GPT4All (filtered) AI Text Inference Function
This is a function node for the GPT4All AI model in its filtered form - inference is done on the CPU and does not require any special hardware.
Having the actual inference as a self-contained function node gives you the possibility to create your own user interface or even use it as part of an autonomous agent.
See the related GitHub repository for any instructions on how to install and use it.
The repo also contains a complete flow for an HTTP endpoint (which uses this function node to answer HTTP requests) and a simple web page which may serve as a user interface for this endpoint.
[{"id":"9becf704aaafb5d7","type":"function","z":"50ed45470ea01d88","name":"GPT4All (filtered)","func":"(async () => {\n  let Prompt = (msg.payload || '').trim()\n  if (Prompt === '') {\n    msg.payload = 'empty or missing prompt'\n    node.send([null,msg])\n    return\n  }\n  \n/**** retrieve GPT4All or load it upon the first request ****/\n  \n  let GPT4All = global.get('GPT4All-filtered')\n  if (GPT4All == null) {\n    GPT4All = new gpt4all.GPT4All('gpt4all-lora-quantized',true)\n  \n    await GPT4All.init()\n    node.log('GPT4All \"filtered\" has been initialized')\n  \n    await GPT4All.open()\n    global.set('GPT4All-filtered',GPT4All)\n    node.log('GPT4All \"filtered\" may be used')\n    \n    node.on('close',(done) => {\n      node.log('GPT4All \"filtered\" is being closed')\n      global.set('GPT4All-filtered',null)\n      GPT4All.close()\n      done()\n    })\n  }\n  \n/**** now infer a response from the given prompt ****/\n\n  let Response = await GPT4All.prompt(Prompt)\n  \n  msg.payload = Response.replace(/^[^m]+?m[^m]+?m[^m]+?m/,'')\n  node.send([msg,null])\n})()\n","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[{"var":"gpt4all","module":"gpt4all"}],"x":330,"y":160,"wires":[["bfbe55aeb9b0792a","cfeb608b1a17b6a6"],["14b3eadd0143dc60"]]}]
Created 3 years, 8 months ago
  • gpt4all
  • ai-text-generator
  • chatterbot
