.payload.stationId==\"MMO\") { msg.payload.stationName = \"Mormont\"; msg.payload.kanton = \"JU\"; msg.payload.altitude = 535; msg.payload.breite = 47.438111; msg.payload.laenge = 7.037333;}\nif(msg.payload.stationId==\"MOA\") { msg.payload.stationName = \"Mosen\"; msg.payload.kanton = \"LU\"; msg.payload.altitude = 453; msg.payload.breite = 47.243842; msg.payload.laenge = 8.232828;}\nif(msg.payload.stationId==\"MSG\") { msg.payload.stationName = \"Mosogno\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 771; msg.payload.breite = 46.198503; msg.payload.laenge = 8.640914;}\nif(msg.payload.stationId==\"MTE\") { msg.payload.stationName = \"Mottec\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1580; msg.payload.breite = 46.147897; msg.payload.laenge = 7.624033;}\nif(msg.payload.stationId==\"MUR\") { msg.payload.stationName = \"Muri, AG\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 577; msg.payload.breite = 47.265381; msg.payload.laenge = 8.327608;}\nif(msg.payload.stationId==\"MOE\") { msg.payload.stationName = \"Möhlin\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 343; msg.payload.breite = 47.572197; msg.payload.laenge = 7.877911;}\nif(msg.payload.stationId==\"MSK\") { msg.payload.stationName = \"Mühleberg / Stockeren\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 706; msg.payload.breite = 46.952103; msg.payload.laenge = 7.282972;}\nif(msg.payload.stationId==\"MUB\") { msg.payload.stationName = \"Mühleberg\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 480; msg.payload.breite = 46.973278; msg.payload.laenge = 7.278217;}\nif(msg.payload.stationId==\"NAS\") { msg.payload.stationName = \"Naluns / Schlivera\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 2380; msg.payload.breite = 46.817164; msg.payload.laenge = 10.2614;}\nif(msg.payload.stationId==\"NAP\") { msg.payload.stationName = \"Napf\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 1404; msg.payload.breite = 47.004667; msg.payload.laenge = 7.940117;}\nif(msg.payload.stationId==\"VSNEN\") { msg.payload.stationName = \"Nendaz\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1938; msg.payload.breite = 46.122092; msg.payload.laenge = 7.311411;}\nif(msg.payload.stationId==\"NEB\") { msg.payload.stationName = \"Nesselboden\"; msg.payload.kanton = \"SO\"; msg.payload.altitude = 1055; msg.payload.breite = 47.245169; msg.payload.laenge = 7.508581;}\nif(msg.payload.stationId==\"NEU\") { msg.payload.stationName = \"Neuchâtel\"; msg.payload.kanton = \"NE\"; msg.payload.altitude = 485; msg.payload.breite = 47.000067; msg.payload.laenge = 6.953297;}\nif(msg.payload.stationId==\"CGI\") { msg.payload.stationName = \"Nyon / Changins\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 458; msg.payload.breite = 46.401053; msg.payload.laenge = 6.227722;}\nif(msg.payload.stationId==\"OBI\") { msg.payload.stationName = \"Oberiberg\"; msg.payload.kanton = \"SZ\"; msg.payload.altitude = 1075; msg.payload.breite = 47.037383; msg.payload.laenge = 8.778656;}\nif(msg.payload.stationId==\"OBR\") { msg.payload.stationName = \"Oberriet / Kriessern\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 409; msg.payload.breite = 47.376608; msg.payload.laenge = 9.612706;}\nif(msg.payload.stationId==\"AEG\") { msg.payload.stationName = \"Oberägeri\"; msg.payload.kanton = \"ZG\"; msg.payload.altitude = 724; msg.payload.breite = 47.133636; msg.payload.laenge = 8.608206;}\nif(msg.payload.stationId==\"OPF\") { msg.payload.stationName = \"Opfikon\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 424; msg.payload.breite = 47.437633; msg.payload.laenge = 8.560339;}\nif(msg.payload.stationId==\"ORO\") { msg.payload.stationName = \"Oron\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 828; msg.payload.breite = 46.572269; msg.payload.laenge = 6.858239;}\nif(msg.payload.stationId==\"ORS\") { msg.payload.stationName = \"Orsières\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 929; msg.payload.breite = 46.021411; msg.payload.laenge = 7.141919;}\nif(msg.payload.stationId==\"VSOTE\") { msg.payload.stationName = \"Otemma\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2357; msg.payload.breite = 45.924364; msg.payload.laenge = 7.393214;}\nif(msg.payload.stationId==\"BEH\") { msg.payload.stationName = \"Passo del Bernina\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 2260; msg.payload.breite = 46.409158; msg.payload.laenge = 10.019567;}\nif(msg.payload.stationId==\"PAY\") { msg.payload.stationName = \"Payerne\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 490; msg.payload.breite = 46.811581; msg.payload.laenge = 6.942469;}\nif(msg.payload.stationId==\"PIL\") { msg.payload.stationName = \"Pilatus\"; msg.payload.kanton = \"OW\"; msg.payload.altitude = 2105; msg.payload.breite = 46.978869; msg.payload.laenge = 8.252256;}\nif(msg.payload.stationId==\"PIO\") { msg.payload.stationName = \"Piotta\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 990; msg.payload.breite = 46.514811; msg.payload.laenge = 8.688039;}\nif(msg.payload.stationId==\"COV\") { msg.payload.stationName = \"Piz Corvatsch\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 3294; msg.payload.breite = 46.418039; msg.payload.laenge = 9.821308;}\nif(msg.payload.stationId==\"PMA\") { msg.payload.stationName = \"Piz Martegnas\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 2670; msg.payload.breite = 46.577181; msg.payload.laenge = 9.529544;}\nif(msg.payload.stationId==\"PLF\") { msg.payload.stationName = \"Plaffeien\"; msg.payload.kanton = \"FR\"; msg.payload.altitude = 1042; msg.payload.breite = 46.747717; msg.payload.laenge = 7.266264;}\nif(msg.payload.stationId==\"ROB\") { msg.payload.stationName = \"Poschiavo / Robbia\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1078; msg.payload.breite = 46.347217; msg.payload.laenge = 10.063031;}\nif(msg.payload.stationId==\"PUY\") { msg.payload.stationName = \"Pully\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 456; msg.payload.breite = 46.512283; msg.payload.laenge = 6.667517;}\nif(msg.payload.stationId==\"QUI\") { msg.payload.stationName = \"Quinten\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 419; msg.payload.breite = 47.128739; msg.payload.laenge = 9.21605;}\nif(msg.payload.stationId==\"REM\") { msg.payload.stationName = \"Rempen\"; msg.payload.kanton = \"SZ\"; msg.payload.altitude = 650; msg.payload.breite = 47.138378; msg.payload.laenge = 8.896797;}\nif(msg.payload.stationId==\"WHF\") { msg.payload.stationName = \"Riedholz / Wallierhof\"; msg.payload.kanton = \"SO\"; msg.payload.altitude = 518; msg.payload.breite = 47.234278; msg.payload.laenge = 7.562697;}\nif(msg.payload.stationId==\"ROE\") { msg.payload.stationName = \"Robièi\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 1898; msg.payload.breite = 46.443067; msg.payload.laenge = 8.513389;}\nif(msg.payload.stationId==\"ROM\") { msg.payload.stationName = \"Romont\"; msg.payload.kanton = \"FR\"; msg.payload.altitude = 692; msg.payload.breite = 46.703694; msg.payload.laenge = 6.934894;}\nif(msg.payload.stationId==\"ROG\") { msg.payload.stationName = \"Rossberg\"; msg.payload.kanton = \"SZ\"; msg.payload.altitude = 1119; msg.payload.breite = 47.073556; msg.payload.laenge = 8.547622;}\nif(msg.payload.stationId==\"ROT\") { msg.payload.stationName = \"Rothenbrunnen\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 622; msg.payload.breite = 46.765706; msg.payload.laenge = 9.418467;}\nif(msg.payload.stationId==\"RUE\") { msg.payload.stationName = \"Rünenberg\"; msg.payload.kanton = \"BL\"; msg.payload.altitude = 611; msg.payload.breite = 47.434572; msg.payload.laenge = 7.879414;}\nif(msg.payload.stationId==\"SBE\") { msg.payload.stationName = \"S. Bernardino\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1639; msg.payload.breite = 46.463542; msg.payload.laenge = 9.1847;}\nif(msg.payload.stationId==\"VSSAB\") { msg.payload.stationName = \"Saas Balen\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1535; msg.payload.breite = 46.148778; msg.payload.laenge = 7.928353;}\nif(msg.payload.stationId==\"SAP\") { msg.payload.stationName = \"Safien Platz\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1296; msg.payload.breite = 46.678703; msg.payload.laenge = 9.315078;}\nif(msg.payload.stationId==\"SAI\") { msg.payload.stationName = \"Saignelégier\"; msg.payload.kanton = \"JU\"; msg.payload.altitude = 883; msg.payload.breite = 47.256906; msg.payload.laenge = 6.980856;}\nif(msg.payload.stationId==\"VSSFE\") { msg.payload.stationName = \"Salanfe\t\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1965; msg.payload.breite = 46.145647; msg.payload.laenge = 6.972969;}\nif(msg.payload.stationId==\"VSSAL\") { msg.payload.stationName = \"Saleina\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1600; msg.payload.breite = 45.986031; msg.payload.laenge = 7.093961;}\nif(msg.payload.stationId==\"HAI\") { msg.payload.stationName = \"Salen-Reutenen\"; msg.payload.kanton = \"TG\"; msg.payload.altitude = 719; msg.payload.breite = 47.651242; msg.payload.laenge = 9.023911;}\nif(msg.payload.stationId==\"SAX\") { msg.payload.stationName = \"Salez / Saxerriet\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 436; msg.payload.breite = 47.232961; msg.payload.laenge = 9.493086;}\nif(msg.payload.stationId==\"SAM\") { msg.payload.stationName = \"Samedan\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1709; msg.payload.breite = 46.526247; msg.payload.laenge = 9.879469;}\nif(msg.payload.stationId==\"SAG\") { msg.payload.stationName = \"Sattel, SZ\"; msg.payload.kanton = \"SZ\"; msg.payload.altitude = 790; msg.payload.breite = 47.081064; msg.payload.laenge = 8.636967;}\nif(msg.payload.stationId==\"SVG\") { msg.payload.stationName = \"Savognin\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1172; msg.payload.breite = 46.594753; msg.payload.laenge = 9.597142;}\nif(msg.payload.stationId==\"SUA\") { msg.payload.stationName = \"Schaan\"; msg.payload.kanton = \"FL\"; msg.payload.altitude = 444; msg.payload.breite = 47.186989; msg.payload.laenge = 9.490686;}\nif(msg.payload.stationId==\"SHA\") { msg.payload.stationName = \"Schaffhausen\"; msg.payload.kanton = \"SH\"; msg.payload.altitude = 438; msg.payload.breite = 47.689842; msg.payload.laenge = 8.620142;}\nif(msg.payload.stationId==\"SRS\") { msg.payload.stationName = \"Schiers\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 626; msg.payload.breite = 46.975506; msg.payload.laenge = 9.668075;}\nif(msg.payload.stationId==\"SCM\") { msg.payload.stationName = \"Schmerikon\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 408; msg.payload.breite = 47.224933; msg.payload.laenge = 8.9403;}\nif(msg.payload.stationId==\"SPF\") { msg.payload.stationName = \"Schüpfheim\"; msg.payload.kanton = \"LU\"; msg.payload.altitude = 744; msg.payload.breite = 46.947042; msg.payload.laenge = 8.012442;}\nif(msg.payload.stationId==\"SCU\") { msg.payload.stationName = \"Scuol\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1304; msg.payload.breite = 46.793275; msg.payload.laenge = 10.283267;}\nif(msg.payload.stationId==\"SIA\") { msg.payload.stationName = \"Segl-Maria\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1804; msg.payload.breite = 46.432331; msg.payload.laenge = 9.762325;}\nif(msg.payload.stationId==\"SIE\") { msg.payload.stationName = \"Siebnen\"; msg.payload.kanton = \"SZ\"; msg.payload.altitude = 452; msg.payload.breite = 47.171511; msg.payload.laenge = 8.900483;}\nif(msg.payload.stationId==\"VSSIE\") { msg.payload.stationName = \"Sierre\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 535; msg.payload.breite = 46.298775; msg.payload.laenge = 7.556386;}\nif(msg.payload.stationId==\"SIH\") { msg.payload.stationName = \"Sihlbrugg\"; msg.payload.kanton = \"ZG\"; msg.payload.altitude = 549; msg.payload.breite = 47.220561; msg.payload.laenge = 8.578283;}\nif(msg.payload.stationId==\"SIM\") { msg.payload.stationName = \"Simplon-Dorf\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1465; msg.payload.breite = 46.196825; msg.payload.laenge = 8.056336;}\nif(msg.payload.stationId==\"SIO\") { msg.payload.stationName = \"Sion\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 482; msg.payload.breite = 46.21865; msg.payload.laenge = 7.330203;}\nif(msg.payload.stationId==\"SOG\") { msg.payload.stationName = \"Soglio\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1086; msg.payload.breite = 46.342244; msg.payload.laenge = 9.535208;}\nif(msg.payload.stationId==\"VSSOR\") { msg.payload.stationName = \"Sorniot-Lac Inférieur\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1990; msg.payload.breite = 46.1666; msg.payload.laenge = 7.099803;}\nif(msg.payload.stationId==\"PRE\") { msg.payload.stationName = \"St-Prex\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 425; msg.payload.breite = 46.483683; msg.payload.laenge = 6.443;}\nif(msg.payload.stationId==\"SAN\") { msg.payload.stationName = \"St. Antönien\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1456; msg.payload.breite = 46.972131; msg.payload.laenge = 9.825917;}\nif(msg.payload.stationId==\"STC\") { msg.payload.stationName = \"St. Chrischona\"; msg.payload.kanton = \"BS\"; msg.payload.altitude = 493; msg.payload.breite = 47.571767; msg.payload.laenge = 7.687094;}\nif(msg.payload.stationId==\"STG\") { msg.payload.stationName = \"St. Gallen\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 776; msg.payload.breite = 47.425475; msg.payload.laenge = 9.398528;}\nif(msg.payload.stationId==\"SMM\") { msg.payload.stationName = \"Sta. Maria, Val Müstair\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1386; msg.payload.breite = 46.602256; msg.payload.laenge = 10.426314;}\nif(msg.payload.stationId==\"SBO\") { msg.payload.stationName = \"Stabio\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 351; msg.payload.breite = 45.843444; msg.payload.laenge = 8.932364;}\nif(msg.payload.stationId==\"VSSTA\") { msg.payload.stationName = \"Stafel\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2183; msg.payload.breite = 46.004586; msg.payload.laenge = 7.678936;}\nif(msg.payload.stationId==\"STB\") { msg.payload.stationName = \"Starkenbach\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 897; msg.payload.breite = 47.184867; msg.payload.laenge = 9.250447;}\nif(msg.payload.stationId==\"STK\") { msg.payload.stationName = \"Steckborn\"; msg.payload.kanton = \"TG\"; msg.payload.altitude = 397; msg.payload.breite = 47.668628; msg.payload.laenge = 8.981433;}\nif(msg.payload.stationId==\"AGSTE\") { msg.payload.stationName = \"Stetten\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 355; msg.payload.breite = 47.396503; msg.payload.laenge = 8.299992;}\nif(msg.payload.stationId==\"STP\") { msg.payload.stationName = \"Stöckalp\"; msg.payload.kanton = \"OW\"; msg.payload.altitude = 1070; msg.payload.breite = 46.8; msg.payload.laenge = 8.281203;}\nif(msg.payload.stationId==\"SUS\") { msg.payload.stationName = \"Susch\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1416; msg.payload.breite = 46.754883; msg.payload.laenge = 10.083011;}\nif(msg.payload.stationId==\"SAE\") { msg.payload.stationName = \"Säntis\"; msg.payload.kanton = \"AI\"; msg.payload.altitude = 2501; msg.payload.breite = 47.249447; msg.payload.laenge = 9.343469;}\nif(msg.payload.stationId==\"THU\") { msg.payload.stationName = \"Thun\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 570; msg.payload.breite = 46.749853; msg.payload.laenge = 7.585222;}\nif(msg.payload.stationId==\"THS\") { msg.payload.stationName = \"Thusis\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 672; msg.payload.breite = 46.709411; msg.payload.laenge = 9.441711;}\nif(msg.payload.stationId==\"TIT\") { msg.payload.stationName = \"Titlis\"; msg.payload.kanton = \"OW\"; msg.payload.altitude = 3040; msg.payload.breite = 46.770506; msg.payload.laenge = 8.425814;}\nif(msg.payload.stationId==\"CTO\") { msg.payload.stationName = \"Torricella / Crana\"; msg.payload.kanton = \"TI\"; msg.payload.altitude = 1002; msg.payload.breite = 46.075808; msg.payload.laenge = 8.895367;}\nif(msg.payload.stationId==\"VSTRI\") { msg.payload.stationName = \"Trient\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1329; msg.payload.breite = 46.046314; msg.payload.laenge = 6.994664;}\nif(msg.payload.stationId==\"TRU\") { msg.payload.stationName = \"Trun\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 834; msg.payload.breite = 46.744397; msg.payload.laenge = 9.008842;}\nif(msg.payload.stationId==\"VSTSN\") { msg.payload.stationName = \"Tsanfleuron\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2052; msg.payload.breite = 46.320703; msg.payload.laenge = 7.301794;}\nif(msg.payload.stationId==\"TST\") { msg.payload.stationName = \"Tschiertschen\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1273; msg.payload.breite = 46.819664; msg.payload.laenge = 9.608142;}\nif(msg.payload.stationId==\"VSTUR\") { msg.payload.stationName = \"Turtmann\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 2180; msg.payload.breite = 46.169831; msg.payload.laenge = 7.692408;}\nif(msg.payload.stationId==\"UEB\") { msg.payload.stationName = \"Uetliberg\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 854; msg.payload.breite = 47.351364; msg.payload.laenge = 8.490225;}\nif(msg.payload.stationId==\"ULR\") { msg.payload.stationName = \"Ulrichen\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1346; msg.payload.breite = 46.504881; msg.payload.laenge = 8.308236;}\nif(msg.payload.stationId==\"UNK\") { msg.payload.stationName = \"Unterkulm\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 454; msg.payload.breite = 47.319819; msg.payload.laenge = 8.111081;}\nif(msg.payload.stationId==\"URN\") { msg.payload.stationName = \"Urnäsch\"; msg.payload.kanton = \"AR\"; msg.payload.altitude = 825; msg.payload.breite = 47.312028; msg.payload.laenge = 9.279797;}\nif(msg.payload.stationId==\"VAD\") { msg.payload.stationName = \"Vaduz\"; msg.payload.kanton = \"FL\"; msg.payload.altitude = 457; msg.payload.breite = 47.127472; msg.payload.laenge = 9.517578;}\nif(msg.payload.stationId==\"VAB\") { msg.payload.stationName = \"Valbella\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1568; msg.payload.breite = 46.755039; msg.payload.laenge = 9.554433;}\nif(msg.payload.stationId==\"VLS\") { msg.payload.stationName = \"Vals\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1242; msg.payload.breite = 46.627758; msg.payload.laenge = 9.188711;}\nif(msg.payload.stationId==\"VSVER\") { msg.payload.stationName = \"Vercorin\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1650; msg.payload.breite = 46.237964; msg.payload.laenge = 7.556281;}\nif(msg.payload.stationId==\"VEV\") { msg.payload.stationName = \"Vevey / Corseaux\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 405; msg.payload.breite = 46.471239; msg.payload.laenge = 6.815056;}\nif(msg.payload.stationId==\"VIO\") { msg.payload.stationName = \"Vicosoprano\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1089; msg.payload.breite = 46.353019; msg.payload.laenge = 9.6278;}\nif(msg.payload.stationId==\"VIT\") { msg.payload.stationName = \"Villars-Tiercelin\"; msg.payload.kanton = \"VD\"; msg.payload.altitude = 859; msg.payload.breite = 46.621778; msg.payload.laenge = 6.710069;}\nif(msg.payload.stationId==\"VIS\") { msg.payload.stationName = \"Visp\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 639; msg.payload.breite = 46.3029; msg.payload.laenge = 7.842958;}\nif(msg.payload.stationId==\"VSVIS\") { msg.payload.stationName = \"Visperterminen\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1352; msg.payload.breite = 46.262883; msg.payload.laenge = 7.904203;}\nif(msg.payload.stationId==\"VRI\") { msg.payload.stationName = \"Vrin\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1384; msg.payload.breite = 46.655797; msg.payload.laenge = 9.103472;}\nif(msg.payload.stationId==\"VAE\") { msg.payload.stationName = \"Vättis\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 939; msg.payload.breite = 46.909078; msg.payload.laenge = 9.4436;}\nif(msg.payload.stationId==\"WAG\") { msg.payload.stationName = \"Waldegg\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 545; msg.payload.breite = 47.362269; msg.payload.laenge = 8.454789;}\nif(msg.payload.stationId==\"WAR\") { msg.payload.stationName = \"Wartau\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 468; msg.payload.breite = 47.096661; msg.payload.laenge = 9.505172;}\nif(msg.payload.stationId==\"WEE\") { msg.payload.stationName = \"Weesen\"; msg.payload.kanton = \"SG\"; msg.payload.altitude = 425; msg.payload.breite = 47.131619; msg.payload.laenge = 9.086092;}\nif(msg.payload.stationId==\"WFJ\") { msg.payload.stationName = \"Weissfluhjoch\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 2691; msg.payload.breite = 46.833325; msg.payload.laenge = 9.806394;}\nif(msg.payload.stationId==\"WIN\") { msg.payload.stationName = \"Winterthur / Seen\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 506; msg.payload.breite = 47.474672; msg.payload.laenge = 8.763189;}\nif(msg.payload.stationId==\"WIT\") { msg.payload.stationName = \"Wittnau\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 463; msg.payload.breite = 47.480403; msg.payload.laenge = 7.968536;}\nif(msg.payload.stationId==\"WYN\") { msg.payload.stationName = \"Wynau\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 422; msg.payload.breite = 47.255025; msg.payload.laenge = 7.787475;}\nif(msg.payload.stationId==\"WAE\") { msg.payload.stationName = \"Wädenswil\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 485; msg.payload.breite = 47.220958; msg.payload.laenge = 8.677706;}\nif(msg.payload.stationId==\"PSI\") { msg.payload.stationName = \"Würenlingen / PSI\"; msg.payload.kanton = \"AG\"; msg.payload.altitude = 334; msg.payload.breite = 47.536475; msg.payload.laenge = 8.226944;}\nif(msg.payload.stationId==\"ZER\") { msg.payload.stationName = \"Zermatt\"; msg.payload.kanton = \"VS\"; msg.payload.altitude = 1638; msg.payload.breite = 46.029272; msg.payload.laenge = 7.752433;}\nif(msg.payload.stationId==\"ZEV\") { msg.payload.stationName = \"Zervreila\"; msg.payload.kanton = \"GR\"; msg.payload.altitude = 1738; msg.payload.breite = 46.578797; msg.payload.laenge = 9.118797;}\nif(msg.payload.stationId==\"ZWE\") { msg.payload.stationName = \"Zweisimmen\"; msg.payload.kanton = \"BE\"; msg.payload.altitude = 1015; msg.payload.breite = 46.550592; msg.payload.laenge = 7.384783;}\nif(msg.payload.stationId==\"ZWK\") { msg.payload.stationName = \"Zwillikon\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 461; msg.payload.breite = 47.290092; msg.payload.laenge = 8.431958;}\nif(msg.payload.stationId==\"REH\") { msg.payload.stationName = \"Zürich / Affoltern\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 444; msg.payload.breite = 47.427694; msg.payload.laenge = 8.517953;}\nif(msg.payload.stationId==\"SMA\") { msg.payload.stationName = \"Zürich / Fluntern\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 556; msg.payload.breite = 47.377925; msg.payload.laenge = 8.565742;}\nif(msg.payload.stationId==\"KLO\") { msg.payload.stationName = \"Zürich / Kloten\"; msg.payload.kanton = \"ZH\"; msg.payload.altitude = 426; msg.payload.breite = 47.479611; msg.payload.laenge = 8.535961;}\n\nmsg.topic = \"Meteoschweiz\"\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":2870,"y":970,"wires":[["7dd275f3.9d823c","9ae617b5.75a6c8"]]},{"id":"910d5176.0d7c18","type":"influxdb out","z":"2a5ccfd3.08f3f","influxdb":"8453eb0e.55e01","name":"","measurement":"","precision":"ms","retentionPolicy":"","x":3270,"y":970,"wires":[]},{"id":"7dd275f3.9d823c","type":"function","z":"2a5ccfd3.08f3f","name":"-> influx","func":"msg.payload = //{payload:\n[\nmsg.payload, //erster Teil unverändert\n{\nstationNameTag: msg.payload.stationName,  //tags für influxdb\nstationIdTag: msg.payload.stationId,\nstationKtTag: msg.payload.kanton\n}]\n\nmsg.measurement = \"meteoschweizFavoritenAb2020\" //für influxdb\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":3080,"y":970,"wires":[["910d5176.0d7c18"]]},{"id":"9ae617b5.75a6c8","type":"debug","z":"2a5ccfd3.08f3f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":3090,"y":1010,"wires":[]},{"id":"8453eb0e.55e01","type":"influxdb","hostname":"127.0.0.1","port":"8086","protocol":"http","database":"plants","name":"","usetls":false,"tls":""}]
Created 5 years, 10 months ago
  • change (x14)
  • comment (x2)
  • debug (x2)
  • function (x2)
  • rbe (x2)
  • switch (x16)
  • meteoswiss
  • swiss
  • switzerland
  • meteo
  • node-red-contrib-swissforecast
  • meteoschweiz
  • stationsdaten
  • weather
  • wetter
  • meteosuisse
