Simple SPC node flow sample
This node takes input from modbus device and uses simple-spc to calculate values
[{"id":"65fad5224db2f8b7","type":"tab","label":"Simple SPC","disabled":false,"info":"","env":[]},{"id":"18abcda1a6df6791","type":"modbus-read","z":"65fad5224db2f8b7","name":"SDM 120 Voltage","topic":"","showStatusActivities":true,"logIOActivities":false,"showErrors":true,"showWarnings":true,"unitid":"1","dataType":"InputRegister","adr":"0","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"b69d19ed.84d768","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":160,"y":160,"wires":[["f638075db1e75788"],[]]},{"id":"f638075db1e75788","type":"energy-meter","z":"65fad5224db2f8b7","name":"","x":370,"y":160,"wires":[["95f30ee7a34df4d1"]]},{"id":"95f30ee7a34df4d1","type":"spc","z":"65fad5224db2f8b7","name":"Simple SPC","limitMultiplier":"2.66","x":550,"y":160,"wires":[["eacfcf16bfcd6845"]]},{"id":"eacfcf16bfcd6845","type":"debug","z":"65fad5224db2f8b7","name":"debug 183","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":730,"y":160,"wires":[]},{"id":"8f1e7e82159e0b3b","type":"comment","z":"65fad5224db2f8b7","name":"Simple SPC application","info":"This sample application takes input from modbus node, in this case it is energy meter and the energy meter node processes the data which is provided as input to Simple SPC node\n\n","x":160,"y":60,"wires":[]},{"id":"b69d19ed.84d768","type":"modbus-client","name":"Serial_2400_8_N_1","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":true,"queueLogEnabled":false,"failureLogEnabled":false,"tcpHost":"10.10.100.254","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB0","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"","unit_id":"1","commandDelay":"30","clientTimeout":"2000","reconnectOnTimeout":true,"reconnectTimeout":"5000","parallelUnitIdsAllowed":false}]
