Store locations in worldmap
This flow lets you draw area's in worldmap and stores this in a flow variable. The name of the flow variable is the name you put when drawing the area.
When typing the name of the variable it is reloaded to the map
[{"id":"e308df9c84a9999b","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"eab4792e38c189ee","type":"worldmap","z":"e308df9c84a9999b","name":"","lat":"","lon":"","zoom":"","layer":"OSMG","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"true","panlock":"false","zoomlock":"false","hiderightclick":"false","coords":"deg","showgrid":"false","allowFileDrop":"false","path":"/worldmap","overlist":"DR,CO,RA,DN,HM","maplist":"OSMG,OSMC,OSMH,EsriC,EsriS,EsriT,EsriO,EsriDG,NatGeo,UKOS,ST,SW","mapname":"","mapurl":"","mapopt":"","mapwms":false,"x":650,"y":220,"wires":[]},{"id":"150926721124bc6a","type":"ui_worldmap","z":"e308df9c84a9999b","group":"1c94b8ec141b8dd3","order":0,"width":0,"height":0,"name":"","lat":"","lon":"","zoom":"","layer":"OSMG","cluster":"","maxage":"","usermenu":"show","layers":"show","panit":"true","panlock":"false","zoomlock":"false","hiderightclick":"false","coords":"deg","showgrid":"false","allowFileDrop":"false","path":"/worldmap","overlist":"DR,CO,RA,DN,HM","maplist":"OSMG,OSMC,EsriC,EsriS,EsriT,EsriDG,UKOS,SW","mapname":"","mapurl":"","mapopt":"","mapwms":false,"x":620,"y":340,"wires":[]},{"id":"e67057dbf3429b35","type":"worldmap in","z":"e308df9c84a9999b","name":"","path":"/worldmap","events":"connect,disconnect,point,layer,bounds,files,draw,other","x":660,"y":280,"wires":[["fe1a3983fdd1b46f","85edffdaeaa6752d"]]},{"id":"fe1a3983fdd1b46f","type":"debug","z":"e308df9c84a9999b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":850,"y":280,"wires":[]},{"id":"3f7ca9735817f92d","type":"debug","z":"e308df9c84a9999b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1010,"y":360,"wires":[]},{"id":"85edffdaeaa6752d","type":"function","z":"e308df9c84a9999b","name":"","func":"var action = msg.payload.action;\nif(action == \"draw\"){\n    var area = msg.payload.area;\n    var name = msg.payload.name;\nflow.set(name,area);\nmsg.payload = area;\nreturn msg;\n}\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":780,"y":500,"wires":[["3f7ca9735817f92d"]]},{"id":"2a17f23b140cdcb1","type":"function","z":"e308df9c84a9999b","name":"","func":"var flowname = msg.payload\nvar area = flow.get(flowname);\nmsg.payload = {\"name\": \"zone1\", \"area\":area};\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":480,"y":340,"wires":[["150926721124bc6a"]]},{"id":"0e5bfdb746a12fec","type":"ui_text_input","z":"e308df9c84a9999b","name":"","label":"Put flowname you entered in the map here","tooltip":"","group":"1c94b8ec141b8dd3","order":1,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"topic","topicType":"msg","x":220,"y":340,"wires":[["2a17f23b140cdcb1"]]},{"id":"1c94b8ec141b8dd3","type":"ui_group","name":"Default","tab":"cf3108690ea4a357","order":1,"disp":true,"width":"17","collapse":false},{"id":"cf3108690ea4a357","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Created 5 years, 2 months ago
  • debug (x2)
  • function (x2)
  • ui_group (x1)
  • ui_text_input (x1)
  • ui_worldmap (x1)
  • worldmap (x1)
  • worldmap in (x1)
  • worldmap
  • mapping
  • alarm-map
