Simulator Time Tracking
This is a node-red based flow that allows you to track simulator (or anything actually) usage based on a list of instructors and selected sim time. Once the instructor and time is selected, the timer starts a countdown. Within a specificed time the system can alert you via pushbullet (free) or SMS (via Twillo (paid)) that the sim session is over or is running late. Includes the ability to pause the session for a break or a maintenance issue without affecting the remaining simulator time available.
Once the session is completed, all of the session information is written to a flat file for storage.
- Download and install steelseries gauges
- Copy the JSON flow to your clipboard and then import into Node-RED using the Import From > Clipboard (Ctrl-I) menu option
- Make necessry changes for steelseries directory locations
- Make necessry changes to your log file locations in the "Session Log File" nodes. Currently ~root/.node-red
Requirements
The only real requirement is the steelseries gauges by Gerrit Grunwald & Mark Crossley. If you want notifications, then you will also need the PushBullet or Twillio Node-Red nodes.
For the steelseries gaugues, download them and untar them at a location that your node-red can access (typically ~user/.node-red/static) and then point to that directory in your widgets. For example this is the js for the "Sim Gauge Tech View" gauge:
<script src="/myjs/steelseries/tween-min.js"></script>
<script src="/myjs/steelseries/steelseries-min.js"></script>
<script>
var radial4;
(function(scope){
scope.$watch('msg', function(msg) {
if (typeof(msg.value) != "undefined") radial4.setValueAnimated(msg.value);
if (typeof(msg.threshold) != "undefined") radial4.setThreshold(msg.threshold);
if (typeof(msg.maxvalue) != "undefined")radial4.setMaxValue(msg.maxvalue);
if (typeof(msg.userLed) != "undefined") radial4.setUserLedOnOff(msg.userLed);
})(scope);
var sections = [steelseries.Section(-40, 5, 'rgba(220, 0, 0, 0.3)'),
steelseries.Section(5, 10, 'rgba(255, 255, 0, 0.5)'),
steelseries.Section(10, 240, 'rgba(0, 255, 0, 0.3)') ],
// Define one area
areas = [steelseries.Section(-40, 5, 'rgba(220, 0, 0, 0.3)')],
radial4 = new steelseries.Radial('canvasRadial4', {
gaugeType: steelseries.GaugeType.TYPE4,
section: sections,
//MaxValue: 240,
area: areas,
lcdDecimals: 0,
minValue: -30,
titleString: "Sim Time Remaining",
unitString: "Minutes",
threshold: 10,
thresholdRising: false,
userLedVisible: true,
userLed: true,
useOdometer: false,
lcdVisible: true,
trendVisible: false,
radial4.setFrameDesign(steelseries.FrameDesign.BLACK_METAL);
radial4.setBackgroundColor(steelseries.BackgroundColor.LIGHT_GRAY);
radial4.setValueAnimated(0);
radial4.setThreshold(10);
radial4.blinkUserLed(0);
</script>
<canvas id="canvasRadial4" width="401" height="401"></canvas>
# Screen Shots
In Use
We use a small 7" touchscreen powered by a Raspberry Pi to run the system:
TODO
- Add MySQL backen to track usage
- Add E-Mail reporting
Authors
- Richard J. Sears - [email protected] - The RS Technical Group, Inc.
This project is licensed under the MIT License - see the MIT License for details
Acknowledgments
- Gerrit Grunwald, Mark Crossley - Steel Series Gauges
- Node-RED Google Group for all the help with my questions!
- My amazing family that puts up with all of my coding projects!
[{"id":"ccf23d5e.abebd","type":"tab","label":"CE525 Time Control","disabled":false,"info":""},{"id":"7fdaf6a4.39c0e8","type":"ui_template","z":"ccf23d5e.abebd","group":"ec394520.8c13e8","name":"State buttons","order":1,"width":"6","height":"8","format":"<style>\ndiv.md-list-item-inner {\n padding: 0;\n}\nmd-menu {\n display: inline-grid;\n width: 100%;\n}\nbutton.md-button {\n border-radius: 5px !important;\n margin: 20px 0 !important;\n height: 50px;\n}\nbutton.md-button.running {\n background: red !important;\n}\nbutton.md-button.stopped {\n background: green !important;\n}\nbutton.md-button[disabled] {\n background: grey !important;\n cursor: not-allowed !important;\n}\n</style>\n\n<md-list-item>\n <md-menu>\n <md-button\n ng-disabled=\"msg.payload.CE525.Break || msg.payload.CE525.Maint || msg.payload.CE525.Start\"\n >\n {{msg.payload.CE525.Instructor ? \"Instructor: \" + msg.payload.CE525.Instructor : \"Select Instructor\"}}\n </md-button>\n <md-menu-content width=\"4\">\n <md-menu-item>\n <md-button\n ng-click=\"msg.payload.CE525.Instructor = 'Richard';\"\n >\n Richard\n </md-button>\n </md-menu-item>\n <md-menu-item>\n <md-button\n ng-click=\"msg.payload.CE525.Instructor = 'Ryan';\"\n >\n Ryan\n </md-button>\n </md-menu-item>\n <md-menu-item>\n <md-button\n ng-click=\"msg.payload.CE525.Instructor = 'Ted';\"\n >\n Ted\n </md-button>\n </md-menu-item>\n </md-menu-content>\n </md-menu>\n</md-list-item>\n\n<md-list-item>\n <md-menu>\n <md-button\n ng-disabled=\"msg.payload.CE525.Break || msg.payload.CE525.Maint || msg.payload.CE525.Start\">\n {{msg.payload.CE525.Session_Time ? \"Session Time: \" + msg.payload.CE525.Session_Time + \" hrs\" : \"Select Session Time\"}}\n </md-button>\n <md-menu-content width=\"4\">\n <md-menu-item>\n <md-button\n ng-click=\"msg.payload.CE525.Session_Time = 0.5;\"\n >\n 0.5 Hour\n </md-button>\n </md-menu-item>\n <md-menu-item>\n <md-button\n ng-click=\"msg.payload.CE525.Session_Time = 1.0;\"\n >\n 1.0 Hour\n </md-button>\n </md-menu-item>\n <md-menu-item>\n <md-button\n ng-click=\"msg.payload.CE525.Session_Time = 1.5;\"\n >\n 1.5 Hours\n </md-button>\n </md-menu-item>\n <md-menu-item>\n <md-button\n ng-click=\"msg.payload.CE525.Session_Time = 2.0;\"\n >\n 2.0 Hours\n </md-button>\n </md-menu-item>\n <md-menu-item>\n <md-button\n ng-click=\"msg.payload.CE525.Session_Time = 2.5;\"\n >\n 2.5 Hours\n </md-button>\n </md-menu-item>\n <md-menu-item>\n <md-button\n ng-click=\"msg.payload.CE525.Session_Time = 3.0;\"\n >\n 3.0 Hours\n </md-button>\n </md-menu-item>\n <md-menu-item>\n <md-button\n ng-click=\"msg.payload.CE525.Session_Time = 3.5;\"\n >\n 3.5 Hours\n </md-button>\n </md-menu-item>\n <md-menu-item>\n <md-button\n ng-click=\"msg.payload.CE525.Session_Time = 4.0;\"\n >\n 4.0 Hours\n </md-button>\n </md-menu-item>\n </md-menu-content>\n </md-menu>\n</md-list-item>\n\n<md-list-item>\n <md-menu>\n <md-button\n ng-class=\"msg.payload.CE525.Start ? 'running' : 'stopped'\"\n ng-disabled=\"!msg.payload.CE525.Instructor || !msg.payload.CE525.Session_Time || msg.payload.CE525.Break || msg.payload.CE525.Maint\"\n ng-click=\"\n msg.payload.CE525.Start = !msg.payload.CE525.Start;\n msg.event = 'CE525 ' + msg.payload.CE525.Instructor + ' (' + msg.payload.CE525.Session_Time + ' hrs) ' + (msg.payload.CE525.Start? 'started': 'stopped');\n msg.payload.CE525.Instructor = (msg.payload.CE525.Start? msg.payload.CE525.Instructor: null);\n msg.payload.CE525.Session_Time = (msg.payload.CE525.Start? msg.payload.CE525.Session_Time: 0);\n send(msg);\n \"\n >\n {{msg.payload.CE525.Start? 'Session Stop': 'Session Start'}}\n </md-button>\n </md-menu>\n</md-list-item>\n\n<md-list-item>\n <md-menu>\n <md-button\n ng-class=\"msg.payload.CE525.Break ? 'running' : 'stopped'\"\n ng-disabled=\"!msg.payload.CE525.Start || msg.payload.CE525.Maint\"\n ng-click=\"\n msg.payload.CE525.Break = !msg.payload.CE525.Break;\n msg.event = 'CE525 Break ' + (msg.payload.CE525.Break? 'started': 'ended');\n send(msg);\n \"\n >\n {{msg.payload.CE525.Break? 'Break Stop': 'Break Start'}}\n </md-button>\n </md-menu>\n</md-list-item>\n\n<md-list-item>\n <md-menu>\n <md-button\n ng-class=\"msg.payload.CE525.Maint ? 'running' : 'stopped'\"\n ng-disabled=\"!msg.payload.CE525.Start || msg.payload.CE525.Break\"\n ng-click=\"\n msg.payload.CE525.Maint = !msg.payload.CE525.Maint;\n msg.event = 'CE525 Maint ' + (msg.payload.CE525.Maint? 'started': 'ended');\n send(msg);\n \"\n >\n {{msg.payload.CE525.Maint? 'Maint Stop': 'Maint Start'}}\n </md-button>\n </md-menu>\n</md-list-item>\n","storeOutMessages":true,"fwdInMessages":false,"templateScope":"local","x":346.8571548461914,"y":85.85714149475098,"wires":[["7c4106f3.27cae8","dd85f860.025158","a6abecfc.d6bee"]]},{"id":"7c4106f3.27cae8","type":"debug","z":"ccf23d5e.abebd","name":"","active":false,"console":"false","complete":"false","x":627,"y":96,"wires":[]},{"id":"b7ea7274.dfb5e","type":"comment","z":"ccf23d5e.abebd","name":"Interactive Session buttons","info":"","x":115,"y":30,"wires":[]},{"id":"62b82d90.9ce6b4","type":"comment","z":"ccf23d5e.abebd","name":"Button Event logger","info":"","x":125,"y":124,"wires":[]},{"id":"dd85f860.025158","type":"function","z":"ccf23d5e.abebd","name":"State events","func":"// Get the event history or an empty array\nvar history = flow.get('CE525') || [];\nvar now = new Date().toLocaleString();\n//var now = Math.round(+new Date()/1000);\n\n// Add the new event to the head of the array\nhistory.unshift(now + '\\t' + msg.event);\nflow.set('CE525', history);\n\n// Return the array of events for displaying\nmsg.payload = history;\nreturn msg;","outputs":1,"noerr":0,"x":420,"y":171,"wires":[["e59fc29e.0ecbf"]]},{"id":"e59fc29e.0ecbf","type":"ui_template","z":"ccf23d5e.abebd","group":"16df6755.0155b9","name":"log table","order":3,"width":"6","height":"9","format":"<style>\nul.plain {\n list-style-type: none;\n padding-left: inherit;\n}\n</style>\n\n<ul class=\"plain\">\n <li ng-repeat=\"event in msg.payload\">\n {{event}}\n </li>\n</ul>","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":611,"y":173,"wires":[[]]},{"id":"35f0c04.85fc44","type":"inject","z":"ccf23d5e.abebd","name":"init states","topic":"","payload":"{\"CE525\":{\"Start\":false,\"Break\":false,\"Maint\":false}}","payloadType":"json","repeat":"","crontab":"","once":true,"x":121,"y":69,"wires":[["7fdaf6a4.39c0e8","2c5199d8.602086","54e883dd.d4b4ac","7f0f367c.2e3518"]]},{"id":"2c5199d8.602086","type":"change","z":"ccf23d5e.abebd","name":"reset history","rules":[{"t":"delete","p":"CE525","pt":"flow"},{"t":"set","p":"event","pt":"msg","to":"Flow initialized","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":159.28571319580078,"y":185.99999904632568,"wires":[["dd85f860.025158"]]},{"id":"547f27d9.2a10f8","type":"link in","z":"ccf23d5e.abebd","name":"From State Button","links":["a6abecfc.d6bee"],"x":20,"y":245,"wires":[["364cf54f.6beb6a","8cbbb4a0.3d4f28","6d21d325.800eac","18767979.01dae7","3bf17938.eaf566","c4b6d565.94acc8","cb262f7c.f9d0f"]]},{"id":"a6abecfc.d6bee","type":"link out","z":"ccf23d5e.abebd","name":"To Guage Control","links":["547f27d9.2a10f8","5d964c3e.4d0344"],"x":596,"y":20,"wires":[]},{"id":"cef2b2f7.71996","type":"comment","z":"ccf23d5e.abebd","name":"Session Timer Gauge Controls","info":"","x":245,"y":236,"wires":[]},{"id":"54e883dd.d4b4ac","type":"link out","z":"ccf23d5e.abebd","name":"From Init States","links":[],"x":278.2857303619385,"y":145.57143115997314,"wires":[]},{"id":"63cc5f3c.46714","type":"ui_template","z":"ccf23d5e.abebd","group":"2c662e9b.76e672","name":"Sim Gauge Tech View","order":0,"width":0,"height":0,"format":"<script src=\"/myjs/steelseries/tween-min.js\"></script>\n<script src=\"/myjs/steelseries/steelseries-min.js\"></script>\n<script>\nvar radial4;\n (function(scope){ \n scope.$watch('msg', function(msg) {\n if (typeof(msg.value) != \"undefined\") radial4.setValueAnimated(msg.value);\n if (typeof(msg.threshold) != \"undefined\") radial4.setThreshold(msg.threshold);\n if (typeof(msg.maxvalue) != \"undefined\")radial4.setMaxValue(msg.maxvalue);\n if (typeof(msg.userLed) != \"undefined\") radial4.setUserLedOnOff(msg.userLed);\n });\n })(scope);\n\n var sections = [steelseries.Section(-40, 5, 'rgba(220, 0, 0, 0.3)'),\n steelseries.Section(5, 10, 'rgba(255, 255, 0, 0.5)'),\n steelseries.Section(10, 240, 'rgba(0, 255, 0, 0.3)') ],\n\n // Define one area\n areas = [steelseries.Section(-40, 5, 'rgba(220, 0, 0, 0.3)')],\n\n radial4 = new steelseries.Radial('canvasRadial4', {\n gaugeType: steelseries.GaugeType.TYPE4,\n size: 292,\n section: sections,\n //MaxValue: 240,\n area: areas,\n lcdDecimals: 0,\n minValue: -30,\n titleString: \"Sim Time Remaining\",\n unitString: \"Minutes\",\n threshold: 10,\n thresholdRising: false,\n userLedVisible: true,\n userLed: true,\n useOdometer: false,\n lcdVisible: true,\n trendVisible: false,\n });\n \n radial4.setFrameDesign(steelseries.FrameDesign.BLACK_METAL);\n radial4.setBackgroundColor(steelseries.BackgroundColor.LIGHT_GRAY);\n radial4.setValueAnimated(0);\n radial4.setThreshold(10);\n radial4.blinkUserLed(0);\n\n</script>\n\n<canvas id=\"canvasRadial4\" width=\"401\" height=\"401\"></canvas>\n\n\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1544.1427993774414,"y":334.5714178085327,"wires":[["18cb3639.9c927a"]]},{"id":"6f6c2eb4.4f8dd","type":"function","z":"ccf23d5e.abebd","name":"Initial Session Time","func":"// This function takes the initial session time and sets our gauge's max value to this time.\n\nmsg.maxvalue=msg.payload;\nreturn msg;","outputs":1,"noerr":0,"x":673.4285888671875,"y":279.00000381469727,"wires":[["63cc5f3c.46714","599483.cfaf5b7c","1c0c2a1e.ae2fa6"]]},{"id":"ae9bd2bb.8b02","type":"switch","z":"ccf23d5e.abebd","name":"time left?","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"-30","vt":"num"}],"checkall":"true","outputs":1,"x":945.1427917480469,"y":443.2856845855713,"wires":[["c80b92a6.d7f48"]]},{"id":"c80b92a6.d7f48","type":"change","z":"ccf23d5e.abebd","name":"-1 minute","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload - 1","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1028.1427917480469,"y":518.2856845855713,"wires":[["3b4d56eb.afd6fa","3c352460.38001c"]]},{"id":"e27ebd99.3e09","type":"link out","z":"ccf23d5e.abebd","name":"decremented time","links":["5be89d80.98fb24"],"x":1210.1427917480469,"y":621.2856845855713,"wires":[]},{"id":"5be89d80.98fb24","type":"link in","z":"ccf23d5e.abebd","name":"check time left","links":["e27ebd99.3e09"],"x":833.1427917480469,"y":468.2856845855713,"wires":[["ae9bd2bb.8b02"]]},{"id":"3b4d56eb.afd6fa","type":"delay","z":"ccf23d5e.abebd","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1033.1427917480469,"y":579.2856845855713,"wires":[["e27ebd99.3e09"]]},{"id":"a8ce1073.52976","type":"change","z":"ccf23d5e.abebd","name":"reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":877.1427917480469,"y":525.2856845855713,"wires":[["3b4d56eb.afd6fa"]]},{"id":"b360da95.909b38","type":"change","z":"ccf23d5e.abebd","name":"delay","rules":[{"t":"set","p":"delay","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":884.1427917480469,"y":568.2856845855713,"wires":[["3b4d56eb.afd6fa"]]},{"id":"3c352460.38001c","type":"change","z":"ccf23d5e.abebd","name":"Output to Gauge","rules":[{"t":"set","p":"time_remaining","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"sim_time_remaining","pt":"flow","to":"time_remaining","tot":"flow"},{"t":"set","p":"value","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1237.1427917480469,"y":518.2856845855713,"wires":[["63cc5f3c.46714","da353055.7c50c","84ee2d8a.083ad","599483.cfaf5b7c","1c0c2a1e.ae2fa6"]]},{"id":"364cf54f.6beb6a","type":"function","z":"ccf23d5e.abebd","name":"Gauge Start Control","func":"/*\nThis function initiates the start sequence. We check to see if a session is alreay running and if not\nand if we are not in break or maint status, we start the sim session and set the session time.\n\nmsg.payload.CE525.Start, Break & Maint return false on startup and true if clicked\n\n*/\n\n\nvar session_start = (msg.payload.CE525.Start);\nvar break_status = (msg.payload.CE525.Break);\nvar maint_status = (msg.payload.CE525.Maint);\nvar session_time = (msg.payload.CE525.Session_Time);\nvar session_running = flow.get(\"ce525_session_running\");\n\n//var session_time_minutes = 2 //UNCOMMENT FOR TESTING\nvar session_time_minutes = session_time*60; //COMMENT FOR TESTING\n\nif (session_start === true && break_status === false && maint_status === false && session_running === false )\n{\n flow.set(\"ce525_session_running\",true);\n flow.set(\"ce525_session_break\",false);\n flow.set(\"ce525_session_maint\",false);\n var session_start_minutes = {payload: session_time_minutes};\n var start_count_timer = {payload: 0}; // This sets the count up timers to 0 when the session starts. \n // needs to go the \"Time Left\" input on each count UP timer.\n return [session_start_minutes, start_count_timer];\n} else {\n return [null,null];\n}\n","outputs":"2","noerr":0,"x":266,"y":284,"wires":[["ae9bd2bb.8b02","6f6c2eb4.4f8dd"],["cc641d4.69d7ee"]],"outputLabels":["","Output to Break Timer \"Time Left\" Input"]},{"id":"8cbbb4a0.3d4f28","type":"function","z":"ccf23d5e.abebd","name":"Gauge Stop Control","func":"// This function \"stops\" the sim session and resets the gauge needle to '0'\n// with a min of '0' and a max of '60' and shuts off the userLed.\n\nvar session_start = (msg.payload.CE525.Start);\n\nif (session_start === false)\n{\n flow.set(\"ce525_session_running\",false);\n flow.set(\"ce525_session_break\",false);\n flow.set(\"ce525_session_maint\",false);\n flow.set(\"break_count_up_started\",false);\n flow.set(\"maint_count_up_started\",false);\n var reset_gauge = {payload: 0, value: 0, maxvalue: 120, userLed: \"false\" };\n var timer_reset = { reset: true, payload: 0 };\n var session_ended = {payload: \"CE525 Sim Session Has Ended\"};\n return [reset_gauge, timer_reset, session_ended];\n} else {\n return [null, null, null];\n}","outputs":"3","noerr":0,"x":269,"y":343,"wires":[["63cc5f3c.46714","599483.cfaf5b7c","1c0c2a1e.ae2fa6"],["a8ce1073.52976","c4f08de1.e54a2","2f503b75.3b6c04"],["ca57873b.f32118"]]},{"id":"6d21d325.800eac","type":"function","z":"ccf23d5e.abebd","name":"Session Break Start","func":"var session_running = flow.get(\"ce525_session_running\");\nvar session_break = (msg.payload.CE525.Break);\n\n\nif (session_running === true && session_break === true)\n{\n flow.set(\"ce525_session_break\",true);\n var session_break = {payload: true };\n return session_break;\n} else {\n return null;\n}","outputs":"1","noerr":0,"x":184,"y":480,"wires":[["a8ce1073.52976","2c19c3a4.aa7f4c","c4f08de1.e54a2"]]},{"id":"18767979.01dae7","type":"function","z":"ccf23d5e.abebd","name":"Session Break Stop","func":"var session_running = flow.get(\"ce525_session_running\");\nvar session_break = (msg.payload.CE525.Break);\n\nif (session_running === true && session_break === false)\n{\n var session_break = {payload: false };\n return session_break;\n} else {\n return null;\n}","outputs":1,"noerr":0,"x":176,"y":523,"wires":[["6086f9ac.bff078","2c19c3a4.aa7f4c"]]},{"id":"6086f9ac.bff078","type":"function","z":"ccf23d5e.abebd","name":"Resume from Break Control","func":"var session_running = flow.get(\"ce525_session_running\");\nvar break_stop = flow.get(\"ce525_session_break\");\n\n\nif (session_running === true && break_stop === false)\n{\n var sim_time_remaining = flow.get(\"sim_time_remaining\");\n var sim_time_used = flow.get(\"sim_time_currently_used\");\n return [{payload: sim_time_remaining}, {payload: sim_time_used}];\n} else {\n return [null,null];\n}\n\n\n","outputs":"2","noerr":0,"x":207,"y":567,"wires":[["b360da95.909b38"],["6f3178da.a355e8"]]},{"id":"41dc4c15.fae4d4","type":"function","z":"ccf23d5e.abebd","name":"Resume from Maint Control","func":"var session_running = flow.get(\"ce525_session_running\");\nvar maint_stop = flow.get(\"ce525_session_maint\");\n\n\nif (session_running === true && maint_stop === false)\n{\n var sim_time_remaining = flow.get(\"sim_time_remaining\");\n var sim_time_used = flow.get(\"sim_time_currently_used\");\n return [{payload: sim_time_remaining}, {payload: sim_time_used}];\n} else {\n return [null,null];\n}","outputs":"2","noerr":0,"x":192,"y":746,"wires":[["b360da95.909b38"],["6f3178da.a355e8"]]},{"id":"3bf17938.eaf566","type":"function","z":"ccf23d5e.abebd","name":"Session Maint Start","func":"var session_running = flow.get(\"ce525_session_running\");\nvar session_maint = (msg.payload.CE525.Maint);\n\n\nif (session_running === true && session_maint === true)\n{\n flow.set(\"ce525_session_maint\",true);\n var session_maint = {payload: true };\n return session_maint;\n} else {\n return null;\n}","outputs":1,"noerr":0,"x":170,"y":654,"wires":[["a8ce1073.52976","62d53df4.691714","c4f08de1.e54a2"]]},{"id":"c4b6d565.94acc8","type":"function","z":"ccf23d5e.abebd","name":"Session Maint Stop","func":"var session_running = flow.get(\"ce525_session_running\");\nvar maint_break = (msg.payload.CE525.Maint);\nvar session_break = (msg.payload.CE525.Break);\n\nif (session_running === true && maint_break === false && session_break === false)\n{\n var session_maint = { payload: false };\n return session_maint;\n} else {\n return null;\n}","outputs":1,"noerr":0,"x":164,"y":699,"wires":[["41dc4c15.fae4d4","62d53df4.691714"]]},{"id":"da353055.7c50c","type":"function","z":"ccf23d5e.abebd","name":"Session Ending Soon?","func":"// Set this to the number of minutes before the sim session ends that you\n// would like to notified that the session is about to end.\nvar warning_minutes = flow.get(\"session_end_warning_minutes\");\n\nif (msg.value == warning_minutes)\n{\n var warning_message = {payload: \"CE525 Sim Session Should be Ending in \" + warning_minutes +\" Minutes\"};\n return [warning_message];\n} else {\n return null;\n}","outputs":"1","noerr":0,"x":1137,"y":246,"wires":[["3e07dfe0.9d6ec"]]},{"id":"8cedb0f2.6169e","type":"twilio out","z":"ccf23d5e.abebd","twilio":"5b0875de.d408bc","twilioType":"sms","url":"","number":"18584142908","name":"Richard's Cell","x":1590,"y":32,"wires":[]},{"id":"9143fe41.3272a","type":"twilio out","z":"ccf23d5e.abebd","twilio":"5b0875de.d408bc","twilioType":"sms","url":"","number":"18588805709","name":"Ryan's Cell","x":1606.5,"y":74,"wires":[]},{"id":"c948407a.06dda","type":"twilio out","z":"ccf23d5e.abebd","twilio":"5b0875de.d408bc","twilioType":"sms","url":"","number":"18587170066","name":"Ted's Cell","x":1605.5,"y":115,"wires":[]},{"id":"1bc2d1c2.d737be","type":"twilio out","z":"ccf23d5e.abebd","twilio":"5b0875de.d408bc","twilioType":"sms","url":"","number":"16198896251","name":"Noel's Cell","x":1604.5,"y":158,"wires":[]},{"id":"825f97a0.ec44f8","type":"pushbullet","z":"ccf23d5e.abebd","config":"6254174c.23f288","pushtype":"note","title":"CE525 Sim Message","chan":"","name":"CE525 Sim Session Messages","x":1552,"y":212,"wires":[]},{"id":"ca57873b.f32118","type":"link out","z":"ccf23d5e.abebd","name":"In from Gauge Stop Control #3 output","links":["739edf88.0991a"],"x":311,"y":419,"wires":[]},{"id":"739edf88.0991a","type":"link in","z":"ccf23d5e.abebd","name":"Out to Sim Session Manual Ended PB Notification","links":["ca57873b.f32118"],"x":985,"y":114,"wires":[["3e07dfe0.9d6ec"]]},{"id":"85d7cbf.8585338","type":"comment","z":"ccf23d5e.abebd","name":"Count Down Timer Control","info":"","x":890.1427917480469,"y":393.2856845855713,"wires":[]},{"id":"4b63d4f2.e5509c","type":"comment","z":"ccf23d5e.abebd","name":"Notifications","info":"","x":1099,"y":25,"wires":[]},{"id":"6dcf7df3.fd89a4","type":"file","z":"ccf23d5e.abebd","name":"Session Log File","filename":"/root/.node-red/ce525_history","appendNewline":true,"createDir":false,"overwriteFile":"false","x":655.0317687988281,"y":1305.0475645065308,"wires":[]},{"id":"cb262f7c.f9d0f","type":"function","z":"ccf23d5e.abebd","name":"Session Start & Stop Log","func":"var session_start = (msg.payload.CE525.Start);\nvar break_status = (msg.payload.CE525.Break);\n//var break_status = flow.get(\"ce525_session_break\");\nvar maint_status = (msg.payload.CE525.Maint);\nvar session_time = (msg.payload.CE525.Session_Time);\nvar session_time_minutes = session_time*60;\nvar session_running = flow.get(\"ce525_session_running\");\nvar was_start_record_written = flow.get(\"start_record_written\");\nvar session_time_minutes = session_time*60;\nvar total_sim_time_minutes = flow.get(\"total_sim_time_used\");\nvar session_id = flow.get(\"session_id\");\nvar total_break_time_used = flow.get(\"total_break_time_used\");\nvar total_maint_time_used = flow.get(\"total_maint_time_used\");\n\nfunction roundUp(num, precision) {\n return Math.ceil(num * precision) / precision\n}\n\nif (session_start === true && break_status === false && maint_status === false && session_running === true && was_start_record_written === false )\n{\n var now_start = Math.round(+new Date()/1000);\n flow.set(\"now_start\",now_start);\n \n var session_start_record = { payload: {Session_ID: session_id, Instructor: msg.payload.CE525.Instructor, \n Scheduled_Time: session_time_minutes, \n Session_Start_Time: now_start, Session: \"START\" } };\n \n flow.set (\"start_record_written\",true);\n return [session_start_record,null];\n \n} else if (session_start === false && break_status === false && maint_status === false && session_running === false)\n{\n var now_start = flow.get(\"now_start\");\n var now_stop = Math.round(+new Date()/1000);\n var total_session_time = (now_stop - now_start)/60;\n var fixed_total_session_time = roundUp(total_session_time,1);\n \n var session_stop_record = { payload: {Session_ID: session_id, \n Session_Stop_Time: now_stop, Session: \"STOP\", \n Total_Client_Time: total_sim_time_minutes, \n Total_Sim_Time: fixed_total_session_time,\n Total_Break_Time: total_break_time_used,\n Total_Maint_Time: total_maint_time_used\n } };\n \n flow.set (\"start_record_written\",false);\n var new_session_id = (session_id + 1);\n return [session_stop_record, {payload: new_session_id}];\n \n} else {\n return [null,null];\n}\n\n\n","outputs":"2","noerr":0,"x":174.85716247558594,"y":1238.999984741211,"wires":[["6dcf7df3.fd89a4","c6a8ce5d.2f746"],["3de5dd76.2656a2","1cbb35c1.97b4da"]]},{"id":"c6a8ce5d.2f746","type":"debug","z":"ccf23d5e.abebd","name":"","active":false,"console":"false","complete":"payload","x":602.1428909301758,"y":1231.2855854034424,"wires":[]},{"id":"2c19c3a4.aa7f4c","type":"function","z":"ccf23d5e.abebd","name":"Session Individual Breaks Log","func":"var break_active = flow.get(\"ce525_session_break\");\nvar session_id = flow.get(\"session_id\");\n\nfunction roundUp(num, precision) {\n return Math.ceil(num * precision) / precision\n}\n\n\nif (msg.payload === true)\n{\n var break_start = Math.round(+new Date()/1000);\n flow.set(\"break_start\",break_start);\n var now = Math.round(+new Date()/1000);\n var break_start_record = { payload: {Session_ID: session_id, Break_Start: now, Break: \"START\" } };\n return [break_start_record,null];\n \n} else if (msg.payload === false && break_active === true)\n{\n var break_start = flow.get(\"break_start\");\n var break_stop = Math.round(+new Date()/1000);\n var total_break_time = (break_stop - break_start)/60;\n var fixed_total_break_time = roundUp(total_break_time,1);\n var now = Math.round(+new Date()/1000);\n \n var break_stop_record = { payload: {Session_ID: session_id, \n Break_Stop: now, Break: \"STOP\", \n Total_Break_Time: fixed_total_break_time } };\n \n flow.set(\"ce525_session_break\",false);\n var break_time = { payload: fixed_total_break_time }; \n return [break_stop_record,break_time];\n} else {\n return [null,null];\n}","outputs":"2","noerr":0,"x":198.85716247558594,"y":1277.999984741211,"wires":[["6dcf7df3.fd89a4"],["7b838086.a0065"]]},{"id":"62d53df4.691714","type":"function","z":"ccf23d5e.abebd","name":"Individual Maintenance Breaks Log","func":"var maint_active = flow.get(\"ce525_session_maint\");\nvar session_id = flow.get(\"session_id\");\n\nfunction roundUp(num, precision) {\n return Math.ceil(num * precision) / precision\n}\n\nif (msg.payload === true)\n{\n var maint_start = Math.round(+new Date()/1000);\n flow.set(\"maint_start\",maint_start);\n var now = Math.round(+new Date()/1000);\n var maint_start_record = { payload: {Session_ID: session_id, Maint_Start: now, Maint: \"START\" } };\n return maint_start_record;\n \n} else if (msg.payload === false && maint_active === true)\n{\n var maint_start = flow.get(\"maint_start\");\n var maint_stop = Math.round(+new Date()/1000);\n var total_maint_time = (maint_stop - maint_start)/60;\n var fixed_total_maint_time = roundUp(total_maint_time,1);\n var now = Math.round(+new Date()/1000);\n \n var maint_stop_record = { payload: {Session_ID: session_id, \n Maint_Stop: now, Maint: \"STOP\", \n Total_Maint_Time: fixed_total_maint_time } };\n \n flow.set(\"ce525_session_maint\",false);\n return maint_stop_record;\n} else {\n return null;\n}\n ","outputs":1,"noerr":0,"x":206.85716247558594,"y":1314.999984741211,"wires":[["6dcf7df3.fd89a4"]]},{"id":"b3161e3.8bba1e","type":"comment","z":"ccf23d5e.abebd","name":"Logging","info":"","x":123.85716247558594,"y":1192.999984741211,"wires":[]},{"id":"cc641d4.69d7ee","type":"switch","z":"ccf23d5e.abebd","name":"time left?","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"-1","vt":"num"}],"checkall":"true","outputs":1,"x":900.1427917480469,"y":732.2856845855713,"wires":[["97ae23a.51fdde"]]},{"id":"97ae23a.51fdde","type":"change","z":"ccf23d5e.abebd","name":"+1 minute","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload + 1","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":940.1427917480469,"y":772.2856845855713,"wires":[["60cd3085.e4d59","3d4b9911.5a8306"]]},{"id":"4c044d9c.348094","type":"link out","z":"ccf23d5e.abebd","name":"decremented time","links":["ed78cf5e.25903"],"x":1115.1427917480469,"y":852.2856845855713,"wires":[]},{"id":"ed78cf5e.25903","type":"link in","z":"ccf23d5e.abebd","name":"check time left","links":["4c044d9c.348094"],"x":745.1427917480469,"y":812.2856845855713,"wires":[["cc641d4.69d7ee"]]},{"id":"60cd3085.e4d59","type":"delay","z":"ccf23d5e.abebd","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1001.1427917480469,"y":832.2856845855713,"wires":[["4c044d9c.348094"]]},{"id":"c4f08de1.e54a2","type":"change","z":"ccf23d5e.abebd","name":"reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":810.1427917480469,"y":872.2856845855713,"wires":[["60cd3085.e4d59"]]},{"id":"6f3178da.a355e8","type":"change","z":"ccf23d5e.abebd","name":"delay","rules":[{"t":"set","p":"delay","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":810.1427917480469,"y":912.2856845855713,"wires":[["60cd3085.e4d59"]]},{"id":"3d4b9911.5a8306","type":"change","z":"ccf23d5e.abebd","name":"Total Sim Time Output to Variable","rules":[{"t":"set","p":"time_remaining1","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"sim_time_currently_used","pt":"flow","to":"time_remaining1","tot":"flow"},{"t":"set","p":"total_sim_time_used","pt":"flow","to":"time_remaining1","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1169.1427917480469,"y":731.2856845855713,"wires":[["f5c33a5b.7b4b18"]]},{"id":"84ee2d8a.083ad","type":"debug","z":"ccf23d5e.abebd","name":"","active":false,"console":"false","complete":"false","x":1427.1427917480469,"y":573.2856845855713,"wires":[]},{"id":"f5c33a5b.7b4b18","type":"debug","z":"ccf23d5e.abebd","name":"","active":false,"console":"false","complete":"false","x":1446.1427917480469,"y":773.2856845855713,"wires":[]},{"id":"37469e4c.e8c9c2","type":"comment","z":"ccf23d5e.abebd","name":"Count Up Timer (Total Active Sim Session Time)","info":"This is the active sim time - ie actual sim time\nnot counting breaks and maintenance stops.","x":955.1427917480469,"y":682.2856845855713,"wires":[]},{"id":"7f0f367c.2e3518","type":"file in","z":"ccf23d5e.abebd","name":"Read New Session ID","filename":"/root/.node-red/ce525_session_id","format":"utf8","chunk":false,"sendError":false,"x":261.4920654296875,"y":959.1429443359375,"wires":[["ecc4bab4.2f5b28","cb995819.e14b38"]]},{"id":"ecc4bab4.2f5b28","type":"debug","z":"ccf23d5e.abebd","name":"","active":false,"console":"false","complete":"false","x":372.92060470581055,"y":884.5715198516846,"wires":[]},{"id":"f0e170cb.df091","type":"change","z":"ccf23d5e.abebd","name":"Set Session ID Globally","rules":[{"t":"set","p":"session_id","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":468.63487243652344,"y":1004.4285535812378,"wires":[[]]},{"id":"3de5dd76.2656a2","type":"file","z":"ccf23d5e.abebd","name":"Write New Session ID","filename":"/root/.node-red/ce525_session_id","appendNewline":false,"createDir":false,"overwriteFile":"true","x":675.7143173217773,"y":1367.1427612304688,"wires":[]},{"id":"1cbb35c1.97b4da","type":"delay","z":"ccf23d5e.abebd","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":169.20638275146484,"y":885.714183807373,"wires":[["7f0f367c.2e3518"]]},{"id":"cb995819.e14b38","type":"function","z":"ccf23d5e.abebd","name":"Convert (str) to (int)","func":"var session_id = { payload: parseInt(msg.payload)};\nreturn session_id;","outputs":1,"noerr":0,"x":250.20632934570312,"y":1053.9998950958252,"wires":[["f0e170cb.df091","882039d4.8fb668"]]},{"id":"882039d4.8fb668","type":"debug","z":"ccf23d5e.abebd","name":"","active":false,"console":"false","complete":"false","x":507.7777557373047,"y":1060.1429605484009,"wires":[]},{"id":"46c2ff1e.97468","type":"comment","z":"ccf23d5e.abebd","name":"Get Session ID","info":"","x":176.920654296875,"y":850.7142543792725,"wires":[]},{"id":"9356f85c.ecb508","type":"config","z":"ccf23d5e.abebd","name":"Notification Configuration","properties":[{"p":"sms_alerts","pt":"flow","to":"false","tot":"bool"},{"p":"pushbullet_alerts","pt":"flow","to":"false","tot":"bool"},{"p":"alert_rjs_cell","pt":"flow","to":"true","tot":"bool"},{"p":"alert_ryan_cell","pt":"flow","to":"true","tot":"bool"},{"p":"alert_ted_cell","pt":"flow","to":"true","tot":"bool"},{"p":"alert_noel_cell","pt":"flow","to":"false","tot":"bool"},{"p":"session_end_warning_minutes","pt":"flow","to":"5","tot":"num"}],"active":true,"x":1101,"y":68,"wires":[]},{"id":"3e07dfe0.9d6ec","type":"function","z":"ccf23d5e.abebd","name":"PB & SMS Alert Control","func":"var sendTo = []\n\nvar sms_alerts_active = flow.get(\"sms_alerts\");\nvar pb_alerts_active = flow.get(\"pushbullet_alerts\");\nsendTo.push(sms_alerts_active===true ? msg:null);\nsendTo.push(pb_alerts_active===true ? msg:null);\n\nnode.send(sendTo);\n","outputs":"2","noerr":0,"x":1150,"y":153,"wires":[["edd6cc75.1d6b3"],["825f97a0.ec44f8"]],"outputLabels":["SMS Alerts","PB Alerts"]},{"id":"edd6cc75.1d6b3","type":"function","z":"ccf23d5e.abebd","name":"Staff Cell Phones","func":"var sendTo = []\nvar alert_rjs_cell = flow.get(\"alert_rjs_cell\");\nvar alert_ryan_cell = flow.get(\"alert_ryan_cell\");\nvar alert_ted_cell = flow.get(\"alert_ted_cell\");\nvar alert_noel_cell = flow.get(\"alert_noel_cell\");\n\nsendTo.push(alert_rjs_cell===true? msg:null);\nsendTo.push(alert_ryan_cell===true? msg:null);\nsendTo.push(alert_ted_cell===true? msg:null);\nsendTo.push(alert_noel_cell===true? msg:null);\n\nreturn sendTo;","outputs":"4","noerr":0,"x":1367,"y":78,"wires":[["8cedb0f2.6169e"],["9143fe41.3272a"],["c948407a.06dda"],["1bc2d1c2.d737be"]],"outputLabels":["To Richard Cell","To Ryan Cell","To Ted Cell","To Noel Cell"]},{"id":"2a06ab13.588234","type":"comment","z":"ccf23d5e.abebd","name":"ToDo","info":"Confirm button on stop session\nRedo outbound SMS system (??) Maybe...?","x":823.3333587646484,"y":34.44454002380371,"wires":[]},{"id":"7b838086.a0065","type":"file","z":"ccf23d5e.abebd","name":"Track Session Break Times","filename":"/root/.node-red/ce525-break-times","appendNewline":true,"createDir":false,"overwriteFile":"false","x":371.26990509033203,"y":1170.4762554168701,"wires":[]},{"id":"b2e5ff45.1a9de","type":"switch","z":"ccf23d5e.abebd","name":"time left?","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"-1","vt":"num"}],"checkall":"true","outputs":1,"x":1375.7144222259521,"y":1122.479917049408,"wires":[["955c30d9.7978a"]]},{"id":"955c30d9.7978a","type":"change","z":"ccf23d5e.abebd","name":"+1 minute","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload + 1","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1537.5000953674316,"y":1126.7656807899475,"wires":[["ce9b3cb0.6d1db","c097136d.3c8e6"]]},{"id":"4a840779.0c5048","type":"link out","z":"ccf23d5e.abebd","name":"decremented time","links":["cec0b23b.fc1b8"],"x":1752.5001220703125,"y":1205.3370022773743,"wires":[]},{"id":"cec0b23b.fc1b8","type":"link in","z":"ccf23d5e.abebd","name":"check time left","links":["4a840779.0c5048"],"x":1318.2144317626953,"y":1188.1941466331482,"wires":[["b2e5ff45.1a9de"]]},{"id":"ce9b3cb0.6d1db","type":"delay","z":"ccf23d5e.abebd","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1638.5001220703125,"y":1185.3370022773743,"wires":[["4a840779.0c5048"]]},{"id":"12c32e12.ddf4a2","type":"change","z":"ccf23d5e.abebd","name":"pause / reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1467.5001220703125,"y":1225.3370022773743,"wires":[["ce9b3cb0.6d1db"]]},{"id":"9d5fe188.17a7c","type":"change","z":"ccf23d5e.abebd","name":"resume / delay","rules":[{"t":"set","p":"delay","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1477.5001220703125,"y":1265.3370022773743,"wires":[["ce9b3cb0.6d1db"]]},{"id":"c097136d.3c8e6","type":"change","z":"ccf23d5e.abebd","name":"Total Break Time Output to Flow Variable","rules":[{"t":"set","p":"accumulated_break_time","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"total_break_time_used","pt":"flow","to":"accumulated_break_time","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1815.7858276367188,"y":1144.69420003891,"wires":[["c770c0c2.56144"]]},{"id":"c770c0c2.56144","type":"debug","z":"ccf23d5e.abebd","name":"","active":false,"console":"false","complete":"false","x":2044.9287185668945,"y":1276.3370909690857,"wires":[]},{"id":"a5a2ad41.d557f","type":"function","z":"ccf23d5e.abebd","name":"Break Count Up Timer","func":"var session_running = flow.get(\"ce525_session_running\");\nvar session_break = (msg.payload.CE525.Break);\nvar break_count_up_started = flow.get(\"break_count_up_started\")\n\n\nif (session_running === true && session_break === true && break_count_up_started === false)\n{\n var break_start_count_timer = {payload: 0};\n flow.set(\"break_count_up_started\",true);\n return [break_start_count_timer,null];\n \n} else if (session_running === true && session_break === true && break_count_up_started === true) {\n var accumulated_break_time = flow.get(\"accumulated_break_time\");\n return [null, {payload: accumulated_break_time}];\n \n} else {\n return [null,null];\n}","outputs":"2","noerr":0,"x":980.1786994934082,"y":1132.142626285553,"wires":[["b2e5ff45.1a9de"],["9d5fe188.17a7c"]]},{"id":"d7b4d9f0.169c28","type":"config","z":"ccf23d5e.abebd","name":"Counters","properties":[{"p":"break_count_up_started","pt":"flow","to":"false","tot":"bool"},{"p":"maint_count_up_started","pt":"flow","to":"false","tot":"bool"}],"active":true,"x":961.4286956787109,"y":1078.392629146576,"wires":[]},{"id":"bf4d8968.15d9a8","type":"function","z":"ccf23d5e.abebd","name":"Break Count Up Timer Pause","func":"var session_running = flow.get(\"ce525_session_running\");\nvar session_break = (msg.payload.CE525.Break);\n\n\nif (session_running === true && session_break === false)\n{\n var session_break = {payload: true };\n return session_break;\n} else {\n return null;\n}","outputs":1,"noerr":0,"x":1008.9286956787109,"y":1193.3926062583923,"wires":[["12c32e12.ddf4a2"]]},{"id":"2f503b75.3b6c04","type":"link out","z":"ccf23d5e.abebd","name":"Out to Counter Resets","links":["25b1edd8.d0de72","fc8ab384.ef242"],"x":414.2857151031494,"y":458.5714168548584,"wires":[]},{"id":"25b1edd8.d0de72","type":"link in","z":"ccf23d5e.abebd","name":"In from Counter Resets","links":["2f503b75.3b6c04"],"x":1193.7501125335693,"y":1268.571171283722,"wires":[["12c32e12.ddf4a2","ad51ef84.6f071"]]},{"id":"ad51ef84.6f071","type":"switch","z":"ccf23d5e.abebd","name":"time left?","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"-1","vt":"num"}],"checkall":"true","outputs":1,"x":1399.1072311401367,"y":1351.0713329315186,"wires":[["99b8f856.f7bf78"]]},{"id":"99b8f856.f7bf78","type":"change","z":"ccf23d5e.abebd","name":"+1 minute","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload + 1","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1562.3214721679688,"y":1346.785569190979,"wires":[["cdc1e00c.140a","f8a178dd.6830c8"]]},{"id":"bb41c388.d1ce5","type":"link out","z":"ccf23d5e.abebd","name":"decremented time","links":["b4bdfba1.349158"],"x":1684.464454650879,"y":1505.3570532798767,"wires":[]},{"id":"b4bdfba1.349158","type":"link in","z":"ccf23d5e.abebd","name":"check time left","links":["bb41c388.d1ce5"],"x":1277.3215408325195,"y":1389.6427812576294,"wires":[["ad51ef84.6f071"]]},{"id":"cdc1e00c.140a","type":"delay","z":"ccf23d5e.abebd","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1707.6072044372559,"y":1413.9285125732422,"wires":[["bb41c388.d1ce5"]]},{"id":"7c1bcdbf.4ddbe4","type":"change","z":"ccf23d5e.abebd","name":"pause / reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1433.7500839233398,"y":1409.6427459716797,"wires":[["cdc1e00c.140a"]]},{"id":"2358272e.4a7058","type":"change","z":"ccf23d5e.abebd","name":"resume / delay","rules":[{"t":"set","p":"delay","pt":"msg","to":"1","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1443.7500839233398,"y":1449.6427459716797,"wires":[["cdc1e00c.140a"]]},{"id":"f8a178dd.6830c8","type":"change","z":"ccf23d5e.abebd","name":"Total Maint TIme Output to Flow Variable","rules":[{"t":"set","p":"accumulated_maint_time","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"total_maint_time_used","pt":"flow","to":"accumulated_maint_time","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1856.321517944336,"y":1341.8571033477783,"wires":[["7d3ab4d8.87f45c"]]},{"id":"7d3ab4d8.87f45c","type":"debug","z":"ccf23d5e.abebd","name":"","active":false,"console":"false","complete":"false","x":2054.0358276367188,"y":1419.2141580581665,"wires":[]},{"id":"d7ad8f66.1d2ed","type":"function","z":"ccf23d5e.abebd","name":"Maint Count Up Timer","func":"var session_running = flow.get(\"ce525_session_running\");\nvar session_maint = (msg.payload.CE525.Maint);\nvar maint_count_up_started = flow.get(\"maint_count_up_started\")\n\n\nif (session_running === true && session_maint === true && maint_count_up_started === false)\n{\n var maint_start_count_timer = {payload: 0};\n flow.set(\"maint_count_up_started\",true);\n return [maint_start_count_timer,null];\n \n} else if (session_running === true && session_maint === true && maint_count_up_started === true) {\n var accumulated_maint_time = flow.get(\"accumulated_maint_time\");\n return [null, {payload: accumulated_maint_time}];\n \n} else {\n return [null,null];\n}","outputs":"2","noerr":0,"x":991.7858200073242,"y":1300.733943939209,"wires":[["ad51ef84.6f071"],["2358272e.4a7058"]]},{"id":"90a01cb9.e4c9a","type":"function","z":"ccf23d5e.abebd","name":"Maint Count Up Timer Pause","func":"var session_running = flow.get(\"ce525_session_running\");\nvar session_maint = (msg.payload.CE525.Maint);\n\n\nif (session_running === true && session_maint === false)\n{\n var session_maint = {payload: true };\n return session_maint;\n} else {\n return null;\n}","outputs":1,"noerr":0,"x":1022.8572158813477,"y":1347.8769011497498,"wires":[["7c1bcdbf.4ddbe4"]]},{"id":"7b689599.8cd09c","type":"comment","z":"ccf23d5e.abebd","name":"Total Timers for Maint & Breaks","info":"","x":1205.7144099644252,"y":1045.7140348298208,"wires":[]},{"id":"5d964c3e.4d0344","type":"link in","z":"ccf23d5e.abebd","name":"","links":["a6abecfc.d6bee"],"x":772.8572368621826,"y":1065.7140774726868,"wires":[["a5a2ad41.d557f","bf4d8968.15d9a8","d7ad8f66.1d2ed","90a01cb9.e4c9a"]]},{"id":"599483.cfaf5b7c","type":"ui_template","z":"ccf23d5e.abebd","group":"10489166.7908ff","name":"Sim Cab Gauge","order":0,"width":0,"height":0,"format":"<script src=\"/myjs/steelseries/tween-min.js\"></script>\n<script src=\"/myjs/steelseries/steelseries-min.js\"></script>\n<script>\nvar radial4;\n (function(scope){ \n scope.$watch('msg', function(msg) {\n if (typeof(msg.value) != \"undefined\") radial4.setValueAnimated(msg.value);\n if (typeof(msg.threshold) != \"undefined\") radial4.setThreshold(msg.threshold);\n if (typeof(msg.maxvalue) != \"undefined\")radial4.setMaxValue(msg.maxvalue);\n if (typeof(msg.userLed) != \"undefined\") radial4.setUserLedOnOff(msg.userLed);\n });\n })(scope);\n\n var sections = [steelseries.Section(-40, 5, 'rgba(220, 0, 0, 0.3)'),\n steelseries.Section(5, 10, 'rgba(255, 255, 0, 0.5)'),\n steelseries.Section(10, 240, 'rgba(0, 255, 0, 0.3)') ],\n\n // Define one area\n areas = [steelseries.Section(-40, 5, 'rgba(220, 0, 0, 0.3)')],\n\n radial4 = new steelseries.Radial('canvasRadial4', {\n gaugeType: steelseries.GaugeType.TYPE4,\n size: 292,\n section: sections,\n //MaxValue: 240,\n area: areas,\n lcdDecimals: 0,\n minValue: -30,\n titleString: \"Sim Time Remaining\",\n unitString: \"Minutes\",\n threshold: 10,\n thresholdRising: false,\n userLedVisible: true,\n userLed: true,\n useOdometer: false,\n lcdVisible: true,\n trendVisible: false,\n });\n \n radial4.setFrameDesign(steelseries.FrameDesign.BLACK_METAL);\n radial4.setBackgroundColor(steelseries.BackgroundColor.LIGHT_GRAY);\n radial4.setValueAnimated(0);\n radial4.setThreshold(10);\n radial4.blinkUserLed(0);\n\n</script>\n\n<canvas id=\"canvasRadial4\" width=\"401\" height=\"401\"></canvas>\n\n\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1805.714096069336,"y":449.99999237060547,"wires":[[]]},{"id":"1c0c2a1e.ae2fa6","type":"ui_template","z":"ccf23d5e.abebd","group":"1e768402.eb9b3c","name":"Sim Bay Gauge","order":0,"width":"0","height":"0","format":"<script src=\"/myjs/steelseries/tween-min.js\"></script>\n<script src=\"/myjs/steelseries/steelseries-min.js\"></script>\n<script>\nvar radial4;\n (function(scope){ \n scope.$watch('msg', function(msg) {\n if (typeof(msg.value) != \"undefined\") radial4.setValueAnimated(msg.value);\n if (typeof(msg.threshold) != \"undefined\") radial4.setThreshold(msg.threshold);\n if (typeof(msg.maxvalue) != \"undefined\")radial4.setMaxValue(msg.maxvalue);\n if (typeof(msg.userLed) != \"undefined\") radial4.setUserLedOnOff(msg.userLed);\n });\n })(scope);\n\n var sections = [steelseries.Section(-40, 5, 'rgba(220, 0, 0, 0.3)'),\n steelseries.Section(5, 10, 'rgba(255, 255, 0, 0.5)'),\n steelseries.Section(10, 240, 'rgba(0, 255, 0, 0.3)') ],\n\n // Define one area\n areas = [steelseries.Section(-40, 5, 'rgba(220, 0, 0, 0.3)')],\n\n radial4 = new steelseries.Radial('canvasRadial4', {\n gaugeType: steelseries.GaugeType.TYPE4,\n size: 292,\n section: sections,\n //MaxValue: 240,\n area: areas,\n lcdDecimals: 0,\n minValue: -30,\n titleString: \"Sim Time Remaining\",\n unitString: \"Minutes\",\n threshold: 10,\n thresholdRising: false,\n userLedVisible: true,\n userLed: true,\n useOdometer: false,\n lcdVisible: true,\n trendVisible: false,\n });\n \n radial4.setFrameDesign(steelseries.FrameDesign.BLACK_METAL);\n radial4.setBackgroundColor(steelseries.BackgroundColor.LIGHT_GRAY);\n radial4.setValueAnimated(0);\n radial4.setThreshold(10);\n radial4.blinkUserLed(0);\n\n</script>\n\n<canvas id=\"canvasRadial4\" width=\"401\" height=\"401\"></canvas>\n\n\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1810.0000228881836,"y":504.285737991333,"wires":[[]]},{"id":"18cb3639.9c927a","type":"debug","z":"ccf23d5e.abebd","name":"","active":true,"console":"false","complete":"true","x":1862.8570938110352,"y":288.5714235305786,"wires":[]},{"id":"ec394520.8c13e8","type":"ui_group","z":"","name":"Cessna CJ1","tab":"7b0178e4.179578","order":1,"disp":false,"width":"6"},{"id":"16df6755.0155b9","type":"ui_group","z":"","name":"Logging","tab":"8dd56678.280db8","order":2,"disp":true,"width":"6"},{"id":"2c662e9b.76e672","type":"ui_group","z":"","name":"CE525 Time Tracking","tab":"8dd56678.280db8","order":1,"disp":true,"width":"6"},{"id":"5b0875de.d408bc","type":"twilio-api","z":"","name":"","sid":"put_your_twillo_acct_info_here","from":"000-000-0000"},{"id":"6254174c.23f288","type":"pushbullet-config","z":"","name":"RJS_PB_ACCOUNT"},{"id":"10489166.7908ff","type":"ui_group","z":"","name":"CE525 Cab Gauge","tab":"8f5b3360.771b4","disp":true,"width":"6"},{"id":"1e768402.eb9b3c","type":"ui_group","z":"","name":"Gauge","tab":"7b0178e4.179578","order":2,"disp":false,"width":"6"},{"id":"7b0178e4.179578","type":"ui_tab","z":"","name":"CE525 Sim Bay","icon":"fa-plane","order":4},{"id":"8dd56678.280db8","type":"ui_tab","z":"","name":"525 Tech View","icon":"fa-plane"},{"id":"8f5b3360.771b4","type":"ui_tab","z":"","name":"525 Cab Gauge","icon":"dashboard","order":3}]
