UI upload file button
Create UI upload button using UI template button. Clicking the button will allow you to open a file dialog that will allow you to select the file then pass the file content to the payload.
[{"id":"c5268070.c55a3","type":"ui_template","z":"5d665294.f65f14","group":"c33a1024a72aa169","name":"Upload Btn","order":8,"width":"3","height":1,"format":"\n<body>\n<button class=\"md-raised md-button md-ink-ripple\" onclick=\"importData()\">Upload</button>    \n\n<script>\nlet restoreScope = scope;\n\nfunction importData() {\n  let input = document.createElement('input');\n  input.type = 'file';\n  input.id = 'restoreBtn';\n  input.onchange = _ => {\n    // you can use this method to get file and perform respective operations\n        let fReader = new FileReader();\n        fReader.readAsText(input.files[0]);\n        fReader.onloadend = function(event){\n        restoreScope.send({payload:event.target.result});}\n        };\n  input.click();\n}\n</script>\n</body>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":270,"y":700,"wires":[["5e18b80e617a3db8"]]},{"id":"5e18b80e617a3db8","type":"debug","z":"5d665294.f65f14","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":510,"y":700,"wires":[]},{"id":"c33a1024a72aa169","type":"ui_group","name":"Default","tab":"cc6c4310cf7b61cc","disp":true,"width":"6","collapse":false},{"id":"cc6c4310cf7b61cc","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Created 5 years, 5 months ago
Rating: 5 1
  • ui_group (x1)
  • ui_template (x1)
  • UI
  • Button
  • Upload
  • Dashboard
