Tilt Pi
Uses bluetooth to scan for Tilt hydrometers (http://tilthydrometer.com) and report data in a dashboard and log data to the cloud and locally.
[{"id":"a564595f.642818","type":"tab","label":"Main"},{"id":"81394fa6.f9523","type":"ui_group","z":"","name":"Quick Start","tab":"6529e313.74108c","order":1,"disp":true,"width":"6"},{"id":"b642e71.9697318","type":"ui_group","z":"","name":"1","tab":"4ede131f.f2e09c","order":1,"disp":false,"width":"6"},{"id":"b914fb40.bc5c78","type":"ui_group","z":"","name":"5","tab":"4ede131f.f2e09c","order":5,"disp":false,"width":"6"},{"id":"4a85df35.41e16","type":"ui_group","z":"","name":"6","tab":"4ede131f.f2e09c","order":6,"disp":false,"width":"6"},{"id":"19fab5c2.199ffa","type":"ui_group","z":"","name":"Cloud Settings","tab":"6529e313.74108c","order":2,"disp":true,"width":"6"},{"id":"307e2bd0.e69514","type":"ui_group","z":"","name":"2","tab":"4ede131f.f2e09c","order":2,"disp":false,"width":"6"},{"id":"8de27cf2.dbd6a","type":"ui_group","z":"","name":"3","tab":"4ede131f.f2e09c","order":3,"disp":false,"width":"6"},{"id":"6acae0b0.a184","type":"ui_group","z":"","name":"Set SG Calibration Points (SG only)","tab":"75f710f5.16d2e","order":2,"disp":true,"width":"6"},{"id":"b8d3bbbf.2c9cb8","type":"ui_group","z":"","name":"4","tab":"4ede131f.f2e09c","order":4,"disp":false,"width":"6"},{"id":"ab6da67f.a47fa8","type":"ui_group","z":"","name":"8","tab":"4ede131f.f2e09c","order":8,"disp":false,"width":"6"},{"id":"a510f969.f28538","type":"ui_group","z":"","name":"7","tab":"4ede131f.f2e09c","order":7,"disp":false,"width":"6"},{"id":"82607108.c5be8","type":"ui_group","z":"","name":"Tilt Pi Settings","tab":"6529e313.74108c","order":3,"disp":true,"width":"6"},{"id":"eb4ab3d5.7b3f1","type":"ui_group","z":"","name":"Calibrate","tab":"75f710f5.16d2e","order":1,"disp":true,"width":"6"},{"id":"5ca7d250.c3938c","type":"ui_group","z":"","name":"Time","tab":"c9c26b4a.4cde78","order":1,"disp":true,"width":"6"},{"id":"c8854cd2.f1773","type":"ui_group","z":"","name":"App Admin (Tilt Pi v.2.1)","tab":"c9c26b4a.4cde78","order":4,"disp":true,"width":"6"},{"id":"6529e313.74108c","type":"ui_tab","z":"","name":"Logging","icon":"fa-line-chart","order":2},{"id":"4ede131f.f2e09c","type":"ui_tab","z":"","name":"Tilt Pi","icon":"fa-tachometer","order":1},{"id":"75f710f5.16d2e","type":"ui_tab","z":"","name":"Calibration","icon":"fa-bullseye","order":3},{"id":"c9c26b4a.4cde78","type":"ui_tab","z":"","name":"System","icon":"fa-clock-o","order":4},{"id":"5fec9a11.37a164","type":"ui_base","theme":{"name":"theme-custom","lightTheme":{"default":"#0094CE","baseColor":"#0094CE","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":false,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#097479","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"customTheme":{"name":"","default":"#4B7930","baseColor":"#666666","baseFont":"Tahoma,Geneva,sans-serif","reset":false},"themeState":{"base-color":{"default":"#4B7930","value":"#4B7930","edited":false},"page-titlebar-backgroundColor":{"value":"#666666","edited":false},"page-backgroundColor":{"value":"#111111","edited":false},"page-sidebar-backgroundColor":{"value":"#000000","edited":false},"group-textColor":{"value":"#8c8c8c","edited":false},"group-borderColor":{"value":"#555555","edited":false},"group-backgroundColor":{"value":"#333333","edited":false},"widget-textColor":{"value":"#eeeeee","edited":false},"widget-backgroundColor":{"value":"#666666","edited":false},"widget-borderColor":{"value":"#333333","edited":false},"base-font":{"value":"Tahoma,Geneva,sans-serif"}}},"site":{"name":"Tilt Pi","hideToolbar":"false","allowSwipe":"false","dateFormat":"DD/MM/YYYY","sizes":{"sx":48,"sy":53,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"c12bcb12.dbd0d8","type":"ui_group","z":"","name":"Set Temp. Calibration Points","tab":"75f710f5.16d2e","order":4,"disp":true,"width":"6"},{"id":"b0619070.ac95d","type":"ui_group","z":"","name":"Tilt Pi Display Units","tab":"c9c26b4a.4cde78","order":2,"disp":true,"width":"6"},{"id":"7e458eda.984cd","type":"ui_group","z":"","name":"Raspberry Pi","tab":"c9c26b4a.4cde78","order":5,"disp":false,"width":"6"},{"id":"2f8a7619.951f3a","type":"ui_group","z":"","name":"Filter Tilt by Signal Strength","tab":"c9c26b4a.4cde78","order":3,"disp":true,"width":"6"},{"id":"822d1243.fc995","type":"ui_link","z":"","name":"Tilt Shop","link":"http://tilthydrometer.com","icon":"open_in_browser","target":"newtab","order":5},{"id":"45fc2eae.52e02","type":"scanBeacon","z":"a564595f.642818","name":"Tilt Scan","beacon_uuid":"","beacon_major":"","beacon_minor":"","x":372.00004959106445,"y":124.00001430511475,"wires":[["8dc4fe46.fc364"]]},{"id":"f42fdaab.48a078","type":"inject","z":"a564595f.642818","name":"Start","topic":"","payload":"on","payloadType":"str","repeat":"","crontab":"","once":true,"x":79.00001525878906,"y":200.00000381469727,"wires":[["b42102fe.e4abd","c0f36d.ab686c9"]]},{"id":"8dc4fe46.fc364","type":"json","z":"a564595f.642818","name":"json","pretty":false,"x":498.0000114440918,"y":125.00001239776611,"wires":[["d504d607.384f48"]]},{"id":"2836e0e1.4ea9c","type":"http request","z":"a564595f.642818","name":"Cloud Service","method":"POST","ret":"obj","url":"","tls":"","x":3207.5,"y":117.5,"wires":[["6cbfa171.d2106","f14feb76.aebb48","d5884cdc.50b47"]]},{"id":"7f2f1fbf.e1098","type":"change","z":"a564595f.642818","name":"Colors","rules":[{"t":"set","p":"payload.Color","pt":"msg","to":"payload.uuid","tot":"msg"},{"t":"change","p":"payload.Color","pt":"msg","from":"a495bb60c5b14b44b5121370f02d74de","fromt":"str","to":"BLUE","tot":"str"},{"t":"change","p":"payload.Color","pt":"msg","from":"a495bb70c5b14b44b5121370f02d74de","fromt":"str","to":"YELLOW","tot":"str"},{"t":"change","p":"payload.Color","pt":"msg","from":"a495bb20c5b14b44b5121370f02d74de","fromt":"str","to":"GREEN","tot":"str"},{"t":"change","p":"payload.Color","pt":"msg","from":"a495bb50c5b14b44b5121370f02d74de","fromt":"str","to":"ORANGE","tot":"str"},{"t":"change","p":"payload.Color","pt":"msg","from":"a495bb10c5b14b44b5121370f02d74de","fromt":"str","to":"RED","tot":"str"},{"t":"change","p":"payload.Color","pt":"msg","from":"a495bb80c5b14b44b5121370f02d74de","fromt":"str","to":"PINK","tot":"str"},{"t":"change","p":"payload.Color","pt":"msg","from":"a495bb30c5b14b44b5121370f02d74de","fromt":"str","to":"BLACK","tot":"str"},{"t":"change","p":"payload.Color","pt":"msg","from":"a495bb40c5b14b44b5121370f02d74de","fromt":"str","to":"PURPLE","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":896.2778701782227,"y":130.5000057220459,"wires":[["7c18d8fe.188168"]]},{"id":"e5652ef0.acaaf","type":"switch","z":"a564595f.642818","name":"Tilts","property":"payload.uuid","propertyType":"msg","rules":[{"t":"regex","v":"a495bb..c5b14b44b5121370f02d74de","vt":"str","case":true}],"checkall":"true","outputs":1,"x":746.5001220703125,"y":130.00000858306885,"wires":[["7f2f1fbf.e1098"]]},{"id":"656f0cf9.e79cd4","type":"ui_text_input","z":"a564595f.642818","name":"Beer Name","label":"Set Beer Name [use RETURN to set]","group":"81394fa6.f9523","order":3,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"","x":3675,"y":509,"wires":[["6040e73e.fa2088"]]},{"id":"6040e73e.fa2088","type":"function","z":"a564595f.642818","name":"Set Beer Name","func":"var color = flow.get('colordropdownSelect')||\"\";\nvar beerArray = msg.payload.split(\",\");\nif (beerArray[1] === undefined){\n    beerArray[1] = true;\n    flow.set(color + \"-URL\",\"\");\n}\nflow.set(color + \"-Beer\",beerArray);\n\nif (beerArray[1] === true){\n    msg.payload = beerArray[0];\n    msg.topic = \"Beer name set for \" + color;\n} else {\n    msg.payload = beerArray[0] + \",\" + beerArray[1];\n    msg.topic = \"[Beer name],[cloud ID] set for \" + color;\n}\nreturn msg;","outputs":1,"noerr":0,"x":3897,"y":508,"wires":[["2f84bf9f.847b6"]]},{"id":"7c18d8fe.188168","type":"function","z":"a564595f.642818","name":"Add Parameters","func":"//set beer name and local name status\nvar beerArray = flow.get(msg.payload.Color + \"-Beer\")||[\"Untitled\",true];\nmsg.payload.Beer = beerArray;\n//set dropdown options\nvar options = flow.get('options')||[];\nvar color = msg.payload.Color;\nif (options.indexOf(color) === -1){ //check if Tilt color has been seen\n    options.push(color);\n    options.sort();\n    //node.warn(options);\n    flow.set('options',options);\n}\n//set SG cal points\nvar actualSGArray = flow.get('actualSGpoints-' + msg.payload.Color)||[];\nvar uncalSGArray = flow.get('uncalSGpoints-' + msg.payload.Color)||[];\nmsg.payload.actualSGPoints = actualSGArray.toString();\nmsg.payload.unCalSGPoints = uncalSGArray.toString();\n//set Temp cal points\nvar actualTempArray = flow.get('actualTemppoints-' + msg.payload.Color)||[];\nvar uncalTempArray = flow.get('uncalTemppoints-' + msg.payload.Color)||[];\nmsg.payload.actualTempPoints = actualTempArray.toString();\nmsg.payload.unCalTempPoints = uncalTempArray.toString();\n//add timeStamp parameter\nmsg.payload.timeStamp = Date.now();\nvar date = new Date();\n//add Timepoint parameter\nvar timeZone = date.getTimezoneOffset()/24/60;\nmsg.payload.formatteddate = date.toLocaleString();\nmsg.payload.Timepoint = msg.payload.timeStamp / 1000 / 60 / 60 / 24 + 25569 - timeZone;\n//add SG parameter, account for extra precision if needed\nmsg.payload.fermunits = flow.get('fermdisplayUnits')||'';\nif (msg.payload.minor > 2000){\nmsg.payload.SG = msg.payload.minor / 10000;\nmsg.payload.major /= 10;\nmsg.payload.hd = true;\n}else{\nmsg.payload.SG = msg.payload.minor / 1000;\nmsg.payload.hd = false;\n}\n//add Temp parameter\nmsg.payload.Temp = msg.payload.major;\nmsg.payload.tempunits = flow.get('displayUnits')||\"°F\";\n//Google Sheet URL for displaying link in display\nmsg.payload.doclongurl = flow.get(msg.payload.Color + '-URL')||\"\";\nmsg.topic = msg.payload.Color;\nmsg.filename = \"/home/pi/\" + msg.payload.Color + \".json\";\n//get custom cloud URL if default cloud URL set to undefined\nmsg.payload.customcloudURL = flow.get('cloudURL-' + msg.payload.Color);\n//set global cloud settings\nmsg.payload.defaultcloudURL = flow.get('cloudURL')||['https://script.google.com/macros/s/AKfycbwNXh6rEWoULd0vxWxDylG_PJwQwe0dn5hdtSkuC4k3D9AXBSA/exec',true];\nmsg.payload.logCloudDataCheck = flow.get('logCloudDataCheck')||true;\nmsg.payload.logLocalDataCheck = flow.get('logLocalDataCheck');\nmsg.payload.localloggingInterval = flow.get('localloggingInterval')||15;\nmsg.payload.loggingInterval = flow.get('loggingInterval')||15;\nmsg.payload.minRSSI = flow.get('minRSSI');\nreturn msg;","outputs":1,"noerr":0,"x":1048.666732788086,"y":129.6666898727417,"wires":[["86447ba5.5d5b68","b90d01ad.44d08"]]},{"id":"1aee8aa4.c92885","type":"ui_template","z":"a564595f.642818","group":"b642e71.9697318","name":"1","order":1,"width":"6","height":"6","format":"<style>\n    .nr-dashboard-template h1 {\n    font-size: .875em;\n    font-weight: normal;\n    margin-top: .1;\n    margin-bottom: .1;\n    }\n    \n    .nr-dashboard-template h2 {\n    font-size: 3.5em;\n    text-indent: .5em;\n    margin-top: 0;\n    margin-bottom: 0;\n    }\n    \n    h5 {\n        font-family:\"Courier New\", Courier, monospace;\n        text-align: center;\n        font-size: .6em;\n        margin-top: .2em;\n        margin-bottom: 0;\n    }\n    \n   \n   div {\n    max-width: 100%;\n   }\n   \n   a:link {\n    color: white; \n    background-color: transparent; \n    text-decoration: none;\n}\n\na:visited {\n    color: white;\n    background-color: transparent;\n    text-decoration: none;\n}\n\n#{{msg.topic}}-div {\n    visibility: {{msg.show}};\n   }  \n</style>\n\n<div id = \"{{msg.topic}}-div\">\n<h1>{{msg.payload.Beer[0]}}</h1>\n<h1><strong>TILT | {{msg.payload.Color}}</strong><span ng-bind-html=\"msg.payload.doclongurl\"></span></h1>\n<div style=\"background: {{msg.payload.Color}};height:40px;width:100%;\"></div>\n<h1>Uncal. SG/Concentration: {{msg.payload.uncalferm}}</h1>\n<h2>{{msg.payload.ferm}}{{msg.payload.fermunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.SG - 0.990)/0.00130}}%;\"></div>\n<h1>Uncal. Temperature: {{msg.payload.displayuncalTemp | number:1}}</h1>\n<h2>{{msg.payload.displayTemp | number:1}}{{msg.payload.tempunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.Temp - 30) / 1.85}}%;\"></div>\n<h5>{{msg.payload.formatteddate}}</h5>\n<h5>Received {{(msg.payload.clock - msg.payload.timeStamp) / 1000 | number:1}} seconds ago {{msg.payload.rssi}} dBm</h5>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":2417,"y":90,"wires":[["394a5d3d.92fa72","1ee5d27c.fa4e8e"]]},{"id":"79bac478.35317c","type":"ui_template","z":"a564595f.642818","group":"b914fb40.bc5c78","name":"5","order":1,"width":"6","height":"6","format":"<!DOCTYPE html>\n<style>\n   #{{msg.topic}}-div {\n    visibility: {{msg.show}};\n   }  \n</style>\n<div id = \"{{msg.topic}}-div\">\n<h1>{{msg.payload.Beer[0]}}</h1>\n<h1><strong>TILT | {{msg.payload.Color}}</strong><span ng-bind-html=\"msg.payload.doclongurl\"></span></h1>\n<div style=\"background: {{msg.payload.Color}};height:40px;width:100%;\"></div>\n<h1>Uncal. SG/Concentration: {{msg.payload.uncalferm}}</h1>\n<h2>{{msg.payload.ferm}}{{msg.payload.fermunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.SG - 0.990)/0.00130}}%;\"></div>\n<h1>Uncal. Temperature: {{msg.payload.displayuncalTemp | number:1}}</h1>\n<h2>{{msg.payload.displayTemp | number:1}}{{msg.payload.tempunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.Temp - 30) / 1.85}}%;\"></div>\n<h5>{{msg.payload.formatteddate}}</h5>\n<h5>Received {{(msg.payload.clock - msg.payload.timeStamp) / 1000 | number:1}} seconds ago {{msg.payload.rssi}} dBm</h5>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":2423,"y":257,"wires":[["1ee5d27c.fa4e8e","394a5d3d.92fa72"]]},{"id":"2ddd6c1f.7838e4","type":"inject","z":"a564595f.642818","name":"Stop","topic":"","payload":"off","payloadType":"str","repeat":"","crontab":"","once":false,"x":95.00000762939453,"y":122.00000190734863,"wires":[["45fc2eae.52e02"]]},{"id":"64f10179.474c9","type":"change","z":"a564595f.642818","name":"1","rules":[{"t":"move","p":"payload","pt":"msg","to":"storage-1","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1623.5,"y":62,"wires":[["5006138a.18932c"]]},{"id":"be15eceb.e8738","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"storage-1","payloadType":"flow","repeat":"1","crontab":"","once":false,"x":1816.5,"y":76,"wires":[["9628a72.af07d58"]]},{"id":"e0d6a855.d4e018","type":"ui_template","z":"a564595f.642818","group":"4a85df35.41e16","name":"6","order":1,"width":"6","height":"6","format":"<!DOCTYPE html>\n<style>\n   #{{msg.topic}}-div {\n    visibility: {{msg.show}};\n   }  \n</style>\n<div id = \"{{msg.topic}}-div\">\n<h1>{{msg.payload.Beer[0]}}</h1>\n<h1><strong>TILT | {{msg.payload.Color}}</strong><span ng-bind-html=\"msg.payload.doclongurl\"></span></h1>\n<div style=\"background: {{msg.payload.Color}};height:40px;width:100%;\"></div>\n<h1>Uncal. SG/Concentration: {{msg.payload.uncalferm}}</h1>\n<h2>{{msg.payload.ferm}}{{msg.payload.fermunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.SG - 0.990)/0.00130}}%;\"></div>\n<h1>Uncal. Temperature: {{msg.payload.displayuncalTemp | number:1}}</h1>\n<h2>{{msg.payload.displayTemp | number:1}}{{msg.payload.tempunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.Temp - 30) / 1.85}}%;\"></div>\n<h5>{{msg.payload.formatteddate}}</h5>\n<h5>Received {{(msg.payload.clock - msg.payload.timeStamp) / 1000 | number:1}} seconds ago {{msg.payload.rssi}} dBm</h5>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":2423,"y":315,"wires":[["1ee5d27c.fa4e8e","394a5d3d.92fa72"]]},{"id":"c4b0f249.af093","type":"switch","z":"a564595f.642818","name":"Display","property":"payload.Color","propertyType":"msg","rules":[{"t":"cont","v":"options[0]","vt":"flow"},{"t":"cont","v":"options[1]","vt":"flow"},{"t":"cont","v":"options[2]","vt":"flow"},{"t":"cont","v":"options[3]","vt":"flow"},{"t":"cont","v":"options[4]","vt":"flow"},{"t":"cont","v":"options[5]","vt":"flow"},{"t":"cont","v":"options[6]","vt":"flow"},{"t":"cont","v":"options[7]","vt":"flow"}],"checkall":"false","outputs":8,"x":1426.4443740844727,"y":235.88890075683594,"wires":[["64f10179.474c9"],["45da85de.0a884c"],["4c140999.2a7428"],["561c3f7f.1b8ab"],["2e45b69e.abf3fa"],["8803bae2.740958"],["5ea7f34.5181f0c"],["eba532a9.2afe3"]]},{"id":"2e45b69e.abf3fa","type":"change","z":"a564595f.642818","name":"5","rules":[{"t":"move","p":"payload","pt":"msg","to":"storage-5","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1645,"y":256,"wires":[[]]},{"id":"5ea7f34.5181f0c","type":"change","z":"a564595f.642818","name":"7","rules":[{"t":"move","p":"payload","pt":"msg","to":"storage-7","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1644,"y":356,"wires":[[]]},{"id":"8803bae2.740958","type":"change","z":"a564595f.642818","name":"6","rules":[{"t":"move","p":"payload","pt":"msg","to":"storage-6","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1645,"y":306,"wires":[[]]},{"id":"2c53503.d97f0b","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"storage-5","payloadType":"flow","repeat":"1","crontab":"","once":false,"x":1827,"y":257,"wires":[["97228e52.47232"]]},{"id":"d66a9ebe.70d94","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"storage-6","payloadType":"flow","repeat":"1","crontab":"","once":false,"x":1820,"y":303,"wires":[["87e70118.323b3"]]},{"id":"9628a72.af07d58","type":"change","z":"a564595f.642818","name":"clock","rules":[{"t":"set","p":"payload.clock","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":2021.0000190734863,"y":64,"wires":[["14d297fb.15dbc8"]]},{"id":"86447ba5.5d5b68","type":"function","z":"a564595f.642818","name":"Interpolate","func":"//this function block requires msg.payload.SG, msg.payload.Temp, msg.payload.actualSGPoints, msg.payload.actualTempPoints(a comma separated string of the actual values), msg.payload.unCalSGPoints, and msg.payload.unCalTempPoints (a comma separated string of the measured raw values)\nfunction linearInterpolation (x, x0, y0, x1, y1) {\n  var a = (y1 - y0) / (x1 - x0);\n  var b = -a * x0 + y0;\n  return a * x + b;\n}\n//calculate calibrated SG by linear interpolation of calibration points\nvar actualSGPoints = [];\nvar unCalSGPoints = [];\nvar unCalSGPointsTemp = [];\nvar SG = msg.payload.SG;\nactualSGPoints = msg.payload.actualSGPoints.split(\",\");\nunCalSGPoints = msg.payload.unCalSGPoints.split(\",\");\nunCalSGPointsTemp = msg.payload.unCalSGPoints.split(\",\");\n//ensure uncal value always between two numbers\nunCalSGPointsTemp.push(0, SG, Number.MAX_VALUE);\nunCalSGPoints.push(0, Number.MAX_VALUE);\nactualSGPoints.push(0, Number.MAX_VALUE);\nunCalSGPointsTemp.sort(function(a, b){return a-b;});\nunCalSGPoints.sort(function(a, b){return a-b;});\nactualSGPoints.sort(function(a, b){return a-b;});\nvar indexSG = unCalSGPointsTemp.indexOf(SG);\nvar calSG = linearInterpolation (Number(SG), Number(unCalSGPoints[indexSG-1]), Number(actualSGPoints[indexSG-1]), Number(unCalSGPoints[indexSG]), Number(actualSGPoints[indexSG]));\nmsg.payload.uncalSG = SG;\nmsg.payload.uncalPlato = 1111.14 * msg.payload.uncalSG - 630.272 * msg.payload.uncalSG * msg.payload.uncalSG + 135.997 * msg.payload.uncalSG * msg.payload.uncalSG * msg.payload.uncalSG - 616.868;\nmsg.payload.uncalBrix = (((182.4601 * msg.payload.uncalSG - 775.6821) * msg.payload.uncalSG + 1262.7794) * msg.payload.uncalSG - 669.5622);\nmsg.payload.SG = calSG;\nmsg.payload.Plato = 1111.14 * msg.payload.SG - 630.272 * msg.payload.SG * msg.payload.SG + 135.997 * msg.payload.SG * msg.payload.SG * msg.payload.SG - 616.868;\nmsg.payload.Brix = (((182.4601 * msg.payload.SG - 775.6821) * msg.payload.SG + 1262.7794) * msg.payload.SG - 669.5622);\nswitch (msg.payload.fermunits){\n    case \"\" :   if (msg.payload.hd){msg.payload.ferm = msg.payload.SG.toFixed(4);\n                                    msg.payload.uncalferm = msg.payload.uncalSG.toFixed(4);\n    }\n                if (!msg.payload.hd){msg.payload.ferm = msg.payload.SG.toFixed(3);\n                                     msg.payload.uncalferm = msg.payload.uncalSG.toFixed(3);\n                }\n    break;\n    case \"°P\" : if (msg.payload.hd){msg.payload.ferm = msg.payload.Plato.toFixed(2);\n                                   msg.payload.uncalferm = msg.payload.uncalPlato.toFixed(2);    \n                }\n                if (!msg.payload.hd){msg.payload.ferm = msg.payload.Plato.toFixed(1);\n                                   msg.payload.uncalferm = msg.payload.uncalPlato.toFixed(1); \n                }\n    break;\n    case \"°Bx\": if (msg.payload.hd){msg.payload.ferm = msg.payload.Brix.toFixed(2);\n                                   msg.payload.uncalferm = msg.payload.uncalBrix.toFixed(2);\n                }\n                if (!msg.payload.hd){msg.payload.ferm = msg.payload.Brix.toFixed(1);\n                    msg.payload.uncalferm = msg.payload.uncalBrix.toFixed(1);\n                }\n}\n\n//calculate calibrated Temp by linear interpolation of calibration points\nvar actualTempPoints = [];\nvar unCalTempPoints = [];\nvar unCalTempPointsTemp = [];\nvar Temp = msg.payload.Temp;\nif (msg.payload.tempunits === \"°C\"){\n    Temp -= 32;\n    Temp *= 0.5555;\n}\nactualTempPoints = msg.payload.actualTempPoints.split(\",\");\nunCalTempPoints = msg.payload.unCalTempPoints.split(\",\");\nunCalTempPointsTemp = msg.payload.unCalTempPoints.split(\",\");\n//ensure uncal value always between two numbers\nunCalTempPointsTemp.push(-999, Temp, Number.MAX_VALUE);\nunCalTempPoints.push(-999, Number.MAX_VALUE);\nactualTempPoints.push(-999, Number.MAX_VALUE);\nunCalTempPointsTemp.sort(function(a, b){return a-b;});\nunCalTempPoints.sort(function(a, b){return a-b;});\nactualTempPoints.sort(function(a, b){return a-b;});\n//node.warn(actualTempPoints);\nvar indexTemp = unCalTempPointsTemp.indexOf(Temp);\nvar calTemp = linearInterpolation (Number(Temp), Number(unCalTempPoints[indexTemp-1]), Number(actualTempPoints[indexTemp-1]), Number(unCalTempPoints[indexTemp]), Number(actualTempPoints[indexTemp]));\nif (Number.isNaN(calTemp)){\n    calTemp = 0;\n}\nmsg.payload.uncalTemp = Temp.toFixed(1);\nmsg.payload.displayuncalTemp = Temp.toFixed(1);\nmsg.payload.displayTemp = calTemp.toFixed(1);\nif (msg.payload.tempunits === \"°C\"){\n    calTemp *= 1.8;\n    calTemp += 32;\n    msg.payload.Temp = calTemp.toFixed(1);\n}else{\nmsg.payload.Temp = calTemp.toFixed(1);\n}\nreturn msg;","outputs":"1","noerr":0,"x":1233.2778091430664,"y":130.44444465637207,"wires":[["c4b0f249.af093"]]},{"id":"93d9202c.d9c1e","type":"ui_dropdown","z":"a564595f.642818","name":"Logging Dropdown","label":"TILT | ","place":"Select Tilt Color","group":"81394fa6.f9523","order":1,"width":0,"height":0,"passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":911.5000762939453,"y":489.0000104904175,"wires":[["6aa75852.1e3068","d5439ed.a8afa6"]]},{"id":"971574e0.783ba8","type":"function","z":"a564595f.642818","name":"Get Beer Name","func":"var color = flow.get('colordropdownSelect')||undefined;\nif (color !== undefined){\nvar beerArray = flow.get(color + \"-Beer\")||[\"\",true];\nif (beerArray[1] === true){\n    msg.payload = beerArray[0];\n}\nelse {\n    msg.payload = beerArray;\n}\nreturn msg;\n}","outputs":1,"noerr":0,"x":1580,"y":500,"wires":[["656f0cf9.e79cd4"]]},{"id":"e899ac8f.ec903","type":"function","z":"a564595f.642818","name":"Send Comment","func":"var color = flow.get('colordropdownSelect')||\"\";\nvar comment = msg.payload;\nflow.set(color + \"-Comment\",comment);\nflow.set('lastpost-' + color,0);\nflow.set('lastlocalpost-' + color,0);\nmsg.payload = \"Sending: \" + comment;\nmsg.topic = \"TILT | \" + color;\nreturn msg;","outputs":1,"noerr":0,"x":1668.5,"y":609,"wires":[["8dec8962.63e398"]]},{"id":"39028c20.4a5fb4","type":"comment","z":"a564595f.642818","name":"Store latest and update every x seconds","info":"Saves iBeacon scans to flow database and reads back at 1 second intervals. Allows read out to continue to display last reading even if out of range.","x":1724.5,"y":21,"wires":[]},{"id":"1ee5d27c.fa4e8e","type":"function","z":"a564595f.642818","name":"Setup Cloud Post","func":"var postEnabled = (flow.get('logCloudDataCheck'))||false;\nvar interval = flow.get('loggingInterval')||15;\ninterval *= 60000;\nif (postEnabled && msg.payload.Color !== undefined){\n    var lastPost = flow.get('lastpost-' + msg.payload.Color)||0;\n    //node.warn(msg.payload.timeStamp - lastPost);\n    //node.warn(msg.payload.Color);\n    if (msg.payload.timeStamp - lastPost > interval){\n        msg.payload.Comment = flow.get(msg.payload.Color + \"-Comment\")||\"\";\n        msg.payload.Beer = flow.get(msg.payload.Color + \"-Beer\")||[\"Untitled\",true];\n        msg.topic = msg.payload.Color;\n        if (msg.payload.Beer[1] === true){\n            msg.payload.Beer = msg.payload.Beer[0];\n        }\n        flow.set('lastpost-' + msg.payload.Color,msg.payload.timeStamp);\n        msg.headers = {};\n        msg.headers['content-type'] = 'application/x-www-form-urlencoded; charset=utf-8';\n        if (flow.get('cloudURL')[1] === true){\n            msg.url = flow.get('cloudURL')[0];\n        }\n        else{\n            msg.url = flow.get('cloudURL-' + msg.payload.Color);\n        }\n        //node.warn(msg.payload.Color + \" \" + msg.url);\n        msg.payload = \"Timepoint=\" + msg.payload.Timepoint + \"&Temp=\" + msg.payload.Temp + \"&SG=\" + msg.payload.SG + \"&Beer=\" + msg.payload.Beer + \"&Color=\" + msg.payload.Color + \"&Comment=\" + msg.payload.Comment;\n        msg.cloudwait = \"Contacting Cloud...<br>(allow up to 30 seconds)\";\n    return msg;\n}\n}","outputs":1,"noerr":0,"x":2757.5,"y":226,"wires":[["bac24b5.6a220b8"]]},{"id":"edb75c90.8414","type":"ui_text_input","z":"a564595f.642818","name":"Cloud URL","label":"Cloud URL [use RETURN to save]","group":"19fab5c2.199ffa","order":1,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"","x":1179.5003280639648,"y":699.000057220459,"wires":[["c79f0193.2a7c7"]]},{"id":"dc8e0ec5.550d","type":"ui_switch","z":"a564595f.642818","name":"","label":"Start Logging to the Cloud","group":"19fab5c2.199ffa","order":3,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":1313.5,"y":773,"wires":[["bed68eaf.abdc3"]]},{"id":"c79f0193.2a7c7","type":"function","z":"a564595f.642818","name":"Set CloudURL","func":"var color = flow.get('colordropdownSelect');\nflow.set(\"cloudURL-\" + color,msg.payload);\nmsg.topic = \"Custom cloud URL set for \" + color;\nreturn msg;","outputs":1,"noerr":0,"x":1367.0002326965332,"y":694.0000705718994,"wires":[["ecffbfac.2fc53"]]},{"id":"bed68eaf.abdc3","type":"function","z":"a564595f.642818","name":"Set Logging to Cloud","func":"var color = flow.get('colordropdownSelect')||\"\";\nflow.set('logCloudDataCheck',msg.payload);\nflow.set('lastpost-' + color,0);\nmsg.topic = \"TILT | \" + color;\nif (msg.payload){\nmsg.payload = \"Logging request sent. Waiting for response.\";\n}\nelse {\n    msg.payload = \"Logging disabled.\";\n}\nreturn msg;","outputs":1,"noerr":0,"x":1596.5,"y":762,"wires":[["8dec8962.63e398"]]},{"id":"777f1a14.1b3e44","type":"function","z":"a564595f.642818","name":"set Uncal SG Value","func":"flow.set('uncalSGpoint',Number(msg.payload).toFixed(3));","outputs":1,"noerr":0,"x":1829.5,"y":839,"wires":[[]]},{"id":"6aa75852.1e3068","type":"function","z":"a564595f.642818","name":"Save selected color","func":"flow.set('colordropdownSelect',msg.payload);\nmsg.payload = \"\";\nreturn msg;","outputs":1,"noerr":0,"x":1255.1428833007812,"y":468.0000057220459,"wires":[["971574e0.783ba8","df1c3ed0.bd3a9","de92b02f.5ebe1","5933654f.572e0c"]]},{"id":"3eb6f3c4.588d1c","type":"function","z":"a564595f.642818","name":"Get Current SG","func":"var options = flow.get('options')||[];\nvar color = msg.payload;\nvar displayNumber = options.indexOf(color) + 1;\nmsg.payload = flow.get(\"storage-\" + displayNumber.toString());\nif (msg.payload !== undefined){\nmsg.payload = msg.payload.uncalSG;\nreturn msg;\n}","outputs":1,"noerr":0,"x":1340,"y":860,"wires":[["777f1a14.1b3e44","ecfbe772.ba4cb8"]]},{"id":"84ffe685.150d58","type":"function","z":"a564595f.642818","name":"set Actual SG Value","func":"var value = Number(msg.payload);\nflow.set('actualSGpoint',value.toFixed(3));\nmsg.payload = flow.get('colordropdownSelect');\nreturn msg;","outputs":1,"noerr":0,"x":1400,"y":1120,"wires":[["6c6270ad.ae742"]]},{"id":"45da85de.0a884c","type":"change","z":"a564595f.642818","name":"2","rules":[{"t":"move","p":"payload","pt":"msg","to":"storage-2","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1631,"y":109,"wires":[[]]},{"id":"4dbe6177.1028","type":"ui_template","z":"a564595f.642818","group":"307e2bd0.e69514","name":"2","order":1,"width":"6","height":"6","format":"<!DOCTYPE html>\n<style>\n   #{{msg.topic}}-div {\n    visibility: {{msg.show}};\n   }  \n</style>\n<div id = \"{{msg.topic}}-div\">\n<h1>{{msg.payload.Beer[0]}}</h1>\n<h1><strong>TILT | {{msg.payload.Color}}</strong><span ng-bind-html=\"msg.payload.doclongurl\"></span></h1>\n<div style=\"background: {{msg.payload.Color}};height:40px;width:100%;\"></div>\n<h1>Uncal. SG/Concentration: {{msg.payload.uncalferm}}</h1>\n<h2>{{msg.payload.ferm}}{{msg.payload.fermunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.SG - 0.990)/0.00130}}%;\"></div>\n<h1>Uncal. Temperature: {{msg.payload.displayuncalTemp | number:1}}</h1>\n<h2>{{msg.payload.displayTemp | number:1}}{{msg.payload.tempunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.Temp - 30) / 1.85}}%;\"></div>\n<h5>{{msg.payload.formatteddate}}</h5>\n<h5>Received {{(msg.payload.clock - msg.payload.timeStamp) / 1000 | number:1}} seconds ago {{msg.payload.rssi}} dBm</h5>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":2418,"y":134,"wires":[["1ee5d27c.fa4e8e","394a5d3d.92fa72"]]},{"id":"4c140999.2a7428","type":"change","z":"a564595f.642818","name":"3","rules":[{"t":"move","p":"payload","pt":"msg","to":"storage-3","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1630,"y":155,"wires":[[]]},{"id":"7c6f1c01.297234","type":"ui_template","z":"a564595f.642818","group":"8de27cf2.dbd6a","name":"3","order":1,"width":"6","height":"6","format":"<!DOCTYPE html>\n<style>\n   #{{msg.topic}}-div {\n    visibility: {{msg.show}};\n   }  \n</style>\n<div id = \"{{msg.topic}}-div\">\n<h1>{{msg.payload.Beer[0]}}</h1>\n<h1><strong>TILT | {{msg.payload.Color}}</strong><span ng-bind-html=\"msg.payload.doclongurl\"></span></h1>\n<div style=\"background: {{msg.payload.Color}};height:40px;width:100%;\"></div>\n<h1>Uncal. SG/Concentration: {{msg.payload.uncalferm}}</h1>\n<h2>{{msg.payload.ferm}}{{msg.payload.fermunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.SG - 0.990)/0.00130}}%;\"></div>\n<h1>Uncal. Temperature: {{msg.payload.displayuncalTemp | number:1}}</h1>\n<h2>{{msg.payload.displayTemp | number:1}}{{msg.payload.tempunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.Temp - 30) / 1.85}}%;\"></div>\n<h5>{{msg.payload.formatteddate}}</h5>\n<h5>Received {{(msg.payload.clock - msg.payload.timeStamp) / 1000 | number:1}} seconds ago {{msg.payload.rssi}} dBm</h5>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":2417,"y":172,"wires":[["1ee5d27c.fa4e8e","394a5d3d.92fa72"]]},{"id":"638214b2.6402bc","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"storage-3","payloadType":"flow","repeat":"1","crontab":"","once":false,"x":1821.5,"y":153,"wires":[["455abe60.6afd4"]]},{"id":"e767b4ca.6228c8","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"storage-2","payloadType":"flow","repeat":"1","crontab":"","once":false,"x":1827,"y":114,"wires":[["b4de88bb.e0e148"]]},{"id":"14d297fb.15dbc8","type":"function","z":"a564595f.642818","name":"check","func":"if(msg.payload === undefined){\n msg.payload = {};\n msg.show = \"hidden\";\n return msg;   \n}\n//set msg.topic for use in displaying the correct color\nmsg.topic = msg.payload.Color;\n//reorder list if a Tilt disconnects\nif (msg.payload.clock - msg.payload.timeStamp > 2*60*1000){\n flow.set('storage-1',undefined);\n flow.set('storage-2',undefined);\n flow.set('storage-3',undefined);\n flow.set('storage-4',undefined);\n flow.set('storage-5',undefined);\n flow.set('storage-6',undefined);\n flow.set('storage-7',undefined);\n flow.set('storage-8',undefined);\n flow.set('options',[]);\n if (msg.topic === flow.get('colordropdownSelect')){\n     flow.set('colordropdownSelect',undefined);\n }\n msg.show = \"hidden\";\n return msg;\n}\nelse{\n msg.show = \"visible\";\n return msg;\n}","outputs":1,"noerr":0,"x":2181.0000534057617,"y":70.00000476837158,"wires":[["1aee8aa4.c92885"]]},{"id":"6c6270ad.ae742","type":"function","z":"a564595f.642818","name":"Add SG Cal Point","func":"var color = msg.payload;\nvar uncalSGcalPoint = flow.get('uncalSGpoint')||0;\nvar actualSGcalPoint = flow.get('actualSGpoint')||0;\nvar uncalpointsArray = flow.get('uncalSGpoints-' + color)||[];\nvar actualpointsArray = flow.get('actualSGpoints-' + color)||[];\nuncalpointsArray.push(uncalSGcalPoint);\nuncalpointsArray.sort(function(a, b){return a-b;});\nflow.set('uncalSGpoints-' + color,uncalpointsArray);\nactualpointsArray.push(actualSGcalPoint);\nactualpointsArray.sort(function(a, b){return a-b;});\nflow.set('actualSGpoints-' + color,actualpointsArray);\nvar msg1 = {payload:uncalpointsArray.toString()};\nvar msg2 = {payload:actualpointsArray.toString()};\nreturn [msg1, msg2];","outputs":"2","noerr":0,"x":1704.5,"y":1126,"wires":[["1be76b3b.e111e5"],["e29d71bb.f0e81"]]},{"id":"63c7bb7c.317274","type":"ui_button","z":"a564595f.642818","name":"","group":"6acae0b0.a184","order":5,"width":0,"height":0,"passthru":false,"label":"Clear Calibration","color":"","bgcolor":"","icon":"","payload":"colordropdownSelect","payloadType":"flow","topic":"","x":1472.5,"y":1246,"wires":[["e38fab7c.6f34e8"]]},{"id":"e38fab7c.6f34e8","type":"function","z":"a564595f.642818","name":"clear calibration","func":"var color = msg.payload;\nvar uncalpointsArray = flow.set('uncalSGpoints-' + color,[]);\nvar actualpointsArray = flow.set('actualSGpoints-' + color,[]);\nmsg.payload = [];\nreturn msg;","outputs":1,"noerr":0,"x":1684.5,"y":1247,"wires":[["1be76b3b.e111e5","e29d71bb.f0e81"]]},{"id":"df1c3ed0.bd3a9","type":"function","z":"a564595f.642818","name":"update display","func":"var color = flow.get('colordropdownSelect')||\"\";\nvar uncalpointsArray = flow.get('uncalSGpoints-' + color)||[];\nvar actualpointsArray = flow.get('actualSGpoints-' + color)||[];\nvar msg1 = {payload:uncalpointsArray.toString()};\nvar msg2 = {payload:actualpointsArray.toString()};\nreturn [msg1, msg2];","outputs":"2","noerr":0,"x":1483.5,"y":1183,"wires":[["1be76b3b.e111e5"],["e29d71bb.f0e81"]]},{"id":"bac24b5.6a220b8","type":"delay","z":"a564595f.642818","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"5","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":2995,"y":183,"wires":[["2836e0e1.4ea9c","6cbfa171.d2106"]]},{"id":"b4de88bb.e0e148","type":"change","z":"a564595f.642818","name":"clock","rules":[{"t":"set","p":"payload.clock","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":2019.00004196167,"y":106.0000057220459,"wires":[["c9e125df.66b318"]]},{"id":"c9e125df.66b318","type":"function","z":"a564595f.642818","name":"check","func":"if(msg.payload === undefined){\n msg.payload = {};\n msg.show = \"hidden\";\n return msg;   \n}\n//set msg.topic for use in displaying the correct color\nmsg.topic = msg.payload.Color;\n//reorder list if a Tilt disconnects\nif (msg.payload.clock - msg.payload.timeStamp > 2*60*1000){\n flow.set('storage-1',undefined);\n flow.set('storage-2',undefined);\n flow.set('storage-3',undefined);\n flow.set('storage-4',undefined);\n flow.set('storage-5',undefined);\n flow.set('storage-6',undefined);\n flow.set('storage-7',undefined);\n flow.set('storage-8',undefined);\n flow.set('options',[]);\n if (msg.topic === flow.get('colordropdownSelect')){\n     flow.set('colordropdownSelect',undefined);\n }\n msg.show = \"hidden\";\n return msg;\n}\nelse{\n msg.show = \"visible\";\n return msg;\n}","outputs":1,"noerr":0,"x":2183.0001068115234,"y":113.00000047683716,"wires":[["4dbe6177.1028"]]},{"id":"455abe60.6afd4","type":"change","z":"a564595f.642818","name":"clock","rules":[{"t":"set","p":"payload.clock","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":2017.000015258789,"y":153.00000476837158,"wires":[["3fc07c6.f563084"]]},{"id":"3fc07c6.f563084","type":"function","z":"a564595f.642818","name":"check","func":"if(msg.payload === undefined){\n msg.payload = {};\n msg.show = \"hidden\";\n return msg;   \n}\n//set msg.topic for use in displaying the correct color\nmsg.topic = msg.payload.Color;\n//reorder list if a Tilt disconnects\nif (msg.payload.clock - msg.payload.timeStamp > 2*60*1000){\n flow.set('storage-1',undefined);\n flow.set('storage-2',undefined);\n flow.set('storage-3',undefined);\n flow.set('storage-4',undefined);\n flow.set('storage-5',undefined);\n flow.set('storage-6',undefined);\n flow.set('storage-7',undefined);\n flow.set('storage-8',undefined);\n flow.set('options',[]);\n if (msg.topic === flow.get('colordropdownSelect')){\n     flow.set('colordropdownSelect',undefined);\n }\n msg.show = \"hidden\";\n return msg;\n}\nelse{\n msg.show = \"visible\";\n return msg;\n}","outputs":1,"noerr":0,"x":2187.0000534057617,"y":158.00001621246338,"wires":[["7c6f1c01.297234"]]},{"id":"97228e52.47232","type":"change","z":"a564595f.642818","name":"clock","rules":[{"t":"set","p":"payload.clock","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":2021.999984741211,"y":251.00000190734863,"wires":[["a6fc7026.3943f"]]},{"id":"a6fc7026.3943f","type":"function","z":"a564595f.642818","name":"check","func":"if(msg.payload === undefined){\n msg.payload = {};\n msg.show = \"hidden\";\n return msg;   \n}\n//set msg.topic for use in displaying the correct color\nmsg.topic = msg.payload.Color;\n//reorder list if a Tilt disconnects\nif (msg.payload.clock - msg.payload.timeStamp > 2*60*1000){\n flow.set('storage-1',undefined);\n flow.set('storage-2',undefined);\n flow.set('storage-3',undefined);\n flow.set('storage-4',undefined);\n flow.set('storage-5',undefined);\n flow.set('storage-6',undefined);\n flow.set('storage-7',undefined);\n flow.set('storage-8',undefined);\n flow.set('options',[]);\n if (msg.topic === flow.get('colordropdownSelect')){\n     flow.set('colordropdownSelect',undefined);\n }\n msg.show = \"hidden\";\n return msg;\n}\nelse{\n msg.show = \"visible\";\n return msg;\n}","outputs":1,"noerr":0,"x":2198.000102996826,"y":255.00001525878906,"wires":[["79bac478.35317c"]]},{"id":"87e70118.323b3","type":"change","z":"a564595f.642818","name":"clock","rules":[{"t":"set","p":"payload.clock","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":2021.0000686645508,"y":300.00002574920654,"wires":[["822668cd.451b98"]]},{"id":"822668cd.451b98","type":"function","z":"a564595f.642818","name":"check","func":"if(msg.payload === undefined){\n msg.payload = {};\n msg.show = \"hidden\";\n return msg;   \n}\n//set msg.topic for use in displaying the correct color\nmsg.topic = msg.payload.Color;\n//reorder list if a Tilt disconnects\nif (msg.payload.clock - msg.payload.timeStamp > 2*60*1000){\n flow.set('storage-1',undefined);\n flow.set('storage-2',undefined);\n flow.set('storage-3',undefined);\n flow.set('storage-4',undefined);\n flow.set('storage-5',undefined);\n flow.set('storage-6',undefined);\n flow.set('storage-7',undefined);\n flow.set('storage-8',undefined);\n flow.set('options',[]);\n if (msg.topic === flow.get('colordropdownSelect')){\n     flow.set('colordropdownSelect',undefined);\n }\n msg.show = \"hidden\";\n return msg;\n}\nelse{\n msg.show = \"visible\";\n return msg;\n}","outputs":1,"noerr":0,"x":2193.9999961853027,"y":313.00002670288086,"wires":[["e0d6a855.d4e018"]]},{"id":"dd81e411.1cdd78","type":"ui_template","z":"a564595f.642818","group":"b8d3bbbf.2c9cb8","name":"4","order":1,"width":"6","height":"6","format":"<!DOCTYPE html>\n<style>\n   #{{msg.topic}}-div {\n    visibility: {{msg.show}};\n   }  \n</style>\n<div id = \"{{msg.topic}}-div\">\n<h1>{{msg.payload.Beer[0]}}</h1>\n<h1><strong>TILT | {{msg.payload.Color}}</strong><span ng-bind-html=\"msg.payload.doclongurl\"></span></h1>\n<div style=\"background: {{msg.payload.Color}};height:40px;width:100%;\"></div>\n<h1>Uncal. SG/Concentration: {{msg.payload.uncalferm}}</h1>\n<h2>{{msg.payload.ferm}}{{msg.payload.fermunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.SG - 0.990)/0.00130}}%;\"></div>\n<h1>Uncal. Temperature: {{msg.payload.displayuncalTemp | number:1}}</h1>\n<h2>{{msg.payload.displayTemp | number:1}}{{msg.payload.tempunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.Temp - 30) / 1.85}}%;\"></div>\n<h5>{{msg.payload.formatteddate}}</h5>\n<h5>Received {{(msg.payload.clock - msg.payload.timeStamp) / 1000 | number:1}} seconds ago {{msg.payload.rssi}} dBm</h5>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":2424,"y":216,"wires":[["1ee5d27c.fa4e8e","394a5d3d.92fa72"]]},{"id":"29f2062c.9eafea","type":"change","z":"a564595f.642818","name":"clock","rules":[{"t":"set","p":"payload.clock","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":2028.00004196167,"y":203.0000057220459,"wires":[["10fa6d83.b3b1b2"]]},{"id":"10fa6d83.b3b1b2","type":"function","z":"a564595f.642818","name":"check","func":"if(msg.payload === undefined){\n msg.payload = {};\n msg.show = \"hidden\";\n return msg;   \n}\n//set msg.topic for use in displaying the correct color\nmsg.topic = msg.payload.Color;\n//reorder list if a Tilt disconnects\nif (msg.payload.clock - msg.payload.timeStamp > 2*60*1000){\n flow.set('storage-1',undefined);\n flow.set('storage-2',undefined);\n flow.set('storage-3',undefined);\n flow.set('storage-4',undefined);\n flow.set('storage-5',undefined);\n flow.set('storage-6',undefined);\n flow.set('storage-7',undefined);\n flow.set('storage-8',undefined);\n flow.set('options',[]);\n if (msg.topic === flow.get('colordropdownSelect')){\n     flow.set('colordropdownSelect',undefined);\n }\n msg.show = \"hidden\";\n return msg;\n}\nelse{\n msg.show = \"visible\";\n return msg;\n}","outputs":1,"noerr":0,"x":2189.0000495910645,"y":205.00000953674316,"wires":[["dd81e411.1cdd78"]]},{"id":"e2227000.fd309","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"storage-4","payloadType":"flow","repeat":"1","crontab":"","once":false,"x":1813.5,"y":207,"wires":[["29f2062c.9eafea"]]},{"id":"228b94fc.188afc","type":"ui_template","z":"a564595f.642818","group":"ab6da67f.a47fa8","name":"8","order":1,"width":"6","height":"6","format":"<!DOCTYPE html>\n<style>\n   #{{msg.topic}}-div {\n    visibility: {{msg.show}};\n   }  \n</style>\n<div id = \"{{msg.topic}}-div\">\n<h1>{{msg.payload.Beer[0]}}</h1>\n<h1><strong>TILT | {{msg.payload.Color}}</strong><span ng-bind-html=\"msg.payload.doclongurl\"></span></h1>\n<div style=\"background: {{msg.payload.Color}};height:40px;width:100%;\"></div>\n<h1>Uncal. SG/Concentration: {{msg.payload.uncalferm}}</h1>\n<h2>{{msg.payload.ferm}}{{msg.payload.fermunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.SG - 0.990)/0.00130}}%;\"></div>\n<h1>Uncal. Temperature: {{msg.payload.displayuncalTemp | number:1}}</h1>\n<h2>{{msg.payload.displayTemp | number:1}}{{msg.payload.tempunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.Temp - 30) / 1.85}}%;\"></div>\n<h5>{{msg.payload.formatteddate}}</h5>\n<h5>Received {{(msg.payload.clock - msg.payload.timeStamp) / 1000 | number:1}} seconds ago {{msg.payload.rssi}} dBm</h5>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":2429,"y":426,"wires":[["1ee5d27c.fa4e8e","394a5d3d.92fa72"]]},{"id":"6d7ca362.0790dc","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"storage-8","payloadType":"flow","repeat":"1","crontab":"","once":false,"x":1816,"y":427,"wires":[["49c2c87.03bfc38"]]},{"id":"49c2c87.03bfc38","type":"change","z":"a564595f.642818","name":"clock","rules":[{"t":"set","p":"payload.clock","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":2027.00004196167,"y":421.0000276565552,"wires":[["ba5663bf.b7cd6"]]},{"id":"ba5663bf.b7cd6","type":"function","z":"a564595f.642818","name":"check","func":"if(msg.payload === undefined){\n msg.payload = {};\n msg.show = \"hidden\";\n return msg;   \n}\n//set msg.topic for use in displaying the correct color\nmsg.topic = msg.payload.Color;\n//reorder list if a Tilt disconnects\nif (msg.payload.clock - msg.payload.timeStamp > 2*60*1000){\n flow.set('storage-1',undefined);\n flow.set('storage-2',undefined);\n flow.set('storage-3',undefined);\n flow.set('storage-4',undefined);\n flow.set('storage-5',undefined);\n flow.set('storage-6',undefined);\n flow.set('storage-7',undefined);\n flow.set('storage-8',undefined);\n flow.set('options',[]);\n if (msg.topic === flow.get('colordropdownSelect')){\n     flow.set('colordropdownSelect',undefined);\n }\n msg.show = \"hidden\";\n return msg;\n}\nelse{\n msg.show = \"visible\";\n return msg;\n}","outputs":1,"noerr":0,"x":2198.0000228881836,"y":421.00000762939453,"wires":[["228b94fc.188afc"]]},{"id":"2cbc023f.86f2de","type":"ui_template","z":"a564595f.642818","group":"a510f969.f28538","name":"7","order":1,"width":"6","height":"6","format":"<!DOCTYPE html>\n<style>\n   #{{msg.topic}}-div {\n    visibility: {{msg.show}};\n   }  \n</style>\n<div id = \"{{msg.topic}}-div\">\n<h1>{{msg.payload.Beer[0]}}</h1>\n<h1><strong>TILT | {{msg.payload.Color}}</strong><span ng-bind-html=\"msg.payload.doclongurl\"></span></h1>\n<div style=\"background: {{msg.payload.Color}};height:40px;width:100%;\"></div>\n<h1>Uncal. SG/Concentration: {{msg.payload.uncalferm}}</h1>\n<h2>{{msg.payload.ferm}}{{msg.payload.fermunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.SG - 0.990)/0.00130}}%;\"></div>\n<h1>Uncal. Temperature: {{msg.payload.displayuncalTemp | number:1}}</h1>\n<h2>{{msg.payload.displayTemp | number:1}}{{msg.payload.tempunits}}</h2>\n<div style=\"background: {{msg.payload.Color}};height:10px;width:{{(msg.payload.Temp - 30) / 1.85}}%;\"></div>\n<h5>{{msg.payload.formatteddate}}</h5>\n<h5>Received {{(msg.payload.clock - msg.payload.timeStamp) / 1000 | number:1}} seconds ago {{msg.payload.rssi}} dBm</h5>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":2418,"y":370,"wires":[["1ee5d27c.fa4e8e","394a5d3d.92fa72"]]},{"id":"8e49f6ea.8fa718","type":"change","z":"a564595f.642818","name":"clock","rules":[{"t":"set","p":"payload.clock","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":2029.00004196167,"y":356.00001525878906,"wires":[["68f079f0.789e18"]]},{"id":"68f079f0.789e18","type":"function","z":"a564595f.642818","name":"check","func":"if(msg.payload === undefined){\n msg.payload = {};\n msg.show = \"hidden\";\n return msg;   \n}\n//set msg.topic for use in displaying the correct color\nmsg.topic = msg.payload.Color;\n//reorder list if a Tilt disconnects\nif (msg.payload.clock - msg.payload.timeStamp > 2*60*1000){\n flow.set('storage-1',undefined);\n flow.set('storage-2',undefined);\n flow.set('storage-3',undefined);\n flow.set('storage-4',undefined);\n flow.set('storage-5',undefined);\n flow.set('storage-6',undefined);\n flow.set('storage-7',undefined);\n flow.set('storage-8',undefined);\n flow.set('options',[]);\n if (msg.topic === flow.get('colordropdownSelect')){\n     flow.set('colordropdownSelect',undefined);\n }\n msg.show = \"hidden\";\n return msg;\n}\nelse{\n msg.show = \"visible\";\n return msg;\n}","outputs":1,"noerr":0,"x":2199.0001068115234,"y":360.00000286102295,"wires":[["2cbc023f.86f2de"]]},{"id":"153b404.67792c","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"storage-7","payloadType":"flow","repeat":"1","crontab":"","once":false,"x":1823.5,"y":357,"wires":[["8e49f6ea.8fa718"]]},{"id":"df1ac3a9.c4472","type":"ui_template","z":"a564595f.642818","group":"81394fa6.f9523","name":"Cloud Response","order":5,"width":"6","height":"4","format":"<!DOCTYPE HTML>\n<style>\n   a:link {\n    color: white; \n    background-color: transparent; \n    text-decoration: none;\n}\n\na:visited {\n    color: white;\n    background-color: transparent;\n    text-decoration: none;\n}\n</style>\n<div ng-bind-html=\"'<strong>Cloud Status: </strong>' + msg.cloudwait\"></div>\n<div ng-bind-html=\"msg.payload.result + msg.cloudlink\"></div>\n<div ng-bind-html=\"msg.payload.this\"></div>\n","storeOutMessages":false,"fwdInMessages":true,"templateScope":"local","x":3502,"y":566,"wires":[[]]},{"id":"f14feb76.aebb48","type":"function","z":"a564595f.642818","name":"update name, clear comment","func":"if (msg.payload.beername !== undefined){\nif (msg.payload.beername.indexOf(\",\") > -1){\nbeerArray = msg.payload.beername.split(\",\");\n//node.warn(msg.payload.beername[1]);\nflow.set(msg.payload.tiltcolor + \"-Beer\",beerArray);\n//node.warn(flow.get(msg.payload.tiltcolor + \"-Beer\"));\nflow.set(msg.payload.tiltcolor + \"-Comment\",\"\");\nif (msg.payload.doclongurl !== undefined) {\nflow.set(msg.payload.tiltcolor + \"-URL\",'<a href=\"' + msg.payload.doclongurl + '\" target=\"_blank\"> | View Cloud Log</a>');\n}\nmsg.payload = beerArray;\nreturn msg;\n}\n}","outputs":1,"noerr":0,"x":3555,"y":155,"wires":[["656f0cf9.e79cd4"]]},{"id":"8dec8962.63e398","type":"ui_toast","z":"a564595f.642818","position":"top right","displayTime":"8","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"","name":"","x":1869,"y":704,"wires":[]},{"id":"561c3f7f.1b8ab","type":"change","z":"a564595f.642818","name":"4","rules":[{"t":"move","p":"payload","pt":"msg","to":"storage-4","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1641,"y":207,"wires":[[]]},{"id":"eba532a9.2afe3","type":"change","z":"a564595f.642818","name":"8","rules":[{"t":"move","p":"payload","pt":"msg","to":"storage-8","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1645,"y":420,"wires":[[]]},{"id":"de92b02f.5ebe1","type":"ui_text_input","z":"a564595f.642818","name":"","label":"Comment [use RETURN to send]","group":"19fab5c2.199ffa","order":6,"width":"6","height":"2","passthru":false,"mode":"text","delay":"0","topic":"","x":1337.5,"y":605,"wires":[["e899ac8f.ec903"]]},{"id":"6cbfa171.d2106","type":"function","z":"a564595f.642818","name":"filter cloud response","func":"var color = flow.get('colordropdownSelect')||\"\";\n//delete cloud wait message\nif (msg.payload.tiltcolor === color){\n    msg.cloudwait = \"\";\n    msg.cloudlink = flow.get(color + \"-URL\");\n}\nreturn msg;","outputs":1,"noerr":0,"x":3418,"y":414,"wires":[["df1ac3a9.c4472"]]},{"id":"b1836d66.f976c","type":"ui_switch","z":"a564595f.642818","name":"","label":"Use Default Cloud URL for All","group":"19fab5c2.199ffa","order":2,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":706,"y":688.0000095367432,"wires":[["d599e3c9.1ae09"]]},{"id":"88a2c98f.f38b08","type":"ui_slider","z":"a564595f.642818","name":"","label":"Time Interval","group":"19fab5c2.199ffa","order":4,"width":0,"height":0,"passthru":true,"topic":"","min":"5","max":"60","step":"5","x":1584.5,"y":798,"wires":[["e95c8a86.0f73c8","1a5d2031.88af3"]]},{"id":"e95c8a86.0f73c8","type":"ui_text","z":"a564595f.642818","group":"19fab5c2.199ffa","order":5,"width":0,"height":0,"name":"","label":"Minutes:","format":"{{msg.payload}}","layout":"row-left","x":1980,"y":800,"wires":[]},{"id":"1a5d2031.88af3","type":"function","z":"a564595f.642818","name":"Save Interval","func":"flow.set('loggingInterval',msg.payload);","outputs":1,"noerr":0,"x":1848,"y":759,"wires":[[]]},{"id":"2f5685a6.76e34a","type":"file","z":"a564595f.642818","name":"","filename":"/home/pi/log.csv","appendNewline":true,"createDir":false,"overwriteFile":"false","x":3129.5007934570312,"y":331.00007247924805,"wires":[]},{"id":"6af4a20b.f5f3cc","type":"http response","z":"a564595f.642818","name":"Show Local Data","x":3140.5,"y":375,"wires":[]},{"id":"dd2bec42.f4069","type":"http in","z":"a564595f.642818","name":"","url":"/log.csv","method":"get","upload":false,"swaggerDoc":"","x":2740.5,"y":374,"wires":[["898ef56a.365648"]]},{"id":"898ef56a.365648","type":"file in","z":"a564595f.642818","name":"","filename":"/home/pi/log.csv","format":"","sendError":false,"x":2931.5,"y":372,"wires":[["6af4a20b.f5f3cc"]]},{"id":"2cabe65a.14f1ba","type":"ui_text","z":"a564595f.642818","group":"82607108.c5be8","order":3,"width":0,"height":0,"name":"","label":"Minimum Minutes:","format":"{{msg.payload}}","layout":"row-left","x":1570,"y":980,"wires":[]},{"id":"7b1370e2.6e8c9","type":"ui_slider","z":"a564595f.642818","name":"","label":"Time Interval","group":"82607108.c5be8","order":2,"width":0,"height":0,"passthru":true,"topic":"","min":".1","max":"60","step":".1","x":1350,"y":960,"wires":[["2cabe65a.14f1ba","b560ab50.dc71d8"]]},{"id":"b560ab50.dc71d8","type":"function","z":"a564595f.642818","name":"Save Interval","func":"flow.set('localloggingInterval',msg.payload);","outputs":1,"noerr":0,"x":1550,"y":940,"wires":[[]]},{"id":"394a5d3d.92fa72","type":"function","z":"a564595f.642818","name":"Setup Local Log","func":"var postEnabled = (flow.get('logLocalDataCheck'));\nvar interval = flow.get('localloggingInterval')||15;\ninterval *= 60000;\nif (postEnabled && msg.payload.Color !== undefined){\n    var lastPost = flow.get('lastlocalpost-' + msg.payload.Color)||0;\n    if (msg.payload.timeStamp - lastPost > interval){\n        msg.payload.Comment = flow.get(msg.payload.Color + \"-Comment\")||\"\";\n        msg.payload.Beer = flow.get(msg.payload.Color + \"-Beer\")||[\"Untitled\",true];\n        msg.topic = msg.payload.Color;\n        var date = new Date().toLocaleString();\n        date = date.replace(\",\",\" \");\n        //unsigned bonus byte\n        var uint8 = new Uint8Array(1);\n        uint8[0] = msg.payload.measuredPower;\n        msg.payload.measuredPower = uint8[0];\n        flow.set('lastlocalpost-' + msg.payload.Color,msg.payload.timeStamp);\n        msg.payload = date + \",\" + msg.payload.Timepoint + \",\" + msg.payload.Temp + \",\" + msg.payload.SG + \",\" + msg.payload.Beer[0] + \",\" + msg.payload.Color + \",\" + msg.payload.Comment + \",\" + msg.payload.rssi + \",\" + msg.payload.measuredPower;\n    return msg;\n}\n}","outputs":1,"noerr":0,"x":2740,"y":280,"wires":[["dcc41bde.fc7208","9b32b69b.089738"]]},{"id":"2316593.5ec70a6","type":"function","z":"a564595f.642818","name":"Set Logging to SD Card","func":"var color = flow.get('colordropdownSelect')||\"\";\nflow.set('logLocalDataCheck',msg.payload);\nflow.set('lastlocalpost-' + color,0);\nmsg.topic = \"TILT | \" + color;\nif (msg.payload){\nmsg.payload = \"Logging to Tilt Pi enabled.\";\n}\nelse {\n    msg.payload = \"Logging disabled.\"\n}\nreturn msg;","outputs":1,"noerr":0,"x":1769,"y":1036,"wires":[["cd2573a4.64137"]]},{"id":"c7601414.73cf68","type":"ui_switch","z":"a564595f.642818","name":"","label":"Start Logging to Tilt Pi","group":"82607108.c5be8","order":1,"width":0,"height":0,"passthru":false,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":1484,"y":1033,"wires":[["2316593.5ec70a6"]]},{"id":"cd2573a4.64137","type":"ui_toast","z":"a564595f.642818","position":"top right","displayTime":"8","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"","name":"","x":1991,"y":1035,"wires":[]},{"id":"644a5410.3ea0bc","type":"ui_text","z":"a564595f.642818","group":"82607108.c5be8","order":6,"width":0,"height":0,"name":"Log Size","label":"","format":"{{msg.payload}}","layout":"row-left","x":3512.5,"y":291,"wires":[]},{"id":"dcc41bde.fc7208","type":"exec","z":"a564595f.642818","command":"stat","addpay":false,"append":"log.csv","useSpawn":"true","timer":"5","oldrc":false,"name":"","x":2930,"y":260,"wires":[["5c5d0dab.293cc4"],[],[]]},{"id":"5c5d0dab.293cc4","type":"split","z":"a564595f.642818","name":"","splt":"\\n","spltType":"str","arraySplt":"1","arraySpltType":"len","stream":false,"addname":"","x":3075,"y":253,"wires":[["7317b5bb.adcf1c"]]},{"id":"7317b5bb.adcf1c","type":"switch","z":"a564595f.642818","name":"","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"Size","vt":"str"}],"checkall":"true","outputs":1,"x":3218,"y":286,"wires":[["ae037878.ee52b8"]]},{"id":"ae037878.ee52b8","type":"change","z":"a564595f.642818","name":"format","rules":[{"t":"change","p":"payload","pt":"msg","from":"Blocks*.*file","fromt":"re","to":" bytes","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":3363.5,"y":290,"wires":[["644a5410.3ea0bc"]]},{"id":"9b51bae9.bed728","type":"file","z":"a564595f.642818","name":"","filename":"/home/pi/log.csv","appendNewline":true,"createDir":false,"overwriteFile":"true","x":2976.5,"y":474,"wires":[]},{"id":"da1dd72.c86df28","type":"ui_button","z":"a564595f.642818","name":"","group":"82607108.c5be8","order":7,"width":0,"height":0,"passthru":true,"label":"Delete Log","color":"white","bgcolor":"red","icon":"","payload":"Time,Timepoint,Temp,SG,Beer,Color,Comment,RSSI,Uptime","payloadType":"str","topic":"","x":2727.5,"y":477,"wires":[["dcc41bde.fc7208","9b51bae9.bed728"]]},{"id":"b418ce11.8981a","type":"ui_dropdown","z":"a564595f.642818","name":"Calibration Dropdown","label":"TILT | ","place":"Select Tilt Color","group":"eb4ab3d5.7b3f1","order":1,"width":0,"height":0,"passthru":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":927.7778167724609,"y":401.6666793823242,"wires":[["6aa75852.1e3068"]]},{"id":"d9ea777.f3c9388","type":"ui_text_input","z":"a564595f.642818","name":"","label":"Actual [use RETURN to set]","group":"6acae0b0.a184","order":2,"width":0,"height":0,"passthru":true,"mode":"text","delay":"0","topic":"","x":1089,"y":1117,"wires":[["84ffe685.150d58"]]},{"id":"ecfbe772.ba4cb8","type":"ui_text","z":"a564595f.642818","group":"6acae0b0.a184","order":1,"width":0,"height":0,"name":"","label":"Uncal. SG","format":"{{msg.payload}}","layout":"row-spread","x":1605,"y":865,"wires":[]},{"id":"9bdc1db3.4ceaa","type":"inject","z":"a564595f.642818","name":"Get Color Selection","topic":"","payload":"colordropdownSelect","payloadType":"flow","repeat":"2","crontab":"","once":false,"x":1096,"y":878,"wires":[["3eb6f3c4.588d1c","d6de2020.56974"]]},{"id":"1be76b3b.e111e5","type":"ui_text_input","z":"a564595f.642818","name":"","label":"Uncalibrated Points [use RETURN to set]","group":"6acae0b0.a184","order":3,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"","x":2086,"y":1166,"wires":[["88f0f33d.110ab"]]},{"id":"e29d71bb.f0e81","type":"ui_text_input","z":"a564595f.642818","name":"","label":"Actual Points [use RETURN to set]","group":"6acae0b0.a184","order":4,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"","x":2078,"y":1233,"wires":[["b36a946.3813e68"]]},{"id":"f9e2fc12.8340c","type":"inject","z":"a564595f.642818","name":"Logging Interval","topic":"","payload":"loggingInterval","payloadType":"flow","repeat":"15","crontab":"","once":false,"x":1263.0002059936523,"y":815.0000438690186,"wires":[["88a2c98f.f38b08"]]},{"id":"b13cb5ba.f355b8","type":"exec","z":"a564595f.642818","command":"sudo reboot","addpay":false,"append":"","useSpawn":false,"timer":"","name":"Reboot","x":460,"y":2140,"wires":[["2a36a03c.47d1f"],[],[]]},{"id":"a85e96c5.56cc58","type":"ui_button","z":"a564595f.642818","name":"","group":"7e458eda.984cd","order":2,"width":0,"height":0,"passthru":false,"label":"Restart","color":"","bgcolor":"","icon":"fa-refresh","payload":"now","payloadType":"str","topic":"","x":220,"y":2137,"wires":[["b13cb5ba.f355b8"]]},{"id":"2a36a03c.47d1f","type":"ui_toast","z":"a564595f.642818","position":"top right","displayTime":"3","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"","name":"","x":686,"y":2131,"wires":[]},{"id":"9fa076ac.17f568","type":"function","z":"a564595f.642818","name":"time zones","func":"var options = [\"Africa/Harare\",\"Africa/Lusaka\",\"Africa/Johannesburg\",\"Indian/Mayotte\",\"Asia/Aden\",\"Pacific/Apia\",\"Pacific/Wallis\",\"Pacific/Efate\",\"Asia/Ho_Chi_Minh\",\"America/St_Thomas\",\"America/Tortola\",\"America/Caracas\",\"America/St_Vincent\",\"Europe/Vatican\",\"Asia/Samarkand\",\"Asia/Tashkent\",\"America/Montevideo\",\"America/Adak\",\"America/Anchorage\",\"America/Boise\",\"America/Chicago\",\"America/Denver\",\"America/Detroit\",\"America/Indiana/Indianapolis\",\"America/Indiana/Knox\",\"America/Indiana/Marengo\",\"America/Indiana/Petersburg\",\"America/Indiana/Tell_City\",\"America/Indiana/Vevay\",\"America/Indiana/Vincennes\",\"America/Indiana/Winamac\",\"America/Juneau\",\"America/Kentucky/Louisville\",\"America/Kentucky/Monticello\",\"America/Los_Angeles\",\"America/Menominee\",\"America/Metlakatla\",\"America/New_York\",\"America/Nome\",\"America/North_Dakota/Beulah\",\"America/North_Dakota/Center\",\"America/North_Dakota/New_Salem\",\"America/Phoenix\",\"America/Sitka\",\"America/Yakutat\",\"Pacific/Honolulu\",\"Pacific/Midway\",\"Pacific/Wake\",\"Africa/Kampala\",\"Europe/Kiev\",\"Europe/Uzhgorod\",\"Europe/Zaporozhye\",\"Africa/Dar_es_Salaam\",\"Asia/Taipei\",\"Pacific/Funafuti\",\"America/Port_of_Spain\",\"Europe/Istanbul\",\"Pacific/Tongatapu\",\"Africa/Tunis\",\"Asia/Ashgabat\",\"Asia/Dili\",\"Pacific/Fakaofo\",\"Asia/Dushanbe\",\"Asia/Bangkok\",\"Africa/Lome\",\"Indian/Kerguelen\",\"Africa/Ndjamena\",\"America/Grand_Turk\",\"Africa/Mbabane\",\"Asia/Damascus\",\"America/Lower_Princes\",\"America/El_Salvador\",\"Africa/Sao_Tome\",\"Africa/Juba\",\"America/Paramaribo\",\"Africa/Mogadishu\",\"Africa/Dakar\",\"Europe/San_Marino\",\"Africa/Freetown\",\"Europe/Bratislava\",\"Arctic/Longyearbyen\",\"Europe/Ljubljana\",\"Atlantic/St_Helena\",\"Asia/Singapore\",\"Europe/Stockholm\",\"Africa/Khartoum\",\"Indian/Mahe\",\"Pacific/Guadalcanal\",\"Asia/Riyadh\",\"Africa/Kigali\",\"Asia/Anadyr\",\"Asia/Barnaul\",\"Asia/Chita\",\"Asia/Irkutsk\",\"Asia/Kamchatka\",\"Asia/Khandyga\",\"Asia/Krasnoyarsk\",\"Asia/Magadan\",\"Asia/Novokuznetsk\",\"Asia/Novosibirsk\",\"Asia/Omsk\",\"Asia/Sakhalin\",\"Asia/Srednekolymsk\",\"Asia/Tomsk\",\"Asia/Ust-Nera\",\"Asia/Vladivostok\",\"Asia/Yakutsk\",\"Asia/Yekaterinburg\",\"Europe/Astrakhan\",\"Europe/Kaliningrad\",\"Europe/Kirov\",\"Europe/Moscow\",\"Europe/Samara\",\"Europe/Saratov\",\"Europe/Simferopol\",\"Europe/Ulyanovsk\",\"Europe/Volgograd\",\"Europe/Belgrade\",\"Europe/Bucharest\",\"Indian/Reunion\",\"Asia/Qatar\",\"America/Asuncion\",\"Pacific/Palau\",\"Atlantic/Azores\",\"Atlantic/Madeira\",\"Europe/Lisbon\",\"Asia/Gaza\",\"Asia/Hebron\",\"America/Puerto_Rico\",\"Pacific/Pitcairn\",\"America/Miquelon\",\"Europe/Warsaw\",\"Asia/Karachi\",\"Asia/Manila\",\"Pacific/Bougainville\",\"Pacific/Port_Moresby\",\"Pacific/Gambier\",\"Pacific/Marquesas\",\"Pacific/Tahiti\",\"America/Lima\",\"America/Panama\",\"Asia/Muscat\",\"Pacific/Auckland\",\"Pacific/Chatham\",\"Pacific/Niue\",\"Pacific/Nauru\",\"Asia/Kathmandu\",\"Europe/Oslo\",\"Europe/Amsterdam\",\"America/Managua\",\"Africa/Lagos\",\"Pacific/Norfolk\",\"Africa/Niamey\",\"Pacific/Noumea\",\"Africa/Windhoek\",\"Africa/Maputo\",\"Asia/Kuala_Lumpur\",\"Asia/Kuching\",\"America/Bahia_Banderas\",\"America/Cancun\",\"America/Chihuahua\",\"America/Hermosillo\",\"America/Matamoros\",\"America/Mazatlan\",\"America/Merida\",\"America/Mexico_City\",\"America/Monterrey\",\"America/Ojinaga\",\"America/Tijuana\",\"Africa/Blantyre\",\"Indian/Maldives\",\"Indian/Mauritius\",\"Europe/Malta\",\"America/Montserrat\",\"Africa/Nouakchott\",\"America/Martinique\",\"Pacific/Saipan\",\"Asia/Macau\",\"Asia/Choibalsan\",\"Asia/Hovd\",\"Asia/Ulaanbaatar\",\"Asia/Yangon\",\"Africa/Bamako\",\"Europe/Skopje\",\"Pacific/Kwajalein\",\"Pacific/Majuro\",\"Indian/Antananarivo\",\"America/Marigot\",\"Europe/Podgorica\",\"Europe/Chisinau\",\"Europe/Monaco\",\"Africa/Casablanca\",\"Africa/Tripoli\",\"Europe/Riga\",\"Europe/Luxembourg\",\"Europe/Vilnius\",\"Africa/Maseru\",\"Africa/Monrovia\",\"Asia/Colombo\",\"Europe/Vaduz\",\"America/St_Lucia\",\"Asia/Beirut\",\"Asia/Vientiane\",\"Asia/Almaty\",\"Asia/Aqtau\",\"Asia/Aqtobe\",\"Asia/Atyrau\",\"Asia/Oral\",\"Asia/Qyzylorda\",\"America/Cayman\",\"Asia/Kuwait\",\"Asia/Seoul\",\"Asia/Pyongyang\",\"America/St_Kitts\",\"Indian/Comoro\",\"Pacific/Enderbury\",\"Pacific/Kiritimati\",\"Pacific/Tarawa\",\"Asia/Phnom_Penh\",\"Asia/Bishkek\",\"Africa/Nairobi\",\"Asia/Tokyo\",\"Asia/Amman\",\"America/Jamaica\",\"Europe/Jersey\",\"Europe/Rome\",\"Atlantic/Reykjavik\",\"Asia/Tehran\",\"Asia/Baghdad\",\"Indian/Chagos\",\"Asia/Kolkata\",\"Europe/Isle_of_Man\",\"Asia/Jerusalem\",\"Europe/Dublin\",\"Asia/Jakarta\",\"Asia/Jayapura\",\"Asia/Makassar\",\"Asia/Pontianak\",\"Europe/Budapest\",\"America/Port-au-Prince\",\"Europe/Zagreb\",\"America/Tegucigalpa\",\"Asia/Hong_Kong\",\"America/Guyana\",\"Africa/Bissau\",\"Pacific/Guam\",\"America/Guatemala\",\"Atlantic/South_Georgia\",\"Europe/Athens\",\"Africa/Malabo\",\"America/Guadeloupe\",\"Africa/Conakry\",\"Africa/Banjul\",\"America/Danmarkshavn\",\"America/Godthab\",\"America/Scoresbysund\",\"America/Thule\",\"Europe/Gibraltar\",\"Africa/Accra\",\"Europe/Guernsey\",\"America/Cayenne\",\"Asia/Tbilisi\",\"America/Grenada\",\"Europe/London\",\"Africa/Libreville\",\"Europe/Paris\",\"Atlantic/Faroe\",\"Pacific/Chuuk\",\"Pacific/Kosrae\",\"Pacific/Pohnpei\",\"Atlantic/Stanley\",\"Pacific/Fiji\",\"Europe/Helsinki\",\"Africa/Addis_Ababa\",\"Africa/Ceuta\",\"Atlantic/Canary\",\"Europe/Madrid\",\"Africa/Asmara\",\"Africa/El_Aaiun\",\"Africa/Cairo\",\"Europe/Tallinn\",\"America/Guayaquil\",\"Pacific/Galapagos\",\"Africa/Algiers\",\"America/Santo_Domingo\",\"America/Dominica\",\"Europe/Copenhagen\",\"Africa/Djibouti\",\"Europe/Berlin\",\"Europe/Busingen\",\"Europe/Prague\",\"Asia/Famagusta\",\"Asia/Nicosia\",\"Indian/Christmas\",\"America/Curacao\",\"Atlantic/Cape_Verde\",\"America/Havana\",\"America/Costa_Rica\",\"America/Bogota\",\"Asia/Shanghai\",\"Asia/Urumqi\",\"Africa/Douala\",\"America/Punta_Arenas\",\"America/Santiago\",\"Pacific/Easter\",\"Pacific/Rarotonga\",\"Africa/Abidjan\",\"Europe/Zurich\",\"Africa/Brazzaville\",\"Africa/Bangui\",\"Africa/Kinshasa\",\"Africa/Lubumbashi\",\"Indian/Cocos\",\"America/Atikokan\",\"America/Blanc-Sablon\",\"America/Cambridge_Bay\",\"America/Creston\",\"America/Dawson\",\"America/Dawson_Creek\",\"America/Edmonton\",\"America/Fort_Nelson\",\"America/Glace_Bay\",\"America/Goose_Bay\",\"America/Halifax\",\"America/Inuvik\",\"America/Iqaluit\",\"America/Moncton\",\"America/Nipigon\",\"America/Pangnirtung\",\"America/Rainy_River\",\"America/Rankin_Inlet\",\"America/Regina\",\"America/Resolute\",\"America/St_Johns\",\"America/Swift_Current\",\"America/Thunder_Bay\",\"America/Toronto\",\"America/Vancouver\",\"America/Whitehorse\",\"America/Winnipeg\",\"America/Yellowknife\",\"America/Belize\",\"Europe/Minsk\",\"Africa/Gaborone\",\"Asia/Thimphu\",\"America/Nassau\",\"America/Araguaina\",\"America/Bahia\",\"America/Belem\",\"America/Boa_Vista\",\"America/Campo_Grande\",\"America/Cuiaba\",\"America/Eirunepe\",\"America/Fortaleza\",\"America/Maceio\",\"America/Manaus\",\"America/Noronha\",\"America/Porto_Velho\",\"America/Recife\",\"America/Rio_Branco\",\"America/Santarem\",\"America/Sao_Paulo\",\"America/Kralendijk\",\"America/La_Paz\",\"Asia/Brunei\",\"Atlantic/Bermuda\",\"America/St_Barthelemy\",\"Africa/Porto-Novo\",\"Africa/Bujumbura\",\"Asia/Bahrain\",\"Europe/Sofia\",\"Africa/Ouagadougou\",\"Europe/Brussels\",\"Asia/Dhaka\",\"America/Barbados\",\"Europe/Sarajevo\",\"Asia/Baku\",\"Europe/Mariehamn\",\"America/Aruba\",\"Antarctica/Macquarie\",\"Australia/Adelaide\",\"Australia/Brisbane\",\"Australia/Broken_Hill\",\"Australia/Currie\",\"Australia/Darwin\",\"Australia/Eucla\",\"Australia/Hobart\",\"Australia/Lindeman\",\"Australia/Lord_Howe\",\"Australia/Melbourne\",\"Australia/Perth\",\"Australia/Sydney\",\"Europe/Vienna\",\"Pacific/Pago_Pago\",\"America/Argentina/Buenos_Aires\",\"America/Argentina/Catamarca\",\"America/Argentina/Cordoba\",\"America/Argentina/Jujuy\",\"America/Argentina/La_Rioja\",\"America/Argentina/Mendoza\",\"America/Argentina/Rio_Gallegos\",\"America/Argentina/Salta\",\"America/Argentina/San_Juan\",\"America/Argentina/San_Luis\",\"America/Argentina/Tucuman\",\"America/Argentina/Ushuaia\",\"Antarctica/Casey\",\"Antarctica/Davis\",\"Antarctica/DumontDUrville\",\"Antarctica/Mawson\",\"Antarctica/McMurdo\",\"Antarctica/Palmer\",\"Antarctica/Rothera\",\"Antarctica/Syowa\",\"Antarctica/Troll\",\"Antarctica/Vostok\",\"Africa/Luanda\",\"Asia/Yerevan\",\"Europe/Tirane\",\"America/Anguilla\",\"America/Antigua\",\"Asia/Kabul\",\"Asia/Dubai\",\"Europe/Andorra\",\"Africa/Asmera\",\"Africa/Timbuktu\",\"America/Argentina/ComodRivadavia\",\"America/Atka\",\"America/Buenos_Aires\",\"America/Catamarca\",\"America/Coral_Harbour\",\"America/Cordoba\",\"America/Ensenada\",\"America/Fort_Wayne\",\"America/Indianapolis\",\"America/Jujuy\",\"America/Knox_IN\",\"America/Louisville\",\"America/Mendoza\",\"America/Montreal\",\"America/Porto_Acre\",\"America/Rosario\",\"America/Santa_Isabel\",\"America/Shiprock\",\"America/Virgin\",\"Antarctica/South_Pole\",\"Asia/Ashkhabad\",\"Asia/Calcutta\",\"Asia/Chongqing\",\"Asia/Chungking\",\"Asia/Dacca\",\"Asia/Harbin\",\"Asia/Istanbul\",\"Asia/Kashgar\",\"Asia/Katmandu\",\"Asia/Macao\",\"Asia/Rangoon\",\"Asia/Saigon\",\"Asia/Tel_Aviv\",\"Asia/Thimbu\",\"Asia/Ujung_Pandang\",\"Asia/Ulan_Bator\",\"Atlantic/Faeroe\",\"Atlantic/Jan_Mayen\",\"Australia/ACT\",\"Australia/Canberra\",\"Australia/LHI\",\"Australia/North\",\"Australia/NSW\",\"Australia/Queensland\",\"Australia/South\",\"Australia/Tasmania\",\"Australia/Victoria\",\"Australia/West\",\"Australia/Yancowinna\",\"Brazil/Acre\",\"Brazil/DeNoronha\",\"Brazil/East\",\"Brazil/West\",\"Canada/Atlantic\",\"Canada/Central\",\"Canada/East-Saskatchewan\",\"Canada/Eastern\",\"Canada/Mountain\",\"Canada/Newfoundland\",\"Canada/Pacific\",\"Canada/Saskatchewan\",\"Canada/Yukon\",\"CET\",\"Chile/Continental\",\"Chile/EasterIsland\",\"CST6CDT\",\"Cuba\",\"EET\",\"Egypt\",\"Eire\",\"EST\",\"EST5EDT\",\"Etc/GMT\",\"Etc/GMT+0\",\"Etc/GMT+1\",\"Etc/GMT+10\",\"Etc/GMT+11\",\"Etc/GMT+12\",\"Etc/GMT+2\",\"Etc/GMT+3\",\"Etc/GMT+4\",\"Etc/GMT+5\",\"Etc/GMT+6\",\"Etc/GMT+7\",\"Etc/GMT+8\",\"Etc/GMT+9\",\"Etc/GMT-0\",\"Etc/GMT-1\",\"Etc/GMT-10\",\"Etc/GMT-11\",\"Etc/GMT-12\",\"Etc/GMT-13\",\"Etc/GMT-14\",\"Etc/GMT-2\",\"Etc/GMT-3\",\"Etc/GMT-4\",\"Etc/GMT-5\",\"Etc/GMT-6\",\"Etc/GMT-7\",\"Etc/GMT-8\",\"Etc/GMT-9\",\"Etc/GMT0\",\"Etc/Greenwich\",\"Etc/UCT\",\"Etc/Universal\",\"Etc/UTC\",\"Etc/Zulu\",\"Europe/Belfast\",\"Europe/Nicosia\",\"Europe/Tiraspol\",\"GB\",\"GB-Eire\",\"GMT\",\"GMT+0\",\"GMT-0\",\"GMT0\",\"Greenwich\",\"Hongkong\",\"HST\",\"Iceland\",\"Iran\",\"Israel\",\"Jamaica\",\"Japan\",\"Kwajalein\",\"Libya\",\"MET\",\"Mexico/BajaNorte\",\"Mexico/BajaSur\",\"Mexico/General\",\"MST\",\"MST7MDT\",\"Navajo\",\"NZ\",\"NZ-CHAT\",\"Pacific/Johnston\",\"Pacific/Ponape\",\"Pacific/Samoa\",\"Pacific/Truk\",\"Pacific/Yap\",\"Poland\",\"Portugal\",\"PRC\",\"PST8PDT\",\"ROC\",\"ROK\",\"Singapore\",\"Turkey\",\"UCT\",\"Universal\",\"US/Alaska\",\"US/Aleutian\",\"US/Arizona\",\"US/Central\",\"US/East-Indiana\",\"US/Eastern\",\"US/Hawaii\",\"US/Indiana-Starke\",\"US/Michigan\",\"US/Mountain\",\"US/Pacific\",\"US/Pacific-New\",\"US/Samoa\",\"UTC\",\"W-SU\",\"WET\",\"Zulu\"];\nmsg.options = options.sort();\nreturn msg;","outputs":1,"noerr":0,"x":610,"y":1600,"wires":[["9bb86c18.f0deb"]]},{"id":"9bb86c18.f0deb","type":"ui_dropdown","z":"a564595f.642818","name":"","label":"Time Zone:","place":"Select","group":"5ca7d250.c3938c","order":1,"width":0,"height":0,"passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":1062,"y":1594,"wires":[["a6b43763.a12aa8","90a37ef8.2317d"]]},{"id":"f49b2576.99e1d8","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":true,"x":55,"y":1597,"wires":[["9fa076ac.17f568","a1357f50.ee57a"]]},{"id":"a1357f50.ee57a","type":"file in","z":"a564595f.642818","name":"","filename":"/etc/timezone","format":"utf8","sendError":true,"x":616,"y":1693,"wires":[["6547f655.0621e8"]]},{"id":"6547f655.0621e8","type":"function","z":"a564595f.642818","name":"remove line breaks","func":"msg.payload = msg.payload.replace(/(\\r\\n|\\n|\\r)/gm,\"\");\nreturn msg;","outputs":1,"noerr":0,"x":823,"y":1692,"wires":[["9bb86c18.f0deb"]]},{"id":"3a8464e7.9213dc","type":"ui_button","z":"a564595f.642818","name":"","group":"5ca7d250.c3938c","order":2,"width":0,"height":0,"passthru":false,"label":"Set Time Zone","color":"","bgcolor":"","icon":"","payload":"tz","payloadType":"flow","topic":"","x":619,"y":1758,"wires":[["c542fa3.77cb308"]]},{"id":"c542fa3.77cb308","type":"exec","z":"a564595f.642818","command":"sudo ln -fs","addpay":true,"append":"/etc/localtime","useSpawn":"true","timer":"","oldrc":false,"name":"set timezone sym link","x":840,"y":1760,"wires":[[],[],["10d7ccc5.8a1033"]]},{"id":"8ee3b7e3.1833a8","type":"ui_toast","z":"a564595f.642818","position":"top right","displayTime":"3","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"","name":"","x":1473,"y":1796,"wires":[]},{"id":"be6c33c3.62e8a","type":"change","z":"a564595f.642818","name":"Set Alerts","rules":[{"t":"set","p":"payload","pt":"msg","to":"Click restart to save changes.","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"Restart Needed","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":1720,"wires":[["8ee3b7e3.1833a8","c08f3c8c.b6e87"]]},{"id":"c08f3c8c.b6e87","type":"ui_text","z":"a564595f.642818","group":"5ca7d250.c3938c","order":4,"width":0,"height":0,"name":"status","label":"","format":"{{msg.payload}}","layout":"col-center","x":1450,"y":1746,"wires":[]},{"id":"1dc3fc9e.e1f193","type":"ui_text_input","z":"a564595f.642818","name":"","label":"GMAIL email [use RETURN to start log]","group":"81394fa6.f9523","order":4,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"","x":585,"y":782,"wires":[["e899ac8f.ec903","4e68e4c.496741c","d656e52b.f2a508"]]},{"id":"4e68e4c.496741c","type":"change","z":"a564595f.642818","name":"turn on logging","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":894.5,"y":823,"wires":[["dc8e0ec5.550d","c7601414.73cf68"]]},{"id":"7496a044.dd719","type":"exec","z":"a564595f.642818","command":"hostname -I","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"hostname","x":320,"y":1880,"wires":[["deb9c4fc.20c098"],[],[]]},{"id":"58a4e2b2.11320c","type":"inject","z":"a564595f.642818","name":"get ip","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"x":131,"y":1879.5,"wires":[["7496a044.dd719"]]},{"id":"a4a5a7ed.d59958","type":"ui_text","z":"a564595f.642818","group":"c8854cd2.f1773","order":2,"width":0,"height":0,"name":"","label":"Tilt Pi Local Address","format":"{{msg.payload}}","layout":"col-center","x":868,"y":1885,"wires":[]},{"id":"5312bf4.09fd44","type":"ui_switch","z":"a564595f.642818","name":"","label":"Celsius","group":"b0619070.ac95d","order":2,"width":0,"height":0,"passthru":false,"decouple":"false","topic":"","style":"","onvalue":"°C","onvalueType":"str","onicon":"","oncolor":"","offvalue":"°F","offvalueType":"str","officon":"","offcolor":"","x":1914.0002632141113,"y":1670.0005922317505,"wires":[["b58e5805.5d5928"]]},{"id":"b58e5805.5d5928","type":"function","z":"a564595f.642818","name":"Change Temp Units","func":"if (msg.payload === \"°C\"){\nflow.set('tempUnits',[-32,0.555]);\nflow.set('displayUnits',\"°C\");\nreturn msg;\n}\nif (msg.payload === \"°F\"){\nflow.set('tempUnits',[0,1]);\nflow.set('displayUnits',\"°F\");\nreturn msg;\n}","outputs":"1","noerr":0,"x":2167.99991607666,"y":1635.0002250671387,"wires":[["5312bf4.09fd44","8951ba9f.798ae8"]]},{"id":"5a69b142.f96b6","type":"exec","z":"a564595f.642818","command":"sudo shutdown","addpay":true,"append":"","useSpawn":false,"timer":"","name":"Shutdown","x":463,"y":2063,"wires":[["f2bdbc36.5644d"],[],[]]},{"id":"2bcbe8c9.eefe28","type":"ui_button","z":"a564595f.642818","name":"","group":"7e458eda.984cd","order":3,"width":0,"height":0,"passthru":false,"label":"Shutdown","color":"","bgcolor":"","icon":"fa-power-off","payload":"now","payloadType":"str","topic":"","x":223,"y":2060,"wires":[["5a69b142.f96b6"]]},{"id":"f2bdbc36.5644d","type":"ui_toast","z":"a564595f.642818","position":"top right","displayTime":"3","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"","name":"","x":679,"y":2054,"wires":[]},{"id":"510190df.5876c","type":"function","z":"a564595f.642818","name":"clear email address","func":"//prevent excessive cloud logs\nmsg.payload = '';\nreturn msg;","outputs":1,"noerr":0,"x":544.5,"y":942,"wires":[["1dc3fc9e.e1f193"]]},{"id":"d656e52b.f2a508","type":"delay","z":"a564595f.642818","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":650.5,"y":852,"wires":[["510190df.5876c"]]},{"id":"13f0085a.0d5178","type":"exec","z":"a564595f.642818","command":"wget -O /home/pi/flow.json https://raw.githubusercontent.com/baronbrew/TILTpi/master/flow.json","addpay":false,"append":"","useSpawn":"true","timer":"","oldrc":false,"name":"Download Update from GitHub","x":363,"y":1991,"wires":[[],[],["ef8b11d3.ed055"]]},{"id":"94e4a0ea.aeb8","type":"ui_button","z":"a564595f.642818","name":"Update App","group":"c8854cd2.f1773","order":1,"width":0,"height":0,"passthru":false,"label":"Update App (flow)","color":"","bgcolor":"","icon":"","payload":"https://raw.githubusercontent.com/baronbrew/TILTpi/master/flow.json","payloadType":"str","topic":"","x":112,"y":1993,"wires":[["13f0085a.0d5178"]]},{"id":"ef8b11d3.ed055","type":"function","z":"a564595f.642818","name":"Check Success","func":"if (msg.payload.code === 0){\n    return msg;\n}\n","outputs":1,"noerr":0,"x":647.5,"y":1996,"wires":[["b0fab2cd.d77d4"]]},{"id":"b0fab2cd.d77d4","type":"exec","z":"a564595f.642818","command":"curl -X POST http://localhost:1880/flows -H \"Content-Type: application/json\" -H \"Node-RED-Deployment-Type: nodes\" --data \"@/home/pi/flow.json\"","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"Update App","x":873,"y":1996,"wires":[[],[],[]]},{"id":"88f0f33d.110ab","type":"function","z":"a564595f.642818","name":"Set Uncal Calibration Array","func":"var color = flow.get('colordropdownSelect')||\"\";\nvar uncalArray = msg.payload.split(\",\");\nflow.set('uncalSGpoints-' + color,uncalArray);","outputs":1,"noerr":0,"x":2389.5,"y":1163,"wires":[[]]},{"id":"b36a946.3813e68","type":"function","z":"a564595f.642818","name":"Set Actual Calibration Array","func":"var color = flow.get('colordropdownSelect')||\"\";\nvar uncalArray = msg.payload.split(\",\");\nflow.set('actualSGpoints-' + color,uncalArray);","outputs":1,"noerr":0,"x":2388,"y":1223,"wires":[[]]},{"id":"640f9404.72d27c","type":"file in","z":"a564595f.642818","name":"cloud_log_color","filename":"","format":"utf8","sendError":false,"x":2580.5,"y":21,"wires":[["68ec71d.2dec29"]]},{"id":"3c8572c8.6a4b1e","type":"function","z":"a564595f.642818","name":"Set Up Tilt Pi","func":"flow.set('cloudURL',[\"https://script.google.com/macros/s/AKfycbwNXh6rEWoULd0vxWxDylG_PJwQwe0dn5hdtSkuC4k3D9AXBSA/exec\",true]);\nflow.set(msg.payload.Color + \"-Comment\",msg.payload.Comment);\nflow.set('logCloudDataCheck',true);\nflow.set('loggingInterval',15);\nflow.set(msg.payload.Color + \"-Beer\",msg.payload.Beer);\n//initialize local logging\nflow.set('logLocalDataCheck',true);\nflow.set('localloggingInterval',15);\nmsg2 = {};\nmsg2.payload = \"Time,Timepoint,Temp,SG,Beer,Color,Comment,RSSI,Uptime\";\n//post now\nflow.set('lastpost-' + msg.payload.Color,0);\nreturn [msg,msg2];","outputs":"2","noerr":0,"x":2686.5,"y":132,"wires":[["cdf7a5f1.e44358"],["da1dd72.c86df28"]]},{"id":"84c05058.79f0d","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"boot","payloadType":"str","repeat":"","crontab":"","once":true,"x":1974,"y":20,"wires":[["5006138a.18932c"]]},{"id":"7b880cec.674314","type":"exec","z":"a564595f.642818","command":"sudo rm","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"Remove Config File","x":3120,"y":27.5,"wires":[[],[],[]]},{"id":"d599e3c9.1ae09","type":"function","z":"a564595f.642818","name":"Custom CloudURL","func":"//get custom cloud URL if previously set\nvar color = flow.get('colordropdownSelect');\nif (msg.payload === true){\n       flow.set(\"cloudURL\",[\"https://script.google.com/macros/s/AKfycbwNXh6rEWoULd0vxWxDylG_PJwQwe0dn5hdtSkuC4k3D9AXBSA/exec\",true]);\n       msg.payload = flow.get(\"cloudURL\")[0];  \n}\nif (msg.payload === false){\n       flow.set(\"cloudURL\",[\"https://script.google.com/macros/s/AKfycbwNXh6rEWoULd0vxWxDylG_PJwQwe0dn5hdtSkuC4k3D9AXBSA/exec\",false]);\n       msg.payload = flow.get(\"cloudURL-\" + color)||\"Not set for \" + color;\n   }\nreturn msg;","outputs":1,"noerr":0,"x":967.0000381469727,"y":690.0000305175781,"wires":[["edb75c90.8414"]]},{"id":"ecffbfac.2fc53","type":"ui_toast","z":"a564595f.642818","position":"top right","displayTime":"3","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"","name":"Cloud URL Status","x":1577.5000076293945,"y":688.0000019073486,"wires":[]},{"id":"5b24e16f.7eab","type":"http in","z":"a564595f.642818","name":"","url":"/data/:color","method":"get","upload":false,"swaggerDoc":"","x":2065.75057220459,"y":552.57643699646,"wires":[["dc9ecd32.25037"]]},{"id":"bdb5caad.d3dba8","type":"file in","z":"a564595f.642818","name":"","filename":"","format":"utf8","chunk":false,"sendError":false,"x":2419.9690017700195,"y":557.607741355896,"wires":[["7b788221.059a2c"]]},{"id":"60f15c0d.04a0b4","type":"http response","z":"a564595f.642818","name":"","statusCode":"","headers":{"Access-Control-Allow-Origin":"*"},"x":2711.861789703369,"y":557.6458740234375,"wires":[]},{"id":"cdc2a491.47b908","type":"file in","z":"a564595f.642818","name":"Tilt Color","filename":"","format":"utf8","chunk":false,"sendError":false,"x":608,"y":276,"wires":[["543d2dd7.2fe974"]]},{"id":"b42102fe.e4abd","type":"function","z":"a564595f.642818","name":"Send Tilt Colors","func":"//initializes settings file for each color\nvar colors = [\"RED\",\"GREEN\",\"BLACK\",\"PURPLE\",\"ORANGE\",\"BLUE\",\"YELLOW\",\"PINK\"];\nvar arrayLength = colors.length;\nfor (var i = 0; i < arrayLength; i++) {\n    node.send({filename:\"/home/pi/\" + colors[i] + \".json\"});\n}\n","outputs":1,"noerr":0,"x":285,"y":279,"wires":[["2c73dfce.b79cc"]]},{"id":"543d2dd7.2fe974","type":"json","z":"a564595f.642818","name":"","pretty":false,"x":739,"y":276,"wires":[["a2f14292.5b0f3"]]},{"id":"a2f14292.5b0f3","type":"function","z":"a564595f.642818","name":"Restore Tilt Settings","func":"flow.set(msg.payload.Color + '-Beer',msg.payload.Beer);\nflow.set('actualSGpoints-' + msg.payload.Color,msg.payload.actualSGPoints);\nflow.set('uncalSGpoints-' + msg.payload.Color,msg.payload.unCalSGPoints);\nflow.set('actualTemppoints-' + msg.payload.Color,msg.payload.actualTempPoints);\nflow.set('uncalTemppoints-' + msg.payload.Color,msg.payload.unCalTempPoints);\n//node.warn(msg.payload.defaultCloudURL);\nflow.set('cloudURL-' + msg.payload.Color,msg.payload.customcloudURL);\nmsg.payload = \"on\";\nreturn msg;","outputs":"1","noerr":0,"x":914,"y":277,"wires":[["45fc2eae.52e02"]]},{"id":"be46656.b2ed298","type":"inject","z":"a564595f.642818","name":"Check Active Tilts","topic":"","payload":"options","payloadType":"flow","repeat":"4","crontab":"","once":false,"x":330,"y":460,"wires":[["423412c2.1b104c"]]},{"id":"d5439ed.a8afa6","type":"function","z":"a564595f.642818","name":"Update","func":"//only updates if custom Cloud URLs are in use\nvar check = flow.get('cloudURL')[1]||false;\nif (check === true){\n}else{\n    return msg;\n}\n","outputs":1,"noerr":0,"x":463.74999237060547,"y":683.9097318649292,"wires":[["b1836d66.f976c"]]},{"id":"2f84bf9f.847b6","type":"ui_toast","z":"a564595f.642818","position":"top right","displayTime":"5","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"","name":"Beer Name Status","x":4135.181529998779,"y":507.5486431121826,"wires":[]},{"id":"982240ba.f2f5","type":"inject","z":"a564595f.642818","name":"Clear Responses","topic":"","payload":"{\"result\":\"Waiting for next time point...\"}","payloadType":"json","repeat":"20","crontab":"","once":false,"x":3210.2008361816406,"y":566.4970045089722,"wires":[["df1ac3a9.c4472"]]},{"id":"e56d18b9.6cbc88","type":"file","z":"a564595f.642818","name":"Backup Tilt Specific Settings","filename":"","appendNewline":false,"createDir":false,"overwriteFile":"true","x":1429.0565185546875,"y":20,"wires":[]},{"id":"dc9ecd32.25037","type":"function","z":"a564595f.642818","name":"set filename","func":"if (msg.req.params.color === undefined){\n    msg.req.params.color = \"global\";\n}\nmsg.filename = \"/home/pi/\" + msg.req.params.color;\nreturn msg;","outputs":1,"noerr":0,"x":2255.3934783935547,"y":555.4592838287354,"wires":[["bdb5caad.d3dba8"]]},{"id":"6a77b965.400cc8","type":"delay","z":"a564595f.642818","name":"","pauseType":"queue","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"15","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":1180.746826171875,"y":32.618064880371094,"wires":[["c6fd016d.ab4a7","e56d18b9.6cbc88"]]},{"id":"7b788221.059a2c","type":"json","z":"a564595f.642818","name":"","pretty":false,"x":2558.406379699707,"y":557.3056106567383,"wires":[["60f15c0d.04a0b4"]]},{"id":"423412c2.1b104c","type":"function","z":"a564595f.642818","name":"Set options","func":"//set default dropdown item if undefined\nmsg.options = msg.payload;\nmsg.payload = flow.get('colordropdownSelect')||msg.options[0];\nreturn msg;","outputs":1,"noerr":0,"x":570,"y":460,"wires":[["93d9202c.d9c1e","b418ce11.8981a"]]},{"id":"f0097da4.edc54","type":"function","z":"a564595f.642818","name":"set Actual Temp Value","func":"var value = Number(msg.payload);\nflow.set('actualTemppoint',value.toFixed(1));\nmsg.payload = flow.get('colordropdownSelect');\nreturn msg;","outputs":1,"noerr":0,"x":1400,"y":1340,"wires":[["a9cf2c6b.4d7f9"]]},{"id":"a9cf2c6b.4d7f9","type":"function","z":"a564595f.642818","name":"Add Temp Cal Point","func":"var color = msg.payload;\nvar uncalTempcalPoint = flow.get('uncalTemppoint')||0;\nvar actualTempcalPoint = flow.get('actualTemppoint')||0;\nvar uncalpointsArray = flow.get('uncalTemppoints-' + color)||[];\nvar actualpointsArray = flow.get('actualTemppoints-' + color)||[];\nuncalpointsArray.push(uncalTempcalPoint);\nuncalpointsArray.sort(function(a, b){return a-b;});\nflow.set('uncalTemppoints-' + color,uncalpointsArray);\nactualpointsArray.push(actualTempcalPoint);\nactualpointsArray.sort(function(a, b){return a-b;});\nflow.set('actualTemppoints-' + color,actualpointsArray);\nvar msg1 = {payload:uncalpointsArray.toString()};\nvar msg2 = {payload:actualpointsArray.toString()};\nreturn [msg1, msg2];","outputs":"2","noerr":0,"x":1714.5,"y":1346,"wires":[["10bda9c0.3dcf66"],["d521fc1b.3653a"]]},{"id":"17e6c4c8.0d7e1b","type":"ui_button","z":"a564595f.642818","name":"","group":"c12bcb12.dbd0d8","order":5,"width":0,"height":0,"passthru":false,"label":"Clear Calibration","color":"","bgcolor":"","icon":"","payload":"colordropdownSelect","payloadType":"flow","topic":"","x":1472.5,"y":1466,"wires":[["721c929.10edb6c"]]},{"id":"721c929.10edb6c","type":"function","z":"a564595f.642818","name":"clear calibration","func":"var color = msg.payload;\nvar uncalpointsArray = flow.set('uncalTemppoints-' + color,[]);\nvar actualpointsArray = flow.set('actualTemppoints-' + color,[]);\nmsg.payload = [];\nreturn msg;","outputs":1,"noerr":0,"x":1684.5,"y":1467,"wires":[["10bda9c0.3dcf66","d521fc1b.3653a"]]},{"id":"5933654f.572e0c","type":"function","z":"a564595f.642818","name":"update display","func":"var color = flow.get('colordropdownSelect')||\"\";\nvar uncalpointsArray = flow.get('uncalTemppoints-' + color)||[];\nvar actualpointsArray = flow.get('actualTemppoints-' + color)||[];\nvar msg1 = {payload:uncalpointsArray.toString()};\nvar msg2 = {payload:actualpointsArray.toString()};\nreturn [msg1, msg2];","outputs":"2","noerr":0,"x":1483.5,"y":1403,"wires":[["10bda9c0.3dcf66"],["d521fc1b.3653a"]]},{"id":"4b7531fb.46829","type":"ui_text_input","z":"a564595f.642818","name":"","label":"Actual [use RETURN to set]","group":"c12bcb12.dbd0d8","order":2,"width":0,"height":0,"passthru":true,"mode":"text","delay":"0","topic":"","x":1089,"y":1337,"wires":[["f0097da4.edc54"]]},{"id":"10bda9c0.3dcf66","type":"ui_text_input","z":"a564595f.642818","name":"","label":"Uncalibrated Points [use RETURN to set]","group":"c12bcb12.dbd0d8","order":3,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"","x":2086,"y":1386,"wires":[["a5ca25c7.fd8c98"]]},{"id":"d521fc1b.3653a","type":"ui_text_input","z":"a564595f.642818","name":"","label":"Actual Points [use RETURN to set]","group":"c12bcb12.dbd0d8","order":4,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"","x":2078,"y":1453,"wires":[["19ca9195.29599e"]]},{"id":"a5ca25c7.fd8c98","type":"function","z":"a564595f.642818","name":"Set Uncal Calibration Array","func":"var color = flow.get('colordropdownSelect')||\"\";\nvar uncalArray = msg.payload.split(\",\");\nflow.set('uncalTemppoints-' + color,uncalArray);","outputs":1,"noerr":0,"x":2389.5,"y":1383,"wires":[[]]},{"id":"19ca9195.29599e","type":"function","z":"a564595f.642818","name":"Set Actual Calibration Array","func":"var color = flow.get('colordropdownSelect')||\"\";\nvar uncalArray = msg.payload.split(\",\");\nflow.set('actualTemppoints-' + color,uncalArray);","outputs":1,"noerr":0,"x":2388,"y":1443,"wires":[[]]},{"id":"d6de2020.56974","type":"function","z":"a564595f.642818","name":"Get Current Temp","func":"var options = flow.get('options')||[];\nvar color = msg.payload;\nvar displayNumber = options.indexOf(color) + 1;\nmsg.payload = flow.get(\"storage-\" + displayNumber.toString());\nif (msg.payload !== undefined){\nmsg.payload = msg.payload.displayuncalTemp;\nreturn msg;\n}","outputs":1,"noerr":0,"x":1350,"y":900,"wires":[["854dec23.fee5f","67b168fa.e90078"]]},{"id":"854dec23.fee5f","type":"ui_text","z":"a564595f.642818","group":"c12bcb12.dbd0d8","order":1,"width":0,"height":0,"name":"","label":"Uncal. Temp.","format":"{{msg.payload | number:1}}","layout":"row-spread","x":1610,"y":900,"wires":[]},{"id":"67b168fa.e90078","type":"function","z":"a564595f.642818","name":"set Uncal Temp Value","func":"flow.set('uncalTemppoint',Number(msg.payload).toFixed(1));","outputs":1,"noerr":0,"x":1840,"y":940,"wires":[[]]},{"id":"15afce7c.5604d2","type":"function","z":"a564595f.642818","name":"Change Ferm Units","func":"if (msg.payload === \"sg\"){\nflow.set('fermdisplayUnits',\"\");\nnode.send([{'payload':'sg'},{'payload':false},{'payload':false}]);\n}\nif (msg.payload === \"plato\"){\nflow.set('fermdisplayUnits',\"°P\");\nnode.send([{'payload':false},{'payload':'plato'},{'payload':false}]);\n}\nif (msg.payload === \"brix\"){\nflow.set('fermdisplayUnits',\"°Bx\");\nnode.send([{'payload':false},{'payload':false},{'payload':'brix'}]);\n}","outputs":"3","noerr":0,"x":2204,"y":1803.0002098083496,"wires":[["d66a9036.7565"],["88a56bea.b66268"],["3c18b104.de8f2e"]]},{"id":"88a56bea.b66268","type":"ui_switch","z":"a564595f.642818","name":"","label":"Plato","group":"b0619070.ac95d","order":4,"width":0,"height":0,"passthru":false,"decouple":"false","topic":"","style":"","onvalue":"plato","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":2025.000690460205,"y":1892.5001878738403,"wires":[["15afce7c.5604d2"]]},{"id":"3c18b104.de8f2e","type":"ui_switch","z":"a564595f.642818","name":"","label":"Brix","group":"b0619070.ac95d","order":5,"width":0,"height":0,"passthru":false,"decouple":"false","topic":"","style":"","onvalue":"brix","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":2029.7503128051758,"y":1979.7501392364502,"wires":[["15afce7c.5604d2"]]},{"id":"2bb152f1.d1cbee","type":"inject","z":"a564595f.642818","name":"Local Logging Interval","topic":"","payload":"localloggingInterval","payloadType":"flow","repeat":"15","crontab":"","once":false,"x":1116.7953567504883,"y":960.0105171203613,"wires":[["7b1370e2.6e8c9"]]},{"id":"c0f36d.ab686c9","type":"file in","z":"a564595f.642818","name":"","filename":"/home/pi/global.json","format":"utf8","chunk":false,"sendError":false,"x":253,"y":336,"wires":[["aa94ced8.4cb66"]]},{"id":"326af4b8.42494c","type":"json","z":"a564595f.642818","name":"","pretty":false,"x":581,"y":338,"wires":[["59df1198.a2519"]]},{"id":"59df1198.a2519","type":"function","z":"a564595f.642818","name":"Restore Global","func":"flow.set('logCloudDataCheck',msg.payload.logCloudDataCheck);\nnode.send([null,{'payload':msg.payload.logCloudDataCheck},null]);\nflow.set('logLocalDataCheck',msg.payload.logLocalDataCheck);\nnode.send([null,null,{'payload':msg.payload.logLocalDataCheck}]);\nflow.set('localloggingInterval',msg.payload.localloggingInterval);\nflow.set('loggingInterval',msg.payload.loggingInterval);\nflow.set('cloudURL',msg.payload.defaultcloudURL);\nnode.send([{'payload':msg.payload.defaultcloudURL[1]},null,null]);\nflow.set('fermdisplayUnits',msg.payload.fermunits);\nflow.set('displayUnits',msg.payload.tempunits);\nflow.set('minRSSI',msg.payload.minRSSI);\n//return msg;","outputs":"3","noerr":0,"x":728,"y":338,"wires":[["b1836d66.f976c"],["dc8e0ec5.550d"],["c7601414.73cf68"]]},{"id":"c6fd016d.ab4a7","type":"file","z":"a564595f.642818","name":"Back Up Global Settings","filename":"/home/pi/global.json","appendNewline":false,"createDir":false,"overwriteFile":"true","x":1418.239501953125,"y":68.01043319702148,"wires":[]},{"id":"dc0ffeac.632b6","type":"http in","z":"a564595f.642818","name":"","url":"/data/","method":"get","upload":false,"swaggerDoc":"","x":2052.6841583251953,"y":618.4548597335815,"wires":[["dc9ecd32.25037"]]},{"id":"d66a9036.7565","type":"ui_switch","z":"a564595f.642818","name":"","label":"SG 15°C/59°F (default)","group":"b0619070.ac95d","order":3,"width":0,"height":0,"passthru":false,"decouple":"false","topic":"","style":"","onvalue":"sg","onvalueType":"str","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":2132.688522338867,"y":1702.2629280090332,"wires":[["15afce7c.5604d2"]]},{"id":"8951ba9f.798ae8","type":"ui_switch","z":"a564595f.642818","name":"","label":"Fahrenheit (default)","group":"b0619070.ac95d","order":1,"width":0,"height":0,"passthru":false,"decouple":"false","topic":"","style":"","onvalue":"°F","onvalueType":"str","onicon":"","oncolor":"","offvalue":"°C","offvalueType":"str","officon":"","offcolor":"","x":1920.3509521484375,"y":1596.010766029358,"wires":[["b58e5805.5d5928"]]},{"id":"681c2428.1c3a5c","type":"ui_template","z":"a564595f.642818","group":"82607108.c5be8","name":"Download Log Button","order":4,"width":0,"height":0,"format":"<script>\nfunction download(){\n        window.location='/log.csv';\n    }\n</script>\n\n<button onclick=\"download();\" class=\"md-raised md-button md-ink-ripple\" type=\"button\">Download Log</button>\n\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":2703.5,"y":338,"wires":[[]]},{"id":"ba245bd3.026ab8","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"displayUnits","payloadType":"str","repeat":"","crontab":"","once":true,"x":1389.5208740234375,"y":1644.8509521484375,"wires":[["cd091791.668ca8"]]},{"id":"69cfcfd8.b2018","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"fermdisplayUnits","payloadType":"str","repeat":"","crontab":"","once":true,"x":1462.7951202392578,"y":1916.6775169372559,"wires":[["e0d9c78e.ee0138"]]},{"id":"cd091791.668ca8","type":"delay","z":"a564595f.642818","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1588.3023681640625,"y":1644.0592041015625,"wires":[["fd49eb70.32ff38"]]},{"id":"e0d9c78e.ee0138","type":"delay","z":"a564595f.642818","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1644.2396240234375,"y":1916.6771240234375,"wires":[["3c9890f9.04d5f"]]},{"id":"3c9890f9.04d5f","type":"function","z":"a564595f.642818","name":"filter","func":"msg.payload = flow.get(msg.payload);\nif (msg.payload === \"\"){\n    msg.payload = \"sg\";\n}\nif (msg.payload === \"°P\"){\n    msg.payload = \"plato\";\n}\nif (msg.payload === \"°Bx\"){\n    msg.payload = \"brix\";\n}\nreturn msg;","outputs":1,"noerr":0,"x":1839.6248779296875,"y":1911.4583740234375,"wires":[["88a56bea.b66268","d66a9036.7565","3c18b104.de8f2e"]]},{"id":"b90d01ad.44d08","type":"function","z":"a564595f.642818","name":"Changed?","func":"var previous = context.get('watchedData-' + msg.payload.Color)||\"\";\n//changes in settings/measurements below trigger a backup\nvar current = \nmsg.payload.Beer + \nmsg.payload.SG + \nmsg.payload.Temp + \nmsg.payload.unCalSGPoints +\nmsg.payload.actualSGPoints +\nmsg.payload.actualTempPoints +\nmsg.payload.unCalTempPoints +\nmsg.payload.fermunits +\nmsg.payload.tempunits +\nmsg.payload.defaultcloudURL +\nmsg.payload.customcloudURL +\nmsg.payload.logCloudDataCheck +\nmsg.payload.logLocalDataCheck +\nmsg.payload.localloggingInterval +\nmsg.payload.loggingInterval +\nmsg.payload.minRSSI;\nif (current !== previous){\n    //node.warn(current);\n    //node.warn(previous);\n    context.set('watchedData-' + msg.payload.Color,current);\n    return msg;\n}","outputs":1,"noerr":0,"x":974.8472900390625,"y":35.68404006958008,"wires":[["6a77b965.400cc8"]]},{"id":"a4d1964e.cb4f78","type":"ui_slider","z":"a564595f.642818","name":"RSSI Filter","label":"RSSI Filter","group":"2f8a7619.951f3a","order":3,"width":0,"height":0,"passthru":true,"topic":"","min":"-105","max":"-35","step":1,"x":290,"y":2200,"wires":[["99ac3bca.7a1868"]]},{"id":"99ac3bca.7a1868","type":"change","z":"a564595f.642818","name":"","rules":[{"t":"set","p":"minRSSI","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":2200,"wires":[["3505363e.8a498a"]]},{"id":"3505363e.8a498a","type":"ui_text","z":"a564595f.642818","group":"2f8a7619.951f3a","order":4,"width":0,"height":0,"name":"","label":"Minimum RSSI in dBm","format":"{{msg.payload}}","layout":"row-spread","x":685.017333984375,"y":2212.232798576355,"wires":[]},{"id":"9b32b69b.089738","type":"function","z":"a564595f.642818","name":"changed?","func":"var previous = context.get('data-' + msg.topic)||[];\nvar currentArray = msg.payload.split(\",\");\nvar current = currentArray[2] + currentArray[3] + currentArray[4] + currentArray[6];\nvar time = context.get('time-' + msg.topic)||Date.now();\n//node.warn(current);\n//node.warn(Date.now() - time);\nif (previous !== current || Date.now() - time > 900000 ){\n    context.set('time-' + msg.topic,Date.now());\n    context.set('data-' + msg.topic,current);\n    //only clear comment if cloud logging not checked\n    if (!flow.get('logCloudDataCheck')){\n    flow.set(msg.topic + \"-Comment\",\"\");\n    }\n    return msg;\n}\n\n","outputs":1,"noerr":0,"x":2940.96915435791,"y":318.01389932632446,"wires":[["2f5685a6.76e34a"]]},{"id":"c908bac9.7cfc38","type":"watch","z":"a564595f.642818","name":"watch for USB drive","files":"/dev","recursive":"","x":95,"y":2370.0626363754272,"wires":[["bc55cff6.44c8d"]]},{"id":"bc55cff6.44c8d","type":"switch","z":"a564595f.642818","name":"get device ID","property":"payload","propertyType":"msg","rules":[{"t":"regex","v":"/dev/sd.","vt":"str","case":false}],"checkall":"false","outputs":1,"x":286.52423095703125,"y":2312.2256088256836,"wires":[["27555620.4af91a"]]},{"id":"32967fe2.78f","type":"exec","z":"a564595f.642818","command":"","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"mount usb drive","x":815.6322784423828,"y":2373.7571334838867,"wires":[[],["eef04124.0438f"],["b2e261f0.d1861"]]},{"id":"c83e4803.8db528","type":"exec","z":"a564595f.642818","command":"sudo umount /mnt/usb","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":1413.8790435791016,"y":2369.706090927124,"wires":[[],["eef04124.0438f"],["801bdfa2.e1664"]]},{"id":"c80707fb.c9ff98","type":"function","z":"a564595f.642818","name":"setup mount","func":"var device = msg.payload;\nmsg.payload = \"sudo mount -o uid=pi,gid=pi \" + device.substring(0,8) + \"1 /mnt/usb\";\nreturn msg;","outputs":1,"noerr":0,"x":697.4063987731934,"y":2308.469259262085,"wires":[["32967fe2.78f"]]},{"id":"d9e2bf6d.bccc7","type":"catch","z":"a564595f.642818","name":"No URL Provided Errors","scope":["2836e0e1.4ea9c"],"x":3254.517433166504,"y":184.9272117614746,"wires":[["ffdc5060.780ca"]]},{"id":"c10d9b6d.0b1098","type":"exec","z":"a564595f.642818","command":"sudo cp /home/pi/log.csv /mnt/usb","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":1113.684310913086,"y":2369.6776008605957,"wires":[[],["eef04124.0438f"],["e9bea5b5.0883e8"]]},{"id":"b2e261f0.d1861","type":"function","z":"a564595f.642818","name":"Check Success","func":"if (msg.payload.code === 0){\n    return msg;\n}\n","outputs":1,"noerr":0,"x":926.4617309570312,"y":2474.011266708374,"wires":[["c10d9b6d.0b1098"]]},{"id":"e9bea5b5.0883e8","type":"function","z":"a564595f.642818","name":"Check Success","func":"if (msg.payload.code === 0){\n    return msg;\n}\n","outputs":1,"noerr":0,"x":1306.1284408569336,"y":2449.010994911194,"wires":[["c83e4803.8db528"]]},{"id":"11f93581.985a8a","type":"function","z":"a564595f.642818","name":"Configure Mount Point","func":"node.send({'payload':'sudo chown -R pi:pi /mnt/usb'});\nnode.send({'payload':'sudo chmod -R 775 /mnt/usb'});\nnode.send({'payload':'sudo setfacl -Rdm g:pi:rwx /mnt/usb'});\nnode.send({'payload':'sudo setfacl -Rm g:pi:rwx /mnt/usb'});","outputs":1,"noerr":0,"x":580.5173492431641,"y":2623.125386238098,"wires":[["1c2730c3.d43b4f"]]},{"id":"34b160f1.5b1ee","type":"exec","z":"a564595f.642818","command":"sudo mkdir /mnt/usb","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":274.52085876464844,"y":2441.4202003479004,"wires":[[],[],["b69d2560.934d18"]]},{"id":"b69d2560.934d18","type":"function","z":"a564595f.642818","name":"Check Success","func":"if (msg.payload.code === 0){\n    return msg;\n}\n","outputs":1,"noerr":0,"x":424.01747131347656,"y":2535.12242603302,"wires":[["11f93581.985a8a"]]},{"id":"39a9e291.1fe1fe","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"Mount Point","payloadType":"str","repeat":"","crontab":"","once":true,"x":75,"y":2439.0731925964355,"wires":[["34b160f1.5b1ee"]]},{"id":"235307e4.347e18","type":"exec","z":"a564595f.642818","command":"","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":929.0173301696777,"y":2619.1218185424805,"wires":[[],[],[]]},{"id":"1c2730c3.d43b4f","type":"delay","z":"a564595f.642818","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":778.5139389038086,"y":2620.732711791992,"wires":[["235307e4.347e18"]]},{"id":"e37566b2.2c78f8","type":"catch","z":"a564595f.642818","name":"","scope":["c0f36d.ab686c9"],"x":140,"y":400,"wires":[["410f235c.c1f2ac"]]},{"id":"410f235c.c1f2ac","type":"change","z":"a564595f.642818","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":400,"wires":[["45fc2eae.52e02"]]},{"id":"6308b03a.25d4a","type":"catch","z":"a564595f.642818","name":"","scope":["c0f36d.ab686c9"],"x":60,"y":2180,"wires":[["6ccc73b5.86205c"]]},{"id":"6ccc73b5.86205c","type":"change","z":"a564595f.642818","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"-105","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":162.5,"y":2255,"wires":[["a4d1964e.cb4f78"]]},{"id":"34ef6654.47916a","type":"ui_toast","z":"a564595f.642818","position":"top right","displayTime":"3","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"","name":"","x":3627.999954223633,"y":206.00000953674316,"wires":[]},{"id":"ffdc5060.780ca","type":"template","z":"a564595f.642818","name":"Alert","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Alert: {{error.message}}","output":"str","x":3440.6319465637207,"y":196.31249809265137,"wires":[["34ef6654.47916a"]]},{"id":"d504d607.384f48","type":"function","z":"a564595f.642818","name":"RSSI","func":"var minRSSI = flow.get('minRSSI');\nif (msg.payload.rssi >= minRSSI){\n return msg;\n}","outputs":1,"noerr":0,"x":622.1944885253906,"y":128.69444465637207,"wires":[["e5652ef0.acaaf"]]},{"id":"eef04124.0438f","type":"ui_text","z":"a564595f.642818","group":"82607108.c5be8","order":5,"width":0,"height":0,"name":"","label":"Download via USB","format":"{{msg.payload}}","layout":"col-center","x":1870.2500305175781,"y":2316.5000343322754,"wires":[]},{"id":"27555620.4af91a","type":"delay","z":"a564595f.642818","name":"send once","pauseType":"rate","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":498.5,"y":2299,"wires":[["c80707fb.c9ff98","113b924.25cc06e"]]},{"id":"85296978.d8a2d8","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"Insert Windows (FAT32, MBR) formatted USB drive.","payloadType":"str","repeat":"30","crontab":"","once":true,"x":1394.375,"y":2225,"wires":[["eef04124.0438f"]]},{"id":"801bdfa2.e1664","type":"function","z":"a564595f.642818","name":"Check Success","func":"if (msg.payload.code === 0){\n    msg.payload = \"Success, remove USB drive.\";\n    return msg;\n}\n","outputs":1,"noerr":0,"x":1646.2500228881836,"y":2381.2500343322754,"wires":[["eef04124.0438f"]]},{"id":"113b924.25cc06e","type":"function","z":"a564595f.642818","name":"Detect USB","func":"msg.payload = msg.payload.substring(0,8) + \"1 detected\";\nreturn msg;","outputs":1,"noerr":0,"x":953.1250152587891,"y":2263.7500343322754,"wires":[["eef04124.0438f"]]},{"id":"68ec71d.2dec29","type":"json","z":"a564595f.642818","name":"","pretty":false,"x":2727.5,"y":20,"wires":[["3c8572c8.6a4b1e","dd8b62f0.c52ca"]]},{"id":"780b4fd0.c274b","type":"function","z":"a564595f.642818","name":"Send IP Addr","func":"var ipAddress = flow.get('ipaddress');\nflow.set(msg.payload.Color + \"-Comment\",ipAddress);\nflow.set('lastpost-' + msg.payload.Color,0);","outputs":1,"noerr":0,"x":3013,"y":112,"wires":[[]]},{"id":"cdf7a5f1.e44358","type":"delay","z":"a564595f.642818","name":"","pauseType":"delay","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"5","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":2844.5,"y":112,"wires":[["780b4fd0.c274b"]]},{"id":"51590585.1fbfec","type":"catch","z":"a564595f.642818","name":"","scope":["cdc2a491.47b908"],"x":233,"y":188,"wires":[[]]},{"id":"fd48b85c.2f1918","type":"catch","z":"a564595f.642818","name":"","scope":["640f9404.72d27c"],"x":3284,"y":48,"wires":[[]]},{"id":"5006138a.18932c","type":"function","z":"a564595f.642818","name":"Send Tilt Colors","func":"//check if system starting up and Tilts are in range.\nif (msg.payload === \"boot\"){\ncontext.set('startup',true);\n}else{\ncontext.set('tilt',true);\n}\n//contine startup if Tilt detected\nif (context.get('startup') && context.get('tilt')){\n//initializes settings file for each color\nvar colors = [\"red\",\"green\",\"black\",\"purple\",\"orange\",\"blue\",\"yellow\",\"pink\"];\nvar arrayLength = colors.length;\nfor (var i = 0; i < arrayLength; i++) {\n    node.send({filename:\"/boot/cloud_log_\" + colors[i] + \".json\"});\n}\ncontext.set('startup',false);\n}","outputs":1,"noerr":0,"x":2189,"y":20,"wires":[["a81ac973.c7f1a8"]]},{"id":"a81ac973.c7f1a8","type":"delay","z":"a564595f.642818","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"5","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":2400,"y":20,"wires":[["640f9404.72d27c"]]},{"id":"2c73dfce.b79cc","type":"delay","z":"a564595f.642818","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":458,"y":275,"wires":[["cdc2a491.47b908"]]},{"id":"d5884cdc.50b47","type":"debug","z":"a564595f.642818","name":"","active":false,"console":"false","complete":"false","x":3439,"y":88,"wires":[]},{"id":"aa94ced8.4cb66","type":"delay","z":"a564595f.642818","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":443,"y":337,"wires":[["326af4b8.42494c"]]},{"id":"dd8b62f0.c52ca","type":"change","z":"a564595f.642818","name":"","rules":[{"t":"move","p":"filename","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":2907.5,"y":22,"wires":[["7b880cec.674314"]]},{"id":"fd49eb70.32ff38","type":"function","z":"a564595f.642818","name":"filter","func":"msg.payload = flow.get(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":1732,"y":1644,"wires":[["5312bf4.09fd44","8951ba9f.798ae8"]]},{"id":"e5905320.33efc","type":"exec","z":"a564595f.642818","command":"date '+%F %T'","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":278.25,"y":1803.5000267028809,"wires":[["437432fd.79dbbc"],[],[]]},{"id":"437432fd.79dbbc","type":"ui_text_input","z":"a564595f.642818","name":"","label":"System Time [use RETURN to set manually]","group":"5ca7d250.c3938c","order":3,"width":0,"height":0,"passthru":false,"mode":"text","delay":"0","topic":"","x":574.0000076293945,"y":1809.2500267028809,"wires":[["f8a4aa49.743c88"]]},{"id":"f8a4aa49.743c88","type":"exec","z":"a564595f.642818","command":"sudo date -s '","addpay":true,"append":"'","useSpawn":"false","timer":"","oldrc":false,"name":"","x":880,"y":1840,"wires":[["673f8112.35a61"],["8ee3b7e3.1833a8"],[]]},{"id":"669c32ed.8030ac","type":"inject","z":"a564595f.642818","name":"","topic":"","payload":"","payloadType":"date","repeat":"60","crontab":"","once":true,"x":97.5,"y":1793.7500267028809,"wires":[["e5905320.33efc"]]},{"id":"673f8112.35a61","type":"function","z":"a564595f.642818","name":"topic","func":"msg.topic = \"System Time Updated\";\nreturn msg;","outputs":1,"noerr":0,"x":1050,"y":1800,"wires":[["8ee3b7e3.1833a8"]]},{"id":"375008fe.27a988","type":"function","z":"a564595f.642818","name":"create URL","func":"var ipAddress = msg.payload.ipv4;\nmsg.payload = \"http://\" + ipAddress.trim() + \":1880/ui\"\nflow.set('ipaddress',msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":630,"y":1880,"wires":[["a4a5a7ed.d59958"]]},{"id":"deb9c4fc.20c098","type":"csv","z":"a564595f.642818","name":"","sep":" ","hdrin":"","hdrout":"","multi":"one","ret":"\\n","temp":"ipv4,ipv6","x":470,"y":1880,"wires":[["375008fe.27a988"]]},{"id":"a6b43763.a12aa8","type":"file","z":"a564595f.642818","name":"","filename":"/home/pi/timezone","appendNewline":false,"createDir":false,"overwriteFile":"true","x":1250,"y":1560,"wires":[]},{"id":"90a37ef8.2317d","type":"function","z":"a564595f.642818","name":"Set Timezone","func":"flow.set(\"tz\",\"/usr/share/zoneinfo/\" + msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":1260,"y":1600,"wires":[[]]},{"id":"10d7ccc5.8a1033","type":"exec","z":"a564595f.642818","command":"sudo cp -f /home/pi/timezone /etc/timezone","addpay":false,"append":"","useSpawn":"","timer":"","oldrc":false,"name":"copy timezone file (for jessie)","x":1080,"y":1700,"wires":[[],[],["be6c33c3.62e8a"]]}]
Created 9 years, 4 months ago
Updated 8 years, 8 months ago
  • catch (x5)
  • change (x24)
  • csv (x1)
  • delay (x11)
  • exec (x16)
  • file (x5)
  • file in (x6)
  • function (x70)
  • http in (x3)
  • http request (x1)
  • http response (x2)
  • inject (x23)
  • json (x5)
  • split (x1)
  • switch (x4)
  • template (x1)
  • watch (x1)
  • scanBeacon (x1)
  • ui_base (x1)
  • ui_button (x7)
  • ui_dropdown (x3)
  • ui_group (x19)
  • ui_link (x1)
  • ui_slider (x3)
  • ui_switch (x8)
  • ui_tab (x4)
  • ui_template (x10)
  • ui_text (x9)
  • ui_text_input (x11)
  • ui_toast (x8)
  • Tilt
  • TiltPi
  • brew
