node-red-contrib-nem2 create mosaic example template
Description
The flow will send two transactions bundled in on aggregate complete transaction to create a mosaic definition and set the mosaic supply. The flow also opens 2 listeners.
- Error listener.
- Confirmed transaction listener
note: The publicAccount need to be send first.
Requirements
Mandatory
- Public account
- publicKey that is linked to the privateKey in the account node.
- account
- privateKey that is linked to the publicKey in the public account node.
- createMosaicDefinitionTransaction
- Registered namespace name (optional subnamespace with ”.” as delimiter)
- Mosaic name
- Duration expressed in NEM blockchain blocks
- mosaicSupplyChangeTransaction
- Full mosaic name (e.g namespace.optionalsubnamespace:mosaicname)
- Amount
- Direction (increase or decrease amount)
- aggregateCompleteTransaction
- Trigger, when the trigger is received the transactions will be bundled in an aggregateComplete transaction
- announce transaction
- url to a catapult server
- listeners
[{"id":"ce341506.754568","type":"createMosaicDefinition","z":"cc26cffa.2b224","name":"","namespace":"","mosaic":"","supplyMutable":false,"transferable":true,"levyMutable":false,"divisibility":"0","duration":"1000","network":"dbf1a14a.ab0c","x":464.4444580078125,"y":77.11111450195312,"wires":[["ef8af4c2.3fdbd8"]]},{"id":"108e0748.0a4299","type":"signTransaction","z":"cc26cffa.2b224","name":"","privateKey":"","network":"dbf1a14a.ab0c","x":1026.3333129882812,"y":149.7777557373047,"wires":[["b70464c3.b79498"]]},{"id":"b70464c3.b79498","type":"announce","z":"cc26cffa.2b224","name":"","server":"551021ac.e378e","announceType":"announce","x":1038.1111450195312,"y":241.66665649414062,"wires":[[]]},{"id":"e5d90994.4c96d8","type":"listener","z":"cc26cffa.2b224","name":"listen for errors","server":"551021ac.e378e","address":"","listenerType":"status","x":431.11109924316406,"y":338.88888454437256,"wires":[["d386266e.062118"]]},{"id":"d386266e.062118","type":"debug","z":"cc26cffa.2b224","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":644.444450378418,"y":338.8888816833496,"wires":[]},{"id":"43d23fda.3af1c","type":"listener","z":"cc26cffa.2b224","name":"","server":"551021ac.e378e","address":"","listenerType":"confirmed","x":442.2222213745117,"y":406.6666374206543,"wires":[["d635393d.cadee8"]]},{"id":"d635393d.cadee8","type":"debug","z":"cc26cffa.2b224","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":642.2222213745117,"y":406.6666374206543,"wires":[]},{"id":"230d3165.49915e","type":"mosaicSupplyChange","z":"cc26cffa.2b224","name":"","amount":"100000000","mosaic":"","direction":"1","network":"dbf1a14a.ab0c","x":464.9999694824219,"y":157.11109924316406,"wires":[["a07534c2.a93e28"]]},{"id":"ef8af4c2.3fdbd8","type":"aggregateComplete","z":"cc26cffa.2b224","name":"","trigger":"bundle","network":"dbf1a14a.ab0c","x":918.2222290039062,"y":77.77779388427734,"wires":[["108e0748.0a4299"]]},{"id":"2a367946.b7a826","type":"publicAccount","z":"cc26cffa.2b224","name":"","publicKey":"","network":"dbf1a14a.ab0c","x":147.44444274902344,"y":78.22222137451172,"wires":[["ce341506.754568"]]},{"id":"bdccf172.650ba","type":"comment","z":"cc26cffa.2b224","name":"Create mosaic","info":"The flow will send two transactions bundled in on aggregate complete transaction to create a mosaic definition and set the mosaic supply. The flow also opens 2 listeners.\n\nError listener.\nConfirmed transaction listener\nnote: The publicAccount need to be send first.","x":144.1111068725586,"y":36.888885498046875,"wires":[]},{"id":"a07534c2.a93e28","type":"change","z":"cc26cffa.2b224","name":"set trigger","rules":[{"t":"set","p":"nem.trigger","pt":"msg","to":"bundle","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":158,"wires":[["ef8af4c2.3fdbd8"]]},{"id":"cc920042.a8e8a","type":"account","z":"cc26cffa.2b224","name":"","privateKey":"","network":"dbf1a14a.ab0c","x":127.55555725097656,"y":156.44444274902344,"wires":[["230d3165.49915e","e5d90994.4c96d8","43d23fda.3af1c"]]},{"id":"dbf1a14a.ab0c","type":"networkConfig","z":"","network":"MIJIN_TEST","customNetwork":""},{"id":"551021ac.e378e","type":"serverConfig","z":"","url":"http://localhost","customUrl":"","network":"2b9cf13.9eaf90e","port":"3000"},{"id":"2b9cf13.9eaf90e","type":"networkConfig","z":"","network":"MIJIN_TEST","customNetwork":""}]
