Honor Router 3 Login
Description
This flow will try to login on a Honor Router 3 located at address 192.168.3.1 which is the default address for this kind of router.
#Setup To set it up, you need to specify your administrative password for the router inside the Login inject node as msg.password. The Login&HB will take care of login on to the router administrative website and will ensure that the connection remains open by sending Heartbeat request the same way a browser would do. As outputs from this Login&HB subflow, you get the required cookies and csrf if you want to use POST requests to change values inside the router. You also get a 5s timer Heartbeat signal if you want to regulary check some data inside the router.
To stop the Heartbeat signal, send a message with reset = true to the subflow.
This flow should work with Huawei AX3 and possibly Huawei AX3 Pro but it has not been tested.
[{"id":"10d86f80.af0b61","type":"subflow","name":"Login&HB","info":"","category":"","in":[{"x":60,"y":380,"wires":[{"id":"44af9fa1.1a288"}]}],"out":[{"x":2400,"y":320,"wires":[{"id":"60bb9b65.be2fe4","port":0}]},{"x":2400,"y":400,"wires":[{"id":"d10ef033.7c78b","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"88942fc3.9c1f1","type":"switch","z":"10d86f80.af0b61","name":"New Cookies?","property":"responseCookies","propertyType":"msg","rules":[{"t":"nnull"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":740,"y":200,"wires":[["eadb0f06.86c3"],["5765be21.0f1af"]]},{"id":"eadb0f06.86c3","type":"change","z":"10d86f80.af0b61","name":"Set New cookies","rules":[{"t":"set","p":"cookies","pt":"flow","to":"responseCookies","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":930,"y":180,"wires":[["5765be21.0f1af"]]},{"id":"ab26aafc.4c51c8","type":"http request","z":"10d86f80.af0b61","name":"user_login_nonce","method":"POST","ret":"obj","paytoqs":"ignore","url":"http://192.168.3.1/api/system/user_login_nonce","tls":"","persist":true,"proxy":"","authType":"","x":630,"y":160,"wires":[["88942fc3.9c1f1"]]},{"id":"af6f90c6.4d487","type":"switch","z":"10d86f80.af0b61","name":"Err = 0 ?","property":"payload.err","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1260,"y":240,"wires":[["b10a7334.aba4"]]},{"id":"905bd407.00a528","type":"switch","z":"10d86f80.af0b61","name":"Errcode = 1 ?","property":"payload.errcode","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":1280,"y":200,"wires":[["49a534a7.1d709c"]]},{"id":"5765be21.0f1af","type":"change","z":"10d86f80.af0b61","name":"Set CSRF","rules":[{"t":"set","p":"csrf.csrf_token","pt":"flow","to":"payload.csrf_token","tot":"msg"},{"t":"set","p":"csrf.csrf_param","pt":"flow","to":"payload.csrf_param","tot":"msg"},{"t":"delete","p":"headers","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1100,"y":200,"wires":[["905bd407.00a528","af6f90c6.4d487"]]},{"id":"6515af37.facd1","type":"function","z":"10d86f80.af0b61","name":"CreateFirstNonce","func":"var CryptoJS = context.global.cryptojs;\n\nvar ret = {payload:{}};\nvar firstNonce = CryptoJS.lib.WordArray.random(32).toString();\nvar csrf = flow.get(\"csrf\")|| {csrf_token:\"\", csrf_param:\"\"};\nret.cookies=flow.get(\"cookies\")|| [];\nret.payload = {data:{username:'admin',firstnonce:firstNonce}, \n    csrf:csrf\n}\n\nret.firstNonce = firstNonce;\nret.password = msg.password;\nreturn ret;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":530,"y":120,"wires":[["ab26aafc.4c51c8"]]},{"id":"49a534a7.1d709c","type":"link out","z":"10d86f80.af0b61","name":"","links":["dbe092c.e07b87"],"x":1455,"y":200,"wires":[]},{"id":"dbe092c.e07b87","type":"link in","z":"10d86f80.af0b61","name":"","links":["49a534a7.1d709c"],"x":75,"y":80,"wires":[["f119464b.47b4e8"]]},{"id":"b10a7334.aba4","type":"function","z":"10d86f80.af0b61","name":"CreateUserLoginProof","func":"var CryptoJS = context.global.cryptojs;\n\nvar password = msg.password;\n\nvar salt = CryptoJS.enc.Hex.parse(msg.payload.salt);\nvar iter = msg.payload.iterations;\nvar finalNonce = msg.payload.servernonce;\nvar firstNonce = msg.firstNonce;\nvar authMsg = firstNonce + \",\" + finalNonce + \",\" + finalNonce;\n\nvar saltPassword = CryptoJS.PBKDF2(password, salt, {\n                keySize: 8,\n                iterations:iter,\n                hasher: CryptoJS.algo.SHA256\n            }).toString();\nvar serverKey = CryptoJS.HmacSHA256(CryptoJS.enc.Hex.parse(saltPassword), \"Server Key\");\nvar clientKey = CryptoJS.HmacSHA256(CryptoJS.enc.Hex.parse(saltPassword), \"Client Key\").toString();\nvar hasher256 = CryptoJS.algo.SHA256.create();\nhasher256.update(CryptoJS.enc.Hex.parse(clientKey));\nvar storekey = hasher256.finalize();\nstorekey = storekey.toString();\nvar clientsignature = CryptoJS.HmacSHA256(CryptoJS.enc.Hex.parse(storekey), authMsg);\n\nclientsignature = clientsignature.toString();\nclientsignature = CryptoJS.enc.Hex.parse(clientsignature);\nclientKey = CryptoJS.enc.Hex.parse(clientKey);\nfor (var i = 0; i < clientKey.sigBytes/4; i++) {\n  clientKey.words[i] = clientKey.words[i] ^ clientsignature.words[i]\n}\nvar csrf = flow.get(\"csrf\");\nvar ret = {payload:{}};\nret.cookies=flow.get(\"cookies\");\nvar param1 = {data:{clientproof:clientKey.toString(),finalnonce:finalNonce},\n    csrf:csrf\n};\n\nret.password = password;\nret.payload = param1;\nreturn ret;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1440,"y":240,"wires":[["7c7e24ff.d72eec"]]},{"id":"7c7e24ff.d72eec","type":"http request","z":"10d86f80.af0b61","name":"user_login_proof","method":"POST","ret":"obj","paytoqs":"ignore","url":"http://192.168.3.1/api/system/user_login_proof","tls":"","persist":true,"proxy":"","authType":"","x":1470,"y":280,"wires":[["c2d65127.c2bea"]]},{"id":"c2d65127.c2bea","type":"switch","z":"10d86f80.af0b61","name":"New Cookies?","property":"responseCookies","propertyType":"msg","rules":[{"t":"nnull"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1500,"y":320,"wires":[["4579e542.e2538c"],["3d3cf09.f49d81"]]},{"id":"4579e542.e2538c","type":"change","z":"10d86f80.af0b61","name":"Set New cookies","rules":[{"t":"set","p":"cookies","pt":"flow","to":"responseCookies","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1710,"y":300,"wires":[["3d3cf09.f49d81"]]},{"id":"3d3cf09.f49d81","type":"change","z":"10d86f80.af0b61","name":"Set CSRF","rules":[{"t":"set","p":"csrf.csrf_token","pt":"flow","to":"payload.csrf_token","tot":"msg"},{"t":"set","p":"csrf.csrf_param","pt":"flow","to":"payload.csrf_param","tot":"msg"},{"t":"delete","p":"headers","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1880,"y":320,"wires":[["e5c80eb0.8e9e1","a508c846.9661a8"]]},{"id":"60bb9b65.be2fe4","type":"change","z":"10d86f80.af0b61","name":"Build Output Msg","rules":[{"t":"set","p":"payload.csrf","pt":"msg","to":"csrf","tot":"flow"},{"t":"set","p":"payload.cookies","pt":"msg","to":"cookies","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":2250,"y":320,"wires":[[]]},{"id":"d3696eb1.20247","type":"trigger","z":"10d86f80.af0b61","name":"","op1":"1","op2":"0","op1type":"num","op2type":"str","duration":"-5","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1540,"y":420,"wires":[["57154bb9.7a6464"]]},{"id":"701151b.d024bb","type":"http request","z":"10d86f80.af0b61","name":"HeartBeat","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.3.1/api/system/heartbeat","tls":"","persist":true,"proxy":"","authType":"","x":1910,"y":420,"wires":[["19c0fdee.2f0a92"]]},{"id":"57154bb9.7a6464","type":"change","z":"10d86f80.af0b61","name":"Set cookies","rules":[{"t":"set","p":"cookies","pt":"msg","to":"cookies","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":1720,"y":420,"wires":[["701151b.d024bb"]]},{"id":"b8918fa2.f4649","type":"change","z":"10d86f80.af0b61","name":"Retry = 2","rules":[{"t":"set","p":"retry","pt":"flow","to":"2","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":140,"wires":[["6515af37.facd1"]]},{"id":"f119464b.47b4e8","type":"change","z":"10d86f80.af0b61","name":"Retry --","rules":[{"t":"set","p":"retry","pt":"flow","to":"$number($flowContext(\"retry\")) - 1","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":200,"y":80,"wires":[["8f66939f.d9cd5"]]},{"id":"8f66939f.d9cd5","type":"switch","z":"10d86f80.af0b61","name":"Retry > 0","property":"retry","propertyType":"flow","rules":[{"t":"gt","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":360,"y":80,"wires":[["6515af37.facd1"]]},{"id":"44af9fa1.1a288","type":"switch","z":"10d86f80.af0b61","name":"Reset?","property":"reset","propertyType":"msg","rules":[{"t":"true"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":200,"y":380,"wires":[["d3696eb1.20247","e5c80eb0.8e9e1"],["b8918fa2.f4649"]]},{"id":"e5c80eb0.8e9e1","type":"trigger","z":"10d86f80.af0b61","name":"","op1":"","op2":"1","op1type":"nul","op2type":"str","duration":"100","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1520,"y":380,"wires":[["d3696eb1.20247"]]},{"id":"19c0fdee.2f0a92","type":"switch","z":"10d86f80.af0b61","name":"Status","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"num"},{"t":"eq","v":"404","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":2150,"y":420,"wires":[["d10ef033.7c78b"],["3e0fb68b.5f678a"]]},{"id":"d10ef033.7c78b","type":"function","z":"10d86f80.af0b61","name":"True","func":"var ret = {payload:true}\nreturn ret;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2290,"y":400,"wires":[[]]},{"id":"3e0fb68b.5f678a","type":"function","z":"10d86f80.af0b61","name":"Password","func":"var ret = {password:msg.password}\nreturn ret;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2300,"y":440,"wires":[["181759e9.f755e6"]]},{"id":"181759e9.f755e6","type":"link out","z":"10d86f80.af0b61","name":"","links":["b208f39.ec6ce1"],"x":2395,"y":440,"wires":[]},{"id":"b208f39.ec6ce1","type":"link in","z":"10d86f80.af0b61","name":"","links":["181759e9.f755e6"],"x":75,"y":140,"wires":[["b8918fa2.f4649"]]},{"id":"a508c846.9661a8","type":"function","z":"10d86f80.af0b61","name":"Clear Msg","func":"var ret = {payload:{}};\nret.payload = msg.payload;\nreturn ret;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2050,"y":320,"wires":[["60bb9b65.be2fe4"]]},{"id":"129b52f6.433dad","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"7baf21c2.11976","type":"inject","z":"129b52f6.433dad","name":"Login","props":[{"p":"password","v":"your_password","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":270,"y":240,"wires":[["5285e5cd.cee1ac"]]},{"id":"5285e5cd.cee1ac","type":"subflow:10d86f80.af0b61","z":"129b52f6.433dad","name":"","env":[],"x":460,"y":260,"wires":[["e4e0eebb.e1a23"],["7babbd7b.95b944"]]},{"id":"eb86165c.436e18","type":"inject","z":"129b52f6.433dad","name":"Stop HB","props":[{"p":"reset","v":"true","vt":"bool"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"str","x":280,"y":280,"wires":[["5285e5cd.cee1ac"]]},{"id":"e4e0eebb.e1a23","type":"change","z":"129b52f6.433dad","name":"Set Cookies and CSRF","rules":[{"t":"set","p":"csrf","pt":"flow","to":"payload.csrf","tot":"msg"},{"t":"set","p":"cookies","pt":"flow","to":"payload.cookies","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":240,"wires":[["6c0aa160.d1813"]]},{"id":"22c3825c.2836de","type":"http request","z":"129b52f6.433dad","name":"HostInfo","method":"GET","ret":"obj","paytoqs":"ignore","url":"http://192.168.3.1/api/system/HostInfo","tls":"","persist":true,"proxy":"","authType":"","x":820,"y":280,"wires":[["c6b4493f.f20118"]]},{"id":"7babbd7b.95b944","type":"change","z":"129b52f6.433dad","name":"","rules":[{"t":"set","p":"cookies","pt":"msg","to":"cookies","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":280,"wires":[["22c3825c.2836de","14a89781.d05a78"]]},{"id":"c6b4493f.f20118","type":"debug","z":"129b52f6.433dad","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1010,"y":280,"wires":[]},{"id":"14a89781.d05a78","type":"http request","z":"129b52f6.433dad","name":"Wan","method":"GET","ret":"obj","paytoqs":"ignore","url":"http://192.168.3.1/api/ntwk/wan?type=active","tls":"","persist":true,"proxy":"","authType":"","x":810,"y":320,"wires":[["771e653d.365dfc"]]},{"id":"6c0aa160.d1813","type":"debug","z":"129b52f6.433dad","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":930,"y":240,"wires":[]},{"id":"771e653d.365dfc","type":"debug","z":"129b52f6.433dad","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1010,"y":320,"wires":[]}]
Created 5 years, 5 months ago
  • change (x10)
  • debug (x3)
  • function (x5)
  • http request (x5)
  • inject (x2)
  • link in (x2)
  • link out (x2)
  • switch (x7)
  • trigger (x2)
  • subflow (x1)
  • subflow:10d86f80.af0b61 (x1)
  • honor
  • huawei
  • Router
  • Wifi
  • login
  • csrf
  • scram
