Het weer (the weather) weerbericht (weather forecast)
Spoken current weather information about the weather in the Netherlands.
With node buienradar.
[{"id":"8e32c085.06189","type":"buienradar","z":"39ebe4b3.7afd0c","name":"","station":"6260","interval":"60000","forecast":false,"x":120,"y":80,"wires":[["5f03f868.562b18","e2eb993d.960958","3e7f0307.effa6c","fa574de.a3d89b","b72fcf0e.3410a","83434179.83a85","2bb3ea81.d06df6"]]},{"id":"e2eb993d.960958","type":"ui_text","z":"39ebe4b3.7afd0c","group":"6482bdde.c8f294","order":1,"width":0,"height":0,"name":"meetstation","label":"","format":"{{payload.buienradar.stationnaam}}","layout":"row-left","x":410,"y":80,"wires":[]},{"id":"5f03f868.562b18","type":"debug","z":"39ebe4b3.7afd0c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":410,"y":40,"wires":[]},{"id":"3e7f0307.effa6c","type":"ui_text","z":"39ebe4b3.7afd0c","group":"6482bdde.c8f294","order":2,"width":0,"height":0,"name":"weer","label":"","format":"Het weer : {{payload.buienradar.icoonzin}}","layout":"row-left","x":390,"y":120,"wires":[]},{"id":"fa574de.a3d89b","type":"ui_text","z":"39ebe4b3.7afd0c","group":"6482bdde.c8f294","order":3,"width":0,"height":0,"name":"temperatuur","label":"","format":"Temperatuur = {{payload.buienradar.temperatuurGC}}  C","layout":"row-left","x":410,"y":160,"wires":[]},{"id":"b72fcf0e.3410a","type":"ui_text","z":"39ebe4b3.7afd0c","group":"6482bdde.c8f294","order":4,"width":0,"height":0,"name":"Luchtvochtigheid","label":"","format":"Luchtvochtigheid = {{payload.buienradar.luchtvochtigheid}}  %","layout":"row-left","x":430,"y":200,"wires":[]},{"id":"cc7056cc.6c5cb8","type":"ui_audio","z":"39ebe4b3.7afd0c","name":"","group":"6482bdde.c8f294","voice":"nl-NL","always":true,"x":460,"y":260,"wires":[]},{"id":"47cdba9b.e7d584","type":"ui_chart","z":"39ebe4b3.7afd0c","name":"","group":"6482bdde.c8f294","order":5,"width":0,"height":0,"label":"temp","chartType":"line","legend":"false","xformat":"dd HH:mm","interpolate":"linear","nodata":"","dot":false,"ymin":"-5","ymax":"35","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":470,"y":300,"wires":[[]]},{"id":"83434179.83a85","type":"function","z":"39ebe4b3.7afd0c","name":"temp","func":"var temp = msg.payload.buienradar.temperatuurGC;\nmsg.payload = temp;\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":300,"wires":[["47cdba9b.e7d584"]]},{"id":"2bb3ea81.d06df6","type":"template","z":"39ebe4b3.7afd0c","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"de buiten temperatuur is {{payload.buienradar.temperatuurGC}} graden celsius;\nmet een luchtdruk van {{payload.buienradar.luchtdruk}} milibar;\nen het weer is {{payload.buienradar.icoonzin}}","output":"str","x":320,"y":260,"wires":[["cc7056cc.6c5cb8"]]},{"id":"6482bdde.c8f294","type":"ui_group","z":"","name":"Het weer","tab":"3e1d9ee1.4017f2","order":3,"disp":true,"width":"8","collapse":false},{"id":"3e1d9ee1.4017f2","type":"ui_tab","z":"","name":"Het weer","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Created 6 years, 2 months ago
  • template (x1)
  • buienradar
  • weer
  • weerbericht
  • temperatuur
  • weather
  • temperature
