Context-Aware Chatbot: OpenAI Integration with Flow Memory
🚀 Hello Node-RED enthusiasts! Sharing how we can natively introduce chat memory to AI-powered conversations with this "Context-Aware Chatbot" demo flow. This approach bridges Node-RED's simplicity with the versatility of OpenAI-compliant API servers, bringing a level of ease and innovation that stands out amidst tools like Flowise, Langflow, and LangChain.
Why This Flow?
  • Adaptable Context Memory: Smartly keeps track of conversations, ensuring relevant and context-rich interactions.
  • OpenAI Flexibility: Tap the power of OpenAI's native platform or point to any OpenAI-compliant API server, offering unparalleled dynamic interactions--works great with LM Studio and Text Generation Web UI.
  • Interactive Testing: Includes intuitive inject nodes to let you easily simulate and explore various conversation scenarios.
How You Can Use It:
  1. Import this flow into your Node-RED environment.
  2. Add the @inductiv/node-red-openai-api node for seamless connectivity with OpenAI's API or other compatible servers.
  3. Experiment by injecting messages to see the chatbot's intelligent contextual responses.
  4. Use the clear memory function to start fresh conversations whenever you need.
Let's make Node-RED the tool for advanced AIoT development!
[{"id":"bfb3bf6a21067928","type":"tab","label":"Flow-based Chat Memory","disabled":false,"info":"","env":[]},{"id":"9efb9986abde06ea","type":"debug","z":"bfb3bf6a21067928","name":"response","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.messages","targetType":"msg","statusVal":"","statusType":"auto","x":1020,"y":300,"wires":[]},{"id":"7372d6ef8decd6d9","type":"inject","z":"bfb3bf6a21067928","name":"1. System Message","props":[{"p":"payload.messages","v":"[{\"role\":\"system\",\"content\":\"You are a helpful assistant.\"},{\"role\":\"user\",\"content\":\"Hi! Can you tell me when daylight savings time 2023 ends in the continental United States?\"}]","vt":"json"},{"p":"payload.model","v":"gpt-4-1106-preview","vt":"str"},{"p":"payload.temperature","v":"0.9","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":350,"y":260,"wires":[["280368fb2958c21e"]]},{"id":"b9ef39c889acb3bd","type":"OpenAI API","z":"bfb3bf6a21067928","name":"Chat Completion","service":"6bf3be50f1f3a262","method":"createChatCompletion","x":750,"y":380,"wires":[["280368fb2958c21e"]]},{"id":"280368fb2958c21e","type":"function","z":"bfb3bf6a21067928","name":"Chat Memory","func":"let messages = flow.get('messages') || [];\n\nif (msg.payload.object){\n    // this is a chat completion response\n    messages.push(msg.payload.choices[0].message);\n} else {\n    // this is an incoming user message\n    messages.push(...msg.payload.messages)\n    delete msg.payload.messages; // no longer needed beyond this point.\n}\n\nflow.set('messages', messages);\nmsg.payload.messages = messages;\nreturn msg;\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":300,"wires":[["b480d24f28b70590"]],"icon":"font-awesome/fa-microchip"},{"id":"4f754fb284b1b42a","type":"inject","z":"bfb3bf6a21067928","name":"Clear","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":570,"y":520,"wires":[["28dbac874c3c379a"]]},{"id":"b482bcbe7bbe5d56","type":"debug","z":"bfb3bf6a21067928","name":"response","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":920,"y":520,"wires":[]},{"id":"28dbac874c3c379a","type":"function","z":"bfb3bf6a21067928","name":"Clear Memory","func":"flow.set(\"messages\", []);\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":740,"y":520,"wires":[["b482bcbe7bbe5d56"]]},{"id":"b480d24f28b70590","type":"switch","z":"bfb3bf6a21067928","name":"Continue or Done","property":"payload.object","propertyType":"msg","rules":[{"t":"eq","v":"chat.completion","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":830,"y":300,"wires":[["9efb9986abde06ea"],["b9ef39c889acb3bd"]]},{"id":"13f06252dc61ff81","type":"inject","z":"bfb3bf6a21067928","name":"2. User Message 1","props":[{"p":"payload.messages","v":"[{\"role\":\"user\",\"content\":\"Thanks! How about in 2024?\"}]","vt":"json"},{"p":"payload.model","v":"gpt-4-1106-preview","vt":"str"},{"p":"payload.temperature","v":"0.9","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":350,"y":300,"wires":[["280368fb2958c21e"]]},{"id":"6c165a067b733835","type":"inject","z":"bfb3bf6a21067928","name":"3. User Message 2","props":[{"p":"payload.model","v":"gpt-4-1106-preview","vt":"str"},{"p":"payload.temperature","v":"0.9","vt":"num"},{"p":"payload.messages","v":"[{\"role\":\"user\",\"content\":\"Got it. Thanks! Does this happen around the same time every year?\"}]","vt":"json"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":350,"y":340,"wires":[["280368fb2958c21e"]]},{"id":"3fa240e52c50090b","type":"comment","z":"bfb3bf6a21067928","name":"Requirement: ☝️ @inductiv/node-red-openai-api node.","info":"Install via the Node-RED Palette Manager or via NPM:\nnpm install @inductiv/node-red-openai-api\n\n## Note\nNode works with any OpenAI-compliant API server.","x":740,"y":440,"wires":[],"icon":"font-awesome/fa-info-circle"},{"id":"86136c735f777368","type":"comment","z":"bfb3bf6a21067928","name":"Simulate conversation sequence: 1, 2, 3...","info":"","x":400,"y":220,"wires":[]},{"id":"3195dd1fc85413d5","type":"comment","z":"bfb3bf6a21067928","name":"Demo: OpenAI Chat Completion with Flow-based Conversation Memory","info":"This is a simple demos highlighting native, flow-based chat completion conversation memory.","x":690,"y":160,"wires":[]},{"id":"6bf3be50f1f3a262","type":"Service Host","apiBase":"https://api.openai.com/v1","secureApiKeyHeaderOrQueryName":"Authorization","name":"OpenAI Auth"}]
Created 2 years, 2 months ago
Rating: 5 1
  • comment (x3)
  • debug (x2)
  • function (x2)
  • inject (x4)
  • switch (x1)
  • node-red-chatbot
  • openai-integration
  • ai-powered-conversations
  • context-aware-chatbot
  • gpt-4-node-red
  • aiot-development
  • conversational-memory
  • node-red-ai
  • openai-api-node-red
  • intelligent-chat-flows
