Webpage Editor
This flow uses suneditor.js (http://suneditor.com/) to generate an HTML editor and publishes the results.
[{"id":"0d042f153bce6088","type":"http in","z":"30db69fe334cb770","name":"","url":"/edit","method":"get","upload":false,"swaggerDoc":"","x":220,"y":140,"wires":[["d33acb53a4dcc288"]]},{"id":"85b16f3540b4475b","type":"http response","z":"30db69fe334cb770","name":"","statusCode":"","headers":{},"x":710,"y":140,"wires":[]},{"id":"d33acb53a4dcc288","type":"template","z":"30db69fe334cb770","name":"suneditor.js","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<link href=\"https://cdn.jsdelivr.net/npm/suneditor@latest/dist/css/suneditor.min.css\" rel=\"stylesheet\">\n<script src=\"https://cdn.jsdelivr.net/npm/suneditor@latest/dist/suneditor.min.js\"></script>\n\n<link rel=\"stylesheet\"\n          href=\"https://fonts.googleapis.com/css?family=Tangerine\">\n    <style>\n      body {\n        font-family: 'Tangerine', serif;\n        font-size: 48px;\n      }\n    </style>\n\n<textarea id=\"sample\" style=\"width:100%;\"></textarea>\n\n<script>SUNEDITOR.create('sample', {\n    buttonList: [\n        ['save', 'template'],\n        ['undo', 'redo'],\n        ['font', 'fontSize', 'formatBlock'],\n        ['paragraphStyle', 'blockquote'],\n        ['bold', 'underline', 'italic', 'strike'],\n        ['fontColor', 'hiliteColor', 'textStyle'],\n        ['removeFormat'],\n        '/', // Line break\n        ['outdent', 'indent'],\n        ['align', 'horizontalRule', 'list', 'lineHeight'],\n        ['table', 'link', 'image', 'video', 'audio' /** ,'math' */], // You must add the 'katex' library at options to use the 'math' plugin.\n        /** ['imageGallery'] */ // You must add the \"imageGalleryUrl\".\n        ['fullScreen', 'showBlocks'],\n        ['preview'],\n        /** ['dir', 'dir_ltr', 'dir_rtl'] */ // \"dir\": Toggle text direction, \"dir_ltr\": Right to Left, \"dir_rtl\": Left to Right\n    ],\n    font: [\n                    'Arial', 'Comic Sans MS', 'Tangerine',  'Impact',\n                    'Georgia','tahoma', 'Trebuchet MS', 'Verdana'\n                  ],\n    templates:  [\n                    {\n                        name: 'Template-1',\n                        html: '<p>HTML source1</p>'\n                    },\n                    {\n                        name: 'Template-2',\n                        html: '<p>HTML source2</p>'\n                    }\n                ],\n    callBackSave: function (contents, isChanged) {\n        fetch('http://localhost:1880/publish', {\n        method: 'POST',\n        headers: {\n            'Accept': 'application/html',\n            'Content-Type': 'application/html'\n        },\n        body: contents\n    })\n    .then(response => response)\n    .then(response => console.log(response))\n        alert(\"Saved!\");\n    }\n})\n</script>","output":"str","x":450,"y":140,"wires":[["85b16f3540b4475b"]]},{"id":"4d6f6a02ccc9f94a","type":"http in","z":"30db69fe334cb770","name":"","url":"/publish","method":"post","upload":false,"swaggerDoc":"","x":230,"y":280,"wires":[["7e0427423f11c13c"]]},{"id":"c46bd6ed6cb66e2b","type":"http response","z":"30db69fe334cb770","name":"","statusCode":"","headers":{},"x":710,"y":280,"wires":[]},{"id":"7e0427423f11c13c","type":"change","z":"30db69fe334cb770","name":"","rules":[{"t":"set","p":"html","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":280,"wires":[["c46bd6ed6cb66e2b"]]},{"id":"c10872cb777d9fb0","type":"http in","z":"30db69fe334cb770","name":"","url":"/live","method":"get","upload":false,"swaggerDoc":"","x":220,"y":420,"wires":[["75e9b50713d125ed"]]},{"id":"cd92cad90043f54e","type":"http response","z":"30db69fe334cb770","name":"","statusCode":"","headers":{},"x":790,"y":420,"wires":[]},{"id":"75e9b50713d125ed","type":"change","z":"30db69fe334cb770","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"html","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":420,"wires":[["9e018adc914e1f98"]]},{"id":"9e018adc914e1f98","type":"template","z":"30db69fe334cb770","name":"","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"<meta charset=\"utf-8\"><meta name=\"viewport\" content=\"width=device-width, initial-scale=1, maximum-scale=1\"><title>Preview</title>\n\n<link href=\"https://cdn.jsdelivr.net/npm/suneditor@latest/dist/css/suneditor.min.css\" rel=\"stylesheet\">\n\n<link rel=\"stylesheet\"\n          href=\"https://fonts.googleapis.com/css?family=Tangerine\">\n<body class=\"sun-editor-editable\" style=\"margin:10px auto !important; height:auto !important;\">{{{payload}}}</body>\n","output":"str","x":620,"y":420,"wires":[["cd92cad90043f54e"]]},{"id":"745df26bd4bebc1f","type":"comment","z":"30db69fe334cb770","name":"Edit HTML on http://<your-NR>/edit","info":"","x":300,"y":80,"wires":[]},{"id":"4a8bdc0ef341b48d","type":"comment","z":"30db69fe334cb770","name":"When user clicks on save button","info":"","x":290,"y":220,"wires":[]},{"id":"8c1dc477e781d3ae","type":"comment","z":"30db69fe334cb770","name":"Page goes live at http://<your-NR>/live","info":"","x":310,"y":360,"wires":[]}]
Created 2 years, 10 months ago
Updated 2 years, 8 months ago
Rating: 5 1
  • change (x2)
  • comment (x3)
  • http in (x3)
  • http response (x3)
  • template (x2)
  • html
  • editor
  • text
  • wysiwyg
  • webpage
  • blog
