Current RMS
Very simple flow for interacting with the Current RMS API.
This example shows number of ongoing projects and uses API keys to authenticate
but OAuth2 is preferred whenever possible due to security reasons.
Will possibly be revised with OAuth2 support.
[{"id":"ba6ef039.d96c6","type":"tab","label":"Current RMS API","disabled":false,"info":"Copyright (C) 2021 Johan Nilsson\nhttps://gobo.ws"},{"id":"b4a62cda.c65b1","type":"function","z":"ba6ef039.d96c6","name":"set headers","func":"msg.headers = {};\nmsg.headers['X-SUBDOMAIN'] = 'yoursubdomain';\nmsg.headers['X-AUTH-TOKEN'] = 'yourapikey';\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":310,"y":320,"wires":[["f9f3fd13.0beca"]]},{"id":"c4d71994.7aad58","type":"inject","z":"ba6ef039.d96c6","name":"","props":[{"p":"payload","v":"","vt":"date"},{"p":"topic","v":"","vt":"string"}],"repeat":"","crontab":"","once":false,"topic":"","payload":"","payloadType":"date","x":160,"y":320,"wires":[["b4a62cda.c65b1"]]},{"id":"f9f3fd13.0beca","type":"http request","z":"ba6ef039.d96c6","name":"connect to API endpoint","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.current-rms.com/api/v1/projects?page=1&per_page=20&filtermode=live&view_id=1","tls":"","persist":false,"proxy":"","authType":"","x":510,"y":320,"wires":[["965f9b89.328568"]]},{"id":"abc83d2e.2dc5c","type":"debug","z":"ba6ef039.d96c6","name":"debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":320,"wires":[]},{"id":"965f9b89.328568","type":"template","z":"ba6ef039.d96c6","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"Currently {{payload.meta.total_row_count}} ongoing projects","output":"str","x":700,"y":320,"wires":[["abc83d2e.2dc5c"]]},{"id":"81b6c6c.118cd38","type":"comment","z":"ba6ef039.d96c6","name":"Ongoing projects","info":"","x":160,"y":260,"wires":[]}]
Created 5 years, 6 months ago
  • http request (x1)
  • template (x1)
  • Current RMS
