Examples for node-red-contrib-bosch-shc
This JSON array represents Node-RED flows which demonstrate how to use the Bosch Smart Home Controller nodes (node-red-contrib-bosch-shc). The controller and device configuration must be updated with your settings after the import to Node-RED.
Compatible with Node-RED version 1.0.0 or higher.
Link to Bosch Smart Home Controller nodes: https://flows.nodered.org/node/node-red-contrib-bosch-shc
[{"id":"8e3172ca.6fe9f","type":"shc-device","z":"10501378.41c385","shc":"","poll":true,"device":"-RoomClimateControl-|roomClimateControl_hz_6|ROOM_CLIMATE_CONTROL|RoomClimateControl,TemperatureLevel","service":"RoomClimateControl","state":"setpointTemperature","name":"","x":380,"y":1280,"wires":[["fe73091d.b63de8","5a139103.03e65"]]},{"id":"fe73091d.b63de8","type":"ui_slider","z":"10501378.41c385","name":"","label":"Room","tooltip":"","group":"63223d46.8c561c","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"","min":"5","max":"30","step":"0.5","x":370,"y":1360,"wires":[["8e3172ca.6fe9f"]]},{"id":"bdac975.d01ace8","type":"shc-device","z":"10501378.41c385","shc":"","poll":true,"device":"TestPlug|hdm:HomeMaticIP:3014F711A0000496D858AC55|PSM|PowerMeter,PowerSwitch","service":"PowerSwitch","state":"switchState","name":"","x":340,"y":780,"wires":[["9b1db41f.dea588","58f25f91.ceca58"]]},{"id":"9b1db41f.dea588","type":"ui_switch","z":"10501378.41c385","name":"","label":"","tooltip":"","group":"1e44a4a9.7e157b","order":0,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":330,"y":860,"wires":[["bdac975.d01ace8"]]},{"id":"4bf7edf0.6ab03c","type":"ui_button","z":"10501378.41c385","name":"","group":"5faf56e2.bac2c","order":4,"width":0,"height":0,"passthru":false,"label":"Trigger Szenario","tooltip":"","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"","x":160,"y":1100,"wires":[["80e274fb.55da2"]]},{"id":"80e274fb.55da2","type":"shc-scenario","z":"10501378.41c385","shc":"","scenario":"TestScenario|3858f62c-9504-4c93-8b58-809b9c5c209a","name":"Scenario","x":360,"y":1100,"wires":[["e4c01c7c.579f"]]},{"id":"ae59beee.4167","type":"shc-fault","z":"10501378.41c385","shc":"","name":"","debug":true,"x":320,"y":80,"wires":[["f323a847.a93e68"]]},{"id":"f323a847.a93e68","type":"debug","z":"10501378.41c385","name":"All messages","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":480,"y":80,"wires":[]},{"id":"cf11f343.f59cd","type":"shc-fault","z":"10501378.41c385","shc":"","name":"","debug":false,"x":320,"y":140,"wires":[["719a40.407f3dc"]]},{"id":"719a40.407f3dc","type":"debug","z":"10501378.41c385","name":"Faults only","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":480,"y":140,"wires":[]},{"id":"95334179.b0a698","type":"shc-device","z":"10501378.41c385","shc":"","poll":true,"device":"-PresenceSimulationService-|presenceSimulationService|PRESENCE_SIMULATION_SERVICE|PresenceSimulationScheduling,PresenceSimulationConfiguration","service":"PresenceSimulationConfiguration","state":"enabled","name":"","x":400,"y":920,"wires":[["73195ddc.55ddf4","b3749d29.9c1d38"]]},{"id":"73195ddc.55ddf4","type":"ui_switch","z":"10501378.41c385","name":"","label":"","tooltip":"","group":"ad44dcb3.6fb6d","order":0,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":350,"y":980,"wires":[["95334179.b0a698"]]},{"id":"224e315e.a15ace","type":"shc-device","z":"10501378.41c385","shc":"","poll":true,"device":"Air|hdm:ZigBee:000d6f000e31309b|TWINGUARD|BatteryLevel,AirQualityLevel,SmokeDetectorCheck","service":"AirQualityLevel","state":"purity","name":"Air Purity ppm","x":360,"y":1180,"wires":[["c0f7e11c.2f6998"]]},{"id":"c0f7e11c.2f6998","type":"ui_chart","z":"10501378.41c385","name":"","group":"bd2539f3.63c2a8","order":0,"width":0,"height":0,"label":"Twinguard","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":550,"y":1180,"wires":[[]]},{"id":"e4c01c7c.579f","type":"debug","z":"10501378.41c385","name":"Scenario event","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":540,"y":1100,"wires":[]},{"id":"425d6e2f.6fa8b","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":1060,"wires":[["80e274fb.55da2"]]},{"id":"af1f2063.633d58","type":"shc-device","z":"10501378.41c385","shc":"","poll":false,"device":"all|all|all|AirQualityLevel,BatteryLevel,HumidityLevel,IntrusionDetectionControl,Keypad,LatestMotion,PowerMeter,PowerSwitch,PresenceSimulationConfiguration,PrivacyMode,RoomClimateControl,ShutterContact, ShutterControl, SmokeDetectorCheck,TemperatureLevel,ValveTappet","service":"all","state":"","name":"Service List","x":350,"y":320,"wires":[["b5e0b31e.730d3"]]},{"id":"16100206.1eaa56","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":260,"wires":[["9c3652c6.d351a"]]},{"id":"b8465b48.e966e","type":"shc-device","z":"10501378.41c385","shc":"","poll":false,"device":"TestPlug|hdm:HomeMaticIP:3014F711A0000496D858AC55|PSM|PowerMeter,PowerSwitch","service":"all","state":"","name":"All services of a device","x":380,"y":560,"wires":[["46634187.06d43"]]},{"id":"9c3652c6.d351a","type":"shc-device","z":"10501378.41c385","shc":"","poll":false,"device":"all|all|all|AirQualityLevel,BatteryLevel,HumidityLevel,IntrusionDetectionControl,Keypad,LatestMotion,PowerMeter,PowerSwitch,PresenceSimulationConfiguration,PrivacyMode,RoomClimateControl,ShutterContact, ShutterControl, SmokeDetectorCheck,TemperatureLevel,ValveTappet","service":"","state":"","name":"Device List","x":350,"y":260,"wires":[["f445c7a0.0c03c"]]},{"id":"faf5ca7d.3f06","type":"function","z":"10501378.41c385","name":"Sum","func":"if (Array.isArray(msg.payload)) {\n    msg.topic = 'Total power consumption'\n    msg.payload = msg.payload.reduce((acc, element) => {\n        return acc + element;\n    }, 0);\n    return msg;\n}\n","outputs":1,"noerr":0,"x":410,"y":500,"wires":[["e53281e7.275d68"]]},{"id":"f445c7a0.0c03c","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":550,"y":260,"wires":[]},{"id":"b5e0b31e.730d3","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":550,"y":320,"wires":[]},{"id":"71d8b358.9b0bbc","type":"shc-device","z":"10501378.41c385","shc":"","poll":false,"device":"all|all|all|AirQualityLevel,BatteryLevel,HumidityLevel,IntrusionDetectionControl,Keypad,LatestMotion,PowerMeter,PowerSwitch,PresenceSimulationConfiguration,PrivacyMode,RoomClimateControl,ShutterContact, ShutterControl, SmokeDetectorCheck,TemperatureLevel,ValveTappet","service":"PowerMeter","state":"","name":"All PowerMeters","x":360,"y":380,"wires":[["4bd504c3.0748ac"]]},{"id":"4bd504c3.0748ac","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":550,"y":380,"wires":[]},{"id":"a88dc763.8f75c","type":"shc-device","z":"10501378.41c385","shc":"","poll":false,"device":"all|all|all|AirQualityLevel,BatteryLevel,HumidityLevel,IntrusionDetectionControl,Keypad,LatestMotion,PowerMeter,PowerSwitch,PresenceSimulationConfiguration,PrivacyMode,RoomClimateControl,ShutterContact, ShutterControl, SmokeDetectorCheck,TemperatureLevel,ValveTappet","service":"PowerMeter","state":"powerConsumption","name":"All powerConsumptions","x":390,"y":440,"wires":[["bf4077c0.92e94","faf5ca7d.3f06"]]},{"id":"bf4077c0.92e94","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":590,"y":440,"wires":[]},{"id":"e53281e7.275d68","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":570,"y":500,"wires":[]},{"id":"46634187.06d43","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":590,"y":560,"wires":[]},{"id":"50ca9339.639eac","type":"shc-device","z":"10501378.41c385","shc":"","poll":true,"device":"TestPlug|hdm:HomeMaticIP:3014F711A0000496D858AC55|PSM|PowerMeter,PowerSwitch","service":"PowerSwitch","state":"","name":"Specific device service","x":380,"y":640,"wires":[["50337531.99e9dc"]]},{"id":"c74ad393.dfe988","type":"shc-device","z":"10501378.41c385","shc":"","poll":true,"device":"TestPlug|hdm:HomeMaticIP:3014F711A0000496D858AC55|PSM|PowerMeter,PowerSwitch","service":"PowerSwitch","state":"switchState","name":"Specific state of a device","x":390,"y":700,"wires":[["a407ef1c.c29bb"]]},{"id":"50337531.99e9dc","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":590,"y":640,"wires":[]},{"id":"a407ef1c.c29bb","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":590,"y":700,"wires":[]},{"id":"74bce0a8.56b6f","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":320,"wires":[["af1f2063.633d58"]]},{"id":"e64fc1c.773dc4","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":380,"wires":[["71d8b358.9b0bbc"]]},{"id":"3d789fbb.29acb8","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":440,"wires":[["a88dc763.8f75c"]]},{"id":"5f3040b3.cf476","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":560,"wires":[["b8465b48.e966e"]]},{"id":"c40559df.c07108","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":640,"wires":[["50ca9339.639eac"]]},{"id":"ba220c99.37d238","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":700,"wires":[["c74ad393.dfe988"]]},{"id":"f8bfbe82.dc904","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":760,"wires":[["bdac975.d01ace8"]]},{"id":"fafa9dae.ce5558","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":800,"wires":[["bdac975.d01ace8"]]},{"id":"58f25f91.ceca58","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":530,"y":780,"wires":[]},{"id":"3ef4c030.c6034","type":"link out","z":"10501378.41c385","name":"Keypad Upper Short","links":[],"x":755,"y":1440,"wires":[]},{"id":"e6992c60.a121c8","type":"link out","z":"10501378.41c385","name":"Keypad Upper Long","links":[],"x":755,"y":1480,"wires":[]},{"id":"c2af8fdb.ab75a8","type":"switch","z":"10501378.41c385","name":"Upper/Lower","property":"payload.state.keyName","propertyType":"msg","rules":[{"t":"eq","v":"UPPER_BUTTON","vt":"str"},{"t":"eq","v":"LOWER_BUTTON","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":485,"y":1480,"wires":[["2d783372.017e2c"],["393c0017.eedfa8"]]},{"id":"2d783372.017e2c","type":"switch","z":"10501378.41c385","name":"Short/Long","property":"payload.state.eventType","propertyType":"msg","rules":[{"t":"eq","v":"PRESS_SHORT","vt":"str"},{"t":"eq","v":"PRESS_LONG","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":645,"y":1460,"wires":[["3ef4c030.c6034"],["e6992c60.a121c8"]]},{"id":"393c0017.eedfa8","type":"switch","z":"10501378.41c385","name":"Short/Long","property":"payload.state.eventType","propertyType":"msg","rules":[{"t":"eq","v":"PRESS_SHORT","vt":"str"},{"t":"eq","v":"PRESS_LONG","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":645,"y":1500,"wires":[[],[]]},{"id":"6d24070.ef11bf8","type":"shc-device","z":"10501378.41c385","shc":"","poll":true,"device":"Keypad|hdm:HomeMaticIP:3014F711A0001596D8599A58|WRC2|BatteryLevel,Keypad","service":"Keypad","state":"","name":"","x":280,"y":1480,"wires":[["c2af8fdb.ab75a8","63020ec3.4fc6b"]]},{"id":"2d01c15d.57a8f6","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":900,"wires":[["95334179.b0a698"]]},{"id":"d9036835.fc8228","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":150,"y":940,"wires":[["95334179.b0a698"]]},{"id":"b3749d29.9c1d38","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":650,"y":920,"wires":[]},{"id":"d66b3afd.d8547","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":160,"y":1180,"wires":[["224e315e.a15ace"]]},{"id":"5a139103.03e65","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":590,"y":1280,"wires":[]},{"id":"df39843.d08d1f8","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"5","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":1280,"wires":[["8e3172ca.6fe9f"]]},{"id":"36c72c82.ff17a4","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"18.5","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":1340,"wires":[["8e3172ca.6fe9f"]]},{"id":"b96e634.5eccba","type":"inject","z":"10501378.41c385","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":1480,"wires":[["6d24070.ef11bf8"]]},{"id":"63020ec3.4fc6b","type":"debug","z":"10501378.41c385","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":490,"y":1540,"wires":[]},{"id":"63223d46.8c561c","type":"ui_group","z":"","name":"Temparature","tab":"35b64c76.37ce1c","order":1,"disp":true,"width":"6","collapse":false},{"id":"1e44a4a9.7e157b","type":"ui_group","z":"","name":"Smart Plug","tab":"35b64c76.37ce1c","order":2,"disp":true,"width":"6","collapse":false},{"id":"5faf56e2.bac2c","type":"ui_group","z":"","name":"Szenario","tab":"35b64c76.37ce1c","order":3,"disp":true,"width":"8","collapse":false},{"id":"ad44dcb3.6fb6d","type":"ui_group","z":"","name":"Presence Simulation","tab":"35b64c76.37ce1c","order":4,"disp":true,"width":"8","collapse":false},{"id":"bd2539f3.63c2a8","type":"ui_group","z":"","name":"Chart","tab":"35b64c76.37ce1c","order":5,"disp":true,"width":"8","collapse":false},{"id":"35b64c76.37ce1c","type":"ui_tab","z":"","name":"Example","icon":"dashboard","disabled":false,"hidden":false}]
Created 7 years, 1 month ago
Updated 6 years, 11 months ago
  • debug (x15)
  • inject (x16)
  • link out (x2)
  • switch (x3)
  • Bosch
  • Smart
  • Home
  • Examples
  • SHC
  • Controller
